[Stable Update] 2024-11-30 - Kernels, Plasma, GNOME, COSMIC, LXQT, SYSTEMD
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: Get 4 months extra
Recent News
Previous News
Notable Package Updates
Additional Info
Nvidia driver downgrade
Nvidia drivers got downgraded to 550.100, therefore update with sudo pacman -Syuu. If you want to stay on the 555 driver series you may either switch to unstable or install nvidia-dkms via: sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/nvidia-dkms-555.58.02-1-x86_64.pkg.tar.zst. More info about Nvidia drivers here:
555 release feedback & discussion - Linux - NVIDIA Developer Forums
550.78 release feedback & discussion thread - Linux - NVIDIA Developer Forums
Python 3.12 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.11.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.11/ :
pacman -Qoq /usr/lib/python3.11/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.11)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
Get our latest daily developer images now from Github: Plasma, GNOME, XFCE. You can get the latest stable releases of Manjaro from CDN77. Stable ISOs including this update are available for review here: Release 202412010210 · manjaro/release-review · GitHub
Our current supported kernels
  • linux419 4.19.324
  • linux54 5.4.286
  • linux510 5.10.230
  • linux515 5.15.173
  • linux61 6.1.119
  • linux66 6.6.63
  • linux611 6.11.10
  • linux612 6.12.1
  • linux61-rt 6.1.112_rt43
  • linux66-rt 6.6.53_rt44
  • linux610-rt 6.10.2_rt14
Package Changes (Thu Nov 28 03:30:47 CET 2024)
  • stable core x86_64: 104 new and 111 removed package(s)
  • stable extra x86_64: 6329 new and 6338 removed package(s)
  • stable multilib x86_64: 70 new and 84 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2024-11-30
Plasma 6.2 might create a black screen when using X11 and default theme
For a while we are tracking the following bug of Plasma 6.2: https://bugs.kde.org/show_bug.cgi?id=483163. There seems to be a regression when using X11 and the default theme breeze. A workaround is to use some other variant of Breeze or use Wayland. People who have issues could comment on that bug report in a polite and helpful way, so the KDE developers may fix it soon.
GTK4 apps may not start due to Vulkan GSK Renderer by Default on Wayland
With GTK 4.16 release GNOME switched to Vulkan GSK Renderer by default. When you have not setup Vulkan support properly your GTK4 apps might not work as expected. Also users with Nvidia drivers might have issues, such as people using RasberryPi and older hardware. You can override it by setting the GSK_RENDERER=ngl or GDK_DISABLE=vulkan environment variable in /etc/environment file. For much more older PCs even GSK_RENDERER=gl is recommended. To boost rendering you can also set GDK_GL_DISABLE=buffer-storage, so the ngl renderer would perform similar to what you knew from GNOME 46.
Graphical interface might not start due to missing libpixbufloader-svg.so
Seems there was a so-name naming change within librsvg: Making sure you're not a bot!. To fix it issue: sudo gdk-pixbuf-query-loaders --update-cache
More information here: After today's update my machine is stuck on loading lightdm, no TTY access possible either - #36 by Photon
Pamac might not find AUR database
It is a known bug to have a message like this:
Failed to read AUR data from /var/lib/pacman/sync/packages-meta-ext-v1.json.gz : Error opening file /var/lib/pacman/sync/packages-meta-ext-v1.json.gz: No such file or directory
You can fix it by doing this: pamac upgrade --aur --force-refresh --dry-run
If it does not work that way try without --dry-run parameter.
Cursor sizes may vary when Wayland is used
If you enabled global scaling in Wayland within Plasma 6, especially with a fractional scale like 2.5x, cursor sizes would be a mess across various apps. For more information see this blog post: Cursor Size Problems In Wayland, Explained - KDE Blogs
Cinnamon 6.4 might change the default theme to a dark one
With Cinnamon 6.4 a lot of changes were made. The theme is significantly darker and offers more contrast than previous versions. Objects within the interface are now rounded, and a gap has been introduced between applets and the panel, giving the desktop environment a modern and polished appearance.
