this one
Oops, as always read the wiki post, I forgot ![]()
Random core dumps since last update.
jun 04 13:06:06 host gnome-shell[18516]: Received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadMatch (invalid parameter attributes)'.
(Details: serial 14020 error_code 8 request_code 147 (unknown) minor_code 6)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the MUTTER_SYNC environment
variable to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the meta_x_error() function.)
jun 04 13:06:06 host gnome-shell[18516]: == Stack trace for context 0x5578f8294a80 ==
jun 04 13:06:06 host systemd[1]: Started Process Core Dump (PID 18813/UID 0).
jun 04 13:06:08 host systemd-coredump[18814]: [đĄ] Process 18516 (gnome-shell) of user 1000 dumped core.
Join the club: [Stable Update] 2023-06-04 - Kernels, Gnome 44.1, Plasma 5.27.5, Python 3.11, Toolchain, Firefox - #31 by karolyi
Core dump is more likely to happen with Google Chrome, which then crashes.
Merger of [community] repository in [extras] is not done in this update ⊠right?
Not in my case, I donât even have chrome installed.
From looking at my log, Iâve now recompiled/reinstalled extras/js102 from the source, to see what gives.
There is no announcment on this Thread about this change so yes.
Will be done on the next one I guess.
The package is called manjaro-release.
[nx-74205:/dev/pts/3][/home/aragorn]
[aragorn] > cat /etc/lsb-release
DISTRIB_ID="ManjaroLinux"
DISTRIB_RELEASE="23.0.0"
DISTRIB_CODENAME="Ultima Thule"
DISTRIB_DESCRIPTION="Manjaro Linux"
Just had another coredump, it seems js102 wasnât the culprit.
The coredump from journalctl:
Jun 04 14:32:29 karolyi-desktop systemd-coredump[615179]: [đĄ] Process 600232 (gnome-shell) of user 1000 dumped core.
Stack trace of thread 600232:
#0 0x00007f9ddc69f26c n/a (libc.so.6 + 0x8926c)
#1 0x00007f9ddc64fa08 raise (libc.so.6 + 0x39a08)
#2 0x000055b2214f3f19 n/a (gnome-shell + 0x3f19)
#3 0x00007f9ddc64fab0 n/a (libc.so.6 + 0x39ab0)
#4 0x00007f9ddcf3e408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#5 0x00007f9ddcf3e703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#6 0x00007f9ddcf3e975 g_logv (libglib-2.0.so.0 + 0x5e975)
#7 0x00007f9ddcf3ec64 g_log (libglib-2.0.so.0 + 0x5ec64)
#8 0x00007f9ddc917bc7 n/a (libmutter-12.so.0 + 0x117bc7)
#9 0x00007f9ddc3293dc _XError (libX11.so.6 + 0x443dc)
#10 0x00007f9ddc3294e8 n/a (libX11.so.6 + 0x444e8)
#11 0x00007f9ddc329585 n/a (libX11.so.6 + 0x44585)
#12 0x00007f9ddc32963a _XEventsQueued (libX11.so.6 + 0x4463a)
#13 0x00007f9ddc317c48 XPending (libX11.so.6 + 0x32c48)
#14 0x00007f9ddc8f60df n/a (libmutter-12.so.0 + 0xf60df)
#15 0x00007f9ddcf3a53b g_main_context_dispatch (libglib-2.0.so.0 + 0x5a53b)
#16 0x00007f9ddcf97219 n/a (libglib-2.0.so.0 + 0xb7219)
#17 0x00007f9ddcf39c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#18 0x00007f9ddc8cdc5b meta_context_run_main_loop (libmutter-12.so.0 + 0xcdc5b)
#19 0x000055b2214f3526 n/a (gnome-shell + 0x3526)
#20 0x00007f9ddc639850 n/a (libc.so.6 + 0x23850)
#21 0x00007f9ddc63990a __libc_start_main (libc.so.6 + 0x2390a)
#22 0x000055b2214f3835 n/a (gnome-shell + 0x3835)
Stack trace of thread 600234:
#0 0x00007f9ddc7192ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007f9ddcf907b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007f9ddcf04fb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007f9ddcf6bf9e n/a (libglib-2.0.so.0 + 0x8bf9e)
#4 0x00007f9ddcf67315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007f9ddc69d44b n/a (libc.so.6 + 0x8744b)
