Just did the update. Both 6.1 and 6.6 LTS kernels behave. Possible to turn or off the wifi and reboot with clean shutdowns on both. Good idea on any production machine to have an LTS kernel one version behind what’s current on the machine just in case. Why I have a version 5 LTS kernel. Disk space is cheap, content not so much
I can confirm that, at least in 6.6, the update fixed the problem for good. Thanks!
Thx for the feedback so far. Could everybody who had tested the patch also reply to the upstream mailing list with a Tested-by: <your name and email>
on [PATCH] wifi: nl80211: fix deadlock in nl80211_set_cqm_rssi (6.6.x) - Léo Lam More on the process here: Submitting patches: the essential guide to getting your code into the kernel — The Linux Kernel documentation
All fine here as well:
rebooting/ wifi toggle switch on laptop case/enabling or disabling wifi/ airplane mode ON-OFF
(just didnt test autosleep or hibernate)
on linux6.6.53, 5.15.142, 6.1.66-2
Thank you for the quick fix, LL and involvees.
Maybe mention this very thread in the email, or thread over there .
Fixed after updating to 6.6.5-3
Brief note here, not something I consider a fault but different. CPU fan operation at the same CPU temperature is higher RPM with 6.1 and 6.6 LTS kernels than it is with the 5.15 kernel. There is no marked difference in CPU utilization. System is an Asus Vivobook with the Ryzen 5 4600H. I monitor the system with GKrellm.
Since this update I am asked for the password when changing the display brightness:
I’m using i3 but the brightness is managed by the xfpm-power-backlight-helper
and indeed it can be run only by the root user.
Got the same error. Deleting and reinstalling didn’t work for me nor any of the classic PGP issue fixes:
changing mirrors, key populate and refresh, deleting and reinstalling package, overwrite;
Still the Error in Kernel 6.6.5 and nouveau Drivers for old nvidia cards as mentioned in this thread:
The boot stucks at a blinking cursor on top left and a working mouse arrow.
dmesg:
[ 0.000000] microcode: updated early: 0xa07 -> 0xa0b, date = 2010-09-28
[ 0.000000] Linux version 6.6.5-3-MANJARO (builduser@fv-az691-588) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 SMP PREEMPT_DYNAMIC Mon Dec 11 10:46:19 UTC 2023
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=6704972e-243c-4d29-81a3-f5c735eaa592 rw quiet resume=UUID=3772f97d-b406-472b-9b9e-9a497c3ec15c
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dbff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009dc00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e4000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bff6ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bff70000-0x00000000bff7dfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000bff7e000-0x00000000bffcffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bffd0000-0x00000000bfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fff00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000013fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: System manufacturer P5Q/P5Q, BIOS 2209 03/11/2010
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2999.716 MHz processor
[ 0.001163] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001167] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001172] last_pfn = 0x140000 max_arch_pfn = 0x400000000
[ 0.001181] total RAM covered: 4096M
[ 0.001388] Found optimal setting for mtrr clean up
[ 0.001389] gran_size: 64K chunk_size: 64K num_reg: 3 lose cover RAM: 0G
[ 0.001393] MTRR map: 7 entries (5 fixed + 2 variable; max 21), built from 8 variable MTRRs
[ 0.001396] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.002738] e820: update [mem 0xc0000000-0xffffffff] usable ==> reserved
[ 0.002748] last_pfn = 0xbff70 max_arch_pfn = 0x400000000
[ 0.012431] found SMP MP-table at [mem 0x000ff780-0x000ff78f]
[ 0.012686] RAMDISK: [mem 0x35f39000-0x36f93fff]
[ 0.012694] ACPI: Early table checksum verification disabled
[ 0.012700] ACPI: RSDP 0x00000000000FAFF0 000024 (v02 ACPIAM)
[ 0.012705] ACPI: XSDT 0x00000000BFF70100 00005C (v01 A_M_I_ OEMXSDT 03001011 MSFT 00000097)
[ 0.012712] ACPI: FACP 0x00000000BFF70290 0000F4 (v03 A_M_I_ OEMFACP 03001011 MSFT 00000097)
[ 0.012718] ACPI: DSDT 0x00000000BFF70440 009720 (v01 A0993 A0993001 00000001 INTL 20060113)
[ 0.012723] ACPI: FACS 0x00000000BFF7E000 000040
[ 0.012726] ACPI: FACS 0x00000000BFF7E000 000040
[ 0.012729] ACPI: APIC 0x00000000BFF70390 00006C (v01 A_M_I_ OEMAPIC 03001011 MSFT 00000097)
[ 0.012733] ACPI: MCFG 0x00000000BFF70400 00003C (v01 A_M_I_ OEMMCFG 03001011 MSFT 00000097)
[ 0.012736] ACPI: OEMB 0x00000000BFF7E040 000089 (v01 A_M_I_ AMI_OEM 03001011 MSFT 00000097)
[ 0.012740] ACPI: HPET 0x00000000BFF79B60 000038 (v01 A_M_I_ OEMHPET 03001011 MSFT 00000097)
[ 0.012744] ACPI: OSFR 0x00000000BFF79BA0 0000B0 (v01 A_M_I_ OEMOSFR 03001011 MSFT 00000097)
[ 0.012748] ACPI: SSDT 0x00000000BFF7EB20 000A7C (v01 DpgPmm CpuPm 00000012 INTL 20060113)
[ 0.012751] ACPI: Reserving FACP table memory at [mem 0xbff70290-0xbff70383]
[ 0.012753] ACPI: Reserving DSDT table memory at [mem 0xbff70440-0xbff79b5f]
[ 0.012754] ACPI: Reserving FACS table memory at [mem 0xbff7e000-0xbff7e03f]
[ 0.012755] ACPI: Reserving FACS table memory at [mem 0xbff7e000-0xbff7e03f]
[ 0.012756] ACPI: Reserving APIC table memory at [mem 0xbff70390-0xbff703fb]
[ 0.012757] ACPI: Reserving MCFG table memory at [mem 0xbff70400-0xbff7043b]
[ 0.012758] ACPI: Reserving OEMB table memory at [mem 0xbff7e040-0xbff7e0c8]
[ 0.012759] ACPI: Reserving HPET table memory at [mem 0xbff79b60-0xbff79b97]
[ 0.012760] ACPI: Reserving OSFR table memory at [mem 0xbff79ba0-0xbff79c4f]
[ 0.012761] ACPI: Reserving SSDT table memory at [mem 0xbff7eb20-0xbff7f59b]
[ 0.012819] No NUMA configuration found
[ 0.012820] Faking a node at [mem 0x0000000000000000-0x000000013fffffff]
[ 0.012823] NODE_DATA(0) allocated [mem 0x13fffb000-0x13fffffff]
[ 0.012850] Zone ranges:
[ 0.012851] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.012853] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.012855] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.012856] Device empty
[ 0.012858] Movable zone start for each node
[ 0.012858] Early memory node ranges
[ 0.012859] node 0: [mem 0x0000000000001000-0x000000000009cfff]
[ 0.012861] node 0: [mem 0x0000000000100000-0x00000000bff6ffff]
[ 0.012862] node 0: [mem 0x0000000100000000-0x000000013fffffff]
[ 0.012864] Initmem setup node 0 [mem 0x0000000000001000-0x000000013fffffff]
[ 0.012870] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.012919] On node 0, zone DMA: 99 pages in unavailable ranges
[ 0.052280] On node 0, zone Normal: 144 pages in unavailable ranges
[ 0.052411] ACPI: PM-Timer IO Port: 0x808
[ 0.052436] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.052441] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.052444] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.052449] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.052451] ACPI: HPET id: 0x8086a301 base: 0xfed00000
[ 0.052460] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.052475] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.052477] PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[ 0.052478] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.052479] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000e3fff]
[ 0.052480] PM: hibernation: Registered nosave memory: [mem 0x000e4000-0x000fffff]
[ 0.052482] PM: hibernation: Registered nosave memory: [mem 0xbff70000-0xbff7dfff]
[ 0.052483] PM: hibernation: Registered nosave memory: [mem 0xbff7e000-0xbffcffff]
[ 0.052484] PM: hibernation: Registered nosave memory: [mem 0xbffd0000-0xbfffffff]
[ 0.052485] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xfedfffff]
[ 0.052486] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.052487] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffefffff]
[ 0.052487] PM: hibernation: Registered nosave memory: [mem 0xfff00000-0xffffffff]
[ 0.052490] [mem 0xc0000000-0xfedfffff] available for PCI devices
[ 0.052491] Booting paravirtualized kernel on bare hardware
[ 0.052496] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.059596] setup_percpu: NR_CPUS:320 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[ 0.061018] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u524288
[ 0.061023] pcpu-alloc: s225280 r8192 d28672 u524288 alloc=1*2097152
[ 0.061027] pcpu-alloc: [0] 0 1 2 3
[ 0.061049] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=6704972e-243c-4d29-81a3-f5c735eaa592 rw quiet resume=UUID=3772f97d-b406-472b-9b9e-9a497c3ec15c
[ 0.061133] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64", will be passed to user space.