Nvidia: drivers might not work with 6.12 kernel
See also this open issue: 6.12: drm_open_helper RIP · Issue #712 · NVIDIA/open-gpu-kernel-modules · GitHub Nvidia provided a patch and shipped it in their 550.135 driver. More information here: Patch for 565.57.01 + Linux kernel 6.12 - Linux - NVIDIA Developer Forums.
We also patched 470xx and 390xx driver series as needed. Based on the current feedback, it seems that 470xx and 390xx drivers might not work at all with 6.12 kernel. 390xx got its last update by end of 2022, and we managed to keep it alive with kernel patches. If you have a legacy gpu you may consider to use the FOSS nouveau driver or exchange the GPU for a newer hardware.
Those who face issues with current provided drivers, may politely voice-up at the Nvidia developer forums in a civil manner and report their issue there: »»»»»»»»»» If you have a problem, PLEASE read this first «««««««««« - Linux - NVIDIA Developer Forums
2024-10-13
Kernel 6.10 has been marked [EOL] on kernel.org
:warning: Linux 6.10 is EOL
Linux 6.10 is EOL and got removed from the repo.
Please ensure your system use a supported kernel mhwd-kernel -l
:zap: KERNELS REMOVED
Linux 6.9 and 6.10 have been removed from repo.
2024-10-10
Steam games may not launch
Those who have issues with steam games may check this thread for help: Steam games won't launch after 2024-10-10 stable update
Electron apps may crash and flatpak apps may not start
It got reported that electron apps may crash. Also flatpaks might not work. Most likely fixed via adwaita-icon-theme-legacy 46.2-3. More information about it here
2024-10-01
Introducing linux-meta package to deal with EOL kernels more automated
Since we got several reports about issues around linux69 removal we created meta packages called linux-meta and packages for the extramodules. It will detect end of life Kernels and replace them with the current recommended kernel. For now with linux610 series. Please report back if you have any issues with this provided solution.
Users with Nvidia graphic cards may get unbootable systems into graphical environments
Since we removed the linux69 kernel from our repositories and most users will use pamac to update their systems, there is a chance that you may land in a TTY after you reboot your system. Here is why:
  • pamac has an auto-conflict resolution and might have put the linux69-nvidia package on the removal list.
  • you only had linux69 as your kernel installed, since it got shipped by default in Manjaro 24.0 ISOs
  • you rebooted your system without noticing that possible issue
How to fix:
  • first don’t panic and log in to your TTY with your user name and password
  • then install a kernel like 6.6 LTS or 6.10 to your system via: sudo mhwd-kernel -i linux66 or sudo mhwd-kernel -i linux610
  • then install the nvidia drivers via: sudo mhwd --auto pci ${DRIVER} 0300
VirtualBox: might show an error message after update to 7.1
You may have an error message like this: Failed to acquire the VirtualBox COM object. The application will now terminate.Callee RC%3ANS_ERROR_FAILURE (0x80004005). Simply restart the application
Random QML widgets and System Settings pages failing to launch in Plasma settings
… until Qt’s QML cache folder is cleared (if you do this, please save it first and attach it to the bug report).
System freeze on suspend
A feature in systemd 256 freezing a user session when suspending may freeze the system.
The issue is most prominent with Nvidia systems but reports exist that it may affect other systems as well.
System freezes for 60 seconds and then wakes back up or hangs after waking up
Since systemd v256, systemd freezes user.slice before sleeping. This process can fail due to kernel bugs, particularly when KVM is in use.[13][14]
Messages in the logs will contain Failed to freeze unit 'user.slice' before sleep. When such an issue occurs, trying to login (start another session) would fail with pam_systemd(process:session): Failed to create session: Job 9876 for unit 'session-6.scope' failed with 'frozen'.
To temporarily revert back to the old behavior, edit systemd-suspend.service, systemd-hibernate.service, systemd-hybrid-sleep.service, and systemd-suspend-then-hibernate.service with the following drop-in:
[Service]
Environment="SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=false"
– Power management/Suspend and hibernate - ArchWiki
KDE Plasma hangs on Shutdown, Restart and Logout
With KDE Plasma 6.1, the session saving feature can make Plasma hang.
