Okay, I had to get work done and do some live streams. Now I just did the updates! Here are my results:
My computer restarted!! YAY!! (Last time it didn’t so I had to use Timeshift to go back)
Firefox took forever to start so I did the fix listed above. It launches fine now!
Steam didn’t work, so I reinstalled it. It works fine now and Elden Ring starts!! YAY!!
OBS doesn’t work!! Here’s what I get:
$ obs
obs: error while loading shared libraries: libpython3.10.so.1.0: cannot open shared object file: No such file or directory
Any ideas would be appreciated. Thanks!!
UPDATE: I just tried to Build obs-studio-git (that’s what I’ve been using) and I got the following error:
CMake Error at plugins/obs-webrtc/cmake/legacy.cmake:9 (find_package):
By not providing "FindLibDataChannel.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"LibDataChannel", but CMake did not find one.
Could not find a package configuration file provided by "LibDataChannel"
with any of the following names:
LibDataChannelConfig.cmake
libdatachannel-config.cmake
Add the installation prefix of "LibDataChannel" to CMAKE_PREFIX_PATH or set
"LibDataChannel_DIR" to a directory containing one of the above files. If
"LibDataChannel" provides a separate development package or SDK, be sure it
has been installed.
Call Stack (most recent call first):
cmake/Modules/ObsHelpers.cmake:519 (include)
plugins/obs-webrtc/CMakeLists.txt:3 (legacy_check)
-- Configuring incomplete, errors occurred!
==> ERROR: A failure occurred in build().
Aborting...
UPDATE 2:
I tried this and my existing OBS does launch now and I did a short test stream. I really DON’T KNOW if this is a bad idea but I did…
$ sudo ln -s libpython3.11.so.1.0 libpython3.10.so.1.0
Use the flatpak from obs, it is more stable and has official support.
Last time I checked, the Flatpak version doesn’t support the plugins I use. I have a huge post about this in the OBS forums. Maybe they fixed stuff in the past couple of months? I don’t know. Here’s my post if you want to take a look…
Hi, I've only been streaming a few weeks but I love OBS. I'm also on Manjaro Linux and it's been my primary OS for over 3 years.
This post is for anyone having trouble with OBS on Manjaro Linux, especially the missing "browser" source. I just spent...
Thanks! I just installed libdatachannel from AUR but I’m not going to try building OBS just yet because I got the current install working with a symbolic link.
Edit: never mind they are: “Library with common API for various GNOME modules”.
Gkirmathal:
Issue regarding the recent Lutris stable update from version 0.5.12.4 to 0.5.13.6.
0.5.13.6 explicitly has set Gnome-Desktop
and Gnome-Desktop-Common
as Dependency and not as Optional Dependency on this update.
Was this suppose to happen?
huebi
11 June 2023 13:21
305
Hardware is detected, I guess.
ip addr show lists my Wi-Fi interface. I am not able to connect to my router anymore. Another Kernel also didn’t fix the issue.
Is there any information which would help to pinpoint this issuo?
I use a 20W4CTO1WW ThinkPad T15 Gen 2i with up-to-date firmware.
The router in question is a Fritzbox 7530AX.
muvvenby:
python-pep517 package
Does deleting it cause any issues? what does it even do?
It was dropped from the Arch repos and nothing requires it.
Yep, no issues noted. Some info .
Steam stopped opening reliably.
src/steamUI/steamuisharedjscontroller.cpp (449) : Failed creating offscreen shared JS context
src/steamUI/steamuisharedjscontroller.cpp (449) : Fatal assert; application exiting
Removed flatpak then xdg-desktop-portal (both unused for me) per https://github.com/ValveSoftware/steam-for-linux/issues/9321 .
It’s a known issue and mentioned in the second post:
philm:
Many applications (firefox, thunderbird, telegram, etc) slow to start on desktops other than Gnome
There is a bug with xdg-desktop-portal-gnome
(more details here ).
Workaround for gtk-based desktops (including Xfce)
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
Workaround for KDE
sudo pacman -S xdg-desktop-portal-kde
Workaround for Lxqt
sudo pacman -S xdg-desktop-portal-lxqt
Workaround for desktops using hyprland
sudo pacman -S xdg-desktop-portal-hyprland
Workaround for desktops using wlroots
The system freezes irregularly after the latest update. (5-10s) Mouse, keyboard input stop working.
Kernel: 6.2.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.2-x86_64
root=UUID=a50abda4-d58e-40dd-9875-ca5a5e7eb47d rw rootflags=subvol=@ quiet
cryptdevice=UUID=0e001bf7-d04b-4e1d-8c86-ef5ddacf1131:luks-0e001bf7-d04b-4e1d-8c86-ef5ddacf1131
root=/dev/mapper/luks-0e001bf7-d04b-4e1d-8c86-ef5ddacf1131 splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-c4ed1763-c0f3-4246-a61b-16db743434fe
udev.log_priority=3
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: LENOVO product: 20N20031US v: ThinkPad T490
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20N20031US v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: N2IETA1W (1.79 ) date: 01/16/2023
ID-1: BAT0 charge: 40.0 Wh (99.5%) condition: 40.2/50.5 Wh (79.8%)
volts: 12.8 min: 11.5 model: SMP 02DL008 type: Li-poly serial: <filter>
status: not charging cycles: 751
System RAM: available: 15.29 GiB used: 5.21 GiB (34.1%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB
note: est.