[ 0.063064] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.064161] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.064263] Fallback order for Node 0: 0
[ 0.064270] Built 1 zonelists, mobility grouping on. Total pages: 1031794
[ 0.064273] Policy zone: Normal
[ 0.065714] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.065725] software IO TLB: area num 4.
[ 0.199127] Memory: 3989132K/4193328K available (16384K kernel code, 2150K rwdata, 13148K rodata, 3424K init, 3784K bss, 203936K reserved, 0K cma-reserved)
[ 0.207346] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.207472] Kernel/User page tables isolation: enabled
[ 0.207601] ftrace: allocating 48996 entries in 192 pages
[ 0.217797] ftrace: allocated 192 pages with 2 groups
[ 0.218028] Dynamic Preempt: full
[ 0.218169] rcu: Preemptible hierarchical RCU implementation.
[ 0.218170] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.218171] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.218173] Trampoline variant of Tasks RCU enabled.
[ 0.218173] Rude variant of Tasks RCU enabled.
[ 0.218174] Tracing variant of Tasks RCU enabled.
[ 0.218175] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.218176] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.222748] NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
[ 0.222976] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.223116] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.223200] Console: colour dummy device 80x25
[ 0.223204] printk: console [tty0] enabled
[ 0.223618] ACPI: Core revision 20230628
[ 0.223844] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.223859] APIC: Switch to symmetric I/O mode setup
[ 0.224220] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.240525] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b3d3930c00, max_idle_ns: 440795337749 ns
[ 0.240531] Calibrating delay loop (skipped), value calculated using timer frequency.. 6001.40 BogoMIPS (lpj=9999053)
[ 0.240555] CPU0: Thermal monitoring enabled (TM2)
[ 0.240568] process: using mwait in idle threads
[ 0.240573] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[ 0.240575] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[ 0.240579] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.240582] Spectre V2 : Mitigation: Retpolines
[ 0.240582] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.240584] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.240584] Speculative Store Bypass: Vulnerable
[ 0.240588] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.240589] MMIO Stale Data: Unknown: No mitigations
[ 0.240594] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.240596] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.240597] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'standard' format.
[ 0.260410] Freeing SMP alternatives memory: 40K
[ 0.260418] pid_max: default: 32768 minimum: 301
[ 0.261119] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,integrity
[ 0.261969] landlock: Up and running.
[ 0.261971] Yama: becoming mindful.
[ 0.261979] LSM support for eBPF active
[ 0.262209] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.262226] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.371819] smpboot: CPU0: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (family: 0x6, model: 0x17, stepping: 0xa)
[ 0.372139] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.372165] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.372195] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.372230] Performance Events: PEBS fmt0+, Core2 events, 4-deep LBR, Intel PMU driver.
[ 0.372249] ... version: 2
[ 0.372250] ... bit width: 40
[ 0.372251] ... generic registers: 2
[ 0.372252] ... value mask: 000000ffffffffff
[ 0.372253] ... max period: 000000007fffffff
[ 0.372254] ... fixed-purpose events: 3
[ 0.372255] ... event mask: 0000000700000003
[ 0.372368] signal: max sigframe size: 1520
[ 0.372417] rcu: Hierarchical SRCU implementation.
[ 0.372419] rcu: Max phase no-delay instances is 1000.
[ 0.373083] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.373182] smp: Bringing up secondary CPUs ...
[ 0.373384] smpboot: x86: Booting SMP configuration:
[ 0.373386] .... node #0, CPUs: #1
[ 0.380631] smp: Brought up 1 node, 2 CPUs
[ 0.380631] smpboot: Max logical packages: 2
[ 0.380631] smpboot: Total of 2 processors activated (12003.81 BogoMIPS)
[ 0.384388] devtmpfs: initialized
[ 0.384388] x86/mm: Memory block size: 128MB
[ 0.384627] ACPI: PM: Registering ACPI NVS region [mem 0xbff7e000-0xbffcffff] (335872 bytes)
[ 0.384693] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.384707] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.384897] pinctrl core: initialized pinctrl subsystem
[ 0.385054] PM: RTC time: 13:41:08, date: 2023-12-12
[ 0.387621] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.387831] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.387915] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.388000] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.388295] audit: initializing netlink subsys (disabled)
[ 0.388351] audit: type=2000 audit(1702388468.163:1): state=initialized audit_enabled=0 res=1
[ 0.388493] thermal_sys: Registered thermal governor 'fair_share'
[ 0.388494] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.388496] thermal_sys: Registered thermal governor 'step_wise'
[ 0.388497] thermal_sys: Registered thermal governor 'user_space'
[ 0.388498] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.388516] cpuidle: using governor ladder
[ 0.388521] cpuidle: using governor menu
[ 0.388571] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.388879] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.388885] PCI: not using MMCONFIG
[ 0.388887] PCI: Using configuration type 1 for base access
[ 0.389086] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.401913] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.401914] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.402719] ACPI: Added _OSI(Module Device)
[ 0.402720] ACPI: Added _OSI(Processor Device)
[ 0.402722] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.402723] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.408777] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.412430] ACPI: Dynamic OEM Table Load:
[ 0.412437] ACPI: SSDT 0xFFFF98B640311000 000277 (v01 DpgPmm P001Ist 00000011 INTL 20060113)
[ 0.412897] ACPI: Dynamic OEM Table Load:
[ 0.412902] ACPI: SSDT 0xFFFF98B64081C000 0004B2 (v01 PmRef P001Cst 00003001 INTL 20060113)
[ 0.413488] ACPI: Dynamic OEM Table Load:
[ 0.413493] ACPI: SSDT 0xFFFF98B640312000 000277 (v01 DpgPmm P002Ist 00000012 INTL 20060113)
[ 0.414027] ACPI: Dynamic OEM Table Load:
[ 0.414031] ACPI: SSDT 0xFFFF98B640BF13C0 000085 (v01 PmRef P002Cst 00003000 INTL 20060113)
[ 0.414442] ACPI: _OSC evaluated successfully for all CPUs
[ 0.414552] ACPI: Interpreter enabled
[ 0.414570] ACPI: PM: (supports S0 S1 S4 S5)
[ 0.414572] ACPI: Using IOAPIC for interrupt routing
[ 0.414996] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.416073] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved as ACPI motherboard resource
[ 0.416087] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.416089] PCI: Using E820 reservations for host bridge windows
[ 0.416260] ACPI: Enabled 15 GPEs in block 00 to 3F
[ 0.422638] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.422646] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.422653] acpi PNP0A08:00: _OSC: OS requested [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.422655] acpi PNP0A08:00: _OSC: platform willing to grant [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.422657] acpi PNP0A08:00: _OSC: platform retains control of PCIe features (AE_NOT_FOUND)
[ 0.423013] PCI host bridge to bus 0000:00
[ 0.423015] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.423018] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.423019] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.423021] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
[ 0.423023] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xdfffffff window]
[ 0.423024] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xffffffff window]
[ 0.423026] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.423043] pci 0000:00:00.0: [8086:2e20] type 00 class 0x060000