A workaround is to disable it in System settings > Session > Desktop Session, by choosing “Start with an empty session”.
Session auto login can't be re-enabled for X11
Once session auto login for X11 gets disabled, it can’t be re-enabled in settings.
A workaround is to edit the /etc/sddm.conf.d/kde_settings.conf file and replace Session=Plasma (X11) by Session=plasma
:information_source: 2024-09-09
Added by @linux-arhus
[Service]
2024-08-20
Some GTK apps on Gnome suddenly changed to other (bright) theme
The adw-gtk3 package is now called adw-gtk-theme which replaces the old adw-gtk-theme.
With that change, you may need to set Legacy Applications to Adw-gtk3-dark in the Tweaks application under Appearance. It may have been set to the now removed Adw-dark previously.
2024-08-08
pipewire-pulse conflicts with pulseaudio-ctl
pulseaudio-ctl is not compatible with PipeWire and should be removed:
pamac remove pulseaudio-ctl
Noisetorch from Extra repository cannot be updated
noisetorch on AUR has been updated to change pulseaudio dependency to pulse-native-provider
A similar change has not been implemented for repository package yet, so pipewire-pulse users may need to remove package before update
pamac remove noisetorch
Noisetorch 0.12.2-4 with pulse-native-provider dependency has been released to all Manjaro branches - Branch compare for Manjaro - noisetorch
2024-07-01
The sshd service needs to be restarted after upgrading to openssh-9.8p1
2024-07-01 - Robin Candau
After upgrading to openssh-9.8p1, the existing SSH daemon will be unable to accept new connections (see Can't login after openssh 9.8p1-1 upgrade, MUST restart sshd (#5) · Issues · Arch Linux / Packaging / Packages / openssh · GitLab).
When upgrading remote hosts, please make sure to restart the sshd service using systemctl try-restart sshd right after upgrading.
We are evaluating the possibility to automatically apply a restart of the sshd service on upgrade in a future release of the openssh-9.8p1 package.
– Arch Linux - News: The sshd service needs to be restarted after upgrading to openssh-9.8p1
Virtual machines using libvirt have no internet if the host uses UFW
This is a known bug. “Workaround” is to change the firewall with firewalld or to disable UFW.
Another easier workaround is to edit /etc/libvirt/network.conf, and add
firewall_backend = "iptables"
2024-05-14
No plasma interface with kernel 6.9 + Nvidia gpu + Wayland
If you encouter a black screen with no inteface after login in, it’s probably a problem with simpledrm loading.
To solve it add nvidia_drm.fbdev=1 to /etc/default/grub
in the line begining with GRUB_CMDLINE_LINUX=" .
Verify that you also have nvidia_drm.modeset=1 in the same line.
Then exec sudo update-grub
Also, verify that you have nvidia_drm in /etc/mkinitcpio.conf in the MODULES= or HOOKS= line.
Exemple :
MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
If it was not present, then run sudo mkinitcpio -P after adding it.
2024-05-13
Python interpreter upgrade
If you have a lot of pip/AUR packages to upgrade to Python 3.12, read this.
If you installed python312 from the AUR, you need to uninstall it before running this update.
Qemu: MacOS is not bootable with 9.0
Due to a bug MacOS is not bootable with 9.0: [9.0.0] qemu breaks mac os vm (#2334) · Issues · QEMU / QEMU · GitLab
Workaround: remove virtio-serial and org.qemu.guest_agent.0 from libvirt XML until bug will be fixed.
If you use KDE you better logout of your session and do the update via Pacman or Pamac in tty.
Helper script to reset plasma The balance of power and brought up from that fact. The Party said that. @liinux-aarhus
Also I would, before the update:
  • make a Timeshift snapshot if you ain’t got no recent one.
