I have Manjaro stable + Cinnamon and now after the update (yesterday full update) even starting System Monitor GUI takes 15-20 sec.
Interestingly starting a Chromium Appimage comes up instantly.
Current kernel which is just updated an hour ago :
$ uname -a
Linux xps15 6.1.31-2-MANJARO #1 SMP PREEMPT_DYNAMIC
Changing back to latest 5.15 (also updated an hour ago) , did not change anything …
Well … ok, fair enough
As I am just a Majaro user and luckily everything works smooth, I do not have to check the forum very often … which is a good sign , I would say.
I promise to spend more time reading the posts next time, before posting something.
Another stupid question …
I am on Cinnamon, so its suggested to do ?
However so far I just have uninstalled the gnome version, rebooted, and so far it’s working (although have not checked much yet).
Should I install the gtk version… or can I live without it ?
People with chromium based browser should test the option of running them with disabled gpu acceleration (–disable-gpu).
For me Chrome runs with graphical glitches after the update. Reinstalling doesn’t help, only the disable gpu option from settings. There seem to be some broken links to libraries when running in console. The strange thing is that chromium in the exact same version runs perfectly fine with gpu support.
+1, but for basically all applications for me (with GNOME). All apps open in a very minimized window, with glitches and artifacts all around. The glitches stop when we maximize the window.
Yes, you can live without any xdg-desktop-portal-* packages if you are NOT using Flatpak (or a few other applications that depend on xdg-desktop-portal directly).