[ 0.423062] pci 0000:00:00.0: DMAR: Disabling IOMMU for graphics on this chipset
[ 0.423064] pci 0000:00:00.0: DMAR: Forcing write-buffer flush capability
[ 0.423125] pci 0000:00:01.0: [8086:2e21] type 01 class 0x060400
[ 0.423159] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.423266] pci 0000:00:1a.0: [8086:3a37] type 00 class 0x0c0300
[ 0.423300] pci 0000:00:1a.0: reg 0x20: [io 0xa800-0xa81f]
[ 0.423415] pci 0000:00:1a.1: [8086:3a38] type 00 class 0x0c0300
[ 0.423449] pci 0000:00:1a.1: reg 0x20: [io 0xa880-0xa89f]
[ 0.423557] pci 0000:00:1a.2: [8086:3a39] type 00 class 0x0c0300
[ 0.423591] pci 0000:00:1a.2: reg 0x20: [io 0xac00-0xac1f]
[ 0.423710] pci 0000:00:1a.7: [8086:3a3c] type 00 class 0x0c0320
[ 0.423724] pci 0000:00:1a.7: reg 0x10: [mem 0xfcfffc00-0xfcffffff]
[ 0.423794] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.423895] pci 0000:00:1b.0: [8086:3a3e] type 00 class 0x040300
[ 0.423910] pci 0000:00:1b.0: reg 0x10: [mem 0xfcff8000-0xfcffbfff 64bit]
[ 0.423971] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.424046] pci 0000:00:1c.0: [8086:3a40] type 01 class 0x060400
[ 0.424111] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.424226] pci 0000:00:1c.4: [8086:3a48] type 01 class 0x060400
[ 0.424291] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.424394] pci 0000:00:1c.5: [8086:3a4a] type 01 class 0x060400
[ 0.424459] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.424562] pci 0000:00:1d.0: [8086:3a34] type 00 class 0x0c0300
[ 0.424595] pci 0000:00:1d.0: reg 0x20: [io 0xa080-0xa09f]
[ 0.424718] pci 0000:00:1d.1: [8086:3a35] type 00 class 0x0c0300
[ 0.424752] pci 0000:00:1d.1: reg 0x20: [io 0xa400-0xa41f]
[ 0.424858] pci 0000:00:1d.2: [8086:3a36] type 00 class 0x0c0300
[ 0.424892] pci 0000:00:1d.2: reg 0x20: [io 0xa480-0xa49f]
[ 0.425005] pci 0000:00:1d.7: [8086:3a3a] type 00 class 0x0c0320
[ 0.425019] pci 0000:00:1d.7: reg 0x10: [mem 0xfcfff800-0xfcfffbff]
[ 0.425089] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.425183] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.425309] pci 0000:00:1f.0: [8086:3a16] type 00 class 0x060100
[ 0.425376] pci 0000:00:1f.0: quirk: [io 0x0800-0x087f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.425380] pci 0000:00:1f.0: quirk: [io 0x0500-0x053f] claimed by ICH6 GPIO
[ 0.425383] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0294 (mask 0003)
[ 0.425387] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 4700 (mask 001f)
[ 0.425520] pci 0000:00:1f.2: [8086:3a20] type 00 class 0x01018f
[ 0.425531] pci 0000:00:1f.2: reg 0x10: [io 0x9000-0x9007]
[ 0.425537] pci 0000:00:1f.2: reg 0x14: [io 0x8c00-0x8c03]
[ 0.425543] pci 0000:00:1f.2: reg 0x18: [io 0x8880-0x8887]
[ 0.425549] pci 0000:00:1f.2: reg 0x1c: [io 0x8800-0x8803]
[ 0.425555] pci 0000:00:1f.2: reg 0x20: [io 0x8480-0x848f]
[ 0.425561] pci 0000:00:1f.2: reg 0x24: [io 0x8400-0x840f]
[ 0.425658] pci 0000:00:1f.3: [8086:3a30] type 00 class 0x0c0500
[ 0.425673] pci 0000:00:1f.3: reg 0x10: [mem 0xfcfff400-0xfcfff4ff 64bit]
[ 0.425689] pci 0000:00:1f.3: reg 0x20: [io 0x0400-0x041f]
[ 0.425751] pci 0000:00:1f.5: [8086:3a26] type 00 class 0x010185
[ 0.425762] pci 0000:00:1f.5: reg 0x10: [io 0xa000-0xa007]
[ 0.425768] pci 0000:00:1f.5: reg 0x14: [io 0x9c00-0x9c03]
[ 0.425774] pci 0000:00:1f.5: reg 0x18: [io 0x9880-0x9887]
[ 0.425780] pci 0000:00:1f.5: reg 0x1c: [io 0x9800-0x9803]
[ 0.425786] pci 0000:00:1f.5: reg 0x20: [io 0x9480-0x948f]
[ 0.425792] pci 0000:00:1f.5: reg 0x24: [io 0x9400-0x940f]
[ 0.425923] pci 0000:01:00.0: [10de:0a65] type 00 class 0x030000
[ 0.425934] pci 0000:01:00.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[ 0.425942] pci 0000:01:00.0: reg 0x14: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.425950] pci 0000:01:00.0: reg 0x1c: [mem 0xce000000-0xcfffffff 64bit pref]
[ 0.425956] pci 0000:01:00.0: reg 0x24: [io 0xbc00-0xbc7f]
[ 0.425961] pci 0000:01:00.0: reg 0x30: [mem 0xfe800000-0xfe87ffff pref]
[ 0.425967] pci 0000:01:00.0: enabling Extended Tags
[ 0.425980] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.426075] pci 0000:01:00.1: [10de:0be3] type 00 class 0x040300
[ 0.426085] pci 0000:01:00.1: reg 0x10: [mem 0xfe8fc000-0xfe8fffff]
[ 0.426114] pci 0000:01:00.1: enabling Extended Tags
[ 0.426192] pci 0000:00:01.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 0.426212] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.426214] pci 0000:00:01.0: bridge window [io 0xb000-0xbfff]
[ 0.426217] pci 0000:00:01.0: bridge window [mem 0xfd000000-0xfe8fffff]
[ 0.426220] pci 0000:00:01.0: bridge window [mem 0xce000000-0xdfffffff 64bit pref]
[ 0.426256] pci 0000:00:1c.0: PCI bridge to [bus 04]
[ 0.426263] pci 0000:00:1c.0: bridge window [mem 0xfbf00000-0xfbffffff 64bit pref]
[ 0.426312] pci 0000:03:00.0: [11ab:6121] type 00 class 0x01018f
[ 0.426330] pci 0000:03:00.0: reg 0x10: [io 0xdc00-0xdc07]
[ 0.426341] pci 0000:03:00.0: reg 0x14: [io 0xd880-0xd883]
[ 0.426351] pci 0000:03:00.0: reg 0x18: [io 0xd800-0xd807]
[ 0.426361] pci 0000:03:00.0: reg 0x1c: [io 0xd480-0xd483]
[ 0.426371] pci 0000:03:00.0: reg 0x20: [io 0xd400-0xd40f]
[ 0.426381] pci 0000:03:00.0: reg 0x24: [mem 0xfeaffc00-0xfeafffff]
[ 0.426445] pci 0000:03:00.0: supports D1
[ 0.426446] pci 0000:03:00.0: PME# supported from D0 D1 D3hot
[ 0.426533] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.426542] pci 0000:00:1c.4: PCI bridge to [bus 03]
[ 0.426545] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
[ 0.426548] pci 0000:00:1c.4: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.426606] pci 0000:02:00.0: [1969:1026] type 00 class 0x020000
[ 0.426630] pci 0000:02:00.0: reg 0x10: [mem 0xfe9c0000-0xfe9fffff 64bit]
[ 0.426641] pci 0000:02:00.0: reg 0x18: [io 0xcc00-0xcc7f]
[ 0.426691] pci 0000:02:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
[ 0.426739] pci 0000:02:00.0: PME# supported from D3hot D3cold
[ 0.426826] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.426835] pci 0000:00:1c.5: PCI bridge to [bus 02]
[ 0.426838] pci 0000:00:1c.5: bridge window [io 0xc000-0xcfff]
[ 0.426841] pci 0000:00:1c.5: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.426857] pci_bus 0000:05: extended config space not accessible
[ 0.426879] pci 0000:05:01.0: [1415:8403] type 00 class 0x070103
[ 0.426892] pci 0000:05:01.0: reg 0x10: [io 0xec00-0xec07]
[ 0.426900] pci 0000:05:01.0: reg 0x14: [io 0xe880-0xe883]
[ 0.426908] pci 0000:05:01.0: reg 0x18: [io 0xe800-0xe81f]
[ 0.426915] pci 0000:05:01.0: reg 0x1c: [mem 0xfebff000-0xfebfffff]
[ 0.426958] pci 0000:05:01.0: supports D2
[ 0.426960] pci 0000:05:01.0: PME# supported from D0 D2 D3hot
[ 0.427012] pci 0000:05:03.0: [11c1:5811] type 00 class 0x0c0010
[ 0.427026] pci 0000:05:03.0: reg 0x10: [mem 0xfebfe000-0xfebfefff]
[ 0.427089] pci 0000:05:03.0: supports D1 D2
[ 0.427091] pci 0000:05:03.0: PME# supported from D0 D1 D2 D3hot
[ 0.427159] pci 0000:00:1e.0: PCI bridge to [bus 05] (subtractive decode)
[ 0.427162] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.427165] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.427170] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.427172] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.427173] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.427175] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
[ 0.427176] pci 0000:00:1e.0: bridge window [mem 0xc0000000-0xdfffffff window] (subtractive decode)
[ 0.427178] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xffffffff window] (subtractive decode)
[ 0.427951] ACPI: PCI: Interrupt link LNKA configured for IRQ 10
[ 0.428015] ACPI: PCI: Interrupt link LNKB configured for IRQ 11
[ 0.428077] ACPI: PCI: Interrupt link LNKC configured for IRQ 15
[ 0.428138] ACPI: PCI: Interrupt link LNKD configured for IRQ 5
[ 0.428200] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.428201] ACPI: PCI: Interrupt link LNKE disabled
[ 0.428262] ACPI: PCI: Interrupt link LNKF configured for IRQ 14
[ 0.428324] ACPI: PCI: Interrupt link LNKG configured for IRQ 3
[ 0.428386] ACPI: PCI: Interrupt link LNKH configured for IRQ 7
[ 0.428569] iommu: Default domain type: Translated
[ 0.428571] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.428824] SCSI subsystem initialized
[ 0.428883] libata version 3.00 loaded.