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB speed:
spec: 2667 MT/s actual: 2400 MT/s volts: curr: 1.2 width (bits): data: 64
total: 64 manufacturer: Samsung part-no: M471A1K43BB1-CTD serial: N/A
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB speed:
total: 64 manufacturer: Micron part-no: 8ATF1G64HZ-2G6E1 serial: <filter>
Info: model: Intel Core i7-8565U socket: BGA1528 (U3E1) note: check bits: 64
type: MT MCP arch: Whiskey Lake gen: core 8 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xB (11)
microcode: 0xF2
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1395 high: 2000 min/max: 400/4600 base/boost: 1800/2000
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 768 2: 2000 3: 800 4: 2000 5: 2000 6: 2000
7: 799 8: 800 bogomips: 32012
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Chicony ThinkPad T490 Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 04f2:b681
Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: AU Optronics 0x2036 built: 2017 res: 2560x1440
hz: 60 dpi: 210 gamma: 1.2 size: 310x170mm (12.2x6.69") diag: 355mm (14")
ratio: 16:9 modes: 2560x1440
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel UHD Graphics 620 (WHL
GT2) direct-render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.2.16-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: cscotun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IP v6: <filter> scope: link
IP v6: <filter> virtual: stable-privacy scope: link
IF-ID-2: virbr0 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-3: virbr1 state: down mac: <filter>
all]
IF-ID-4: virbr2 state: down mac: <filter>
all]
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3
Device-1: luks-0e001bf7-d04b-4e1d-8c86-ef5ddacf1131 maj-min: 254:0
type: LUKS dm: dm-0 size: 936.75 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 936.75 GiB
Device-2: luks-c4ed1763-c0f3-4246-a61b-16db743434fe maj-min: 254:1
type: LUKS dm: dm-1 size: 16.82 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 16.82 GiB
Local Storage: total: 953.87 GiB used: 546.66 GiB (57.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 5108AGLA temp: 36.9 C
scheme: GPT
SMART: yes health: PASSED on: 1y 218d 7h cycles: 4,639
read-units: 179,917,561 [92.1 TB] written-units: 100,250,607 [51.3 TB]
ID-1: / raw-size: 936.75 GiB size: 936.75 GiB (100.00%)
used: 546.64 GiB (58.4%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-0e001bf7-d04b-4e1d-8c86-ef5ddacf1131 label: N/A
uuid: a50abda4-d58e-40dd-9875-ca5a5e7eb47d
used: 24.7 MiB (8.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: F387-CE96
ID-3: /home raw-size: 936.75 GiB size: 936.75 GiB (100.00%)
ID-4: /var/cache raw-size: 936.75 GiB size: 936.75 GiB (100.00%)
ID-5: /var/log raw-size: 936.75 GiB size: 936.75 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.82 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-c4ed1763-c0f3-4246-a61b-16db743434fe label: swap
uuid: b4900c7f-6571-43e6-8074-8b096da53f5d
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-8:2 info: Chicony ThinkPad T490 Webcam type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b681 class-ID: 0e02 serial: <filter>
Device-2: 1-10:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 45.0 C pch: 47.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 2516
Processes: 315 Uptime: 10m wakeups: 6 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1567 libs: 377 tools: gnome-software,pamac,yay pm: rpm pkgs: 0
pm: flatpak pkgs: 0 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.27
[ 35.399505] rfkill: input handler disabled
[ 39.775236] input: Satechi M1 Mouse as /devices/virtual/misc/uhid/0005:1915:0040.0001/input/input17
[ 39.775666] input: Satechi M1 Mouse Consumer Control as /devices/virtual/misc/uhid/0005:1915:0040.0001/input/input18
[ 39.776048] hid-generic 0005:1915:0040.0001: input,hidraw0: BLUETOOTH HID v0.01 Mouse [Satechi M1 Mouse] on 98:2c:bc:c7:7a:99
[ 44.198482] systemd-journald[330]: /var/log/journal/05b37fb490ea4cd294f3c481a71fe538/user-1000.journal: Monotonic clock jumped backwards relative to last journal entry, rotating.
[ 44.605011] rfkill: input handler enabled
[ 46.984380] rfkill: input handler disabled
[ 47.073685] Bluetooth: RFCOMM TTY layer initialized
[ 47.073696] Bluetooth: RFCOMM socket layer initialized
[ 47.073703] Bluetooth: RFCOMM ver 1.11
[ 60.069364] systemd-journald[330]: Time jumped backwards, rotating.
[ 70.419357] rfkill: input handler enabled
[ 72.776426] rfkill: input handler disabled
[ 81.661082] rfkill: input handler enabled
[ 83.572816] rfkill: input handler disabled
I just noticed that screen brightness controls no longer works, for my thinkpad T420.
I’ll try rebuilding some of those python packages and reboot and see if it solve it.
Welp, after a year and a half I finally had an update take me down. When trying to boot, after I enter my disk password I get:
Slot 0 opened
error: symbol ‘grub_debug_malloc’ not found.
Entering rescue mode…
Any ideas? I don’t think this is the same issue as the “no such cryptodisk found” problem from the last update.
hactarr:
Pretty serious to affect the clock too, makes me think of either conflicting IRQ ports, or mis-handling of mouse events.
How frequently are the freezes?
As a diagnostic step, can you try the mouse in a different USB port?
And another test, do you get the freezes on a boot from live USB?
Im having issues with performance after login. System freezes for around 20-30 seconds. Also i have freezes and lags after suspension. Im using tkg-pds kernel with nvidia-dkms module. I tryed the original kernel but that does not affect degraded performance. Also im on gnome.
If you’re using openweather Gnome extension, deactivate it. For me, it was this extension which froze system during 20-30s after login.
Updates on my XFCE server and GNOME notebook went fine, only nomacs failed to build via AUR. Looks like an issue with exiv2 . Really just the smallest of annoyances, I’ll use something else meanwhile.
I am using a Bluetooth mouse—but all the input devices freeze on my laptop
