[Stable Update] 2023-01-24 - Kernels, Plasma, Frameworks, Gear, Libreoffice, Mesa, Nvidia, Deepin
Hello community,
Another stable branch update with some usual package updates for you.
Recent News:
Previous News
Notable Package Updates:
  • Most of the Kernels got updated
  • GNOME 43.2
  • Mesa 22.3.3
  • NVIDIA 525.85.05
  • VirtualBox 7.0.6
  • OpenJDK 19.0.2.u7, 11.0.18.u10 & 8.362.u09
  • KDE Frameworks 5.102.0
  • KDE Gear (Apps) 22.12.1
  • Plasma 5.26 ends out with its last point-release
  • LibreOffice 7.4.4
  • Deepin got a lot of updated packages
  • The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. See also the Arch post.
  • Beside the usual upstream updates like Firefox-Beta, python, haskell and others we added our KDE-git packages as usual
Additional Info
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
Info about GNOME 43
GNOME 43 is here! :partying_face:
New in Manjaro GNOME:
Lonely leftover orphan packages that have been removed from the Arch / Manjaro repositories:
  • adwaita-maia
  • dynamic-wallpaper-editor
  • firefox-gnome-theme-maia
  • gtkhash-nautilus
    (Not compatible with Nautilus 43)
  • manjaro-dynamic-wallpaper
  • manjaro-gdm-tweak
  • nautilus-terminal
    (Not compatible with Nautilus 43 & EOL)
Our current supported kernels
  • linux419 4.19.270
  • linux54 5.4.229
  • linux510 5.10.164
  • linux515 5.15.89
  • linux60 6.0.19 [EOL]
  • linux61 6.1.7
  • linux62 6.2.0rc4
  • linux515-rt 5.15.86_rt56
  • linux60-rt 6.0.5_rt14
Package changes (Fri Jan 20 18:18:24 CET 2023)
  • stable community x86_64: 2383 new and 2286 removed package(s)
  • stable core x86_64: 86 new and 84 removed package(s)
  • stable extra x86_64: 1150 new and 1243 removed package(s)
  • stable kde-unstable x86_64: 410 new and 410 removed package(s)
  • stable multilib x86_64: 56 new and 53 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2023-01-24
PHP 8.2 update and introduction of legacy branch
2023-01-13 - Pierre Schmitz
The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. These will follow the oldest but still actively supported PHP branch. This enables users to install the latest version but also introduces the option to use third party applications that might rely on an older version. Both branches will be kept up to date following our rolling release model. php and php-legacy can be installed at the same time as the latter uses a -legacy suffix for its binaries and configuration files.
In addition to this, the php7 packages have been removed as they reached end of life. The imap extension will no longer be provided as it relies on the c-client library which has been abandoned for many years.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
2022-12-20
pacman-mirrors was temporarily renamed to manjaro-mirrors (changed has been reverted)
This was done to avoid confusion with an AUR / WSL package with the same name and avoid possible breakage. It should be a seamless transition.
Rename project (#183) · Issues · Applications / pacman-mirrors · GitLab
dbus-x11 demoted to AUR
dbus-x11 was installed out of the box on some flavors of Manjaro as of a year ago, but is no longer needed. If you have it installed, please replace it with dbus using the following:
sudo pacman -Syu dbus
XFCE becomes unusable if libxfce4ui-nocsd is still installed
So far XFCE Classic project hasn’t updated yet to 4.18 series. We pushed 4.17.0 version of the package, but don’t know if that helps in that situation. It is recommended to install the regular libxfce4ui package to avoid issues and comment on this issue: libxfce4ui 4.18.0 released · Issue #15 · Xfce-Classic/libxfce4ui-nocsd · GitHub
2022-12-06
python-cairo 1.23.0-2 update requires manual intervention
The python-cairo package prior to version 1.23.0-2 was missing the compiled python module. This has been fixed in 1.23.0-2, so the upgrade will need to overwrite the untracked pyc file that was created. If you receive this error
python-cairo: /usr/lib/python3.10/site-packages/cairo/__pycache__/__init__.cpython-310.pyc exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/python3.10/site-packages/cairo/__pycache__/\*
to perform the upgrade.