[ 0.428889] ACPI: bus type USB registered
[ 0.428904] usbcore: registered new interface driver usbfs
[ 0.428915] usbcore: registered new interface driver hub
[ 0.428922] usbcore: registered new device driver usb
[ 0.428944] pps_core: LinuxPPS API ver. 1 registered
[ 0.428945] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.428953] PTP clock support registered
[ 0.428965] EDAC MC: Ver: 3.0.0
[ 0.429363] NetLabel: Initializing
[ 0.429364] NetLabel: domain hash size = 128
[ 0.429365] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.429382] NetLabel: unlabeled traffic allowed by default
[ 0.429387] mctp: management component transport protocol core
[ 0.429388] NET: Registered PF_MCTP protocol family
[ 0.429393] PCI: Using ACPI for IRQ routing
[ 0.434098] PCI: pci_cache_line_size set to 64 bytes
[ 0.434147] e820: reserve RAM buffer [mem 0x0009dc00-0x0009ffff]
[ 0.434149] e820: reserve RAM buffer [mem 0xbff70000-0xbfffffff]
[ 0.434166] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.434166] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.434166] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.434166] vgaarb: loaded
[ 0.435819] hpet: 4 channels of 0 reserved for per-cpu timers
[ 0.435830] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.435836] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.437315] clocksource: Switched to clocksource tsc-early
[ 0.441102] VFS: Disk quotas dquot_6.6.0
[ 0.441136] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.441239] pnp: PnP ACPI init
[ 0.441349] system 00:00: [mem 0xfed14000-0xfed19fff] has been reserved
[ 0.441664] system 00:02: [io 0x0290-0x029f] has been reserved
[ 0.441840] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.441843] system 00:03: [io 0x0800-0x087f] has been reserved
[ 0.441845] system 00:03: [io 0x0500-0x057f] could not be reserved
[ 0.441847] system 00:03: [mem 0xfed08000-0xfed08fff] has been reserved
[ 0.441849] system 00:03: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.441851] system 00:03: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.441853] system 00:03: [mem 0xfed50000-0xfed8ffff] has been reserved
[ 0.441986] system 00:04: [mem 0xffc00000-0xffefffff] has been reserved
[ 0.442217] pnp 00:05: [dma 0 disabled]
[ 0.442435] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.442439] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.442567] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.442734] pnp 00:08: disabling [mem 0x000c0000-0x000cffff] because it overlaps 0000:01:00.0 BAR 6 [mem 0x000c0000-0x000dffff]
[ 0.442762] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.442764] system 00:08: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.442766] system 00:08: [mem 0x00100000-0xbfffffff] could not be reserved
[ 0.442768] system 00:08: [mem 0xe0000000-0xffffffff] could not be reserved
[ 0.442911] pnp: PnP ACPI: found 9 devices
[ 0.449247] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.449423] NET: Registered PF_INET protocol family
[ 0.449566] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.450779] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.450839] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.450899] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.451194] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.451344] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.451518] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.451575] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.451606] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.451695] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.451707] NET: Registered PF_XDP protocol family
[ 0.451715] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 04] add_size 1000
[ 0.451719] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 04] add_size 200000 add_align 100000
[ 0.451723] pci 0000:00:1c.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[ 0.451726] pci 0000:00:1c.5: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 0.451740] pci 0000:00:1c.0: BAR 14: assigned [mem 0xc0000000-0xc01fffff]
[ 0.451744] pci 0000:00:1c.4: BAR 15: assigned [mem 0xc0200000-0xc03fffff 64bit pref]
[ 0.451747] pci 0000:00:1c.5: BAR 15: assigned [mem 0xc0400000-0xc05fffff 64bit pref]
[ 0.451750] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.451753] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.451756] pci 0000:00:01.0: bridge window [io 0xb000-0xbfff]
[ 0.451759] pci 0000:00:01.0: bridge window [mem 0xfd000000-0xfe8fffff]
[ 0.451761] pci 0000:00:01.0: bridge window [mem 0xce000000-0xdfffffff 64bit pref]
[ 0.451764] pci 0000:00:1c.0: PCI bridge to [bus 04]
[ 0.451766] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.451770] pci 0000:00:1c.0: bridge window [mem 0xc0000000-0xc01fffff]
[ 0.451772] pci 0000:00:1c.0: bridge window [mem 0xfbf00000-0xfbffffff 64bit pref]
[ 0.451777] pci 0000:00:1c.4: PCI bridge to [bus 03]
[ 0.451779] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
[ 0.451782] pci 0000:00:1c.4: bridge window [mem 0xfea00000-0xfeafffff]
[ 0.451785] pci 0000:00:1c.4: bridge window [mem 0xc0200000-0xc03fffff 64bit pref]
[ 0.451789] pci 0000:00:1c.5: PCI bridge to [bus 02]
[ 0.451791] pci 0000:00:1c.5: bridge window [io 0xc000-0xcfff]
[ 0.451795] pci 0000:00:1c.5: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.451798] pci 0000:00:1c.5: bridge window [mem 0xc0400000-0xc05fffff 64bit pref]
[ 0.451802] pci 0000:00:1e.0: PCI bridge to [bus 05]
[ 0.451805] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.451808] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.451814] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.451816] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.451818] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.451819] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.451821] pci_bus 0000:00: resource 8 [mem 0xc0000000-0xdfffffff window]
[ 0.451823] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xffffffff window]
[ 0.451824] pci_bus 0000:01: resource 0 [io 0xb000-0xbfff]
[ 0.451826] pci_bus 0000:01: resource 1 [mem 0xfd000000-0xfe8fffff]
[ 0.451828] pci_bus 0000:01: resource 2 [mem 0xce000000-0xdfffffff 64bit pref]
[ 0.451829] pci_bus 0000:04: resource 0 [io 0x1000-0x1fff]
[ 0.451831] pci_bus 0000:04: resource 1 [mem 0xc0000000-0xc01fffff]
[ 0.451832] pci_bus 0000:04: resource 2 [mem 0xfbf00000-0xfbffffff 64bit pref]
[ 0.451834] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.451836] pci_bus 0000:03: resource 1 [mem 0xfea00000-0xfeafffff]
[ 0.451837] pci_bus 0000:03: resource 2 [mem 0xc0200000-0xc03fffff 64bit pref]
[ 0.451839] pci_bus 0000:02: resource 0 [io 0xc000-0xcfff]
[ 0.451841] pci_bus 0000:02: resource 1 [mem 0xfe900000-0xfe9fffff]
[ 0.451842] pci_bus 0000:02: resource 2 [mem 0xc0400000-0xc05fffff 64bit pref]
[ 0.451844] pci_bus 0000:05: resource 0 [io 0xe000-0xefff]
[ 0.451845] pci_bus 0000:05: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 0.451847] pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7 window]
[ 0.451849] pci_bus 0000:05: resource 5 [io 0x0d00-0xffff window]
[ 0.451850] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.451852] pci_bus 0000:05: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.451853] pci_bus 0000:05: resource 8 [mem 0xc0000000-0xdfffffff window]
[ 0.451855] pci_bus 0000:05: resource 9 [mem 0xf0000000-0xffffffff window]
[ 0.452983] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[ 0.453015] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.453042] PCI: CLS 32 bytes, default 64
[ 0.453051] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.453052] software IO TLB: mapped [mem 0x00000000bbf70000-0x00000000bff70000] (64MB)
[ 0.453192] Trying to unpack rootfs image as initramfs...