  • ( export content of widgets like your radio stations in Advanced Radio Player or your Podcasts in Kasts or any podcatcher as a backup )
  • make a fresh boot, but before that even:
  • System Settings > Appearance > Global Theme > set to Breath and tick both options for defaults
  • You might go to the hamburger menu in System Settings and look what changes you made away from default by selecting: Highlight Changed Settings and see if you want to make the effort to get back more defaults
  • System Settings > Workspace > Startup and Shutdown: SDDM defaults and Desktop Session: Start with empty session
  • disable all user-installed widgets that are still on your desktop, panels and even lock screen or wallpaper (e.g. Active Blur)
  • Export your custom shortcuts or mouse gestures in SS> Workspace > Shortcuts
  • Reboot, Timeshift snapshot, reboot
  • then do not log in, do the update via tty (CTRL+ALT+F3, same with F2 gets you back)
  • reboot, login, check through System Settings
  • reboot again
  • enjoy 8)
post-install:
  • look for Plasma 6 replacements for your widgets after the install
  • in case you have Github-installed theming: uninstall the KDE5-version of klassy, install the Plasma 6 version of klassy, maybe reinstall lightly
(greetings, @1efaf7d71a8637c6800a , PS: these are just my thoughts; I didn’t do this update yet!)
How to fix `plasma-firewall` error in System Settings GUI when running `ufw`
Open /usr/lib/kde_ufw_plugin_helper.py and change the first line from #!/usr/bin/python3.11 to #!/usr/bin/python3.12. This fixed the issue for me immediately and makes sense since Manjaro is currently on Python 3.12.
Xfce has inconsistent themes for Qt applications
Qt 6 is now default but some apps are still using Qt 5
To restore the look of QT apps after this update
pamac install kvantum-qt5
Manjaro-settings-manager has light theme instead of dark
2024-04-04
DKMS fails for v4l2loopback on 6.8 kernel
DKMS fails for v4l2loopback on 6.8 kernel (#2) · Issues · Arch Linux / Packaging / Packages / v4l2loopback · GitLab
issues with auto-mount of ntfs filesystem using Kernel 6.8
The kernel changed default ntfs driver from FUSE one to ntfs3.
These two are not fully compatible, mainly as far as mount options go. If you have custom mount options in the fstab (or any other application, such as VeraCrypt) they need to be changed.
Symptoms:
Mount fails with: Device or resource busy
DMesg reports: Can't open blockdev
Solution:
Migrate your mount options. For me the changes were:
  • allow_other → umask=000
  • default_permissions → [drop]
  • user_id=1000 → uid=1000
  • group_id=1000 → gid=1000
2024-03-06
gnome-keyring: ssh component is not included
ssh component is not included (#3) · Issues · Arch Linux / Packaging / Packages / gnome-keyring · GitLab
2024-02-21
plymouth update may cause black screens
With a newer version of plymouth than 22.02.122 you may experience an unbootable system with a black screen. This might be due to not having early KMS enabled. If you have an Nvidia GPU you could set nvidia_drm.modeset=1 nvidia_drm.fbdev=1 to the kernel parameters in your bootloader config to avoid the need of KMS. However, with Wayland around the corner, KMS will be needed.
To “fix” the current problem, we have downgraded plymouth once again to have more time to find a proper solution to migrate most of your installations to a working state with newer plymouth versions.
sudo pacman -Syuu
Those who don’t have issues can enjoy the newer version of plymouth.
Directions for adding kms to your system configuration and how you can help troubleshooting by providing some sysinfo, read more → Black Screen with Plymouth - Cause and Solution
polkit update might remove your local modified config
With polkit 124-1 there were changes made to etc/pam.d/polkit-1. So check if you made local changes to the file. See also: https://www.reddit.com/r/archlinux/comments/19bnj0i/comment/kit2v33/
bashrc-manjaro is now merged into bash
  • Yes, replace bashrc-manjaro with bash
  • Please also compare your:
    /etc/bash.bashrc
    with the generated
    /etc/bash.bashrc.pacsave
    and retrofit all of your customisations as there was no .pacnew file generated.