#6 0x00007f9ddc720e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 600237:
#0 0x00007f9ddc713c0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007f9ddcf9717f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007f9ddcf39c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#3 0x00007f9ddd139d3c n/a (libgio-2.0.so.0 + 0x10ed3c)
Stack trace of thread 600235:
#2 0x00007f9ddcf391a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007f9ddcf391f2 n/a (libglib-2.0.so.0 + 0x591f2)
Stack trace of thread 600238:
#3 0x00007f9ddd554fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 600259:
#0 0x00007f9ddc699f0e n/a (libc.so.6 + 0x83f0e)
#1 0x00007f9ddc69c7a0 pthread_cond_wait (libc.so.6 + 0x867a0)
#2 0x00007f9ddb3a54d1 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-102.so + 0x15a54d1)
#3 0x00007f9ddb3a53d2 n/a (libmozjs-102.so + 0x15a53d2)
#4 0x00007f9ddb55771e n/a (libmozjs-102.so + 0x175771e)
Stack trace of thread 600261:
Stack trace of thread 600260:
Stack trace of thread 600262:
Stack trace of thread 600258:
Stack trace of thread 600263:
Stack trace of thread 600264:
Stack trace of thread 600265:
Upon trying to recompile gnome-shell package itself (the one that contains the binary that crashes), I get coredumps from the test phase. Probably because of the current gnome-shell is faulty. Commented out the test phase, installed gnome-shell.
Letâs see if I get another coredump.
Hello:
I am one Issue in gnome 44.1 Ăt doesnât work Oh no something Wrong!
Xorg session ATI card with radeon kernel 5.15 series, not an kernel issue because kernel 4.14 the same problem, gnome 43 fine but gnome 44.1 doesnât works
regards
Fernando
Plasma 5.27.5 on Wayland: Dolphin still wonât remove moved files from the view, I made a thread for that if anyone can help⊠control / shift dragging still doesnât work right either. Icons still appear to be missing from the system tray too. Canât tell if SDDM was updated to the needed version to solve the nearly 3 minute wait time in a console when shutting down due to a missing signal. Other than those things everything seems to be working fine, no new issues introduced since the last snapshot at least.
Yep, somethingâs seriously off. Another coredump with gnome-session recompiled/reinstalled:
Jun 04 15:01:53 karolyi-desktop systemd-coredump[5397]: [đĄ] Process 1515 (gnome-shell) of user 1000 dumped core.
Stack trace of thread 1515:
#0 0x00007ff9e109f26c n/a (libc.so.6 + 0x8926c)
#1 0x00007ff9e104fa08 raise (libc.so.6 + 0x39a08)
#2 0x00005609c9a89f19 n/a (gnome-shell + 0x3f19)
#3 0x00007ff9e104fab0 n/a (libc.so.6 + 0x39ab0)
#4 0x00007ff9e193e408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#5 0x00007ff9e193e703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#6 0x00007ff9e193e975 g_logv (libglib-2.0.so.0 + 0x5e975)
#7 0x00007ff9e193ec64 g_log (libglib-2.0.so.0 + 0x5ec64)
#8 0x00007ff9e1317bc7 n/a (libmutter-12.so.0 + 0x117bc7)
#9 0x00007ff9e0d293dc _XError (libX11.so.6 + 0x443dc)
#10 0x00007ff9e0d294e8 n/a (libX11.so.6 + 0x444e8)
#11 0x00007ff9e0d29585 n/a (libX11.so.6 + 0x44585)
#12 0x00007ff9e0d2963a _XEventsQueued (libX11.so.6 + 0x4463a)
#13 0x00007ff9e0d17c48 XPending (libX11.so.6 + 0x32c48)
#14 0x00007ff9e193a10b g_main_context_prepare (libglib-2.0.so.0 + 0x5a10b)
#15 0x00007ff9e1996fe6 n/a (libglib-2.0.so.0 + 0xb6fe6)
#16 0x00007ff9e1939c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#17 0x00007ff9e12cdc5b meta_context_run_main_loop (libmutter-12.so.0 + 0xcdc5b)
#18 0x00005609c9a89526 n/a (gnome-shell + 0x3526)
#19 0x00007ff9e1039850 n/a (libc.so.6 + 0x23850)
