Stuck at boot after gdm starts
Hello everyone,
I’d like some help troubleshooting a weird issue I’m having.
The problem
At startup, after grup menu, when using kernel 5.10 or 5.11, booting stops after gdm service starts, and a grey screen with a blinking horizontal cursor shows up (as can happen when gdm is about to start) but stops there.
This does not happen using LTS kernel 5.4, which is a good thing.
Also, when the bug occurs, I can still open a tty.
What happened just before
I updated my system via the command line using sudo pacman -Syu. Rebooted for unrelated reasons, then the bug happened.
System info
  Kernel: 5.11.16-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
  root=UUID=8475a443-cbc4-45d6-8e0e-4eab94b2ffd5 rw apparmor=1
  Console: tty 2 DM: GDM 40.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: GL502VSK v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: GL502VSK v: 1.0 serial: <filter>
  UEFI: American Megatrends v: GL502VSK.309 date: 05/03/2019
  ID-1: BAT0 charge: 43.7 Wh (97.3%) condition: 44.9/62.6 Wh (71.7%)
  volts: 15.2 min: 15.2 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Not charging cycles: 206
  RAM: total: 15.47 GiB used: 617.1 MiB (3.9%)
  Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
  cache: L2: 6 MiB bogomips: 44817
  Speed: 1130 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 1130 2: 1200
  3: 1200 4: 1200 5: 1188 6: 1200 7: 1201 8: 1201
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: NVIDIA GP104BM [GeForce GTX 1070 Mobile] vendor: ASUSTeK
  driver: N/A alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0
  chip-ID: 10de:1be1 class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus-ID: 1-4:3 chip-ID: 13d3:5666 class-ID: 0e02 serial: <filter>
  Display: server: X.org 1.20.11 driver: loaded: nvidia tty: 240x67
  Message: Advanced graphics data unavailable in console. Try -G --display
  Device-1: Intel CM238 HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
  Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
  class-ID: 0403
  Device-3: Plantronics HD1 type: USB driver: plantronics,snd-usb-audio,usbhid
  bus-ID: 1-1:2 chip-ID: 047f:c03b class-ID: 0300
  Sound Server-1: ALSA v: k5.11.16-2-MANJARO running: yes
  Sound Server-3: PulseAudio v: 14.2 running: no
  Sound Server-4: PipeWire v: 0.3.26 running: no
  Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel port: e000
  bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
  vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
  IF: enp4s0 state: down mac: <filter>
  bus-ID: 1-9:6 chip-ID: 8087:0a2b class-ID: e001
  Local Storage: total: 8.64 TiB used: 2.44 TiB (28.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
  model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
  logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 00WD
  scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS721010A9E630
  rotation: 7200 rpm serial: <filter> rev: A3V0 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 type: USB model: External USB 3.0
  size: 7.28 TiB block-size: physical: 4096 B logical: 512 B serial: <filter>
  rev: 0104 scheme: GPT
  ID-1: / raw-size: 150 GiB size: 146.64 GiB (97.76%) used: 52.76 GiB (36.0%)
  fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 8475a443-cbc4-45d6-8e0e-4eab94b2ffd5
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
  used: 26.9 MiB (2.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 73DF-165F
  ID-3: /home raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
  used: 272.06 GiB (29.7%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
  uuid: 660fad62-d62e-44fb-9760-0a86bb9a28f3
  ID-4: /media/Externe 3.5 8To raw-size: 7.28 TiB size: 7.22 TiB (99.20%)
  used: 2.12 TiB (29.4%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
  label: Externe 3.5 8To uuid: bab7a0e0-c509-4178-9dbb-77d06807544e
  ID-1: /dev/sda3 maj-min: 8:3 size: 258.59 GiB fs: ntfs label: N/A
  uuid: A4AC6D1DAC6CEAEE
  ID-2: /dev/sda4 maj-min: 8:4 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-1:2 info: Plantronics HD1 type: Audio,HID
  driver: plantronics,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 047f:c03b class-ID: 0300
  Device-2: 1-4:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  Device-3: 1-5:4 info: Microdia Backlit Gaming Keyboard type: Keyboard,Mouse
  power: 400mA chip-ID: 0c45:652f class-ID: 0301
  Device-4: 1-8:5 info: ASUSTek ROG MacroKey type: Keyboard,Mouse
  driver: asus,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
  chip-ID: 0b05:1837 class-ID: 0301
  Device-5: 1-9:6 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-6:2 info: Unknown External USB 3.0 type: Mass Storage
  driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 8mA
  chip-ID: 0080:0578 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 57.5 C mobo: N/A
  Fan Speeds (RPM): cpu: 2600
  Processes: 223 Uptime: N/A wakeups: 1 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1813 pacman: 1788 lib: 480
  flatpak: 16 snap: 9 Shell: Zsh (login) v: 5.8 running-in: tty 2 inxi: 3.3.04
xrandr output
None, it errors out with no display.