2022-11-14
We recommend to install openssl-1.1
Due to the update to openssl 3.0 some things still look for the older LTS version 1.1. You may install openssl-1.1 and maybe lib32-openssl-1.1 packages. However report such issues to us.
Known issues:
  • some SDDM themes might not work
  • dkms might not sign modules properly as header files may still depend on 1.1 version of openssl
Issues reported to Archlinux so far:
FS#76567 : [plasma-framework] 5.99.0 needs a rebuild against openssl 3.0
libx11 1.8.2 causes firefox to freeze
libx11 1.8.2 causes Firefox to freeze, mainly when highlighting text and copying things to the clipboard (e.g. password manager).
Issues reported:
Workaround (UNTESTED - at your own risk!):
Install the AUR Package libx11-firefox-fix
Kernel 6.0: AMDGPU - Screen freezes when waking from hibernation or suspend
Making sure you're not a bot!
Mesa 22.2.x renders Calamares black on Gnome Development ISOs
For some yet unknown reason Calamares is rendered black on Gnome when Mesa 22.2.x is used. Current workaround is to install 22.1.x series and relogin to the live-session.
2022-11-02
Kernel 6.1-rc# might break backlight control on old/weird laptops, please test
https://hansdegoede.livejournal.com/26427.html
2022-10-28
signature from "Manjaro Build Server <build_at_manjaro_dot_org>" is unknown trust
Seems our signing key for our Build Server had the 2022-10-28 as expire date set when generated. This is now fixed for chroot builds and fresh as also current existing installs via manjaro-keyring 20221028-4 Simply update your system to get that package, which got pushed to all our branches.
NVIDIA 520.56.06 - 525.60.11 Color banding and animation issues
Current (not so good) Workaround:
  • Open nvidia-settings
  • Select the problematic monitor under the GPU Tab (e.g. DP-0 - (LG ...))
  • Under Controls, change Depth to 6 bpc and set dither mode to temporal (or play with the Dithering Controls)
NVIDIA already replied to the Bug-Report, so there is a good chance that this issue will be fixed with the next NVIDIA driver release.
Finally Announced :smile:
I had a issue of brightness but removing a kernel parameter of backlight=video removed the issue.
But I am still confused why I am not able to downgrade my kernel using pacman -U while I have the package cache with me. It still boots into linux 61. I have opened a thread for this do check out :slight_smile:
i see that linux60 6.0.19 [EOL]
i’m currently running 6.0.15-1;
does this means that I’ll get updated to 6.0.19 and would have to change before the next Stable update,or do i need to do it before this update?
I would run the updates reboot upgrade the kernel to 6.1 the reboot again and remove 6.0 if everything seems to be working.
i’ll deal with upgrading the Kernel another time,
i just want to know if it’s fine to keep my current one for this update.
Still have to keep firefox pinned at 108.0 to be able to use it.
I updated all the packages as well as the kernel. After rebooting, my external display is no longer receiving any signal. I usually have it connected over USB-C. The display configuration settings doesn’t detect the monitor, nor does xrandr.
Switching to an HDMI cable fixed the problem but I’d like to use the USB C port ideally.
In this case EOL means that the kernel is nearing the end of its support, but it is still supported. Support will be dropped when 6.2 releases. So no, you don’t need to switch to 6.1 yet. You will automatically update from 6.0.15-1 to 6.0.19 when you update the linux60 package.
Generally, the most recent 2 stable kernels are supported, and the less recent kernel’s support is dropped when a new stable release comes out.
I updated today and everything was working fine so far.
However, I just discovered a bug, where the lockscreen seemed to had some issues.
I just let my PC unattended for a while, so the screen got locked.
But when i moved my mouse again, the following appeared:
I was able to resolve the issue by myself using the steps that are shown.
I can’t find much useful in the logs, but maybe it helps:
Jan 24 17:31:15 laurenz-ManjaroKDE kscreenlocker_greet[48570]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/MediaControls.qml:81:9: QML Image: Blocked request.
