Start problems, I can't go from the start screen (resolved)
After putting my password and press Enter, the message that always appears from the file system appears on the left, in my case XFS, before the desk appears, but instead of appearing the desktop I return to the home screen of session and I have to oppose the password again and this is an endless loop. If you start the system in terminal mode and run Startx, I receive this message:
Mesa: glthread destroy reason:Enable(DEBUG_OUTPUT_SYNCHROUNUS)
Failed to connect to bus: No medium found dbus-update-activation-enviroment: errore: unable to connect to D-Bus: Using X11 for dbus-daemon autolanch was disable at compile time, set your DBUS_SESSION_BUS_ADDRES instead xinit: connection to X server lost
Waiting for X server to shut down (II) Server terminaste succssfully (0).Closing log file.
Can anyone add me to solve this?
Thank you so much.
  • Did you update lately ?
  • Where there error-messages ?
  • Was the update finished ?
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
    (Wisdom lies in reading :wink: )
Thanks for answering, I can’t show you the output of inxi, because I can only boot by pressing e in the grub menu and adding init=/bin/bash and I can’t copy anything on the screen because there is no mouse and the output of inxi is very long.
How to boot from USB into live Manjaro (for repair):
Sorry but I think you’re wrong, because I think your answer was not for me.
Although now that I think about it, I can boot with a flash drive and execute the inxi command that you propose, does it work for you?
I have started with a pendraive and I have done a manjaro-chroot -a and I have executed inxi with the parameters that you requested and this is what has come out:
12System:
  12Kernel 6.1.9-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 12.2.1
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=es_ES keytable=es
    tz=Europe/Madrid misobasedir=manjaro misolabel=MANJARO_KDE_2202 quiet
    systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1
    radeon.modeset=1
  12Desktop KDE Plasma 12v 5.26.5 12tk Qt 12v 5.15.8 12wm kwin_x11 12dm N/A
    12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Desktop 12System ASUS 12product N/A 12v N/A 12serial N/A
  12Mobo ASUSTeK 12model ROG CROSSHAIR VIII HERO 12v Rev X.0x 12serial <filter>
    12UEFI American Megatrends 12v 4304 12date 12/12/2022
(upower:34): UPower-WARNING **: 10:27:51.076: Cannot connect to upowerd: Could not connect: No such file or directory
12Battery:
  12Device-1 hidpp_battery_0 12model Logitech Marathon Mouse/Performance Plus M705
    12serial <filter> 12charge Normal 12status discharging
  12Device-2 hidpp_battery_1 12model Logitech MK700 12serial <filter> 12charge High
12Memory:
  12RAM 12total 31.26 GiB 12used 3.07 GiB (9.8%)
  12Array-1 12capacity 128 GiB 12slots 4 12EC None 12max-module-size 32 GiB 12note est.
  12Device-1 DIMM_A1 12type DDR4 12detail synchronous unbuffered (unregistered)
    12size 8 GiB 12speed 3600 MT/s 12volts 12curr 1.2 12min 1.2 12max 1.2 12width (bits)
    12data 64 12total 64 12manufacturer G Skill Intl 12part-no F4-3600C16-8GTZN
    12serial N/A
  12Device-2 DIMM_A2 12type DDR4 12detail synchronous unbuffered (unregistered)
    12serial N/A
  12Device-3 DIMM_B1 12type DDR4 12detail synchronous unbuffered (unregistered)
    12serial N/A
  12Device-4 DIMM_B2 12type DDR4 12detail synchronous unbuffered (unregistered)
    12serial N/A
12CPU:
  12Info 12model AMD Ryzen 9 3900X 12socket AM4 12bits 64 12type MT MCP 12arch Zen 2 12gen 3
    12level v3 12note check 12built 2020-22 12process TSMC n7 (7nm) 12family 0x17 (23)
    12model-id 0x71 (113) 12stepping 0 12microcode 0x8701030