:+1: Welcome back to the forum! :+1:
  1. Just a reminder as you’ve been away for a while:
    How to provide good information
    so please post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
First of all, thanks for the help.
I’ve restarted with kernel 5.11, and by looking at the logs that I dumped I see Nvidia kernel module errors :
$ cat journal-dump.txt | grep gdm | less
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]: (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]: (EE) NVIDIA:     system's kernel log for additional error messages and
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]: (EE) NVIDIA:     consult the NVIDIA README for details.
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]: (EE) No devices detected.
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]: Fatal server error:
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]: (EE) no screens found(EE)
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]: Please consult the The X.Org Foundation support
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]:          at http://wiki.x.org
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]:  for help.
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]: (EE) Please also check the log file at "/var/lib/gdm/.local/share/xorg/Xorg.0.log" for additional information.
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1307]: (EE) Server terminated with error (1). Closing log file.
avril 24 15:50:31 SNIF-2 /usr/lib/gdm-x-session[1305]: Unable to run X server
So this definetly seems to be the cause, so I dumped kernel logs too :
$ cat journal-kernel-dump.txt | grep nvidia | less
avril 24 15:50:09 SNIF-2 kernel: audit: type=1400 audit(1619272209.147:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=269 comm="apparmor_parser"
avril 24 15:50:09 SNIF-2 kernel: audit: type=1400 audit(1619272209.147:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=269 comm="apparmor_parser"
avril 24 15:50:09 SNIF-2 kernel: nvidia: version magic '5.11.15-1-MANJARO SMP preempt mod_unload ' should be '5.11.16-2-MANJARO SMP preempt mod_unload '
avril 24 15:50:10 SNIF-2 kernel: nvidia: version magic '5.11.15-1-MANJARO SMP preempt mod_unload ' should be '5.11.16-2-MANJARO SMP preempt mod_unload '
avril 24 15:50:31 SNIF-2 kernel: nvidia: version magic '5.11.15-1-MANJARO SMP preempt mod_unload ' should be '5.11.16-2-MANJARO SMP preempt mod_unload '
Content of /var/lib/gdm/.local/share/xorg/Xorg.0.log :
[    24.353] (--) Log file renamed from "/var/lib/gdm/.local/share/xorg/Xorg.pid-1326.log" to "/var/lib/gdm/.local/share/xorg/Xorg.0.log"
[    24.354] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[    24.355]
X.Org X Server 1.20.11
[    24.355] Build Operating System: Linux Manjaro Linux
[    24.355] Current Operating System: Linux SNIF-2 5.11.16-2-MANJARO #1 SMP PREEMPT Thu Apr 22 09:53:11 UTC 2021 x86_64
[    24.355] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=8475a443-cbc4-45d6-8e0e-4eab94b2ffd5 rw apparmor=1 security=apparmor udev.log_priority=3
[    24.355] Build Date: 13 April 2021  04:11:08PM
[    24.355]
[    24.355] Current version of pixman: 0.40.0
[    24.355] 	Before reporting problems, check http://wiki.x.org
[    24.355] Markers: (--) probed, (**) from config file, (==) default setting,
[    24.355] (==) Log file: "/var/lib/gdm/.local/share/xorg/Xorg.0.log", Time: Sat Apr 24 16:24:33 2021
[    24.357] (==) Using config file: "/etc/X11/xorg.conf"
[    24.357] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    24.357] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    24.360] (==) ServerLayout "layout"
[    24.360] (**) |-->Screen "Screen0" (0)
[    24.360] (**) |   |-->Monitor "Monitor0"
[    24.360] (**) |   |-->Device "Device0"
[    24.360] (**) |   |-->GPUDevice "Device0"
[    24.360] (==) Automatically adding devices
[    24.360] (==) Automatically enabling devices
[    24.360] (==) Automatically adding GPU devices
[    24.360] (==) Automatically binding GPU devices
[    24.360] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    24.363] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    24.363] 	Entry deleted from font path.
[    24.363] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    24.363] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    24.363] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    24.363] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[    24.363] (==) ModulePath set to "/usr/lib/xorg/modules"
[    24.363] (**) Extension "COMPOSITE" is enabled
[    24.363] (II) The server relies on udev to provide the list of input devices.