Jan 24 17:34:19 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Provided presentation timestamp is invalid: 24014299 (current: 24014303)
Jan 24 17:34:19 laurenz-ManjaroKDE kernel: i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
Jan 24 17:34:19 laurenz-ManjaroKDE rtkit-daemon[1199]: Supervising 12 threads of 7 processes of 1 users.
Jan 24 17:34:19 laurenz-ManjaroKDE rtkit-daemon[1199]: Successfully made thread 49139 of process 1800 owned by '1000' RT at priority 5.
Jan 24 17:34:19 laurenz-ManjaroKDE rtkit-daemon[1199]: Supervising 13 threads of 7 processes of 1 users.
Jan 24 17:34:19 laurenz-ManjaroKDE dbus-daemon[453]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.542' (uid=1000 pid=48570 comm="/usr/lib/kscreenlocker_greet --graceTime 5000 --ks")
Jan 24 17:34:19 laurenz-ManjaroKDE dbus-daemon[453]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 24 17:34:19 laurenz-ManjaroKDE kscreenlocker_greet[48570]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_UP → DEBOUNCE_EVENT_OTHERBUTTON → DEBOUNCE_STATE_IS_UP
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_UP → DEBOUNCE_EVENT_PRESS → DEBOUNCE_STATE_IS_DOWN_WAITING
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_DOWN_WAITING → DEBOUNCE_EVENT_TIMEOUT → DEBOUNCE_STATE_IS_DOWN
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_DOWN → DEBOUNCE_EVENT_RELEASE → DEBOUNCE_STATE_IS_UP_DELAYING_SPURIOUS
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_UP_DELAYING_SPURIOUS → DEBOUNCE_EVENT_PRESS → DEBOUNCE_STATE_IS_DOWN
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_DOWN → DEBOUNCE_EVENT_OTHERBUTTON → DEBOUNCE_STATE_IS_DOWN
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_UP_DELAYING_SPURIOUS → DEBOUNCE_EVENT_OTHERBUTTON → DEBOUNCE_STATE_IS_UP
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_DOWN_WAITING → DEBOUNCE_EVENT_OTHERBUTTON → DEBOUNCE_STATE_IS_DOWN
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_UP_DELAYING_SPURIOUS → DEBOUNCE_EVENT_TIMEOUT_SHORT → DEBOUNCE_STATE_IS_UP_WAITING
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_UP_WAITING → DEBOUNCE_EVENT_OTHERBUTTON → DEBOUNCE_STATE_IS_UP
Jan 24 17:34:20 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_libinput: Libinput: event9  - debounce state: DEBOUNCE_STATE_IS_UP_WAITING → DEBOUNCE_EVENT_TIMEOUT → DEBOUNCE_STATE_IS_UP
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: Received change event for monitored drm device "/dev/dri/card1"
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: Removing output KWin::DrmOutput(0x55ac8fb16660, name="DP-2", geometry=QRect(0,0 3072x1728), scale=1.25)
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Reading output configuration for  KWin::DrmOutput(0x55ac8fdf4370, name="HDMI-A-4", geometry=QRect(0,227 1920x1080), scale=1)
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Reading output configuration for  KWin::DrmOutput(0x55ac8fe1c470, name="HDMI-A-1", geometry=QRect(3072,648 1920x1080), scale=1)
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: Atomic test failed! Das Argument ist ungültig
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: Drm objects:
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: "connector" 110
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_ID": 0->77
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "non-desktop": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "DPMS": 3->0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "EDID": 114
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "vrr_capable": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "underscan": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "underscan vborder": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "underscan hborder": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "max bpc": 10
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "link-status": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: "crtc" 77
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "MODE_ID": 0->139
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "ACTIVE": 0->1
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "VRR_ENABLED": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "GAMMA_LUT": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "GAMMA_LUT_SIZE": 4096
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: "plane" 65
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "type": 1
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_X": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_Y": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_W": 3840->1920
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_H": 2160->1080
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_X": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_Y": 0
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_W": 3840->1920
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_H": 2160->1080
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "FB_ID": 0->138
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "rotation": 1
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "IN_FORMATS": 66
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: "plane" 75
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "type": 2
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_W": 256
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_H": 256
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_X": 0->1709
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_Y": 0->810
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_W": 256
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_H": 256
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "FB_ID": 0->101
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "IN_FORMATS": 76
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_xwl: Setting primary KWin::DrmOutput(0x55ac8fdf4370, name="HDMI-A-4", geometry=QRect(0,0 1920x1080), scale=1) 33
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: precision lost! floating value sent to X 36.25
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: precision lost! floating value sent to X 1313.75
Jan 24 17:34:21 laurenz-ManjaroKDE kernel: i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
Jan 24 17:34:21 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_colord: "HDMI-A-4" has no any color profile assigned
Jan 24 17:34:21 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600ff1cde0 as subsurface because its parent is not mapped.
