Does the system still use ceph-libs package?
I’ve been building it for the last two days.
No.
thanks man ill try
It was indeed this extension. Thanks for hint man
after the update, my chromium became black and so have all my websites. also i had to relogin on every website. how can i set a normal light theme to chromium back?
That issue was discussed earlier in this thread
Hello,
I’ve updated the Manjaro to the current stable update. After upgrading manually Python and his packages and dependent programs after the complete update, the Firefox (official repository package version 114.0.1-1) and Telegram Desktop (official repository package version 4.8.1-2) is freezing randomly one or two times a day, forcing me to kill the process.
sudo lshw
output:
aurelio-inspiron3576
description: Notebook
product: Inspiron 3576 (083F)
vendor: Dell Inc.
serial: 31P39T2
width: 64 bits
capabilities: smbios-3.1.1 dmi-3.1.1 smp vsyscall32
configuration: boot=normal chassis=notebook family=Inspiron sku=083F uuid=44454C4C-3100-1050-8033-B3C04F395432
*-core
description: Motherboard
product: 0208V7
vendor: Dell Inc.
physical id: 0
version: A01
serial: /31P39T2/BRCMJ008BU0190/
*-firmware
description: BIOS
vendor: Dell Inc.
physical id: 0
version: 1.12.1
date: 05/06/2021
capacity: 16MiB
capabilities: pci pnp upgrade shadowing cdboot bootselect edd int13floppynec int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification netboot uefi
*-memory
description: System Memory
physical id: 3d
slot: System board or motherboard
*-bank:0
description: SODIMM DDR4 Synchronous Unbuffered (Unregistered) 2400 MHz (0,4 ns)
product: CMSX32GX4M2A2400C16
vendor: AMI
physical id: 0
serial: 00000000
slot: DIMM A
width: 64 bits
clock: 2400MHz (0.4ns)
*-bank:1
vendor: AMI
physical id: 1
serial: 00000000
slot: DIMM B
width: 64 bits
*-cache:0
description: L1 cache
physical id: 41
slot: L1 Cache
capacity: 256KiB
capabilities: synchronous internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: 42
slot: L2 Cache
capacity: 1MiB
configuration: level=2
*-cache:2
description: L3 cache
physical id: 43
slot: L3 Cache
capacity: 8MiB
configuration: level=3
*-cpu
description: CPU
product: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
vendor: Intel Corp.
physical id: 44
bus info: cpu@0
version: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
serial: To Be Filled By O.E.M.
slot: U3E1
capacity: 4GHz
width: 64 bits
clock: 100MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d arch_capabilities cpufreq
configuration: cores=4 enabledcores=4 threads=8
*-pci
description: Host bridge
product: Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 08
width: 32 bits
clock: 33MHz
configuration: driver=skl_uncore
resources: irq:0
*-display
description: VGA compatible controller
product: UHD Graphics 620
physical id: 2
bus info: pci@0000:00:02.0
version: 07
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:130 memory:d1000000-d1ffffff memory:b0000000-bfffffff ioport:f000(size=64) memory:c0000-dffff
*-generic:0
description: Signal processing controller
product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
physical id: 4
bus info: pci@0000:00:04.0
version: 08
width: 64 bits
clock: 33MHz
capabilities: msi pm cap_list
configuration: driver=proc_thermal latency=0
resources: irq:16 memory:d2220000-d2227fff
*-usb
description: USB controller
product: Sunrise Point-LP USB 3.0 xHCI Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 21
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:126 memory:d2210000-d221ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 5.15.114-2-MANJARO xhci-hcd
physical id: 0
bus info: usb@1
logical name: usb1
version: 5.15
capabilities: usb-2.00
configuration: driver=hub slots=12 speed=480Mbit/s
*-usb:0
description: Generic USB device
product: Android
vendor: Android
physical id: 1
bus info: usb@1:1
version: 3.18
serial: 737640890405
configuration: driver=usbfs maxpower=500mA speed=480Mbit/s
