Hello, I am using manjaro with KDE, updated with the latest LTS kernel. 5.15.41-1 as of the time I am writing.
I have an Acer F5 laptop with an Intel i5-7200U and Nividia 940MX graphics. I run an hybrid system using nvidia-prime to run applications on the graphics card and it works as intended for everything.
Whenever I start Steam and try to play a game that uses proton it tries to launch the game and after a few minutes it simply cancel the launch, with play button returning back to normal. This seems to happen with every game on my steam library (I haven’t really tried with all of them, but a few dozen, for sure).
However, I can launch a lot of games using Heroic Launcher, even the same games i have in Steam, using “Run Exe on this prefix” option that the Heroic launcher have. The weird thing is that once I start steam-runtime or steam-native, i can’t launch anything from either steam or heroic, and I have to restart the computer to be able to launch from heroic again.
I have tried reinstalling steam and all it’s libraries, deleting every single file related to steam on my pc a few times, I have tried reinstalling all the games that i tested too. Also tried different versions of the Nvidia drivers, default proton, proton-ge and wine-ge. Short of reinstalling the whole system, I believe i have installed and reinstalled every related program to steam and proton. I have no idea how to debug this, but it seems to me that launching steam sets some kind of system-wide variable or temp-file that borks everything related to proton.
When I run the games with PROTON_LOG=1, It usually complains with some variation of
64589.239:0020:00bc:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
64589.239:0020:00bc:err:winediag:nodrv_CreateWindow The explorer process failed to start.
on the game “.log” file and
ERROR: ld.so: object '[share]/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '[share]/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
GameAction [AppID 979120, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
on the terminal that i ran Steam from.
If anyone has encountered this problem before or have a way to debug so I can discover what steam is doing in my system, any help is greatly appreciated. Thanks.
inxi output:
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f820f8ef-666d-49bc-896c-0a935ea4fd82 rw quiet apparmor=1
security=apparmor resume=UUID=94b7f922-9ae3-4c23-bef9-b84f8e6bf681
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire F5-573G v: V1.27
serial: <superuser required>
Mobo: Acer model: Captain_SK v: V1.27 serial: <superuser required>
UEFI: Insyde v: 1.27 date: 05/26/2017
ID-1: BAT1 charge: 18.8 Wh (100.0%) condition: 18.8/41.4 Wh (45.5%)
volts: 16.8 min: 14.8 model: PANASONIC AS16A5K type: Li-ion serial: <filter>
status: full
ID-2: hidpp_battery_4 charge: 97% condition: N/A volts: 4.1 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: <filter> status: discharging
Device-1: hidpp_battery_5 model: Logitech Wireless Keyboard ERGO K860
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 15.5 GiB used: 12.29 GiB (79.3%)
RAM Report:
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 799 high: 800 min/max: 400/3100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 799 3: 800 4: 800
bogomips: 21607
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:5916 class-ID: 0300
Device-2: NVIDIA GM107 [GeForce 940MX] vendor: Acer Incorporated ALI
driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Maxwell pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:179c class-ID: 0302
Device-3: Realtek HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:5
chip-ID: 0bda:57f2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15dc built: 2015 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.0.4
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
Device-3: ZhuHai JieLi BR17 type: USB
driver: hid-generic,snd-usb-audio,usb-storage,usbhid bus-ID: 1-4.1:19
chip-ID: e5b7:0811 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.51 running: yes
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0036 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.1 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0f1 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Lite-On Qualcomm Atheros Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-5:12 chip-ID: 04ca:3014 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 1.36 TiB used: 398.65 GiB (28.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EDFK0N01 temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10JPVX-22JC3T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 456.66 GiB size: 448.43 GiB (98.20%)
used: 393.77 GiB (87.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: f820f8ef-666d-49bc-896c-0a935ea4fd82
label: NO_LABEL uuid: 05E3-D4A1
ID-1: swap-1 type: partition size: 8.8 GiB used: 4.88 GiB (55.5%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 94b7f922-9ae3-4c23-bef9-b84f8e6bf681
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: ESP
uuid: 7045-37E2
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 262.46 GiB fs: ntfs label: Acer
uuid: AEDA46AEDA46729F
ID-4: /dev/sda4 maj-min: 8:4 size: 1024 MiB fs: ntfs label: Recovery
uuid: FAC44792C4475055
ID-5: /dev/sda5 maj-min: 8:5 size: 314.98 GiB fs: ext4 label: N/A
uuid: 213e8bc7-c916-436a-b4a4-659350175307
ID-6: /dev/sda6 maj-min: 8:6 size: 7.87 GiB fs: swap label: N/A
uuid: 02b779c6-8496-4576-8d4e-b61decc4e12c
ID-7: /dev/sda7 maj-min: 8:7 size: 1024 KiB fs: <superuser required>
ID-8: /dev/sda8 maj-min: 8:8 size: 48.6 GiB fs: ext4 label: N/A
uuid: fab5449f-ad63-4c81-b19c-6cb790ac5703
ID-9: /dev/sda9 maj-min: 8:9 size: 296.48 GiB fs: ext4 label: N/A
uuid: b9bada9c-3f78-4b66-b312-8bef55581ac8
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-4:16 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-4.1:19 info: ZhuHai JieLi BR17 type: Mass Storage,Audio,HID
driver: hid-generic,snd-usb-audio,usb-storage,usbhid interfaces: 5 rev: 1.1
speed: 12 Mb/s power: 400mA chip-ID: e5b7:0811 class-ID: 0300
serial: <filter>
Device-2: 1-4.2:17 info: Logitech Cordless Mouse Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-3: 1-4.3:18 info: Logitech Unifying Receiver
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-4: 1-5:12 info: Lite-On Qualcomm Atheros Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Device-5: 1-7:5 info: Realtek HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:57f2
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 53.0 C pch: 48.5 C mobo: N/A
Processes: 306 Uptime: 1d 4h 0m wakeups: 146 Init: systemd v: 250
tool: systemctl Compilers: gcc: 12.1.0 alt: 10 clang: 13.0.1 Packages:
pacman: 2005 lib: 493 flatpak: 0 Shell: Bash v: 5.1.16
running-in: terminator inxi: 3.3.16