Jan 24 17:34:21 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600c237da0 as subsurface because its parent is not mapped.
Jan 24 17:34:21 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600ff1dfc0 as subsurface because its parent is not mapped.
Jan 24 17:34:21 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600d3158c0 as subsurface because its parent is not mapped.
Jan 24 17:34:21 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600fa780e0 as subsurface because its parent is not mapped.
Jan 24 17:34:21 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600d315c00 as subsurface because its parent is not mapped.
Jan 24 17:34:21 laurenz-ManjaroKDE rtkit-daemon[1199]: Supervising 12 threads of 7 processes of 1 users.
Jan 24 17:34:22 laurenz-ManjaroKDE rtkit-daemon[1199]: Successfully made thread 49160 of process 1800 owned by '1000' RT at priority 5.
Jan 24 17:34:22 laurenz-ManjaroKDE rtkit-daemon[1199]: Supervising 13 threads of 7 processes of 1 users.
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_xwl: Setting primary KWin::DrmOutput(0x55ac8fdf4370, name="HDMI-A-4", geometry=QRect(0,0 1920x1080), scale=1) 1097
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Provided presentation timestamp is invalid: 24016503 (current: 24016504)
Jan 24 17:34:22 laurenz-ManjaroKDE kernel: i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49167]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49168]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49188]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49176]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49203]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49189]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kscreenlocker_greet[48570]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Jan 24 17:34:22 laurenz-ManjaroKDE kscreenlocker_greet[48570]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/MediaControls.qml:81:9: QML Image: Blocked request.
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49198]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49190]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: Received change event for monitored drm device "/dev/dri/card1"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49211]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: New output on GPU /dev/dri/card1: PHL 326M6V/354
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49240]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49192]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49237]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49232]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49210]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: requesting unexisting screen 0
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:500:25: Unable to assign [undefined] to bool
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:387:21: Unable to assign [undefined] to bool
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: libpng warning: iCCP: known incorrect sRGB profile
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:99: TypeError: Cannot read property 'pluginName' of null
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:78: TypeError: Cannot read property 'configuration' of null
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:81: TypeError: Cannot read property 'pluginName' of null
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:83: TypeError: Cannot read property 'configuration' of null
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:84: TypeError: Cannot read property 'configuration' of null
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:85: TypeError: Cannot read property 'configuration' of null
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:86: TypeError: Cannot read property 'configuration' of null
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:87: TypeError: Cannot read property 'configuration' of null
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:19: TypeError: Cannot read property 'configuration' of null
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:20: TypeError: Cannot read property 'configuration' of null
Jan 24 17:34:22 laurenz-ManjaroKDE plasmashell[1313]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:21: TypeError: Cannot read property 'configuration' of null
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Reading output configuration for  KWin::DrmOutput(0x55ac8fdf4370, name="HDMI-A-4", geometry=QRect(0,0 1920x1080), scale=1)
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Reading output configuration for  KWin::DrmOutput(0x55ac8fe1c470, name="HDMI-A-1", geometry=QRect(1920,0 1920x1080), scale=1)
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Reading output configuration for  KWin::DrmOutput(0x55ac90e7cd90, name="DP-2", geometry=QRect(0,0 3840x2160), scale=1)
