Hey everyone
I have been using manjaro for couple days (gnome) and had a problem with wayland and sharing my screen etc… so i was trying to update to budgie, after i restarted my laptop it keeps being stuck at asus logo screen loading
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
(Wisdom lies in reading )
How to boot from USB into live Manjaro (for repair):
Hi newbi question my desktop is XFCE my pc is 64bit 60gig hardrive. I did a recent up date and now manjaro won’t boot up. I get a message saying I need to have a kernel installed first. I’ve tried advanced option but even the fallback won’t boot. I did some research that it’s possible to recover my installed system by chroot using usb but not really sure what to do after I get the message below. In the terminal I typed “manjaro-chroot -a” below is the message I got.
“Mounting (ManjaroLinux) …
brahma
24 January 2023 09:34
3
there were some issues with budgie, the display manager is not being enabled, so check these topics:
Hello,
So I previously had Ubuntu 20.04 installed in Dual Boot along with W11, I installed Manjaro with Budgie Desktop after deleting the Ubuntu partition.
When I startup Manjaro I get a prompt (tty) where I can log in, I have to start wifi manually everytime, I just followed this guide (sorry but it doesn’t allow me to use links) :
https://forum.manjaro.org/t/fix-system-doesn-t-boot-boots-to-a-black-screen-or-stops-at-a-message/3906
and found out problem is coming from DisplayManager becaus…
Hello everybody!
I’m new on both Linux and on this forum. I tried to find a solution in this forum and have been reading posts about similar problems but none worked so far.
I had been running Manjaro KDE for a couple of months but after an update I couldn’t boot into my system anymore. That was two years ago. Then life happened and I was using Windows on my computer. This week I tried reinstalling Manjaro Budgie but I still get a black screen. The only thing I can do is Ctrl+Alt+Del to reboot…
I tried installing Manjaro Budgie after downloading the ISO from manjaro.org (full install) and it results into booting to a tty login after installation and no graphic desktop. I tried this with multiple (different manufacture) usb sticks, usb imaging software apps as well as downloading it multiple times and confirming the checksum. I also tried the ISO in a VM and the results are the same. You may want to look into the latest Manjaro Budgie ISO you have posted.
Also going to software.manjaro…