  • Same goes for /etc/skel/.bashrc
pacman and pacman-contrib changes
pacman-contrib is now split out from pacman. If you have anything installed that depends on pacman-contrib, update (after you finished the Release Update) with:
sudo pacman -Syu pacman-contrib
2024-01-13
Initramfs image can be bigger on 6.7 kernel due to Nvidia GSP Boot firmware
We all known that kernel 6.7 is very feature rich. One of the features is the inclusion of Nvidia’s GSP Boot firmware into Initramfs. However this will increase your image by 150 MB and the fallback image might be 240 MB in size. A way would be to remove kms from mkinitcpio.conf and redo your initramfs images. A discussion regarding that can be found at Arch Gitlab: kms hook increases the initramfs size heavily starting with 6.7 kernel (#238) · Issues · Arch Linux / Mkinitcpio / mkinitcpio · GitLab
To reduce size add fallback_options="-S autodetect -S kms" to /etc/mkinitcpio.d/linux67.preset
Making dbus-broker our default D-Bus daemon
2024-01-09 - Jan Alexander Steffens
We are making dbus-broker our default implementation of D-Bus, for improved performance, reliability and integration with systemd.
For the foreseeable future we will still support the use of dbus-daemon, the previous implementation. Pacman will ask you whether to install dbus-broker-units or dbus-daemon-units. We recommend picking the default.
For a more detailed rationale, please see our RFC 25.
– Arch Linux - News: Making dbus-broker our default D-Bus daemon
In some cases, however it is better to keep the legacy way. Here are some examples: Dbus-broker warnings
Just updated on Cinnamon, with kernel 6.11 on a laptop with AMD and Nvidia, no issues, flawless update.
Cinnamon 6.4 seems real smooth.
:+1:
I’m getting this error when I try to pacman -Syu:
mutter46-46.5-1 and mutter-47.2-1 are in conflict
Spectacle crashes after update, but it works if I remove libva-vdpau-driver.
To confirm, is it safe to remove libva-vdpau-driver on a KDE-wayland-nvidia system ? Thanks.
https://bugs.kde.org/show_bug.cgi?id=481977
Spectacle log without libva-vdpau-driver :
$ journalctl -r --grep=spectacle
Nov 30 19:39:52 workstation systemd[835]: app-org.kde.spectacle.service: Consumed 456ms CPU time, 191.4M memory peak.
Nov 30 19:39:50 workstation systemd[835]: Started Spectacle screenshot capture utility.
Nov 30 19:39:50 workstation systemd[835]: Starting Spectacle screenshot capture utility...
Spectacle log with lbva-vdpau-driver :
Nov 30 18:33:32 workstation systemd[835]: Failed to start Spectacle screenshot capture utility.
Nov 30 18:33:32 workstation systemd[835]: app-org.kde.spectacle.service: Failed with result 'core-dump'.
Nov 30 18:33:32 workstation systemd[835]: app-org.kde.spectacle.service: Main process exited, code=dumped, status=11/SEGV
Nov 30 18:33:32 workstation systemd-coredump[3115]: [🡕] Process 3108 (spectacle) of user 1000 dumped core.
