[Stable Update] 2024-07-01 - Kernels, Systemd, KDE Gear, LibreOffice, Firefox, Wine, Qemu
system won’t shutdown/poweroff
KDE Plasma Version: 6.0.5
KDE Frameworks Version: 6.3.0
Qt Version: 6.7.1
Kernel Version: 6.9.5-1-MANJARO (64-bit)
Graphics Platform: X11
shutting down the system results in a blank screen with a cursor - keyboard appears to be dead
inxi --admin --verbosity=8 --filter --no-host --width
  Kernel: 6.9.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=bb1d3d93-e1ee-4b58-94bc-d9b9b6f183a1 rw
    resume=UUID=365557ba-d129-4798-90eb-91ecda0db65d udev.log_priority=3
    nowatchdog
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
  Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 3.B0 date: 05/12/2021
  System RAM: total: 16 GiB available: 13.57 GiB used: 2.89 GiB (21.3%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3200C16-8GVGB serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
    type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
    built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
    stepping: 1 microcode: 0x8108109
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 2083 high: 3700 min/max: 1400/3700 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1229 2: 1400
    3: 3061 4: 1400 5: 1400 6: 3074 7: 3700 8: 1400 bogomips: 59223
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1
    empty: DVI-D-1,HDMI-A-2,HDMI-A-3 bus-ID: 27:00.0 chip-ID: 1002:15d8
    class-ID: 0300 temp: 44.0 C
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: BenQ EX2510 serial: <filter> built: 2020
    res: 1920x1080 dpi: 90 gamma: 1.2 chroma: red: x: 0.651 y: 0.341 green:
    x: 0.310 y: 0.631 blue: x: 0.145 y: 0.051 white: x: 0.314 y: 0.329
    size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9
    modes: 1920x1080, 3840x2160, 1680x1050, 1600x900, 1280x1024, 1440x900,
    1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 96 2: parse_edid:
    unhandled CEA mode 97
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 11 Graphics
    (radeonsi raven LLVM 17.0.6 DRM 3.57 6.9.5-1-MANJARO) device-ID: 1002:15d8
    memory: 1.95 GiB unified: no
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Vega 11 Graphics (RADV RAVEN) driver: mesa radv v: 24.1.1-manjaro1.1
    device-ID: 1002:15d8 surfaces: xcb,xlib
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Micro-Star MSI
    bus-ID: 27:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: Mark of the Unicorn M Series driver: cdc_acm,snd-usb-audio
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
    chip-ID: 07fd:000b class-ID: 0a00 serial: <filter>
  API: ALSA v: k6.9.5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: azirevpn-us-nyc state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  Local Storage: total: 9.1 TiB used: 2.2 TiB (24.1%)
    model: WDS100T3XHC-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 102000WD temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 4TB
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SDSSDH32000G
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 70RL scheme: MBR
  ID-1: / raw-size: 905.34 GiB size: 890.05 GiB (98.31%) used: 14.84 GiB (1.7%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: Root
    uuid: bb1d3d93-e1ee-4b58-94bc-d9b9b6f183a1
  ID-2: /archive raw-size: 1.82 TiB size: 1.79 TiB (98.42%)
    used: 8.54 GiB (0.5%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: Archive
    uuid: 1eb02be6-20af-4ad8-9e1b-d592992fab43
  ID-3: /av raw-size: 3.64 TiB size: 3.58 TiB (98.40%) used: 1.87 TiB (52.3%)
    fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: Media
    uuid: 45c9271b-5cff-490c-bd91-37fc1c7ffeb7
  ID-4: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: BOOT
    uuid: 61A2-791F
  ID-5: /home raw-size: 931.02 GiB size: 915.33 GiB (98.31%)
    used: 96.77 GiB (10.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Home
    uuid: d186724a-14d9-46e5-a29d-b16ae175fd25