[ 0.453760] Initialise system trusted keyrings
[ 0.453794] Key type blacklist registered
[ 0.453927] workingset: timestamp_bits=41 max_order=20 bucket_order=0
[ 0.453940] zbud: loaded
[ 0.454450] integrity: Platform Keyring initialized
[ 0.454458] integrity: Machine keyring initialized
[ 0.465546] Key type asymmetric registered
[ 0.465553] Asymmetric key parser 'x509' registered
[ 0.465609] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.465732] io scheduler mq-deadline registered
[ 0.465735] io scheduler kyber registered
[ 0.465776] io scheduler bfq registered
[ 0.466249] pcieport 0000:00:1c.0: enabling device (0106 -> 0107)
[ 0.466577] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.466692] Monitor-Mwait will be used to enter C-1 state
[ 0.466705] Monitor-Mwait will be used to enter C-2 state
[ 0.466711] Monitor-Mwait will be used to enter C-3 state
[ 0.466716] ACPI: \_PR_.P001: Found 3 idle states
[ 0.467144] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.467176] ACPI: button: Power Button [PWRB]
[ 0.467214] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.467267] ACPI: button: Power Button [PWRF]
[ 0.467608] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.467784] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.470685] Non-volatile memory driver v1.3
[ 0.470688] Linux agpgart interface v0.103
[ 0.470715] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.470736] ACPI: bus type drm_connector registered
[ 0.471049] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[ 0.471625] fbcon: Deferring console take-over
[ 0.471628] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 0.471941] ahci 0000:03:00.0: version 3.0
[ 0.472120] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 0.472127] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.472134] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 0.472168] uhci_hcd 0000:00:1a.0: irq 16, io port 0x0000a800
[ 0.472384] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.06
[ 0.472388] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.472390] usb usb1: Product: UHCI Host Controller
[ 0.472391] usb usb1: Manufacturer: Linux 6.6.5-3-MANJARO uhci_hcd
[ 0.472393] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.472512] hub 1-0:1.0: USB hub found
[ 0.472519] hub 1-0:1.0: 2 ports detected
[ 0.472706] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 0.472711] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 2
[ 0.472721] ehci-pci 0000:00:1a.7: debug port 1
[ 0.476632] ehci-pci 0000:00:1a.7: irq 18, io mem 0xfcfffc00
[ 0.486940] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 0.486991] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 0.486994] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.486996] usb usb2: Product: EHCI Host Controller
[ 0.486997] usb usb2: Manufacturer: Linux 6.6.5-3-MANJARO ehci_hcd
[ 0.486999] usb usb2: SerialNumber: 0000:00:1a.7
[ 0.487111] hub 2-0:1.0: USB hub found
[ 0.487119] hub 2-0:1.0: 6 ports detected
[ 0.513694] hub 1-0:1.0: USB hub found
[ 0.513708] hub 1-0:1.0: 2 ports detected
[ 0.513864] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 0.513871] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 3
[ 0.513885] ehci-pci 0000:00:1d.7: debug port 1
[ 0.517848] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfcfff800
[ 0.530271] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.530344] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 0.530347] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.530349] usb usb3: Product: EHCI Host Controller
[ 0.530350] usb usb3: Manufacturer: Linux 6.6.5-3-MANJARO ehci_hcd
[ 0.530352] usb usb3: SerialNumber: 0000:00:1d.7
[ 0.530495] hub 3-0:1.0: USB hub found
[ 0.530504] hub 3-0:1.0: 6 ports detected
[ 0.530726] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 0.530737] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 0.530768] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 0.530796] uhci_hcd 0000:00:1a.1: irq 21, io port 0x0000a880
[ 0.530852] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.06
[ 0.530855] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.530857] usb usb4: Product: UHCI Host Controller
[ 0.530859] usb usb4: Manufacturer: Linux 6.6.5-3-MANJARO uhci_hcd
[ 0.530860] usb usb4: SerialNumber: 0000:00:1a.1
[ 0.530964] hub 4-0:1.0: USB hub found
[ 0.530973] hub 4-0:1.0: 2 ports detected
[ 0.531228] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 0.531233] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[ 0.531238] uhci_hcd 0000:00:1a.2: detected 2 ports
[ 0.531254] uhci_hcd 0000:00:1a.2: irq 18, io port 0x0000ac00
[ 0.531304] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.06
[ 0.531307] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.531309] usb usb5: Product: UHCI Host Controller
[ 0.531310] usb usb5: Manufacturer: Linux 6.6.5-3-MANJARO uhci_hcd
[ 0.531311] usb usb5: SerialNumber: 0000:00:1a.2
[ 0.531403] hub 5-0:1.0: USB hub found
[ 0.531420] hub 5-0:1.0: 2 ports detected
[ 0.531594] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.531599] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 0.531604] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 0.531619] uhci_hcd 0000:00:1d.0: irq 23, io port 0x0000a080
[ 0.531667] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.06
[ 0.531669] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.531671] usb usb6: Product: UHCI Host Controller
[ 0.531672] usb usb6: Manufacturer: Linux 6.6.5-3-MANJARO uhci_hcd
[ 0.531674] usb usb6: SerialNumber: 0000:00:1d.0
[ 0.531763] hub 6-0:1.0: USB hub found
[ 0.531770] hub 6-0:1.0: 2 ports detected
[ 0.531963] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.531968] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 0.531973] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 0.531998] uhci_hcd 0000:00:1d.1: irq 19, io port 0x0000a400
[ 0.532071] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.06
[ 0.532073] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.532075] usb usb7: Product: UHCI Host Controller
[ 0.532077] usb usb7: Manufacturer: Linux 6.6.5-3-MANJARO uhci_hcd
[ 0.532078] usb usb7: SerialNumber: 0000:00:1d.1
[ 0.532193] hub 7-0:1.0: USB hub found
[ 0.532200] hub 7-0:1.0: 2 ports detected
[ 0.532375] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.532380] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 0.532385] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 0.532404] uhci_hcd 0000:00:1d.2: irq 18, io port 0x0000a480
[ 0.532450] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.06
[ 0.532453] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.532455] usb usb8: Product: UHCI Host Controller
[ 0.532456] usb usb8: Manufacturer: Linux 6.6.5-3-MANJARO uhci_hcd
[ 0.532457] usb usb8: SerialNumber: 0000:00:1d.2
[ 0.532549] hub 8-0:1.0: USB hub found
[ 0.532556] hub 8-0:1.0: 2 ports detected
[ 0.532722] usbcore: registered new interface driver usbserial_generic
[ 0.532728] usbserial: USB Serial support registered for generic
[ 0.532826] rtc_cmos 00:01: RTC can wake from S4
[ 0.533057] rtc_cmos 00:01: registered as rtc0
[ 0.533084] rtc_cmos 00:01: setting system clock to 2023-12-12T13:41:08 UTC (1702388468)
[ 0.533118] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.533217] intel_pstate: CPU model not supported
[ 0.533235] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.533567] hid: raw HID events driver (C) Jiri Kosina
[ 0.533715] drop_monitor: Initializing network drop monitor service
[ 0.548217] Initializing XFRM netlink socket
[ 0.548672] NET: Registered PF_INET6 protocol family
[ 0.607938] Freeing initrd memory: 16748K
[ 0.615316] Segment Routing with IPv6
[ 0.615321] RPL Segment Routing with IPv6
[ 0.615345] In-situ OAM (IOAM) with IPv6
[ 0.615387] NET: Registered PF_PACKET protocol family
[ 0.615678] microcode: Microcode Update Driver: v2.2.
[ 0.615683] IPI shorthand broadcast: enabled
[ 0.618203] sched_clock: Marking stable (616070446, 860576)->(639849524, -22918502)
[ 0.618362] registered taskstats version 1
[ 0.618539] Loading compiled-in X.509 certificates
[ 0.623800] Loaded X.509 cert 'Build time autogenerated kernel key: 4f75a76f7e87ad3983d95af7d20361b35b5fa931'
[ 0.627227] zswap: loaded using pool zstd/zsmalloc
[ 0.630279] Key type .fscrypt registered
[ 0.630281] Key type fscrypt-provisioning registered
[ 0.630796] PM: Magic number: 3:450:685
[ 0.630825] misc nvram: hash matches
[ 0.630856] clocksource: hash matches
[ 0.737054] RAS: Correctable Errors collector initialized.