*-usb:1
description: USB hub
product: USB2.1 Hub
vendor: GenesysLogic
physical id: 3
bus info: usb@1:3
version: 6.55
capabilities: usb-2.10
configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
*-usb:0
description: Mouse
product: Rapoo 2.4G Wireless Touchpad Keyboard
vendor: RAPOO
physical id: 1
bus info: usb@1:3.1
version: 1.10
configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
*-usb:1
description: Mouse
product: G203 LIGHTSYNC Gaming Mouse
vendor: Logitech
physical id: 2
bus info: usb@1:3.2
version: 52.00
serial: 205C38764743
configuration: driver=usbhid maxpower=300mA speed=12Mbit/s
*-usb:2
description: Keyboard
product: Logi TKL Mechanical Keyboard
vendor: Logitech
physical id: 3
bus info: usb@1:3.3
version: 56.00
*-usb:2
description: Video
product: Integrated_Webcam_HD
vendor: CN0F08KGLOG0087LA008A02
physical id: 5
bus info: usb@1:5
version: 52.68
serial: 200901010001
configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
*-usb:3
description: MMC Host
product: USB2.0-CRW
vendor: Generic
physical id: 6
bus info: usb@1:6
logical name: mmc0
version: 39.60
serial: 20100201396000000
configuration: driver=rtsx_usb maxpower=500mA speed=480Mbit/s
*-usb:4
description: Bluetooth wireless interface
vendor: Qualcomm Atheros Communications
physical id: 7
bus info: usb@1:7
version: 0.02
capabilities: bluetooth usb-1.10
configuration: driver=btusb maxpower=100mA speed=12Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 5.15
capabilities: usb-3.00
configuration: driver=hub slots=6 speed=5000Mbit/s
*-generic:1
product: Sunrise Point-LP Thermal subsystem
physical id: 14.2
bus info: pci@0000:00:14.2
version: 21
width: 64 bits
clock: 33MHz
capabilities: pm msi cap_list
configuration: driver=intel_pch_thermal latency=0
resources: irq:18 memory:d2237000-d2237fff
*-generic:2
product: Sunrise Point-LP Serial IO I2C Controller #0
physical id: 15
bus info: pci@0000:00:15.0
version: 21
width: 64 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=intel-lpss latency=0
resources: irq:16 memory:d2236000-d2236fff
*-communication
description: Communication controller
product: Sunrise Point-LP CSME HECI #1
physical id: 16
bus info: pci@0000:00:16.0
version: 21
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_me latency=0
resources: irq:127 memory:d2235000-d2235fff
*-sata
description: SATA controller
product: Sunrise Point-LP SATA Controller [AHCI mode]
physical id: 17
bus info: pci@0000:00:17.0
logical name: scsi0
logical name: scsi1
version: 21
width: 32 bits
clock: 66MHz
capabilities: sata msi pm ahci_1.0 bus_master cap_list emulated
configuration: driver=ahci latency=0
resources: irq:125 memory:d2230000-d2231fff memory:d2234000-d22340ff ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:d2233000-d22337ff
*-disk:0
description: ATA Disk
product: KINGSTON SA400S3
physical id: 0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 61K1
serial: 50026B76830171AF
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=5cd892a1-67e6-48b0-b03c-1cd41b9525f6 logicalsectorsize=512 sectorsize=512
*-volume:0 UNCLAIMED
description: Windows FAT volume
vendor: mkfs.fat
physical id: 1
bus info: scsi@0:0.0.0,1
version: FAT32
serial: 4fa3-d898
capacity: 499MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat name=EFI
*-volume:1
description: EXT4 volume
vendor: Linux
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
logical name: /
logical name: /var/lib/snapd/snap
version: 1.0
serial: e988a6d7-a281-418c-bb9b-678e35ce0076
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2022-04-18 08:09:31 filesystem=ext4 lastmountpoint=/ modified=2023-06-14 20:07:01 mount.fstype=ext4 mount.options=rw,noatime mounted=2023-06-14 20:07:01 name=ROOT state=mounted
*-volume:2
vendor: Linux
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
logical name: /timeshift
version: 1.0
serial: 04e67242-8e07-4619-aeca-1105bcbc4674
