This is a long going issue with Intel AX20x series cards where iwlwifi keeps breaking. If you have one of these cards, I suggest you fix the linux-firmware version to one of the ones identified as working in the link above. Otherwise this will keep breaking. Not sure what is the best way to disseminate this information.
I’ve noticed an issue where I can’t delete any file off the desktop now.
When you either right click and choose “Move To Wastebin” from the desktop widget or Del, the “Move To Wastebin – Plasma” comes up.
Clicking “Move To Wastebin” returns Error --Plasma “The Wastebin is Full. Empty it or remove items manually” even when the wastebin is empty.
Moving the file to another folder I am able to delete it to the wastebin normally.
I haven’t noticed this until this recent release.
I had the same problem on Plasma too.
It’s strange that it affected only my bluetooth mouse, while natural scrolling persisted for the TrackPoint and Touchpad.
After downgrading libinput from 1.20.0-1 to 1.19.3-2, both works fine.
It’s probably a fault of the new libinput.
UPDATED:
Tried suspending and rebooting several times, the bug is still there.
It seems that scrolling config in KDE system settings didn’t re-apply on the reconnect wireless mouse. When my bluetooth mouse reconnects or system resumes from suspend, the wireless mouse loses natural scrolling. The internal track point and touch pad are actually wired devices, so they are not affected.
I have to give props to someone about this. I ran windows in a VM soon after this update and it was 10x smoother than it’s ever been before. I went from barely being able to browse the web, to running professional modeling software without any complaints. (To be fair, I don’t use that VM very often, so this could have been a while ago.)
I have a similar problem in KDE, tho I suspect it’s been going on for longer than just this update: the mouse pointer speed isn’t saved across reboots. It’s almost exactly as the problem described here, I similarly have to go into KDE options and set the pointer speed manually. The OP of that thread solved it with enabling the ‘keyboard daemon’, which I’m not sure wtf that is.
Also they still haven’t removed the unnecessary OOMScoreAdjust=100 line in /usr/lib/systemd/system/user@.service, which results in oom_score_adjust errors in the journal. I did a little script to comment that line out:
#!/bin/bash
sudo sed -e '/OOMScoreAdjust=100/ s/^#*/#/' -i /usr/lib/systemd/system/user@.service
Same here. It only happens if the screen gets turned off, e.g. when I close my laptop. Not right away. But when I open it I only see the mouse. Sometimes parts of the screen start to show up when I move the mouse around, as if they are then drawn. I can even click on applications. The mouse courser also changes if I hover over e.g. a link that is not visible.
KDE Plasma 5.24.2
After upgrading to this version, KDE GUI wifi connection went wrong, it just stuck at “waiting for authorization”. I could still connect to wifi if I force its password stored as unencrypted from systemsettings (it could be seen password field left blank there if chosen to store password encrypted for current user, though I’ve already entered my password for sure), or through something like nmtui/nmcli etc.
Seems something with kwallet and kde network manager went wrong, still diagnosing
I have the same problem, also narrowed it down to KDE and KDE-framworks now,
Plasma 5.23.5 + Frameworks 5.90.0 is fine, 5.24.2 + 5.91.0 is not. All other packages are fine to upgrade.
It also causes Bluetooth to be always disabled on boot.
KDE Plasma. I use Dolphin with picture previews enabled.
I am able to visualize all pictures in common folders but I cannot display picture previews in Vault folders.
I can open that picture files in Gwenview and similar but Dolphin doesn´t show previews for Vault folders.
Can I fix it some way?
I’m not sure what a vault folder is, but I do know Dolphin preview generation has two separate controls for local versus remote files… Dolphin hamburger=>Configure=>Configure Dolphin=>General=>Previews… two settings on the bottom:
Skip previews for local files above: (you select size)
Skip Previews for remote files above: (you select size, no previews by default)
THANK YOUUUUU !!!
That did the trick: I enabled previews for REMOTE files lower than 80mb. Vault folder is local but it seems to be processed as remote. Now I can see all previews again.
The rare thing is it was working ok until this last update.