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: Atomic test failed! Das Argument ist ungültig
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: Drm objects:
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: "connector" 94
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_ID": 0->80
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "non-desktop": 0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "DPMS": 3->0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "EDID": 140
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "vrr_capable": 1
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "underscan": 0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "underscan vborder": 0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "underscan hborder": 0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "max bpc": 10
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "link-status": 0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: "crtc" 80
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "MODE_ID": 0->137
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "ACTIVE": 0->1
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "VRR_ENABLED": 0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "GAMMA_LUT": 0->135
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "GAMMA_LUT_SIZE": 4096
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: "plane" 60
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "type": 1
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_X": 0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_Y": 0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_W": 1920->3840
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_H": 1080->2160
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_X": 0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_Y": 0
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_W": 1920->3840
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_H": 1080->2160
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "FB_ID": 0->101
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "rotation": 1
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "IN_FORMATS": 61
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm: "plane" 78
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "type": 2
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_W": 256
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "SRC_H": 256
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_X": 0->2136
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_Y": 0->1013
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_W": 256
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "CRTC_H": 256
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "FB_ID": 0->131
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_wayland_drm:         "IN_FORMATS": 79
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Provided presentation timestamp is invalid: 24016650 (current: 24016654)
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_xwl: Setting primary KWin::DrmOutput(0x55ac90e7cd90, name="DP-2", geometry=QRect(0,0 3072x1728), scale=1.25) 1097
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: precision lost! floating value sent to X 323.52
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: precision lost! floating value sent to X 1533.6
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: precision lost! floating value sent to X 1078.4
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: KWin::LayerShellV1Window doesn't support setting fullscreen state
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: KWin::LayerShellV1Window doesn't support setting maximized state
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_colord: "DP-2" has no any color profile assigned
Jan 24 17:34:22 laurenz-ManjaroKDE rtkit-daemon[1199]: Supervising 12 threads of 7 processes of 1 users.
Jan 24 17:34:22 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600ff1cde0 as subsurface because its parent is not mapped.
Jan 24 17:34:22 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600c237da0 as subsurface because its parent is not mapped.
Jan 24 17:34:22 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600ff1dfc0 as subsurface because its parent is not mapped.
Jan 24 17:34:22 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600d3158c0 as subsurface because its parent is not mapped.
Jan 24 17:34:22 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600fa780e0 as subsurface because its parent is not mapped.
Jan 24 17:34:22 laurenz-ManjaroKDE firefox[40473]: Couldn't map window 0x7f600d315c00 as subsurface because its parent is not mapped.
Jan 24 17:34:22 laurenz-ManjaroKDE rtkit-daemon[1199]: Successfully made thread 49322 of process 1800 owned by '1000' RT at priority 5.