#20 0x00007ff9e103990a __libc_start_main (libc.so.6 + 0x2390a)
#21 0x00005609c9a89835 n/a (gnome-shell + 0x3835)
Stack trace of thread 1520:
#0 0x00007ff9e1113c0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007ff9e199717f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007ff9e1939c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#3 0x00007ff9e1b39d3c n/a (libgio-2.0.so.0 + 0x10ed3c)
#4 0x00007ff9e1967315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007ff9e109d44b n/a (libc.so.6 + 0x8744b)
#6 0x00007ff9e1120e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 1517:
#0 0x00007ff9e11192ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007ff9e19907b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007ff9e1904fb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007ff9e196bf9e n/a (libglib-2.0.so.0 + 0x8bf9e)
Stack trace of thread 1525:
#0 0x00007ff9e1099f0e n/a (libc.so.6 + 0x83f0e)
#1 0x00007ff9e109c7a0 pthread_cond_wait (libc.so.6 + 0x867a0)
#2 0x00007ff9dfda54d1 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-102.so + 0x15a54d1)
#3 0x00007ff9dfda53d2 n/a (libmozjs-102.so + 0x15a53d2)
#4 0x00007ff9dff5771e n/a (libmozjs-102.so + 0x175771e)
Stack trace of thread 1526:
Stack trace of thread 1521:
#2 0x00007ff9e19391a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007ff9e1f42fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 1530:
Stack trace of thread 1518:
#3 0x00007ff9e19391f2 n/a (libglib-2.0.so.0 + 0x591f2)
Stack trace of thread 1528:
Stack trace of thread 1527:
Stack trace of thread 1523:
Stack trace of thread 1529:
Stack trace of thread 1524:
Iâve no clue what this could be.
This update has made Google Chrome 114 unusable for me with GPU acceleration. Major glitches when browsing. I have an AMD CPU and GPU. When I start it with the disable GPU option it works fine.
i think its the wrong place but i need help
i use openrazer and polychromatic for my keyboard.
i need to rebuild the package, and use the command from above but if i do, i went into trouble, can someone help?
~ âŻâŻâŻ pacman -Qoq /usr/lib/python3.10/ openrazer-daemon python-openrazer
~ âŻâŻâŻ pamac build $(pacman -Qoq /usr/lib/python3.10)
Vorbereitung...
ĂberprĂŒfe python-openrazer AbhĂ€ngigkeiten...
ĂberprĂŒfe openrazer-daemon AbhĂ€ngigkeiten...
Warnung: python-openrazer-3.6.1-1 ist aktuell -- Reinstalliere
Warnung: openrazer-daemon-3.6.1-1 ist aktuell -- Reinstalliere
AbhÀngigkeiten werden aufgelöst...
Interne Konflikte werden ĂŒberprĂŒft...
Zu erstellen (2):
openrazer-daemon 3.6.1-1 AUR
python-openrazer 3.6.1-1 AUR
Build-Dateien bearbeiten : [e]
Transaktion anwenden ? [e/j/N] j
** (pamac:14060): WARNING **: 15:13:00.971: transaction.vala:1026: Fehler beim Ăffnen der Datei »/var/tmp/pamac-build-marika/openrazer/.SRCINFO«: Datei oder Verzeichnis nicht gefunden
Remove openrazer-meta and then reinstall it.
Thatâs probably because openrazer-driver-dkms doesnât work right now because of this
it was fixed for a while but resurface with dolphin 23.04 and finally seems to be fixed for good. but will only be delivered with KF 5.107. you are almost certainly having issues with a symlinked directory, if you are confused with it happening only on some directories.
refer;
https://bugs.kde.org/show_bug.cgi?id=463184
https://bugs.kde.org/show_bug.cgi?id=469254
Hi all! I am using manjaro i3, and after upgrade canât access online-accounts from gnome-calendar. I check dmesg but nothing there. Any help will be very appreciatted!
After update, brave browser does not display any image.
PS - Fixed by reinstall.