[ 0.737149] clk: Disabling unused clocks
[ 0.740046] Freeing unused decrypted memory: 2028K
[ 0.740808] Freeing unused kernel image (initmem) memory: 3424K
[ 0.760283] Write protecting the kernel read-only data: 30720k
[ 0.760948] Freeing unused kernel image (rodata/data gap) memory: 1188K
[ 0.807863] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.807869] rodata_test: all tests were successful
[ 0.807875] x86/mm: Checking user space page tables
[ 0.853252] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.853259] Run /init as init process
[ 0.853261] with arguments:
[ 0.853262] /init
[ 0.853263] with environment:
[ 0.853264] HOME=/
[ 0.853265] TERM=linux
[ 0.853266] BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
[ 0.940670] usb 5-1: new full-speed USB device number 2 using uhci_hcd
[ 1.020443] ata_piix 0000:00:1f.2: version 2.13
[ 1.020561] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.021840] scsi host0: ata_piix
[ 1.028192] scsi host1: ata_piix
[ 1.028262] ata1: SATA max UDMA/133 cmd 0x9000 ctl 0x8c00 bmdma 0x8480 irq 19
[ 1.028266] ata2: SATA max UDMA/133 cmd 0x8880 ctl 0x8800 bmdma 0x8488 irq 19
[ 1.028391] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.032653] scsi host2: ata_piix
[ 1.032789] scsi host4: ata_piix
[ 1.032832] ata3: SATA max UDMA/133 cmd 0xa000 ctl 0x9c00 bmdma 0x9480 irq 19
[ 1.032835] ata4: SATA max UDMA/133 cmd 0x9880 ctl 0x9800 bmdma 0x9488 irq 19
[ 1.033058] scsi host3: pata_marvell
[ 1.033753] scsi host5: pata_marvell
[ 1.033795] ata5: PATA max UDMA/100 cmd 0xdc00 ctl 0xd880 bmdma 0xd400 irq 16
[ 1.033797] ata6: PATA max UDMA/133 cmd 0xd800 ctl 0xd480 bmdma 0xd408 irq 16
[ 1.139944] usb 5-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10
[ 1.139952] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.139955] usb 5-1: Product: USB Receiver
[ 1.139957] usb 5-1: Manufacturer: Logitech
[ 1.157328] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.0/0003:046D:C52B.0001/input/input2
[ 1.194025] ata5.00: ATAPI: HL-DT-STDVD-RAM GH22NP20, 1.02, max UDMA/66
[ 1.213824] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1a.2-1/input0
[ 1.217533] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/0003:046D:C52B.0002/input/input3
[ 1.217607] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/0003:046D:C52B.0002/input/input4
[ 1.277654] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/0003:046D:C52B.0002/input/input5
[ 1.277868] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1a.2-1/input1
[ 1.280384] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1a.2-1/input2
[ 1.280416] usbcore: registered new interface driver usbhid
[ 1.280417] usbhid: USB HID core driver
[ 1.365302] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.375915] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.477557] tsc: Refined TSC clocksource calibration: 2999.666 MHz
[ 1.477563] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b3d09b8651, max_idle_ns: 440795214890 ns
[ 1.477583] clocksource: Switched to clocksource tsc
[ 1.674577] ata2.00: SATA link down (SStatus 0 SControl 300)
[ 1.674588] ata2.01: SATA link down (SStatus 0 SControl 300)
[ 1.810931] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.810941] ata1.01: SATA link down (SStatus 0 SControl 300)
[ 1.813415] ata1.00: supports DRM functions and may not be fully accessible
[ 1.813417] ata1.00: ATA-9: ST1000DM003-1ER162, CC43, max UDMA/133
[ 1.813421] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.814979] ata1.00: Features: Trust
[ 1.819638] ata1.00: supports DRM functions and may not be fully accessible
[ 1.821050] ata1.00: configured for UDMA/133
[ 1.821208] scsi 0:0:0:0: Direct-Access ATA ST1000DM003-1ER1 CC43 PQ: 0 ANSI: 5
[ 1.821829] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.821832] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.821844] sd 0:0:0:0: [sda] Write Protect is off
[ 1.821847] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.821940] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.821982] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[ 1.822826] scsi 3:0:0:0: CD-ROM HL-DT-ST DVD-RAM GH22NP20 1.02 PQ: 0 ANSI: 5
[ 1.839287] sda: sda1 sda2 sda3
[ 1.840284] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.112515] sr 3:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.112523] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.124410] firewire_ohci 0000:05:03.0: added OHCI v1.0 device as card 0, 8 IR + 8 IT contexts, quirks 0x0
[ 2.141938] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 2.228361] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1a.2-1/input2
[ 2.344597] input: Logitech Wireless Device PID:101b Mouse as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.2/0003:046D:C52B.0003/0003:046D:101B.0004/input/input7
[ 2.344876] hid-generic 0003:046D:101B.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Wireless Device PID:101b] on usb-0000:00:1a.2-1/input2:1
[ 2.346436] input: Logitech Wireless Device PID:2008 Keyboard as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.2/0003:046D:C52B.0003/0003:046D:2008.0005/input/input11
[ 2.347983] hid-generic 0003:046D:2008.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Device PID:2008] on usb-0000:00:1a.2-1/input2:2
[ 2.348316] input: Logitech Wireless Device PID:406d Mouse as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.2/0003:046D:C52B.0003/0003:046D:406D.0006/input/input16
[ 2.348381] hid-generic 0003:046D:406D.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:406d] on usb-0000:00:1a.2-1/input2:3
[ 2.368001] input: Logitech M705 as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.2/0003:046D:C52B.0003/0003:046D:101B.0004/input/input20
[ 2.368103] logitech-hidpp-device 0003:046D:101B.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech M705] on usb-0000:00:1a.2-1/input2:1
[ 2.651027] firewire_core 0000:05:03.0: created device fw0: GUID 001e8c000176ba6a, S400
[ 2.815984] logitech-hidpp-device 0003:046D:2008.0005: HID++ 1.0 device connected.
[ 3.570207] input: Logitech MK700 as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.2/0003:046D:C52B.0003/0003:046D:2008.0005/input/input21
[ 3.570394] logitech-hidpp-device 0003:046D:2008.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech MK700] on usb-0000:00:1a.2-1/input2:2
[ 3.606003] input: Logitech M705 as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.2/0003:046D:C52B.0003/0003:046D:406D.0006/input/input22
[ 3.606094] logitech-hidpp-device 0003:046D:406D.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech M705] on usb-0000:00:1a.2-1/input2:3
[ 3.616113] PM: Image not found (code -22)
[ 3.682312] fbcon: Taking over console
[ 3.683830] Console: switching to colour frame buffer device 80x30
[ 4.048872] EXT4-fs (sda2): mounted filesystem 6704972e-243c-4d29-81a3-f5c735eaa592 r/w with ordered data mode. Quota mode: none.
[ 5.664414] systemd[1]: systemd 254.7-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 5.664433] systemd[1]: Detected architecture x86-64.
[ 5.709827] systemd[1]: Hostname set to <rich-pc>.
[ 5.896196] random: crng init done
[ 5.995638] systemd[1]: bpf-lsm: LSM BPF program attached
[ 11.056962] systemd[1]: /usr/lib/systemd/system/avahi-daemon.socket:22: ListenStream= references a path below legacy directory /var/run/, updating /var/run/avahi-daemon/socket → /run/avahi-daemon/socket; please update the unit file accordingly.
[ 11.191653] systemd[1]: /usr/lib/systemd/system/teamviewerd.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/teamviewerd.pid → /run/teamviewerd.pid; please update the unit file accordingly.
[ 11.313011] systemd[1]: Queued start job for default target Graphical Interface.
[ 11.328828] systemd[1]: Created slice Slice /system/getty.
[ 11.329248] systemd[1]: Created slice Slice /system/modprobe.
[ 11.329619] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 11.329925] systemd[1]: Created slice User and Session Slice.
[ 11.330008] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 11.330076] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.330278] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.330328] systemd[1]: Reached target Local Encrypted Volumes.
[ 11.330351] systemd[1]: Reached target Login Prompts.
[ 11.330374] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 11.330419] systemd[1]: Reached target Slice Units.
[ 11.330461] systemd[1]: Reached target Local Verity Protected Volumes.
[ 11.330554] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 11.352554] systemd[1]: Listening on LVM2 poll daemon socket.
[ 11.354322] systemd[1]: Listening on Process Core Dump Socket.
[ 11.354469] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.354614] systemd[1]: Listening on Journal Socket.
[ 11.361822] systemd[1]: Listening on udev Control Socket.
[ 11.361970] systemd[1]: Listening on udev Kernel Socket.
[ 11.363159] systemd[1]: Mounting Huge Pages File System...
[ 11.364233] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.365311] systemd[1]: Mounting Kernel Debug File System...
[ 11.366354] systemd[1]: Mounting Kernel Trace File System...