configuration: created=2022-04-18 08:09:35 filesystem=ext4 lastmountpoint=/run/timeshift/70813/backup modified=2023-06-14 20:07:03 mount.fstype=ext4 mount.options=rw,noatime mounted=2023-06-14 20:07:03 name=TIMESH state=mounted
*-disk:1
product: WDC WD20SPZX-75U
vendor: Western Digital
physical id: 1
bus info: scsi@1:0.0.0
logical name: /dev/sdb
version: 1A01
serial: WXB1E588LRD8
configuration: ansiversion=5 guid=756b2f3e-573c-4152-9d0d-fbc3643b6c33 logicalsectorsize=512 sectorsize=4096
*-volume:0
description: Windows NTFS volume
vendor: Windows
physical id: 1
bus info: scsi@1:0.0.0,1
logical name: /dev/sdb1
logical name: /mnt/DADOS
version: 3.1
serial: fa3eb0dc-865d-1f46-ae3d-87b48a5591ca
capacity: 1363GiB
capabilities: ntfs initialized
configuration: clustersize=4096 created=2019-12-30 11:01:14 filesystem=ntfs label=DADOS mount.fstype=fuseblk mount.options=rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 state=mounted
*-volume:1
vendor: Linux
physical id: 2
bus info: scsi@1:0.0.0,2
logical name: /dev/sdb2
logical name: /home
version: 1.0
serial: 36af8a56-38ff-4e53-83cc-c66f236ecc00
configuration: created=2022-04-18 08:09:39 filesystem=ext4 lastmountpoint=/home modified=2023-06-14 20:07:03 mount.fstype=ext4 mount.options=rw,noatime mounted=2023-06-14 20:07:03 state=mounted
*-pci:0
description: PCI bridge
product: Sunrise Point-LP PCI Express Root Port #1
physical id: 1c
bus info: pci@0000:00:1c.0
version: f1
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:122 ioport:e000(size=4096) memory:c0000000-d00fffff
*-display
description: Display controller
product: Jet PRO [Radeon R5 M230 / R7 M260DX / Radeon 520/610 Mobile]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:01:00.0
version: c3
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:129 memory:c0000000-cfffffff memory:d0000000-d003ffff ioport:e000(size=256) memory:d0040000-d005ffff
*-pci:1
product: Sunrise Point-LP PCI Express Root Port #5
physical id: 1c.4
bus info: pci@0000:00:1c.4
version: f1
width: 32 bits
clock: 33MHz
resources: irq:123 ioport:d000(size=4096) memory:d2100000-d21fffff
*-network
description: Ethernet interface
product: RTL810xE PCI Express Fast Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 07
serial: b8:85:84:fd:ed:d4
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.15.114-2-MANJARO firmware=rtl8106e-1_0.0.1 06/29/12 latency=0 link=no multicast=yes port=twisted pair
resources: irq:16 ioport:d000(size=256) memory:d2104000-d2104fff memory:d2100000-d2103fff
*-pci:2
product: Sunrise Point-LP PCI Express Root Port #6
physical id: 1c.5
bus info: pci@0000:00:1c.5
version: f1
width: 32 bits
clock: 33MHz
resources: irq:124 memory:d2000000-d20fffff
*-network
description: Wireless interface
product: QCA9565 / AR9565 Wireless Network Adapter
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 01
serial: 90:32:4b:c0:b1:d9
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical wireless
configuration: broadcast=yes driver=ath9k driverversion=5.15.114-2-MANJARO firmware=N/A ip=192.168.100.144 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:17 memory:d2000000-d207ffff memory:d2080000-d208ffff
*-isa
description: ISA bridge
product: Sunrise Point LPC Controller/eSPI Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 21
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
configuration: latency=0
*-memory UNCLAIMED
description: Memory controller
product: Sunrise Point-LP PMC
physical id: 1f.2
bus info: pci@0000:00:1f.2
version: 21
width: 32 bits
clock: 33MHz (30.3ns)
resources: memory:d222c000-d222ffff
*-multimedia
description: Audio device
product: Sunrise Point-LP HD Audio
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 21
width: 64 bits
clock: 33MHz
configuration: driver=snd_hda_intel latency=32
resources: irq:131 memory:d2228000-d222bfff memory:d2200000-d220ffff
*-serial
description: SMBus
product: Sunrise Point-LP SMBus
physical id: 1f.4
bus info: pci@0000:00:1f.4
version: 21
width: 64 bits
clock: 33MHz
configuration: driver=i801_smbus latency=0