  ID-6: /storage raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 210.45 GiB (11.5%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Storage
    uuid: 5cc0fb64-e894-4df0-9075-42cdb94500b1
  Kernel: swappiness: 20 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: partition size: 25.39 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
    uuid: 365557ba-d129-4798-90eb-91ecda0db65d
  Device-1: 1-1:2 info: Mark of the Unicorn M Series
    type: audio,abstract (modem),CDC-data driver: cdc_acm,snd-usb-audio
    interfaces: 7 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 07fd:000b class-ID: 0a00 serial: <filter>
  Device-2: 1-2:3 info: Logitech G502 X type: mouse,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 046d:c099 class-ID: 0300
    serial: <filter>
  Device-3: 1-8:4 info: Cyber Power System CP1500 AVR UPS type: HID
    lanes: 1 mode: 1.1 power: 2mA chip-ID: 0764:0501 class-ID: 0300
    serial: <filter>
  Device-4: 1-9:5 info: Apple Aluminium Keyboard (ISO) type: keyboard,mouse
    driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 05ac:0250 class-ID: 0301
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 43.6 C mobo: N/A gpu: amdgpu temp: 43.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1363 libs: 297 tools: pamac pm: flatpak pkgs: 0
    1: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    3: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    5: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    6: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    7: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 259
  1: cpu: 18.8% command: konsole pid: 24255 mem: 152.1 MiB (1.0%)
  2: cpu: 7.2% command: firefox pid: 3283 mem: 490.8 MiB (3.5%)
  3: cpu: 3.1% command: easyeffects pid: 1279 mem: 92.3 MiB (0.6%)
  4: cpu: 2.5% command: firefox pid: 22734 mem: 212.3 MiB (1.5%)
  5: cpu: 2.1% command: kwin_x11 pid: 967 mem: 130.4 MiB (0.9%)
  Memory top: 5 of 259
  1: mem: 490.8 MiB (3.5%) command: firefox pid: 3283 cpu: 7.2%
  2: mem: 423.6 MiB (3.0%) command: thunderbird pid: 1291 cpu: 0.3%
  3: mem: 342.1 MiB (2.4%) command: plasmashell pid: 1005 cpu: 0.1%
  4: mem: 219.6 MiB (1.5%) command: firefox pid: 3413 cpu: 0.3%
  5: mem: 212.3 MiB (1.5%) command: firefox pid: 22734 cpu: 2.5%
  Processes: 259 Power: uptime: 8h 10m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.41 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: gcc: 14.1.1 Shell: Bash v: 5.2.26 running-in: konsole
    inxi: 3.3.35
journalctl --boot=-1 --priority=3 --catalog --no-pager
amdgpu 0000:27:00.0: amdgpu: Secure display: Generic Failure.
amdgpu 0000:27:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Also have exactly the same problem as @hannodv and I am also on old AMD Radeon (Sapphire R9 290).
After log-in screen (into Wayland session), just flashing happens and KDE Plasma desktop crashes back to login screen after applying this update.
And it is not an issue with linux-kernel … both under kernel 6.8 (which is EOL) and under LTS 6.6 KDE Plasma, Wayland session just flashes and then crashes.
For the time being I only time-shifted back and cancelled the update.
After changing to amdgpu, I am not having any issue anymore. Are you using the radeon or amdgpu module?
inxi -G
will show what you are using. The Arch linux wiki gives good guidance on changing the kernel module to amdgpu.
As noted by @hannodv it seem to be a problem with the old radeon driver. Your card is supported by amdgpu and instructions on how to switch to it are at https://wiki.archlinux.org/title/AMDGPU#Enable_Southern_Islands_(SI)and_Sea_Islands(CIK)_support.
Thanks for this ‘one-liner’. :+1:
Funny enough, when I tried it out, I noticed the same error message on /var/lib/libvirt/swtpm/ permission has already been logged on May 25th in my pacman.log because of a Stable Update then. Must have slipped through the crack. :wink:
I must say, as @jackdinn says in post #22, there is something fishy with bluetooth devices after update.