                                                    Stack trace of thread 3113:
                                                    #0  0x000072d3bf0e6514 XDisplayString (libX11.so.6 + 0x27514)
                                                    #1  0x000072d39c6fad00 __vaDriverInit_1_21 (nvidia_drv_video.so + 0xdd00)
                                                    #2  0x000072d3bd170064 vaInitialize (libva.so.2 + 0x8064)
                                                    #3  0x000072d3c1ae8589 _ZN10VaapiUtils10openDeviceEPiRK10QByteArray (libKPipeWire.so.6 + 0x1c589)
                                                    #4  0x000072d3c1ae8b22 _ZNK10VaapiUtils12supportsH264ERK10QByteArray (libKPipeWire.so.6 + 0x1cb22)
                                                    #5  0x000072d3c1ae8cd5 _ZN10VaapiUtilsC1ENS_7PrivateE (libKPipeWire.so.6 + 0x1ccd5)
                                                    #6  0x000072d3c1ae8e98 _ZN10VaapiUtils8instanceEv (libKPipeWire.so.6 + 0x1ce98)
                                                    #7  0x000072d3c7c747af _ZNK25PipeWireBaseEncodedStream17suggestedEncodersEv (libKPipeWireRecord.so.6 + 0xd7af)
                                                    #8  0x000072d3c7c74f3c _ZN25PipeWireBaseEncodedStreamC1EP7QObject (libKPipeWireRecord.so.6 + 0xdf3c)
                                                    #9  0x000072d3c7c77d86 _ZN14PipeWireRecordC2EP7QObject (libKPipeWireRecord.so.6 + 0x10d86)
                                                    #10 0x000060571de1d3f1 n/a (spectacle + 0xc93f1)
                                                    #11 0x000060571de2401b n/a (spectacle + 0xd001b)
                                                    #12 0x000072d3c26dec15 n/a (libQt6Core.so.6 + 0x2dec15)
                                                    #13 0x000072d3c26d840f n/a (libQt6Core.so.6 + 0x2d840f)
                                                    #14 0x000072d3c1ea339d n/a (libc.so.6 + 0x9439d)
                                                    #15 0x000072d3c1f2849c n/a (libc.so.6 + 0x11949c)
                                                    Stack trace of thread 3109:
                                                    #0  0x000072d3c1f1abb0 ppoll (libc.so.6 + 0x10bbb0)
                                                    #1  0x000072d3be67d227 n/a (libglib-2.0.so.0 + 0xc0227)
                                                    #2  0x000072d3be619a55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
                                                    #3  0x000072d3c27bf71d _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3bf71d)
                                                    #4  0x000072d3c2564566 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x164566)
                                                    #5  0x000072d3c2657072 _ZN7QThread4execEv (libQt6Core.so.6 + 0x257072)
                                                    #6  0x000072d3c4f7379e n/a (libQt6DBus.so.6 + 0x2e79e)
                                                    #7  0x000072d3c26d840f n/a (libQt6Core.so.6 + 0x2d840f)
                                                    #8  0x000072d3c1ea339d n/a (libc.so.6 + 0x9439d)
                                                    #9  0x000072d3c1f2849c n/a (libc.so.6 + 0x11949c)
                                                    Stack trace of thread 3110:
                                                    #0  0x000072d3c1e9fa19 n/a (libc.so.6 + 0x90a19)
                                                    #1  0x000072d3c1ea2479 pthread_cond_wait (libc.so.6 + 0x93479)
                                                    #2  0x000072d3c26dd030 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x2dd030)
                                                    #3  0x000072d3c596e3af n/a (libQt6WaylandClient.so.6 + 0x5f3af)
                                                    #4  0x000072d3c26d840f n/a (libQt6Core.so.6 + 0x2d840f)
                                                    #5  0x000072d3c1ea339d n/a (libc.so.6 + 0x9439d)
                                                    #6  0x000072d3c1f2849c n/a (libc.so.6 + 0x11949c)
                                                    Stack trace of thread 3111:
                                                    #0  0x000072d3c1f1a63d __poll (libc.so.6 + 0x10b63d)
                                                    #1  0x000072d3c596e417 n/a (libQt6WaylandClient.so.6 + 0x5f417)
                                                    #2  0x000072d3c26d840f n/a (libQt6Core.so.6 + 0x2d840f)
                                                    #3  0x000072d3c1ea339d n/a (libc.so.6 + 0x9439d)