[ 11.366488] systemd[1]: Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[ 11.367739] systemd[1]: Starting Create List of Static Device Nodes...
[ 11.369025] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 11.370613] systemd[1]: Starting Load Kernel Module configfs...
[ 11.372373] systemd[1]: Starting Load Kernel Module dm_mod...
[ 11.373908] systemd[1]: Starting Load Kernel Module drm...
[ 11.376674] systemd[1]: Starting Load Kernel Module fuse...
[ 11.377986] systemd[1]: Starting Load Kernel Module loop...
[ 11.378163] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 11.381797] systemd[1]: Starting Journal Service...
[ 11.561472] systemd[1]: Starting Load Kernel Modules...
[ 11.561522] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[ 11.562808] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.563903] systemd[1]: Starting Coldplug All udev Devices...
[ 11.565975] systemd[1]: Mounted Huge Pages File System.
[ 11.566100] systemd[1]: Mounted POSIX Message Queue File System.
[ 11.566205] systemd[1]: Mounted Kernel Trace File System.
[ 11.581093] systemd[1]: Finished Create List of Static Device Nodes.
[ 11.581600] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 11.594422] systemd[1]: Finished Load Kernel Module configfs.
[ 11.594810] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 11.607832] systemd[1]: Finished Load Kernel Module drm.
[ 11.608460] systemd[1]: Mounted Kernel Debug File System.
[ 11.621130] systemd[1]: Mounting Kernel Configuration File System...
[ 11.622390] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 11.623509] systemd[1]: Mounted Kernel Configuration File System.
[ 11.649556] fuse: init (API version 7.39)
[ 11.650500] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 11.667747] systemd[1]: Finished Load Kernel Module fuse.
[ 11.681010] systemd[1]: Mounting FUSE Control File System...
[ 11.683171] systemd[1]: Mounted FUSE Control File System.
[ 11.704474] EXT4-fs (sda2): re-mounted 6704972e-243c-4d29-81a3-f5c735eaa592 r/w. Quota mode: none.
[ 11.721098] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 11.731290] systemd-journald[182]: Collecting audit messages is disabled.
[ 11.855306] loop: module loaded
[ 11.947740] systemd[1]: Starting Rebuild Hardware Database...
[ 11.949094] systemd[1]: Starting Load/Save OS Random Seed...
[ 11.949344] systemd[1]: Started Journal Service.
[ 11.969004] device-mapper: uevent: version 1.0.3
[ 11.969117] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 12.138871] systemd-journald[182]: Received client request to flush runtime journal.
[ 12.234079] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 12.234118] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 12.683542] i2c_dev: i2c /dev entries driver
[ 13.024221] vboxdrv: loading out-of-tree module taints kernel.
[ 13.024233] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 13.044950] vboxdrv: Found 2 processor cores/threads
[ 13.045191] vboxdrv: fAsync=0 offMin=0x21c offMax=0x1437
[ 13.145333] vboxdrv: TSC mode is Synchronous, tentative frequency 2999665710 Hz
[ 13.145340] vboxdrv: Successfully loaded version 7.0.12 r159484 (interface 0x00330004)
[ 13.259881] VBoxNetAdp: Successfully started.
[ 13.319901] VBoxNetFlt: Successfully started.
[ 13.566242] systemd-journald[182]: /var/log/journal/18af89b33ecf46d9b18af59e9a5e77ce/system.journal: Journal file uses a different sequence number ID, rotating.
[ 13.566251] systemd-journald[182]: Rotating system journal.
[ 21.061392] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000800-0x000000000000084F (\PMRG) (20230628/utaddress-204)
[ 21.061404] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 21.061407] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000053F (\GPS0) (20230628/utaddress-204)
[ 21.061411] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 21.061412] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000053F (\GPS0) (20230628/utaddress-204)
[ 21.061416] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 21.061417] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 21.316575] ACPI Warning: SystemIO range 0x0000000000000400-0x000000000000041F conflicts with OpRegion 0x0000000000000400-0x000000000000040F (\SMRG) (20230628/utaddress-204)
[ 21.316588] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 21.334212] PCI parallel port detected: 1415:8403, I/O at 0xec00(0xe880), IRQ 17
[ 21.334307] parport0: PC-style at 0xec00 (0xe880), irq 17, using FIFO [PCSPP,TRISTATE,EPP,ECP]
[ 21.458160] ATL1E 0000:02:00.0 enp2s0: renamed from eth0
[ 21.652950] ppdev: user-space parallel port driver
[ 21.666856] input: PC Speaker as /devices/platform/pcspkr/input/input23
[ 21.722614] iTCO_vendor_support: vendor-support=0
[ 21.842200] iTCO_wdt iTCO_wdt.1.auto: Found a ICH10R TCO device (Version=2, TCOBASE=0x0860)
[ 21.842389] iTCO_wdt iTCO_wdt.1.auto: initialized. heartbeat=30 sec (nowayout=0)
[ 22.212460] Adding 2097148k swap on /dev/sda1. Priority:-2 extents:1 across:2097148k
[ 22.688851] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 22.688874] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 22.701019] Console: switching to colour dummy device 80x25
[ 22.714616] nouveau 0000:01:00.0: vgaarb: deactivate vga console
[ 22.714722] nouveau 0000:01:00.0: NVIDIA GT218 (0a8280b1)
[ 22.830291] nouveau 0000:01:00.0: bios: version 70.18.a6.00.00
[ 22.831857] nouveau 0000:01:00.0: fb: 1024 MiB DDR3
[ 22.897633] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input24
[ 22.898046] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input25
[ 22.898102] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input26
[ 22.898153] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input27
[ 23.109789] intel_powerclamp: No package C-state available
[ 23.154339] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC1200: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 23.154348] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 23.154350] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 23.154352] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 23.154354] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 23.154355] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 23.154357] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 23.154359] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 23.154360] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 23.171423] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input28
[ 23.172220] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input29
[ 23.172275] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input30
[ 23.172326] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input31
[ 23.172384] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input32
[ 23.172437] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input33
[ 23.172487] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input34
[ 23.172540] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input35
[ 23.908261] EXT4-fs (sda3): mounted filesystem 98893c76-e211-4a89-9cfb-e108f9f0ee6f r/w with ordered data mode. Quota mode: none.
[ 23.937787] nouveau 0000:01:00.0: DRM: VRAM: 1024 MiB
[ 23.937791] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 23.937795] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 23.937797] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 23.937799] nouveau 0000:01:00.0: DRM: DCB outp 00: 01000302 00020030
[ 23.937802] nouveau 0000:01:00.0: DRM: DCB outp 01: 02000300 00000000
[ 23.937804] nouveau 0000:01:00.0: DRM: DCB outp 02: 02011362 00020010
[ 23.937806] nouveau 0000:01:00.0: DRM: DCB outp 03: 01022310 00000000
[ 23.937808] nouveau 0000:01:00.0: DRM: DCB conn 00: 00001030
[ 23.937810] nouveau 0000:01:00.0: DRM: DCB conn 01: 00002161
[ 23.937811] nouveau 0000:01:00.0: DRM: DCB conn 02: 00000200
[ 23.939630] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 23.947411] [drm] Initialized nouveau 1.4.0 20120801 for 0000:01:00.0 on minor 0
[ 23.991246] fbcon: nouveaudrmfb (fb0) is primary device
[ 24.080238] Console: switching to colour frame buffer device 240x67
[ 24.084605] nouveau 0000:01:00.0: [drm] fb0: nouveaudrmfb frame buffer device
[ 25.952643] RPC: Registered named UNIX socket transport module.
[ 25.952649] RPC: Registered udp transport module.
[ 25.952650] RPC: Registered tcp transport module.
[ 25.952651] RPC: Registered tcp-with-tls transport module.
[ 25.952651] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 27.986417] mousedev: PS/2 mouse device common for all mice
[ 39.358954] NET: Registered PF_QIPCRTR protocol family
[ 39.635703] ATL1E 0000:02:00.0 enp2s0: NIC Link is Up <1000 Mbps Full Duplex>
[ 70.883570] sddm-greeter[985]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 78.238111] nouveau 0000:01:00.0: fifo: DMA_PUSHER - ch 4 [sddm-greeter[985]] get 000021e000 put 000021e088 ib_get 00000007 ib_put 00000008 state 80000024 (err: INVALID_CMD) push 00400040
[ 81.933765] nouveau 0000:01:00.0: fifo: DMA_PUSHER - ch 4 [sddm-greeter[985]] get 000021e004 put 000021e088 ib_get 0000000b ib_put 0000000c state 800081a4 (err: INVALID_CMD) push 00400040
[ 82.057472] nouveau 0000:01:00.0: fifo: DMA_PUSHER - ch 4 [sddm-greeter[985]] get 000021e090 put 000021f6d8 ib_get 0000000d ib_put 0000000e state 80000000 (err: INVALID_CMD) push 00400040
[ 133.490152] systemd-journald[182]: /var/log/journal/18af89b33ecf46d9b18af59e9a5e77ce/user-1000.journal: Journal file uses a different sequence number ID, rotating.