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_xwl: Setting primary KWin::DrmOutput(0x55ac90e7cd90, name="DP-2", geometry=QRect(0,0 3072x1728), scale=1.25) 1099
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49251]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49300]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49267]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49335]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Provided presentation timestamp is invalid: 24017234 (current: 24017237)
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49295]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49287]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49355]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49352]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49376]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49349]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49342]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49373]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49340]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE kcminit[49366]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:22 laurenz-ManjaroKDE audit[48570]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 subj=unconfined pid=48570 comm="kscreenlocker_g" exe="/usr/lib/kscreenlocker_greet" sig=11 res=1
Jan 24 17:34:22 laurenz-ManjaroKDE kernel: traps: kscreenlocker_g[48570] general protection fault ip:7fb838cafd48 sp:7fff45046230 error:0 in libQt5Core.so.5.15.8[7fb838a9f000+2ca000]
Jan 24 17:34:22 laurenz-ManjaroKDE kernel: audit: type=1701 audit(1674578062.990:589): auid=1000 uid=1000 gid=1000 ses=3 subj=unconfined pid=48570 comm="kscreenlocker_g" exe="/usr/lib/kscreenlocker_greet" sig=11 res=1
Jan 24 17:34:23 laurenz-ManjaroKDE kcminit[49344]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:23 laurenz-ManjaroKDE plasmashell[1313]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Jan 24 17:34:23 laurenz-ManjaroKDE plasmashell[1313]: requesting unexisting screen 0
Jan 24 17:34:23 laurenz-ManjaroKDE kcminit[49381]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:23 laurenz-ManjaroKDE kcminit[49400]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:23 laurenz-ManjaroKDE kcminit[49410]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:23 laurenz-ManjaroKDE kcminit[49416]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_xwl: Setting primary KWin::DrmOutput(0x55ac90e7cd90, name="DP-2", geometry=QRect(0,0 3072x1728), scale=1.25) 1099
Jan 24 17:34:23 laurenz-ManjaroKDE kcminit[49429]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland_wrapper[1164]: not a valid new object id (2), message get_registry(n)
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland_wrapper[1164]: error in client communication (pid 1164)
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland_wrapper[49426]: error: received delete_id for unknown id (19)
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland_wrapper[49426]: error: received delete_id for unknown id (37)
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland_wrapper[49426]: error: received delete_id for unknown id (59)
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland_wrapper[49426]: error: received delete_id for unknown id (43)
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland_wrapper[49426]: error: received delete_id for unknown id (57)
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland_wrapper[49426]: error: received delete_id for unknown id (39)
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland_wrapper[49426]: error: received delete_id for unknown id (18)
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland_wrapper[49426]: wl_display@1: error 1: invalid arguments for wl_display@1.get_registry
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Provided presentation timestamp is invalid: 24017634 (current: 24017637)
Jan 24 17:34:23 laurenz-ManjaroKDE kscreenlocker_greet[49426]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jan 24 17:34:23 laurenz-ManjaroKDE kscreenlocker_greet[49426]: The Wayland connection experienced a fatal error: Das Argument ist ungültig
Jan 24 17:34:23 laurenz-ManjaroKDE kcminit[49438]: Initializing  "/usr/lib/qt/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Jan 24 17:34:23 laurenz-ManjaroKDE plasmashell[1313]: libpng warning: iCCP: known incorrect sRGB profile
Jan 24 17:34:23 laurenz-ManjaroKDE plasmashell[1313]: libpng warning: known incorrect sRGB profile
Jan 24 17:34:23 laurenz-ManjaroKDE plasmashell[1313]: libpng warning: profile matches sRGB but writing iCCP instead
Jan 24 17:34:23 laurenz-ManjaroKDE kscreenlocker_greet[49448]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jan 24 17:34:23 laurenz-ManjaroKDE kscreenlocker_greet[49448]: The Wayland connection broke. Did the Wayland compositor die?
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Provided presentation timestamp is invalid: 24017717 (current: 24017721)
Jan 24 17:34:23 laurenz-ManjaroKDE kscreenlocker_greet[49457]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jan 24 17:34:23 laurenz-ManjaroKDE kscreenlocker_greet[49457]: The Wayland connection broke. Did the Wayland compositor die?
Jan 24 17:34:23 laurenz-ManjaroKDE kwin_wayland[1164]: kwin_core: Provided presentation timestamp is invalid: 24017767 (current: 24017771)
Jan 24 17:35:24 laurenz-ManjaroKDE rtkit-daemon[1199]: Supervising 12 threads of 7 processes of 1 users.
Jan 24 17:35:24 laurenz-ManjaroKDE rtkit-daemon[1199]: Successfully made thread 49484 of process 1800 owned by '1000' RT at priority 5.
Jan 24 17:35:24 laurenz-ManjaroKDE rtkit-daemon[1199]: Supervising 13 threads of 7 processes of 1 users.
Jan 24 17:35:35 laurenz-ManjaroKDE systemd[1]: Started Getty on tty3.