                                                    #4  0x000072d3c1f2849c n/a (libc.so.6 + 0x11949c)
                                                    Stack trace of thread 3108:
                                                    #0  0x000072d3c1f1d8dc fdatasync (libc.so.6 + 0x10e8dc)
                                                    #1  0x000072d3c2527bdd _ZN9QLockFile7tryLockENSt6chrono8durationIlSt5ratioILl1ELl1000EEEE (libQt6Core.so.6 + 0x127bdd)
                                                    #2  0x000072d3c2527ef7 _ZN9QLockFile7tryLockENSt6chrono8durationIlSt5ratioILl1ELl1000EEEE (libQt6Core.so.6 + 0x127ef7)
                                                    #3  0x000072d3c2527ef7 _ZN9QLockFile7tryLockENSt6chrono8durationIlSt5ratioILl1ELl1000EEEE (libQt6Core.so.6 + 0x127ef7)
                                                    #4  0x000072d3c58ce2f5 n/a (n/a + 0x0)
                                                    #5  0x000072d3c58bab62 n/a (n/a + 0x0)
                                                    #6  0x000060571dda4186 n/a (spectacle + 0x50186)
                                                    #7  0x000060571dda9256 n/a (spectacle + 0x55256)
                                                    #8  0x000060571de9a55f n/a (spectacle + 0x14655f)
                                                    #9  0x000060571dde086d n/a (spectacle + 0x8c86d)
                                                    #10 0x000060571de9d908 n/a (spectacle + 0x149908)
                                                    #11 0x000060571dd9c3e2 n/a (spectacle + 0x483e2)
                                                    #12 0x000072d3c1e34e08 n/a (libc.so.6 + 0x25e08)
                                                    #13 0x000072d3c1e34ecc __libc_start_main (libc.so.6 + 0x25ecc)
                                                    #14 0x000060571dd9fd55 n/a (spectacle + 0x4bd55)
Nov 30 18:33:32 workstation systemd-coredump[3114]: Process 3108 (spectacle) of user 1000 terminated abnormally with signal 11/SEGV, processing...
Nov 30 18:33:32 workstation systemd[835]: Starting Spectacle screenshot capture utility...
System summary :
$ inxi -zv1
  Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.2.4 Distro: Manjaro Linux
  Info: 6-core 12th Gen Intel Core i5-12400F [MT MCP] speed (MHz): avg: 800
    min/max: 800/4400
  Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] driver: nvidia v: 550.135
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia resolution:
    1: 2048x1152 2: 2048x1152
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
    renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
  Local Storage: total: 1.86 TiB used: 70.7 GiB (3.7%)
  Memory: total: 32 GiB available: 31.14 GiB used: 5.6 GiB (18.0%)
  Processes: 358 Uptime: 21m Shell: Zsh inxi: 3.3.36
I’m getting this message when trying to update through pacman -Syu and pamac update
:: installing expat (2.6.4-1) breaks dependency 'expat=2.6.3' required by lib32-expat
:: installing libcap (2.71-1) breaks dependency 'libcap=2.70' required by lib32-libcap
:: installing libelf (0.192-2) breaks dependency 'libelf=0.191' required by lib32-libelf
:: installing ppp (2.5.1-1) breaks dependency 'ppp=2.5.0' required by networkmanager-l2tp
:: installing ppp (2.5.1-1) breaks dependency 'ppp=2.5.0' required by networkmanager-pptp
After the update, Manjaro would not restart. Error was at systemd startup “nvidia-persistance […]”. Then it stopped few lines later.
Had to enter grub menu, edit the grub parameters by adding a " 3" after the linux boot parameter. Then I started in the console, logged in and restored with Timeshift.
God bless Timeshift! :hugs:
@JPL, you may want to check via pacman -Qi mutter46 why you might have installed this package. Normally it is a dependency of these packages: gala, lightdm-pantheon-greeter, wingpanel
@rousseau: libva-vdpau-driver got removed from the repos and is therefore orphan. It is save to remove it. libva is now provided by mesa.
@Kyoketsu9513 networkmanager-pptp 1.2.12-4 and networkmanager-l2tp 1.20.16-2 are fine with ppp 2.5.1. So your mirrorlist might not been updated. Check that and try again.
@Humbi your issue sounds like this one: [SOLVED]Nvidia Persistence Daemon fails to start / Newbie Corner / Arch Linux Forums. This update normally removes linux610 kernel. You can check first if you have all modules of nvidia drivers installed for the newer kernel. You also can install an older kernel like 6.6. You can check with pacman -Q | grep nvidia on what is installed Nvidia related on your system.