[ 151.593338] logitech-hidpp-device 0003:046D:406D.0006: HID++ 4.5 device connected.
And INXI:
Host: rich-pc Kernel: 6.6.5-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
Console: tty 3 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P5Q v: Rev 1.xx serial: <superuser required>
BIOS: American Megatrends v: 2209 date: 03/11/2010
Device-1: hidpp_battery_0 model: Logitech MK700 serial: b9-e4-c8-7d
charge: 10% (should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech Marathon Mouse/Performance Plus M705
serial: 76-a6-79-0f charge: 55% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 4 GiB available: 3.83 GiB used: 692.9 MiB (17.7%)
Info: model: Intel Core2 Duo E8400 bits: 64 type: MCP arch: Penryn level: v1 built: 2008
process: Intel 45nm family: 6 model-id: 0x17 (23) stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB
L2: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3000 min/max: 2003/3003 scaling: driver: acpi-cpufreq governor: schedutil
cores: 1: 3000 2: 3000 bogomips: 12002
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid cx16 cx8 de
ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht lahf_lm lm mca mce mmx monitor msr mtrr
nopl nx pae pat pbe pdcm pebs pge pni pse pse36 pti rep_good sep smx sse sse2 sse4_1 ssse3
syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling, PBRSB-eIBRS: Not
affected
Device-1: NVIDIA GT218 [GeForce 210] vendor: Micro-Star MSI N210 driver: nouveau v: kernel
non-free: series: 340.xx status: legacy (EOL~2019-12-xx) last: release: 340.108 kernel: 5.4
xorg: 1.20 arch: Tesla process: 40-80nm built: 2006-2013 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 ports: active: VGA-1 empty: DVI-I-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:0a65
class-ID: 0300 temp: 55.0 C
Display: server: X.org v: 1.21.1.9 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau tty: 240x67
Monitor-1: VGA-1 model: Samsung S23B550 serial: H4MCB01752 built: 2012 res: 1920x1080 dpi: 96
gamma: 1.2 chroma: red: x: 0.643 y: 0.337 green: x: 0.322 y: 0.624 blue: x: 0.149 y: 0.043
white: x: 0.314 y: 0.329 size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9
modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
1024x768, 832x624, 800x600, 640x480, 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 egl: 1.4 drv: nouveau device: 1
drv: swrast gbm: egl: 1.4 drv: nouveau surfaceless: egl: 1.4 drv: nouveau inactive: wayland,x11
API: OpenGL v: 4.5 compat-v: 3.3 vendor: mesa v: 23.1.9-manjaro1.1 note: console (EGL sourced)
renderer: NVA8, llvmpipe (LLVM 16.0.6 128 bits)
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3a3e class-ID: 0403
Device-2: NVIDIA High Definition Audio vendor: Micro-Star MSI N210 Geforce 210 PCIe
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0be3 class-ID: 0403
API: ALSA v: k6.6.5-3-MANJARO status: kernel-api with: aoss type: oss-emulator
Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: off with: 1: pulseaudio-alsa type: plugin
2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet vendor: ASUSTeK
driver: ATL1E v: N/A modules: atl1e pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: cc00
bus-ID: 02:00.0 chip-ID: 1969:1026 class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: XXXX
IP v4: 192.168.178.55/24 type: dynamic noprefixroute scope: global broadcast: XXXX
IP v6: 2003:ed:3f14:db00:cd16:c286:3a9a:81bb/64 type: dynamic noprefixroute scope: global
IP v6: fe80::69ba:a126:538:1085/64 type: noprefixroute scope: link
WAN IP: XXXX
Local Storage: total: 931.51 GiB used: 357.29 GiB (38.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: S4Y0BELE
fw-rev: CC43 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD-RAM GH22NP20 rev: 1.02 dev-links: cdrom
Features: speed: 48 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram
state: running
ID-1: / raw-size: 214.84 GiB size: 210.41 GiB (97.94%) used: 59.63 GiB (28.3%) fs: ext4
dev: /dev/sda2 maj-min: 8:2 label: N/A uuid: 6704972e-XXXXXXXXXX
ID-2: /home raw-size: 714.67 GiB size: 702.38 GiB (98.28%) used: 297.66 GiB (42.4%) fs: ext4
dev: /dev/sda3 maj-min: 8:3 label: N/A uuid: 98893c76-XXXXXXXXXX
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: yes compressor: zstd
max-pool: 20%
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 3772f97d-XXXXXXXXXXXX
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 chip-ID: 1d6b:0001 class-ID: 0900
Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
Hub-3: 3-0:1 info: full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
Hub-4: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
Device-1: 5-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
Hub-7: 7-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
Hub-8: 8-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
System Temperatures: cpu: 54.5 C mobo: 41.0 C gpu: nouveau temp: 55.0 C
Fan Speeds (rpm): cpu: 2343 case-1: 0 case-2: 0
Power: 12v: 12.21 5v: N/A 3.3v: 3.34 vbat: N/A gpu: nouveau mV: 900.00
Packages: pm: pacman pkgs: 1721 libs: 448 tools: pamac,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 0
1: https://mirror.23m.com/manjaro/stable/$repo/$arch
2: https://manjaro.kurdy.org/stable/$repo/$arch
3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
4: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
5: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
6: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
7: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
8: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
9: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
10: https://mirror.seahost.de/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 139
1: cpu: 93.5% command: sddm-greeter pid: 985 mem: 145.3 MiB (3.7%)
2: cpu: 0.6% command: nxserver.bin pid: 680 mem: 105.1 MiB (2.6%)
3: cpu: 0.4% command: [kworker/0:0-events] pid: 8 mem: 0.00 MiB (0.0%)
4: cpu: 0.4% command: upowerd pid: 1006 mem: 17.2 MiB (0.4%)
5: cpu: 0.3% command: init pid: 1 mem: 12.7 MiB (0.3%)
Memory top: 5 of 139
1: mem: 145.3 MiB (3.7%) command: sddm-greeter pid: 985 cpu: 93.5%
2: mem: 105.1 MiB (2.6%) command: nxserver.bin pid: 680 cpu: 0.6%
3: mem: 75.9 MiB (1.9%) command: xorg pid: 722 cpu: 0.3%
4: mem: 73.9 MiB (1.8%) command: nxnode.bin pid: 1035 cpu: 0.3%
5: mem: 25.7 MiB (0.6%) command: smbd pid: 731 cpu: 0.0%
Processes: 139 Uptime: 4m wakeups: 0 Init: systemd v: 254 default: graphical tool: systemctl
Compilers: gcc: 13.2.1 clang: 16.0.6 Shell: Bash (login) v: 5.2.21 running-in: tty 3
inxi: 3.3.31
For me its recommended to have 6.1. still installed when using nouveau driver.
With 6.1 no errors occure
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
I’ve been using kernel 6.6.6 (the kernel of the beast ) for an hour and everything seems to work fine. Nothing weird in boot log (only warnings from virtualbox because vbox modules for this kernel were not installed), wifi can be switched on and off over and over without freezes or hangs, connect and disconnect to a vpn lots of times using wired network or wifi, shutdown ok, reboot ok.
I waited and updated only now, no issues so far (using kernel 6.1 LTS, 5.15 LTS as backup), in fact this update solved a bug I had with pamac tray (caused by an update months ago).
Before this update pamac tray only warned me about updates of manjaro repo and AUR, no warning about flatpaks updates but now works normally warning about flatpaks updates also!
But pamac still is all white tho (caused by the same update I think) not respecting system dark theme but that doesn’t bother me at all…
Posting here for better visibility:
It seems that something is (still) happening with XFCE on proprietary Nvidia drivers (since [Stable Update] 2023-12-01) that causes problems with session locking and switching
Xfce4 black screen with cursor when switching between users
After 2023-12-01 I can not get in to a timed out session
EDIT: it still happens on Kernel 6.6.5-3
I had that problem, too. At first I reverted to an older kernel, then, today, 6.6.5-3 was available via the kernel utility. Installed it, problem gone.
So great when things move so fast -thanks, folks!
Same with xfce. Just had to change the icon theme back.