Jan 24 17:35:35 laurenz-ManjaroKDE audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=getty@tty3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 17:35:35 laurenz-ManjaroKDE kernel: audit: type=1130 audit(1674578135.199:590): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=getty@tty3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 24 17:35:46 laurenz-ManjaroKDE login[49526]: pam_faillock(login:auth): User unknown
Jan 24 17:35:49 laurenz-ManjaroKDE login[49526]: pam_unix(login:auth): check pass; user unknown
Jan 24 17:35:49 laurenz-ManjaroKDE login[49526]: pam_unix(login:auth): authentication failure; logname=LOGIN uid=0 euid=0 tty=/dev/tty3 ruser= rhost=
Jan 24 17:35:49 laurenz-ManjaroKDE login[49526]: pam_faillock(login:auth): User unknown
Jan 24 17:35:49 laurenz-ManjaroKDE audit[49526]: USER_AUTH pid=49526 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=? acct=6C6F67696E63746C20756E6C6F636B2D73657373696F6E2032 exe="/usr/bin/login" hostname=laurenz-ManjaroKDE addr=? terminal=/dev/tty3 res=failed'
Jan 24 17:35:49 laurenz-ManjaroKDE kernel: audit: type=1100 audit(1674578149.082:591): pid=49526 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=? acct=6C6F67696E63746C20756E6C6F636B2D73657373696F6E2032 exe="/usr/bin/login" hostname=laurenz-ManjaroKDE addr=? terminal=/dev/tty3 res=failed'
Jan 24 17:35:51 laurenz-ManjaroKDE login[49526]: FAILED LOGIN 1 FROM tty3 FOR loginctl unlock-session 2, Authentication failure
It seems to be some kind of Kwin related issue.
more likely a wayland issue…
When running DBeaver I needed to set default java version to 19 in order to Dbeaver to start. Default version was set to java-8-openjdk/jre.
This solved the issue:
sudo archlinux-java set java-19-openjdk
Censored
Hey, first time posting here, and first month using Linux outside of experiments with VMs! So forgive me if anything sounds a bit noob-ish.
There’s an issue with Krita, specifically when opening the G’MIC-qt plugin to apply filters. I get an error message saying “Krita cannot launch the gmic-qt plugin. No bundled library found.” and I simply cannot use those filters.
So far this seems to be the only issue, we’ll see if that remains the case.
I’m using a Lenovo ThinkPad T14gen2 AMD and a Lenovo USB-C DockingStation 40AS0090EU.
With kernel 6.0 I have no problems, but with all kernels 6.1 the connected displays will not wake up after a suspend of the notebook. Even a reboot with kernel 6.1 will not switch the external displays on. I have to boot with kernel 6.0 and everything is fine again.
When the problem shows up, and I switch of the displays with the hardware buttons, it’s detected by the os and the main task bar is moved to the notebook display. When I then switch the displays again on, they stay in power safe mode.
Is this behaviour known?
Can I do something myself to convince the kernel 6.1 to switch the displays on?
OBS does not start anymore (flatpack version runs without problems) obsdebug: Found portal inhibitordebug: Attempted path: share/obs/obs-studio/ - Pastebin.com
VLC crash if a video is loaded (can fix this if I set output to vdpau) vlcVLC media player 3.0.18 Vetinari (revision 3.0.13-8-g41878ff4f2)[0000559a - Pastebin.com
A post was split to a new topic: Installing libplacebo (5.229.1-2) breaks dependency ‘libplacebo.so=208-64’ required by jellyfin-ffmpeg5
I am experiencing the following:
sudo pamac update         ✔  21s 
Preparing...
https://packages.manjaro-sway.download/x86_64/manjaro-sway.db: Error 404
Failed to synchronize databases
I tried refreshing mirrors with both:
sudo pacman-mirrors --continent
sudo pacman-mirrors --geoip
Both mirror refreshes work but still give me the error when running sudo pamac update. :man_shrugging:
And this update breaks… OBS, nice one.
 error: VAAPI: Failed to initialize display in vaapi_device_h264_supported
 Segmentation fault (core dumped)
I could fix it. I installed libva-nvidia-driver from aur.
that fixed my vlc problem, too