If I type in terminal “pacman -Syyu” it says “nothing to update”. It is normally?
Yes, just wait a bit until your mirrors have updated.
The correct command would be:
sudo pacman -Syu
Don’t use a double-y. I’ve heard it can cause problems and it thrashes the servers if you do it unnecessarily. Rather just be patient.
The correct Firefox version is 133.0.
Firefox 132 got passed over.
@Marsa thx. I’ve double-checked the release versions and corrected the list.
Do you use dark mode or light mode? Several apps default to dark mode after the update regardless of the setting in preferences. They only swap to light mode if I toggle the setting. The novelty is already wearing off.
Everything worked fine on my side.
pacman remove -o now lists several packages to remove. Is it safe to do that? I feel like it would remove too much, I have kernel 6.11 still installed.
To remove (15):
v86d 0.1.10-13
python-validate-pyproject 0.22-1 extra
python-fastjsonschema 2.20.0-1 (Orphan Of: python-validate-pyproject) extra
python-trove-classifiers 2024.10.21.16-1 (Orphan Of: python-validate-pyproject) extra
python-tomli 2.0.1-4 extra
linux-meta 6.11-1 core
libgusb 0.4.9-1 extra
python-ordered-set 4.1.0-5 extra
libsoup 2.74.3-1 extra
linux-headers-meta 6.11-1 core
linux611-headers 6.11.10-2 (Orphan Of: linux-headers-meta) core
linux-nvidia-meta 6.11-1 extra
linux611-nvidia 550.135-3 (Orphan Of: linux-nvidia-meta) extra
linux-virtualbox-host-modules-meta 6.11-1 extra
lua52 5.2.4-7 extra
Total removed size: 202,3 MB
But actually, I don’t need kernel 6.11 anymore. I tried to remove it via the Manjaro settings. It says it can’t uninstall that because of dependencies:
Starting
checking dependencies…
:: removing linux611-headers breaks dependency ‘linux611-headers’ required by linux-headers-meta
:: removing linux611 breaks dependency ‘linux611’ required by linux-meta
:: removing linux611-nvidia breaks dependency ‘linux611-nvidia’ required by linux-nvidia-meta
:: removing linux611-virtualbox-host-modules breaks dependency ‘linux611-virtualbox-host-modules’ required by linux-virtualbox-host-modules-meta
I think the root problem of both is the same.
The linux-meta packages get installed when we drop a kernel from the repos. In this case 6.10 series got dropped. You can remove the meta packages with the kernel packages it installed for you. More information about it here: Find a proper solution to automate EOL kernel removal via ALPM (#13) · Issues · Release plan / Packaging · GitLab
Pamac somehow crashed (gui disappeared) twice during update-download so I used pacman instead and it worked flawlessly.
It is recommended to use the cli tools for bigger updates on GNOME and Plasma. The newer pamac might be more robust in that regard.
The only thing that broke is dino, a xmpp client, version 0.4.4-1 It does not start and gives the following message when
(dino:3264): Adwaita-WARNING **: 10:22:03.434: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
followed by some gstreamer errors.
System info:
Kernel: 6.11.10-2-MANJARO arch: x86_64 bits: 64
Info: 8-core AMD Ryzen 7 7800X3D [MT MCP] speed (MHz): avg: 3599
min/max: 545/5050
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
7800 XT] driver: amdgpu v: kernel
Device-2: Advanced Micro Devices [AMD/ATI] Raphael driver: amdgpu
v: kernel
compositor: kwin_wayland driver: X: loaded: amdgpu
unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu,amdgpu
resolution: 3072x1728
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
renderer: AMD Radeon RX 7800 XT (radeonsi navi32 LLVM 18.1.8 DRM 3.59
6.11.10-2-MANJARO)
You can check your GTK settings and remove the preffered dark theme flag. With GNOME 47 release accent colours got added. That got also updated in gtk3 and gtk4 packages.