  12Topology 12cpus 1x 12cores 12 12tpc 2 12threads 24 12smt enabled 12cache 12L1 768 KiB
    12desc d-12x32 KiB; i-12x32 KiB 12L2 6 MiB 12desc 12x512 KiB 12L3 64 MiB
    12desc 4x16 MiB
  12Speed (MHz) 12avg 2833 12high 4100 12min/max 2200/5041 12boost disabled
    12base/boost 4100/4650 12scaling 12driver acpi-cpufreq 12governor schedutil
    12volts 1.1 V 12ext-clock 100 MHz 12cores 121 4100 122 4100 123 2200 124 4100 125 2200
    126 2200 127 2200 128 2200 129 2200 1210 2200 1211 2200 1212 2200 1213 2200 1214 4100 1215 2200
    1216 2200 1217 2200 1218 2200 1219 2200 1220 2200 1221 4100 1222 4100 1223 4100 1224 4100
    12bogomips 196886
  12Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  12Vulnerabilities
  12Type itlb_multihit 12status Not affected
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type mmio_stale_data 12status Not affected
  12Type retbleed 12mitigation untrained return thunk; SMT enabled with STIBP
    protection
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
  12Type spectre_v2 12mitigation Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
    12vendor ASUSTeK 12driver amdgpu 12v kernel 12arch RDNA-1 12code Navi
    12process TSMC n7 (7nm) 12built 2019-20 12pcie 12gen 4 12speed 16 GT/s 12lanes 16 12ports
    12active DP-3 12empty DP-1,DP-2,HDMI-A-1 12bus-ID 0a:00.0 12chip-ID 1002:731f
    12class-ID 0300
  12Display 12server X.Org 12v 21.1.6 12with Xwayland 12v 22.1.7 12compositor kwin_x11
    12driver 12dri radeonsi 12gpu amdgpu 12note X driver n/a 12display-ID :0 12screens 1
  12Screen-1 0 12s-res 1920x1080 12s-dpi 96 12s-size 508x285mm (20.00x11.22")
    12s-diag 582mm (22.93")
  12Monitor-1 DP-3 12mapped DisplayPort-2 12model Samsung S22C650 12built 2012
    12res 1920x1080 12hz 60 12dpi 102 12gamma 1.2 12size 477x268mm (18.78x10.55")
    12diag 547mm (21.5") 12ratio 16:9 12modes 12max 1920x1080 12min 720x400
  12API OpenGL 12v 4.6 Mesa 22.3.4 12renderer AMD Radeon RX 5700 (navi10 LLVM
    15.0.7 DRM 3.49 6.1.9-1-MANJARO) 12direct render Yes
12Audio:
  12Device-1 AMD Navi 10 HDMI Audio 12driver snd_hda_intel 12v kernel 12pcie 12gen 4
    12speed 16 GT/s 12lanes 16 12bus-ID 0a:00.1 12chip-ID 1002:ab38 12class-ID 0403
  12Device-2 AMD Starship/Matisse HD Audio 12vendor ASUSTeK 12driver snd_hda_intel
    12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 16 12bus-ID 0c:00.4 12chip-ID 1022:1487
    12class-ID 0403
  12Sound API ALSA 12v k6.1.9-1-MANJARO 12running yes
  12Sound Server-1 PulseAudio 12v 16.1 12running yes
  12Sound Server-2 PipeWire 12v 0.3.65 12running yes
12Network:
  12Device-1 Intel I211 Gigabit Network 12vendor ASUSTeK 12driver igb 12v kernel 12pcie
    12gen 1 12speed 2.5 GT/s 12lanes 1 12port f000 12bus-ID 04:00.0 12chip-ID 8086:1539
    12class-ID 0200
  12IF enp4s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
  12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter> 12type noprefixroute 12scope link
  12WAN IP <filter>
12Bluetooth:
  12Device-1 ASUSTek ASUS USB-BT500 12type USB 12driver btusb 12v 0.8 12bus-ID 3-3:3
    12chip-ID 0b05:190e 12class-ID e001 12serial <filter>
  12Report rfkill 12ID hci0 12rfk-id 0 12state down 12bt-service N/A 12rfk-block
    12hardware no 12software yes 12address see --recommends
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 18.2 TiB 12used 514.38 GiB (2.8%)
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Gigabyte 12model GP-ASM2NE6100TTTD
    12size 931.51 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 63.2 Gb/s
    12lanes 4 12type SSD 12serial <filter> 12rev EGFM13.0 12temp 29.9 C
  12SMART yes 12health PASSED 12on 178d 20h 12cycles 1,647
    12read-units 35,085,478 [17.9 TB] 12written-units 32,066,614 [16.4 TB]
  12ID-2 /dev/sda 12maj-min 8:0 12vendor Seagate 12model ST3000DM001-1ER166