resources: irq:16 memory:d2232000-d22320ff ioport:f040(size=32)
*-pnp00:00
product: Motherboard registers
physical id: 1
capabilities: pnp
configuration: driver=system
*-pnp00:01
product: AT Real-Time Clock
physical id: 2
capabilities: pnp
configuration: driver=rtc_cmos
*-pnp00:02
product: PnP device INT3f0d
vendor: Interphase Corporation
physical id: 3
capabilities: pnp
*-pnp00:03
product: IBM Enhanced keyboard controller (101/2-key)
physical id: 4
capabilities: pnp
configuration: driver=i8042 kbd
*-pnp00:04
product: PnP device DLL083f
vendor: Dell Inc
physical id: 5
capabilities: pnp
configuration: driver=i8042 aux
*-pnp00:05
physical id: 6
capabilities: pnp
*-pnp00:06
physical id: 7
capabilities: pnp
*-pnp00:07
physical id: 8
capabilities: pnp
*-pnp00:08
physical id: 9
capabilities: pnp
*-pnp00:09
physical id: a
capabilities: pnp
*-battery
product: DELL GR43747
vendor: SMP
physical id: 1
version: 06/09/2018
serial: 142A
slot: Sys. Battery Bay
capacity: 41440mWh
configuration: voltage=14,8V
uname -a
output:
Linux aurelio-inspiron3576 5.15.114-2-MANJARO #1 SMP PREEMPT Sun Jun 4 10:32:43 UTC 2023 x86_64 GNU/Linux
Do have any workarounds to correct this problem?
3 posts were split to a new topic: Steam and Add/Remove Software won’t launch
I’m having issues when connecting and touching my Wacom Intuos Manga pen over the tablet. Gnome Shell freezes and restarts. A few minutes latter, the keyboard stops do respond, and I forced to restarts the whole system.
I managed to extract a log file, but I can’t found the source of the bug.
A post was split to a new topic: GNOME Shell crashes every time I unplug my Wacom Tablet
Hi!
Kicad 7.0.3 was not officially released due to critical bugs (see 7.0.5 announcement on the kicad website).
These bugs render Kicad unusable for me!
Arch already updated to 7.0.5 and it seems testing also contains 7.0.5 already - however, stable uses the “unreleased” 7.0.3. Could that get hot-fixed?
Regards
Johann
Fixed it, completely reset all wifi settings and reinstalled network components.
I’m replying to myself but the reason for the artifacting was a bug in mutter:
Fixed in gtk4
version 4.10.4
, the next update should fix it. I’ve installed it for myself and it made the problem go away.
KiCad update will probably be released with next stable update
To use latest version of KiCad now either switch to Manjaro testing branch; install kicad-git
from AUR or use flatpack package - KiCad | Flathub
Hi everyone,
I have a small graphical glitch under gnome with non gnome apps (GTK4) since the update, usually after resizing, such as with thunar, cantata, etc.
There is also a cursor issue (not showing the right cursor at the right time). I’ve had no problems with slow loading apps (since I am on gnome).
This issue happens under gnome with X or under Wayland, and with different kernels.
Any ideas?
[EDIT]
Solved thanks to @karolyi 's post above. Installed new gtk as well, which did solve the problem.
I fixed the slow startup issue of many apps by uninstalling xdg-desktop-portal-gnome
. I am using manjaro xfce but manually installed i3wm. This also fixed not being able to launch steam.
Seems that this is a problem with mutter 44.1rc. In my post about this problem (Steam games won't lauch (Problem with Mutter)), I posted some links to another articles that show the same issue.
I believe that this can be marked as a issue, even that is not everyone suffering from the same problem.
Any help on this one? I’d like to get this laptop working again. I tried following a guide I had found, booting a live ISO and chrooting into the disk to reinstall GRUB, but in my case the combination of encryption + btrfs filesystem meant the instructions don’t work.
hey @MeLikeyTacos, there is a discussion about chroot / grub / btrfs here, may be useful with a tweak for your luks …
Thank you, I’ll give it a try!
6 posts were split to a new topic: I get this error on 6.3 sometimes