I’m using a bluetooth speaker (ASUS ZenBook). After update it started to fail to play sounds after powered on and auto-connected. The volume slider wouldn’t go to previous level. After reconnecting the device from settings, and using volume up/down buttons on speaker, the sound started working sometimes. But then the speaker turned off itself after a while. And the intervals between the power on & reconnect procedure and the sudden power off became shorter and shorter. After a few hours it wouldn’t play sound at all. The settings said connected, no sound and even couldn’t disconnect. (Also when I switched to internal audio and fast-forwarded a video, the system froze, but it’s probably another issue)
After a timeshift leap to a state before update, everything began to work and works as intended until now (1 day).
The weird thing is, there was no bluetooth pkg update at my system (GNOME), it has to be something else as bluez-qt pkg, which @jackdinn mentions.
I shall tell you something that is really odd, i cant believe its not just a coincidence, but, after i found that i needed to mask the TMP2 device to stop it trying to mount at boot & hanging my system boot for 2 minutes, the system now booted properly and my USB bluetooth device also worked again. Its been fine since.
Make of it what you will :confounded:
Thread cleaned of off-topic discussion.
:broom:
However, feel free to talk about whatever you wish (within reason) in the Member Hub.
This update seems to permanently kill my display - once logged from sddm to the plasma session my display started blinking rapidly and then shut down permanently. I guess some unsupported mode fried it for good.
(I’m using mesa, might be related to the issues other folks reported.)
within the past few stable updates I experienced a display issue too that seemed to coincide with an update/reboot… ended up the DP port on the monitor died… I’m still using the same monitor now, just off one of it’s HDMI ports.
Hi there !
So if i run kernel 5.4 and cgroup2 i should update without any problem ?
Does anyone can confirm this ?
Thanks !
I can’t speak for kernel 5.4 but you should be using a newer kernel anyway. 6.1 and 6.6 are good LTS choices. It appears some users are having issues booting with older kernels, so you might want to install a newer kernel, reboot, then start the system update.
If mount | grep cgroup outputs cgroup2, you shouldn’t have issues booting, unless you have a separate issue, of course.
Thanks for the reply but it didn’t work out with the 5.4 kernel,not even when chroot and modify the grub !
However changing the kernel with a newer one did the trick !
Thank to both of you very very much. @MrLavender the instructions made it very, very clear what card I am using and that I need to prefer loading amdgpu kernel module on Sea Islands (CIK) or more commonly known as AMD Radeon R9 290 graphic chips.
@hannodv thanks for reporting solution. I can now confirm that Manjaro out-of-the-box loads radeon kernel module. And I guess packages at current version have a trouble working with it.
If nothing else, this solution will work for more than just the 2 of us that confirmed it.
A post was split to a new topic: Issues after cancelling update
I also had a monitor die after recent updates. No idea if it is related.
Sounds like a failed backlight (or its driver). Can you see anything if you shine a bright light at the screen?
EDIT:
I forgot to reboot for several days, and I initially attempted a hibernate state.
On attempted resume it did a clean reboot. I found that the “resume” hook was missing from
/etc/mkinitcpio.conf
… so, restored that, ran
sudo mkinitcpio -P
and a reboot followed with several tests with hibernate (an essential function in my use case) is once again working fine.
I had the same problem a few months ago and went back to Kernel 6.1 LTS. This has solved the problem for me.
A post was merged into an existing topic: I would have expected Plasma 6.1
I had the same error.
error: failed to commit transaction (conflicting files)
npm: /usr/lib/node_modules/npm/node_modules/cidr-regex/dist/index.js exists in filesystem
npm: /usr/lib/node_modules/npm/node_modules/is-cidr/dist/index.js exists in filesystem
Errors occured, no packages were upgraded.
I tried to uninstall them via “npm uninstall -g” with no effect.
Eventually, I resorted to delete both module folders in question manually and the update did succeed. (Don’t know if this is recommendable, though.) :melting_face:
