Current proprietary Nvidia drivers (550 branch) are unusable on laptops with RTX graphics
The 550 branch of the Nvidia drivers have system-breaking bug in memory allocation which affects every laptop with switchable RTX graphics - see this thread on Nvidia forums. My machine (Thinkpad P1G6 running current Manjaro) is also affected: I am getting random process crashes before or after suspend cycles, sometimes leading to cascade system failure and/or kernel panics.
It’s been this way for a month now, and Nvidia still haven’t been able to fix it. It would be nice if Manjaro could provide a way to downgrade to 545 drivers at least with the LTS kernel support, which worked perfectly.
For reference, this is my previous thread where I didn’t know what was going on - https://forum.manjaro.org/t/some-apps-freeze-after-suspend-indefinitely/157890/10. It has all the relevant logs for crashes. I have established since that the fault is in the Nvidia 550 driver, and other laptop users have the same issue (see Nvidia forums link above).
While I’m unable to help much in this instance, I’d suggest posting full logs so that others can give useful input.
Use the following command to generate information about your system while filtering out personally identifiable information:
inxi --admin --verbosity=8 --filter --no-host --width
…and this, as one example of log generation (filters also apply):
journalctl --boot=-1 --priority=3 --catalog --no-pager
Cheers.
  Kernel: 6.8.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.8-x86_64
    root=UUID=5d1499dd-3e69-4be6-a05a-5bf92c72f0a3 rw mitigations=off
    zswap.enabled=0 quiet udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_x11 tools: avail: xscreensaver vt: 2 dm: SDDM
  Type: Laptop System: LENOVO product: 21FVCTO1WW v: ThinkPad P1 Gen 6
  Mobo: LENOVO model: 21FVCTO1WW v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_21FV_BU_Think_FM_ThinkPad P1 Gen 6
    uuid: <superuser required> UEFI: LENOVO v: N3ZET21W (1.08 )
    date: 07/07/2023
  ID-1: BAT0 charge: 73.1 Wh (79.3%) condition: 92.2/90.1 Wh (102.4%)
    volts: 16.6 min: 15.5 model: SMP 5B11K07736 type: Li-poly serial: <filter>
    status: not charging cycles: 29
  System RAM: total: 64 GiB available: 62.46 GiB used: 7.62 GiB (12.2%)
  Array-1: capacity: 64 GiB note: est. slots: 2 modules: 2 EC: None
  Device-1: Controller0-ChannelA/B-DIMM0 type: DDR5 detail: synchronous
    size: 32 GiB speed: 5600 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Crucial Technology part-no: CT32G56C46S5.M16B2
    serial: <filter>
  Device-2: Controller1-ChannelA/B-DIMM0 type: DDR5 detail: synchronous
    serial: <filter>
  Info: model: 13th Gen Intel Core i7-13800H bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
    microcode: 0x411C
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 444 high: 915 min/max: 400/5000:5200:4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 915 6: 400 7: 400 8: 400 9: 770 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 116780
    de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase
    fsrm fxsr gfni hfi ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req
    ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid lahf_lm lm mca mce
    md_clear mmx monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx
    ospke pae pat pbe pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni
    popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg sep
    serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1
    sse4_2 ssse3 stibp syscall tm tm2 tme tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vpclmulqdq waitpkg x2apic xgetbv1
    xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: reg_file_data_sampling status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
    PBRSB-eIBRS: Vulnerable; BHI: Vulnerable (Syscall hardening enabled)
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Lenovo driver: i915
    v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm) built: 2022+
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:a7a0
    class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: Lenovo
    driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
    ports: active: none empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:28a0 class-ID: 0300
  Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 174f:1812
  Display: x11 server: X.Org v: 21.1.12 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-1 mapped: eDP-1-1 model: BOE Display 0x0ae0 built: 2021
    res: 2560x1600 hz: 165 dpi: 189 gamma: 1.2 chroma: red: x: 0.643 y: 0.333
    green: x: 0.298 y: 0.624 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
    modes: 2560x1600
  EDID-Warnings: 1: parse_edid: unknown tag 112
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
    drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4060 Laptop GPU driver: nvidia v: 550.67 device-ID: 10de:28a0
    surfaces: xcb,xlib
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51ca class-ID: 0401
  Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
    class-ID: 0403
  Device-3: XMOS iFi (by AMR) HD USB Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-1:7 chip-ID: 20b1:3008 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.8.5-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.3 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
  Local Storage: total: 1.82 TiB used: 1.54 TiB (84.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 47.9 C
    scheme: MBR
  ID-1: / raw-size: 100.27 GiB size: 98.14 GiB (97.87%) used: 86.71 GiB (88.4%)
    fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 5d1499dd-3e69-4be6-a05a-5bf92c72f0a3
  ID-2: /boot/efi raw-size: 1.29 GiB size: 1.29 GiB (99.80%)
    used: 29 MiB (2.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 6E9C-B8C7
  ID-3: /home raw-size: 879.88 GiB size: 865 GiB (98.31%)
    used: 768.3 GiB (88.8%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    label: N/A uuid: 8bbf33d9-bb68-4209-96c4-66fc5b4b4df7
  ID-4: /media/Music raw-size: 849.34 GiB size: 834.94 GiB (98.30%)
    used: 719.56 GiB (86.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: N/A uuid: e6233da2-d374-45b8-853f-558e8d4224b5
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 32.23 GiB fs: swap label: N/A
    uuid: 2b37dbd5-9b81-4a14-8256-18e5de581126
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 1 KiB fs: <superuser required>
    label: N/A uuid: N/A
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:7 info: XMOS iFi (by AMR) HD USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 20b1:3008
    class-ID: 0300 serial: <filter>
  Device-2: 1-6:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
  Device-3: 1-8:4 info: Syntek Integrated Camera type: video driver: uvcvideo
    interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 174f:1812 class-ID: fe01 serial: <filter>
  System Temperatures: cpu: 57.0 C mobo: N/A gpu: nvidia temp: 50 C
  Fan Speeds (rpm): fan-1: 2363 fan-2: 2178
  Packages: 2122 pm: pacman pkgs: 2115 libs: 479 tools: pamac,yay pm: flatpak
    pkgs: 7
    1: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    3: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    5: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    6: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    7: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    8: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 448
  1: cpu: 13.8% command: vivaldi-bin pid: 23958 mem: 411.3 MiB (0.6%)
  2: cpu: 11.7% command: vivaldi-bin pid: 26462 mem: 224.5 MiB (0.3%)
  3: cpu: 3.9% command: Discord pid: 3520 mem: 774.8 MiB (1.2%)
  4: cpu: 3.4% command: Xorg pid: 1379 mem: 512.1 MiB (0.8%)
  5: cpu: 3.2% command: thunderbird pid: 2606 mem: 778.4 MiB (1.2%)
  Memory top: 5 of 448
  1: mem: 778.4 MiB (1.2%) command: thunderbird pid: 2606 cpu: 3.2%
  2: mem: 774.8 MiB (1.2%) command: Discord pid: 3520 cpu: 3.9%
  3: mem: 666.9 MiB (1.0%) command: plasmashell pid: 1588 cpu: 0.2%
  4: mem: 523.0 MiB (0.8%) command: baloo_file pid: 1516 cpu: 1.8%
  5: mem: 512.1 MiB (0.8%) command: Xorg pid: 1379 cpu: 3.4%
  Processes: 448 Power: uptime: 17h 35m states: freeze,mem,disk suspend: s2idle
    wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
    image: 24.98 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 255
  Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Zsh v: 5.9
    default: Bash v: 5.2.26 running-in: yakuake inxi: 3.3.34
апр 30 22:14:18 ~-P1G6 kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
апр 30 22:14:18 ~-P1G6 kernel: spi-nor spi0.0: unrecognized JEDEC id bytes: f7 f0 30 09 03 00
апр 30 22:14:19 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
апр 30 22:14:19 ~-P1G6 kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
апр 30 22:14:20 ~-P1G6 kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
апр 30 22:14:21 ~-P1G6 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
апр 30 22:14:25 ~-P1G6 bluetoothd[1247]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
апр 30 22:14:25 ~-P1G6 bluetoothd[1247]: Failed to clear UUIDs: Failed (0x03)
апр 30 22:14:25 ~-P1G6 bluetoothd[1247]: Failed to add UUID: Failed (0x03)
апр 30 22:14:25 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
апр 30 22:14:26 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
апр 30 22:14:29 ~-P1G6 nmbd[1407]: [2024/04/30 22:14:29.485730,  0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
апр 30 22:14:29 ~-P1G6 nmbd[1407]:   NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
апр 30 22:14:37 ~-P1G6 kernel: Bluetooth: hci0: command 0x0c03 tx timeout
апр 30 22:14:37 ~-P1G6 kernel: Bluetooth: hci0: HCI reset during shutdown failed
апр 30 22:14:38 ~-P1G6 pulseaudio[1718]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.UnknownObject:Method "UnregisterBatteryProvider" with signature "o" on interface "org.bluez.BatteryProviderManager1" doesn't exist
апр 30 22:14:38 ~-P1G6 fingerprint-polkit-agent[1907]: Could not register listener "/fingerprintgui/PolicyKit1/AuthenticationAgent". Aborting.
апр 30 22:14:38 ~-P1G6 systemd-analyze[2101]: Bootup is not yet finished (org.freedesktop.systemd1.Manager.FinishTimestampMonotonic=0).
апр 30 22:14:38 ~-P1G6 systemd-analyze[2101]: Please try again later.
апр 30 22:14:38 ~-P1G6 systemd-analyze[2101]: Hint: Use 'systemctl list-jobs' to see active jobs
апр 30 22:14:40 ~-P1G6 nmbd[1407]: [2024/04/30 22:14:40.559246,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 22:14:40 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 22:14:40 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 22:19:56 ~-P1G6 nmbd[1407]: [2024/04/30 22:19:56.134394,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 22:19:56 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 22:19:56 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 22:24:58 ~-P1G6 nmbd[1407]: [2024/04/30 22:24:58.440148,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 22:24:58 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 22:24:58 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 22:29:17 ~-P1G6 pulseaudio[1718]: ALSA сообщила о возможности записи новых данных в устройство, но на самом деле писать было нечего.
апр 30 22:29:17 ~-P1G6 pulseaudio[1718]: Скорее всего, это ошибка в драйвере ALSA «snd_usb_audio». Пожалуйста, сообщите об этой проблеме разработчикам ALSA.
апр 30 22:29:17 ~-P1G6 pulseaudio[1718]: Процесс разбужен с установленным POLLOUT, однако последующий вызов snd_pcm_avail() вернул 0 или другое значение, меньшее чем min_avail.
апр 30 22:29:59 ~-P1G6 nmbd[1407]: [2024/04/30 22:29:59.633395,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 22:29:59 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 22:29:59 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 22:35:01 ~-P1G6 nmbd[1407]: [2024/04/30 22:35:01.938572,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 22:35:01 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 22:35:01 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 22:40:10 ~-P1G6 nmbd[1407]: [2024/04/30 22:40:10.741848,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 22:40:10 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 22:40:10 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 22:45:19 ~-P1G6 nmbd[1407]: [2024/04/30 22:45:19.616791,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 22:45:19 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 22:45:19 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 22:50:26 ~-P1G6 nmbd[1407]: [2024/04/30 22:50:26.618700,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 22:50:26 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 22:50:26 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 22:55:29 ~-P1G6 nmbd[1407]: [2024/04/30 22:55:29.042279,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 22:55:29 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 22:55:29 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 23:00:19 ~-P1G6 nmbd[1407]: [2024/04/30 23:00:19.598055,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 23:00:19 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 23:00:19 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 23:05:33 ~-P1G6 nmbd[1407]: [2024/04/30 23:05:33.207342,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 23:05:33 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 23:05:33 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 23:10:25 ~-P1G6 nmbd[1407]: [2024/04/30 23:10:25.505238,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 23:10:25 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 23:10:25 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 23:15:39 ~-P1G6 nmbd[1407]: [2024/04/30 23:15:39.719838,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 23:15:39 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 23:15:39 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 23:20:42 ~-P1G6 nmbd[1407]: [2024/04/30 23:20:42.024049,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 23:20:42 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 23:20:42 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 23:25:49 ~-P1G6 nmbd[1407]: [2024/04/30 23:25:49.205006,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 23:25:49 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 23:25:49 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 23:30:49 ~-P1G6 nmbd[1407]: [2024/04/30 23:30:49.658273,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 23:30:49 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 23:30:49 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 23:35:54 ~-P1G6 nmbd[1407]: [2024/04/30 23:35:54.933539,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 23:35:54 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 23:35:54 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 23:40:57 ~-P1G6 nmbd[1407]: [2024/04/30 23:40:57.241958,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 23:40:57 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 23:40:57 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
апр 30 23:45:59 ~-P1G6 nmbd[1407]: [2024/04/30 23:45:59.765358,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
апр 30 23:45:59 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
апр 30 23:45:59 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 00:45:53 ~-P1G6 wpa_supplicant[1346]: WPA: No PMK set for PTK derivation
мая 01 00:50:09 ~-P1G6 nmbd[1407]: [2024/05/01 00:50:09.906840,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
мая 01 00:50:09 ~-P1G6 nmbd[1407]:   Packet send failed to 192.168.1.255(138) ERRNO=Network is unreachable
мая 01 00:50:09 ~-P1G6 nmbd[1407]: [2024/05/01 00:50:09.906954,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
мая 01 00:51:44 ~-P1G6 nmbd[1407]: [2024/05/01 00:51:44.046993,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 00:51:44 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 00:51:44 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 00:56:43 ~-P1G6 nmbd[1407]: [2024/05/01 00:56:43.762090,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 00:56:43 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 00:56:43 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:01:49 ~-P1G6 nmbd[1407]: [2024/05/01 01:01:49.713583,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:01:49 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:01:49 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:06:55 ~-P1G6 nmbd[1407]: [2024/05/01 01:06:55.904200,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:06:55 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:06:55 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:11:58 ~-P1G6 nmbd[1407]: [2024/05/01 01:11:58.313765,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:11:58 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:11:58 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:16:59 ~-P1G6 nmbd[1407]: [2024/05/01 01:16:59.728544,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:16:59 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:16:59 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:22:02 ~-P1G6 nmbd[1407]: [2024/05/01 01:22:02.033446,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:22:02 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:22:02 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:27:11 ~-P1G6 nmbd[1407]: [2024/05/01 01:27:11.333513,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:27:11 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:27:11 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:32:19 ~-P1G6 nmbd[1407]: [2024/05/01 01:32:19.759517,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:32:19 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:32:19 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:37:22 ~-P1G6 nmbd[1407]: [2024/05/01 01:37:22.077259,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:37:22 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:37:22 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:39:38 ~-P1G6 kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
мая 01 01:42:24 ~-P1G6 nmbd[1407]: [2024/05/01 01:42:24.759487,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:42:24 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:42:24 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:47:29 ~-P1G6 nmbd[1407]: [2024/05/01 01:47:29.770348,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:47:29 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:47:29 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:52:29 ~-P1G6 nmbd[1407]: [2024/05/01 01:52:29.478173,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:52:29 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:52:29 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 01:57:32 ~-P1G6 nmbd[1407]: [2024/05/01 01:57:32.647438,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 01:57:32 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 01:57:32 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 02:02:36 ~-P1G6 nmbd[1407]: [2024/05/01 02:02:36.583050,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 02:02:36 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 02:02:36 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 02:07:38 ~-P1G6 nmbd[1407]: [2024/05/01 02:07:38.887501,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 02:07:38 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 02:07:38 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 02:12:38 ~-P1G6 nmbd[1407]: [2024/05/01 02:12:38.695314,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 02:12:38 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 02:12:38 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 02:14:39 ~-P1G6 kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
мая 01 14:21:53 ~-P1G6 kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
мая 01 14:21:53 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
мая 01 14:21:53 ~-P1G6 nmbd[1407]: [2024/05/01 14:21:53.332594,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
мая 01 14:21:53 ~-P1G6 nmbd[1407]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
мая 01 14:21:53 ~-P1G6 nmbd[1407]: [2024/05/01 14:21:53.333172,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
мая 01 14:21:53 ~-P1G6 nmbd[1407]:   Packet send failed to 192.168.0.255(137) ERRNO=Network is unreachable
мая 01 14:21:53 ~-P1G6 nmbd[1407]: [2024/05/01 14:21:53.333227,  0] ../../source3/nmbd/nmbd_packets.c:180(send_netbios_packet)
мая 01 14:21:53 ~-P1G6 nmbd[1407]:   send_netbios_packet: send_packet() to IP 192.168.0.255 port 137 failed
мая 01 14:21:53 ~-P1G6 nmbd[1407]: [2024/05/01 14:21:53.333273,  0] ../../source3/nmbd/nmbd_namequery.c:245(query_name)
мая 01 14:21:53 ~-P1G6 nmbd[1407]:   query_name: Failed to send packet trying to query name WORKGROUP<1d>
мая 01 14:21:53 ~-P1G6 kernel: BUG: unable to handle page fault for address: 0000000000003858
мая 01 14:21:53 ~-P1G6 kernel: #PF: supervisor read access in kernel mode
мая 01 14:21:53 ~-P1G6 kernel: #PF: error_code(0x0000) - not-present page
мая 01 14:21:53 ~-P1G6 (sd-exec-strv)[14497]: /usr/lib/systemd/system-sleep/tlp failed with exit status 137.
мая 01 14:21:54 ~-P1G6 kernel: ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-95)
мая 01 14:21:55 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
мая 01 16:42:12 ~-P1G6 systemd-coredump[19222]: [🡕] Process 19220 (QtWebEngineProc) of user 1000 dumped core.
                                                           Stack trace of thread 1:
                                                           #0  0x00007c2ca0126a2d n/a (libc.so.6 + 0x10ca2d)
░░ Subject: Процесс 19220 (QtWebEngineProc) сбросил дамп памяти
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Процесс 19220 (QtWebEngineProc) завершился из-за критической ошибки.
░░ Записан дамп памяти.
░░ Вероятно, это произошло из-за ошибки, допущенной в коде программы.
░░ Рекомендуется сообщить её разработчикам о возникшей проблеме.
мая 01 19:27:24 ~-P1G6 kernel: BUG: unable to handle page fault for address: 0000000000003858
мая 01 19:27:24 ~-P1G6 kernel: #PF: supervisor read access in kernel mode
мая 01 19:27:25 ~-P1G6 kernel: #PF: error_code(0x0000) - not-present page
мая 01 19:27:25 ~-P1G6 (udev-worker)[25117]: BAT0: Process '/usr/bin/tlp auto' terminated by signal KILL.
мая 01 19:27:25 ~-P1G6 (udev-worker)[25117]: BAT0: Failed to wait for spawned command '/usr/bin/tlp auto': Input/output error
мая 01 20:13:23 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
мая 01 20:13:24 ~-P1G6 kernel: BUG: unable to handle page fault for address: 0000000000005ec6
мая 01 20:13:24 ~-P1G6 kernel: #PF: supervisor read access in kernel mode
мая 01 20:13:24 ~-P1G6 kernel: #PF: error_code(0x0000) - not-present page
мая 01 20:13:24 ~-P1G6 (sd-exec-strv)[25363]: /usr/lib/systemd/system-sleep/tlp failed with exit status 137.
мая 01 20:13:26 ~-P1G6 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
мая 01 20:13:31 ~-P1G6 nmbd[1407]: [2024/05/01 20:13:31.634478,  0] ../../source3/nmbd/nmbd_namequery.c:109(query_name_response)
мая 01 20:13:31 ~-P1G6 nmbd[1407]:   query_name_response: Multiple (2) responses received for a query on subnet 192.168.0.16 for name WORKGROUP<1d>.
мая 01 20:13:31 ~-P1G6 nmbd[1407]:   This response was from IP 192.168.0.10, reporting an IP address of 192.168.0.10.
мая 01 20:14:45 ~-P1G6 nmbd[1407]: [2024/05/01 20:14:45.708233,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
мая 01 20:14:45 ~-P1G6 nmbd[1407]:   Packet send failed to 192.168.0.255(138) ERRNO=Network is unreachable
мая 01 20:19:55 ~-P1G6 (udev-worker)[26723]: BAT0: Process '/usr/bin/tlp auto' terminated by signal KILL.
мая 01 20:19:55 ~-P1G6 (udev-worker)[26723]: BAT0: Failed to wait for spawned command '/usr/bin/tlp auto': Input/output error
мая 01 20:19:55 ~-P1G6 kernel: BUG: unable to handle page fault for address: 0000000000005ec6
мая 01 20:19:55 ~-P1G6 kernel: #PF: supervisor read access in kernel mode
мая 01 20:19:55 ~-P1G6 kernel: #PF: error_code(0x0000) - not-present page
мая 01 20:19:58 ~-P1G6 kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
мая 01 20:34:31 ~-P1G6 nmbd[1407]: [2024/05/01 20:34:31.788065,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
мая 01 20:34:31 ~-P1G6 nmbd[1407]:   Packet send failed to 192.168.1.255(138) ERRNO=Network is unreachable
мая 01 20:34:31 ~-P1G6 nmbd[1407]: [2024/05/01 20:34:31.788169,  0] ../../source3/libsmb/nmblib.c:923(send_udp)
мая 01 22:27:37 ~-P1G6 kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
мая 01 22:37:26 ~-P1G6 systemd-coredump[31314]: [🡕] Process 4300 (Discord) of user 1000 dumped core.
                                                           Stack trace of thread 4300:
                                                           #0  0x0000597fdd70d831 n/a (Discord + 0x5d1f831)
                                                           #1  0x0000597fdc907cba n/a (Discord + 0x4f19cba)
                                                           #2  0x0000597fdc904a18 n/a (Discord + 0x4f16a18)
                                                           #3  0x0000597fdc90381b n/a (Discord + 0x4f1581b)
                                                           #4  0x0000597fdc90f832 n/a (Discord + 0x4f21832)
                                                           #5  0x0000597fdc910db7 n/a (Discord + 0x4f22db7)
                                                           #6  0x0000597fdc720dcf n/a (Discord + 0x4d32dcf)
                                                           #7  0x0000597fdc78e38f n/a (Discord + 0x4da038f)
                                                           #8  0x0000597fdc78e661 n/a (Discord + 0x4da0661)
                                                           #9  0x0000597fdd7593fd n/a (Discord + 0x5d6b3fd)
                                                           #10 0x0000597fdd774d91 n/a (Discord + 0x5d86d91)
                                                           #11 0x0000597fdd7753a5 n/a (Discord + 0x5d873a5)
                                                           #12 0x0000597fdd7d468e n/a (Discord + 0x5de668e)
                                                           #13 0x000074153ab0df69 n/a (libglib-2.0.so.0 + 0x59f69)
                                                           #14 0x000074153ab6c3a7 n/a (libglib-2.0.so.0 + 0xb83a7)
                                                           #15 0x000074153ab0c162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                           #16 0x0000597fdd7d3d35 n/a (Discord + 0x5de5d35)
                                                           #17 0x0000597fdd775b05 n/a (Discord + 0x5d87b05)
                                                           #18 0x0000597fdd73b02a n/a (Discord + 0x5d4d02a)
                                                           #19 0x0000597fdc73dcdf n/a (Discord + 0x4d4fcdf)
                                                           #20 0x0000597fdc73fb32 n/a (Discord + 0x4d51b32)
                                                           #21 0x0000597fdc73b199 n/a (Discord + 0x4d4d199)
                                                           #22 0x0000597fda1f36b4 n/a (Discord + 0x28056b4)
                                                           #23 0x0000597fda1f4fce n/a (Discord + 0x2806fce)
                                                           #24 0x0000597fda1f4db6 n/a (Discord + 0x2806db6)
                                                           #25 0x0000597fda1f25fd n/a (Discord + 0x28045fd)
                                                           #26 0x0000597fda1f2706 n/a (Discord + 0x2804706)
                                                           #27 0x0000597fd9ed3469 n/a (Discord + 0x24e5469)
                                                           #28 0x0000741539714cd0 n/a (libc.so.6 + 0x29cd0)
                                                           #29 0x0000741539714d8a __libc_start_main (libc.so.6 + 0x29d8a)
                                                           #30 0x0000597fd9add02a _start (Discord + 0x20ef02a)
                                                           Stack trace of thread 4311:
                                                           #0  0x00007415397f7e66 epoll_wait (libc.so.6 + 0x10ce66)
                                                           #1  0x0000597fdd8e7d80 n/a (Discord + 0x5ef9d80)
                                                           #2  0x0000597fdd8e5b66 n/a (Discord + 0x5ef7b66)
                                                           #3  0x0000597fdd7cb593 n/a (Discord + 0x5ddd593)
                                                           #4  0x0000597fdd775b05 n/a (Discord + 0x5d87b05)
                                                           #5  0x0000597fdd73b02a n/a (Discord + 0x5d4d02a)
                                                           #6  0x0000597fdd7974c8 n/a (Discord + 0x5da94c8)
                                                           #7  0x0000597fdd781e0d n/a (Discord + 0x5d93e0d)
                                                           #8  0x0000597fdd797641 n/a (Discord + 0x5da9641)
                                                           #9  0x0000597fdd7ab109 n/a (Discord + 0x5dbd109)
                                                           #10 0x000074153977a55a n/a (libc.so.6 + 0x8f55a)
                                                           #11 0x00007415397f7a3c n/a (libc.so.6 + 0x10ca3c)
                                                           Stack trace of thread 4315:
                                                           #0  0x0000597fddab2087 n/a (Discord + 0x60c4087)
                                                           #1  0x0000597fda211ebf n/a (Discord + 0x2823ebf)
                                                           #2  0x0000597fda2d7896 n/a (Discord + 0x28e9896)
                                                           #3  0x0000597fda2cd923 n/a (Discord + 0x28df923)
                                                           #4  0x0000597fda2bf937 n/a (Discord + 0x28d1937)
                                                           #5  0x0000597fda2c67d2 n/a (Discord + 0x28d87d2)
                                                           #6  0x0000597fda2ad6c3 n/a (Discord + 0x28bf6c3)
                                                           #7  0x0000597fda215fde n/a (Discord + 0x2827fde)
                                                           #8  0x0000597fda1fdfc8 n/a (Discord + 0x280ffc8)
                                                           #9  0x0000597fda22b2a3 n/a (Discord + 0x283d2a3)
                                                           #10 0x0000597fdd7cb107 n/a (Discord + 0x5ddd107)
                                                           #11 0x0000597fdd8e5974 n/a (Discord + 0x5ef7974)
                                                           #12 0x0000597fdd7cb44c n/a (Discord + 0x5ddd44c)
                                                           #13 0x0000597fdd775b05 n/a (Discord + 0x5d87b05)
                                                           #14 0x0000597fdd73b02a n/a (Discord + 0x5d4d02a)
                                                           #15 0x0000597fdd7974c8 n/a (Discord + 0x5da94c8)
                                                           #16 0x0000597fdc7408bf n/a (Discord + 0x4d528bf)
                                                           #17 0x0000597fdd797641 n/a (Discord + 0x5da9641)
                                                           #18 0x0000597fdd7ab109 n/a (Discord + 0x5dbd109)
                                                           #19 0x000074153977a55a n/a (libc.so.6 + 0x8f55a)
                                                           #20 0x00007415397f7a3c n/a (libc.so.6 + 0x10ca3c)
                                                           Stack trace of thread 4312:
                                                           #0  0x0000741539776ebe n/a (libc.so.6 + 0x8bebe)
                                                           #1  0x0000741539779750 pthread_cond_wait (libc.so.6 + 0x8e750)
                                                           #2  0x0000597fdd7aa8a5 n/a (Discord + 0x5dbc8a5)
                                                           #3  0x0000597fdd7d0654 n/a (Discord + 0x5de2654)
                                                           #4  0x0000597fdd7561f3 n/a (Discord + 0x5d681f3)
                                                           #5  0x0000597fdd78fc14 n/a (Discord + 0x5da1c14)
                                                           #6  0x0000597fdd7907c2 n/a (Discord + 0x5da27c2)
                                                           #7  0x0000597fdd79040d n/a (Discord + 0x5da240d)
                                                           #8  0x0000597fdd790320 n/a (Discord + 0x5da2320)
                                                           Stack trace of thread 4301:
                                                           #0  0x00007415397ea0bf __poll (libc.so.6 + 0xff0bf)
                                                           #1  0x0000597fdce27b11 n/a (Discord + 0x5439b11)
                                                           #2  0x0000597fdd7ab109 n/a (Discord + 0x5dbd109)
                                                           #3  0x000074153977a55a n/a (libc.so.6 + 0x8f55a)
                                                           #4  0x00007415397f7a3c n/a (libc.so.6 + 0x10ca3c)
                                                           Stack trace of thread 4313:
                                                           #7  0x0000597fdd79043d n/a (Discord + 0x5da243d)
                                                           #8  0x0000597fdd790334 n/a (Discord + 0x5da2334)
                                                           Stack trace of thread 4314:
                                                           Stack trace of thread 4316:
                                                           #4  0x0000597fdd7560dc n/a (Discord + 0x5d680dc)
                                                           #5  0x0000597fdd714205 n/a (Discord + 0x5d26205)
                                                           #6  0x0000597fdd775b05 n/a (Discord + 0x5d87b05)
                                                           #7  0x0000597fdd73b02a n/a (Discord + 0x5d4d02a)
                                                           #8  0x0000597fdd7974c8 n/a (Discord + 0x5da94c8)
                                                           #9  0x0000597fdd797641 n/a (Discord + 0x5da9641)
                                                           #10 0x0000597fdd7ab109 n/a (Discord + 0x5dbd109)
                                                           #11 0x000074153977a55a n/a (libc.so.6 + 0x8f55a)
                                                           #12 0x00007415397f7a3c n/a (libc.so.6 + 0x10ca3c)
                                                           Stack trace of thread 4320:
                                                           #2  0x0000597fd9ecdf29 uv_cond_wait (Discord + 0x24dff29)
                                                           #3  0x0000597fe18e8a6d n/a (Discord + 0x9efaa6d)
                                                           #4  0x000074153977a55a n/a (libc.so.6 + 0x8f55a)
                                                           #5  0x00007415397f7a3c n/a (libc.so.6 + 0x10ca3c)
                                                           Stack trace of thread 4322:
                                                           #1  0x0000741539782470 n/a (libc.so.6 + 0x97470)
                                                           #2  0x0000597fd9ecdd56 uv_sem_wait (Discord + 0x24dfd56)
                                                           #3  0x0000597fe198213c n/a (Discord + 0x9f9413c)
                                                           Stack trace of thread 4369:
                                                           #0  0x00007415397f588d syscall (libc.so.6 + 0x10a88d)
                                                           #1  0x000074153ab67337 g_cond_wait (libglib-2.0.so.0 + 0xb3337)
                                                           #2  0x000074153aad91b4 n/a (libglib-2.0.so.0 + 0x251b4)
                                                           #3  0x000074153aad921c g_async_queue_pop (libglib-2.0.so.0 + 0x2521c)
                                                           #4  0x000074153948fc48 n/a (libpangoft2-1.0.so.0 + 0x8c48)
                                                           #5  0x000074153ab3fa45 n/a (libglib-2.0.so.0 + 0x8ba45)
                                                           #6  0x000074153977a55a n/a (libc.so.6 + 0x8f55a)
                                                           #7  0x00007415397f7a3c n/a (libc.so.6 + 0x10ca3c)
                                                           Stack trace of thread 4318:
                                                           #1  0x0000597fd9ed0c34 n/a (Discord + 0x24e2c34)
                                                           #2  0x0000597fd9ec2755 uv_run (Discord + 0x24d4755)
                                                           #3  0x0000597fe18eae5c n/a (Discord + 0x9efce5c)
                                                           Stack trace of thread 4361:
                                                           #3  0x0000597fd9ebeefc n/a (Discord + 0x24d0efc)
                                                           Stack trace of thread 4363:
                                                           Stack trace of thread 4317:
                                                           Stack trace of thread 4364:
                                                           #3  0x000074153ab41ace n/a (libglib-2.0.so.0 + 0x8dace)
                                                           #4  0x000074153ab3fa45 n/a (libglib-2.0.so.0 + 0x8ba45)
                                                           #5  0x000074153977a55a n/a (libc.so.6 + 0x8f55a)
                                                           #6  0x00007415397f7a3c n/a (libc.so.6 + 0x10ca3c)
                                                           Stack trace of thread 4370:
                                                           #3  0x0000597fdd7cb44c n/a (Discord + 0x5ddd44c)
                                                           #7  0x0000597fdd797641 n/a (Discord + 0x5da9641)
                                                           #8  0x0000597fdd7ab109 n/a (Discord + 0x5dbd109)
                                                           #9  0x000074153977a55a n/a (libc.so.6 + 0x8f55a)
                                                           #10 0x00007415397f7a3c n/a (libc.so.6 + 0x10ca3c)
                                                           Stack trace of thread 4319:
                                                           Stack trace of thread 4367:
                                                           #1  0x000074153ab6c2f6 n/a (libglib-2.0.so.0 + 0xb82f6)
                                                           #2  0x000074153ab0c162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
                                                           #3  0x00007415349cafde n/a (libdconfsettings.so + 0x5fde)
                                                           Stack trace of thread 4321:
                                                           Stack trace of thread 4372:
                                                           Stack trace of thread 4373:
                                                           #1  0x0000597fdd7ae307 n/a (Discord + 0x5dc0307)
                                                           Stack trace of thread 4360:
                                                           Stack trace of thread 4381:
                                                           Stack trace of thread 4362:
                                                           Stack trace of thread 4374:
                                                           #1  0x0000741539779a65 pthread_cond_timedwait (libc.so.6 + 0x8ea65)
                                                           #2  0x0000597fdd7aa9b8 n/a (Discord + 0x5dbc9b8)
                                                           #3  0x0000597fdd7d0682 n/a (Discord + 0x5de2682)
                                                           #5  0x0000597fdd78fbc1 n/a (Discord + 0x5da1bc1)
                                                           #7  0x0000597fdd79046d n/a (Discord + 0x5da246d)
                                                           #8  0x0000597fdd79032a n/a (Discord + 0x5da232a)
                                                           Stack trace of thread 4366:
                                                           #2  0x000074153ab0eb97 g_main_loop_run (libglib-2.0.so.0 + 0x5ab97)
                                                           #3  0x000074153a9ed19c n/a (libgio-2.0.so.0 + 0x11219c)
                                                           Stack trace of thread 4375:
                                                           #3  0x0000597fde9272d0 n/a (Discord + 0x6f392d0)
                                                           #4  0x0000597fdd7ab109 n/a (Discord + 0x5dbd109)
                                                           Stack trace of thread 4376:
                                                           Stack trace of thread 4365:
                                                           #3  0x000074153ab0c1b2 n/a (libglib-2.0.so.0 + 0x581b2)
                                                           Stack trace of thread 4384:
                                                           Stack trace of thread 4387:
                                                           Stack trace of thread 4371:
                                                           #0  0x00007415397ea6bc read (libc.so.6 + 0xff6bc)
                                                           #1  0x0000597fda08980b n/a (Discord + 0x269b80b)
                                                           Stack trace of thread 4506:
                                                           #6  0x0000597fdd790597 n/a (Discord + 0x5da2597)
                                                           Stack trace of thread 4386:
                                                           Stack trace of thread 4377:
                                                           #1  0x0000597fda09b060 n/a (Discord + 0x26ad060)
                                                           #2  0x0000597fda0622d4 n/a (Discord + 0x26742d4)
░░ Subject: Процесс 4300 (Discord) сбросил дамп памяти
░░ Процесс 4300 (Discord) завершился из-за критической ошибки.
мая 01 22:37:34 ~-P1G6 kernel: BUG: unable to handle page fault for address: 00000000000062bb
мая 01 22:37:34 ~-P1G6 kernel: #PF: supervisor read access in kernel mode
мая 01 22:37:34 ~-P1G6 kernel: #PF: error_code(0x0000) - not-present page
So the specific process which crashes is random - usually it’s tlp, kworker, or systemd but could be literally anything. I know for a fact now that the nvidia driver is the culprit. I have this happening on 2 different motherboards now which excludes hardware issues, and running on intel gpu doesn’t cause any crashes.