[    24.363] (II) Module ABI versions:
[    24.363] 	X.Org ANSI C Emulation: 0.4
[    24.363] 	X.Org Video Driver: 24.1
[    24.363] 	X.Org XInput driver : 24.1
[    24.363] 	X.Org Server Extension : 10.0
[    24.364] (++) using VT number 1
[    24.367] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[    24.371] (--) PCI:*(1@0:0:0) 10de:1be1:1043:1800 rev 161, Mem @ 0xee000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[    24.371] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    24.371] (II) LoadModule: "glx"
[    24.382] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    24.392] (II) Module glx: vendor="X.Org Foundation"
[    24.392] 	compiled for 1.20.11, module version = 1.0.0
[    24.392] 	ABI class: X.Org Server Extension, version 10.0
[    24.392] (II) LoadModule: "nvidia"
[    24.393] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    24.400] (II) Module nvidia: vendor="NVIDIA Corporation"
[    24.400] 	compiled for 1.6.99.901, module version = 1.0.0
[    24.400] 	Module class: X.Org Video Driver
[    24.401] (II) NVIDIA dlloader X Driver  465.24.02  Thu Apr  8 17:55:59 UTC 2021
[    24.401] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    24.401] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[    24.402] (II) Loading sub module "fb"
[    24.402] (II) LoadModule: "fb"
[    24.402] (II) Loading /usr/lib/xorg/modules/libfb.so
[    24.404] (II) Module fb: vendor="X.Org Foundation"
[    24.404] 	compiled for 1.20.11, module version = 1.0.0
[    24.404] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    24.404] (II) Loading sub module "wfb"
[    24.404] (II) LoadModule: "wfb"
[    24.404] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    24.406] (II) Module wfb: vendor="X.Org Foundation"
[    24.406] 	compiled for 1.20.11, module version = 1.0.0
[    24.406] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    24.406] (II) Loading sub module "ramdac"
[    24.406] (II) LoadModule: "ramdac"
[    24.406] (II) Module "ramdac" already built-in
[    24.578] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    24.578] (EE) NVIDIA:     system's kernel log for additional error messages and
[    24.578] (EE) NVIDIA:     consult the NVIDIA README for details.
[    24.723] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    24.723] (EE) NVIDIA:     system's kernel log for additional error messages and
[    24.723] (EE) NVIDIA:     consult the NVIDIA README for details.
[    24.723] (EE) No devices detected.
[    24.723] (EE)
Fatal server error:
[    24.723] (EE) no screens found(EE)
[    24.723] (EE)
 for help.
[    24.723] (EE) Please also check the log file at "/var/lib/gdm/.local/share/xorg/Xorg.0.log" for additional information.
[    24.723] (EE)
[    24.727] (EE) Server terminated with error (1). Closing log file.
Where do I go from there ?
How did you install the nVidia driver???
:thinking:
Well I followed the wiki’s method :
https://wiki.manjaro.org/index.php/Configure_Graphics_Cards
$ mhwd -l --pci
$ sudo mhwd -i pci [name of driver]
  1. That’s good, sorry for asking. :man_shrugging:
  2. Please install both 5.4 and 5.10 LTS (Long Time Support) and see which one of the two troubles you least.
If the above doesn’t make sense yto you, please shout out!
:+1:
Huh that’s weird, seems like I can’t do this because of dependencies conflicting…
I’m using manjaro-settings-manager and I can’t install 5.10 for some reason (I swear I had 5.4 and 5.10 side by side :face_with_raised_eyebrow:) after I uninstalled 5.10 to reinstall it just to be sure.
The following packages will be installed:
linux510
linux510-headers
linux510-virtualbox-host-modules
linux510-nvidia
Starting
resolving dependencies...
:: installing nvidia-utils (460.73.01-1) breaks dependency 'nvidia-utils=465.24.02' required by linux511-nvidia
:: installing nvidia-utils (460.73.01-1) breaks dependency 'nvidia-utils=465.24.02' required by linux54-nvidia
  • Print this page so you have it as a reference while in TTY2
  • Log off
  • Switch to TTY2 by pressing Ctrl+Alt+F2
  • Log in there
  • Execute:
    mhwd --listinstalled
    mhwd --remove pci EverythingThatCameUpAboveOnePerLine
    sudo mhwd-kernel --install linux54
    sudo mhwd-kernel --install linux510
    sudo mhwd --install pci video-nvidia
  • to ensure grub is showing, execute:
    sudo nano --backup /etc/default/grub
  • Change (or add?) the following 3 lines:
    GRUB_TIMEOUT=3
    #GRUB_HIDDEN_TIMEOUT=0
    #GRUB_TIMEOUT_STYLE=hidden
    (3 or higher is fine, add the # before the lines above if those lines are present)
  • Ctrl+X Y Enter to save if there is anything to save
  • If you did save, execute:
    sudo update-grub
  • Reboot
  • Go to grub’s Advanced options
  • Choose these kernels one by one and try them out one by one and see if that helps.
:+1:
It worked !
  • 5.4 OK
  • 5.10 OK
  • 5.11 OK
You rock ! Reinstalling kernels and video driver did the trick :smiley:
(I believe only the video driver would have been fine, but that’s just a supposition)
This community definitely doesn’t get enough recognition :pray:
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