    12family Barracuda 7200.14 (AF) 12size 2.73 TiB 12block-size 12physical 4096 B
    12logical 512 B 12sata 3.1 12speed 6.0 Gb/s 12type HDD 12rpm 7200 12serial <filter>
    12rev CC25 12temp 24 C
  12SMART yes 12state enabled 12health PASSED 12on 1y 26d 14h 12cycles 4807
    12read 418.33 TiB 12written 46.65 TiB 12Pre-Fail 12attribute Spin_Retry_Count
    12value 100 12worst 100 12threshold 97
  12ID-3 /dev/sdb 12maj-min 8:16 12vendor SanDisk 12model ST8000DM004-2CX188
    12family BarraCuda 3.5 (SMR) 12size 7.28 TiB 12block-size 12physical 4096 B
    12logical 512 B 12sata 3.1 12speed 6.0 Gb/s 12type HDD 12rpm 5425 12serial <filter>
    12rev 0001 12temp 25 C
  12SMART yes 12state enabled 12health PASSED 12on 2262h+32m+23.790s 12cycles 775
    12read 14.18 TiB 12written 14.25 TiB 12Pre-Fail 12attribute Spin_Retry_Count
  12ID-4 /dev/sdc 12maj-min 8:32 12vendor SanDisk 12model ST8000DM004-2CX188
    12rev 0001 12temp 27 C
  12SMART yes 12state enabled 12health PASSED 12on 6213h+38m+11.901s 12cycles 2772
    12read 105.78 TiB 12written 62.14 TiB 12Pre-Fail 12reallocated sector 100
    12threshold 10 12attribute Spin_Retry_Count 12value 100 12worst 100 12threshold 97
  12ID-5 /dev/sdd 12maj-min 8:48 12type USB 12vendor Kingston 12model DataTraveler G3
    12size 7.25 GiB 12block-size 12physical 512 B 12logical 512 B 12type N/A
    12serial <filter> 12rev 1.00
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
  12Message No optical or floppy data found.
12Partition:
  12ID-1 / 12raw-size 70 GiB 12size 69.94 GiB (99.91%) 12used 28.89 GiB (41.3%) 12fs xfs
    12block-size 512 B 12dev /dev/nvme0n1p6 12maj-min 259:6 12label N/A
    12uuid 263f69dd-86f9-4e9b-8143-ed731cee0384
  12ID-2 /boot/efi 12raw-size 582 MiB 12size 95 MiB (16.32%) 12used 39.4 MiB (41.5%)
    12fs vfat 12block-size 512 B 12dev /dev/nvme0n1p2 12maj-min 259:2 12label N/A
    12uuid EE6F-3698
  12ID-3 /home 12raw-size 500 GiB 12size 499.8 GiB (99.96%) 12used 485.45 GiB (97.1%)
    12fs xfs 12block-size 512 B 12dev /dev/nvme0n1p7 12maj-min 259:7 12label home
    12uuid a078b499-ba48-4972-9352-ecb90684798c
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/nvme0n1p1 12maj-min 259:1 12size 16 MiB 12fs N/A 12label N/A 12uuid N/A
  12ID-2 /dev/nvme0n1p3 12maj-min 259:3 12size 220.17 GiB 12fs ntfs 12label N/A
    12uuid DC3871C438719DE8
  12ID-3 /dev/nvme0n1p4 12maj-min 259:4 12size 615 MiB 12fs ntfs 12label N/A
    12uuid A06CB19D6CB16EA2
  12ID-4 /dev/nvme0n1p5 12maj-min 259:5 12size 575 MiB 12fs ntfs 12label N/A
    12uuid C8B0F28EB0F281EC
  12ID-5 /dev/sda1 12maj-min 8:1 12size 2.73 TiB 12fs xfs 12label Dades
    12uuid 5ee7320b-3bb4-4901-85ee-3762e99be5a2
  12ID-6 /dev/sdb1 12maj-min 8:17 12size 7.28 TiB 12fs xfs 12label Series
    12uuid 4453e1a0-6312-4cf5-952b-268d96428346
  12ID-7 /dev/sdc1 12maj-min 8:33 12size 7.28 TiB 12fs xfs 12label pelis
    12uuid dd42a8a6-50a9-43f6-8e8b-c827626e11b8
  12ID-8 /dev/sdd1 12maj-min 8:49 12size 3.87 GiB 12fs N/A 12label MANJARO_KDE_2202
    12uuid 2023-02-03-04-22-42-00
  12ID-9 /dev/sdd2 12maj-min 8:50 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid 562D-9CF6
12USB:
  12Hub-1 1-0:1 12info Hi-speed hub with single TT 12ports 6 12rev 2.0 12speed 480 Mb/s
    12chip-ID 1d6b:0002 12class-ID 0900
  12Hub-2 1-5:2 12info Genesys Logic Hub 12ports 4 12rev 2.0 12speed 480 Mb/s
    12power 100mA 12chip-ID 05e3:0610 12class-ID 0900
  12Device-1 1-5.3:3 12info ASUSTek AURA LED Controller 12type HID
    12driver hid-generic,usbhid 12interfaces 2 12rev 2.0 12speed 12 Mb/s 12power 16mA
    12chip-ID 0b05:18f3 12class-ID 0300 12serial <filter>
  12Hub-3 2-0:1 12info Super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s
    12chip-ID 1d6b:0003 12class-ID 0900
  12Hub-4 3-0:1 12info Hi-speed hub with single TT 12ports 6 12rev 2.0 12speed 480 Mb/s
  12Hub-5 3-2:2 12info ASMedia ASM1074 High-Speed hub 12ports 4 12rev 2.1
    12speed 480 Mb/s 12power 100mA 12chip-ID 174c:2074 12class-ID 0900
  12Device-1 3-3:3 12info ASUSTek ASUS USB-BT500 12type Bluetooth 12driver btusb
    12interfaces 2 12rev 1.1 12speed 12 Mb/s 12power 500mA 12chip-ID 0b05:190e
  12Device-2 3-4:4 12info Logitech Unifying Receiver 12type Keyboard,Mouse,HID
    12driver logitech-djreceiver,usbhid 12interfaces 3 12rev 2.0 12speed 12 Mb/s
    12power 98mA 12chip-ID 046d:c52b 12class-ID 0300
  12Hub-6 4-0:1 12info Super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s
  12Hub-7 4-2:2 12info ASMedia ASM1074 SuperSpeed hub 12ports 4 12rev 3.0
    12speed 5 Gb/s 12power 8mA 12chip-ID 174c:3074 12class-ID 0900
  12Hub-8 5-0:1 12info Hi-speed hub with single TT 12ports 4 12rev 2.0 12speed 480 Mb/s
  12Device-1 5-1:2 12info Feitian FIDO KB 12type Keyboard,HID
    12driver hid-generic,usbhid 12interfaces 2 12rev 1.1 12speed 12 Mb/s 12power 30mA
    12chip-ID 096e:0854 12class-ID 0300
  12Device-2 5-2:3 12info Kingston DataTraveler G3 12type Mass Storage
    12driver usb-storage 12interfaces 1 12rev 2.0 12speed 480 Mb/s 12power 100mA
    12chip-ID 0951:1643 12class-ID 0806 12serial <filter>
  12Hub-9 6-0:1 12info Super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s
12Sensors:
  12System Temperatures 12cpu 30.0 C 12mobo 29.0 C 12gpu amdgpu 12temp 30.0 C 12mem 26.0 C
  12Fan Speeds (RPM) 12cpu 1424 12gpu amdgpu 12fan 0
12Info:
  12Processes 452 12Uptime 5m 12wakeups 4 12Init systemd 12v 252 12default graphical
  12tool systemctl 12Compilers 12gcc 12.2.1 12clang 15.0.7 12Packages 1589 12pm pacman
  12pkgs 1578 12libs 395 12tools pamac,yay 12pm flatpak 12pkgs 11 12Client Unknown Client:
  slub_flushwq 12inxi 3.3.24
I was trying to get the number block to be enabled when I’m on the home screen and for that I’ve done this script in /etc/rc.local:
#!/bin/bash
enable number block
numlockx on
continue with the next script
exit 0
And then I have given it execution permissions with:
sudo chmod +x /etc/rc.local
And when I restart my system, what I explained at the beginning of my post happens.
I immediately deleted the script, but that did not solve the problem.
  • Can you switch to a console with [ctrl + alt +F4] ?
  • Can you login (there) using your username and password ?
  • Or can you only login as root ?
(May be your login is rejected,
  • because the system thinks this is not the correct password, or
  • because the system thinks you have tried to often
    As root you can give your user a new password that may work
Did you run startx as root ? (don´t !)
If I understand you properly, you want the number pad enabled on the login screen? You need to edit the etc/sddm.conf, so at the very top section should look something like this:
[General]
InputMethod=
Numlock=on
If I can log in with my user in a consolé.
4 questions, 1 answer ?
  • If I can open a console with ctrl + alt + F4.
  • If I can log in to the console with my username and password.
  • If I can log in to the console as root.
After logging with my user, I have executed Startx and I have received the following message:
“xinit: connection to X server Lost.”
As I have Wayland installed, it has given me to see what happened if I entered with Wayland instead of xorg. And entered. But since wayland is not fully optimized yet, I would like to fix xorg.
when you type startx in tty, take a picture of it and post it here, and also take picture of this:
mhwd-kernel -li && mhwd -l -li
I have fixed the problem by reinstalling mesa and xorg.
sudo -S pacman mes xorg.
Thanks everyone for your help.
