One possibility is new config files and you need to merge in you changes, check for pacnew files. More info in the arch wiki
I use meld to check for changes that need to be merged:
$ pamac install meld
$ sudo DIFFPROG=meld pacdiff
Thanks, I see no pacnew files related to this.
I am certain it is something in this update, because I have two machines with Manjaro installed and Vagrant VMs are broken on both of them now after this update. Totally at my wits endâŠ
Something screwed up with virtualbox possibly. Iâve tried downgrading it but issue persists.
Update
Iâve installed EndeavourOS on another drive, installed virtualbox, vagrant, etc. And now my VMs are working again⊠so it looks like something specific in this upgrade on Manjaro. Iâve spent the whole day on this issue, and now looks like I will have to reinstall a different distro to fix it⊠ugh, not exactly what I wanted, but I have no choice as I use this for work.
I guess one last plea for help, anyone know whats up with vagrant/virtualbox on the latest Manjaro update?
Links (eg in Mails) do not open in firefox anymore. I have this problem since the the update from 10th december. After this update links (urls) opened wine, now they open âedit bookâ.
Anybody an idea?
Same Problem.
I didât try so far. Is there an easy way to switch it back?
Also found this on the internet:
https://unix.stackexchange.com/questions/677878/supernumber-key-combos-remapping-in-gnome-40-switch-workspaces-instead-of-laun
Iâm having a strange issue since the latest update.
Tech details
OS: Manjaro Linux x86_64
Host: 20T0001CRT ThinkPad T14s Gen 1
Kernel: 5.13.19-2-MANJARO
DE: Plasma 5.23.4
Today I encountered issue with nginx
not starting, due to âunknown host: domain.localâ
domain.local
is a fake host which I put to /etc/hosts
along with domain2.local
and domain3.local
For some reason, ping domain.local
also results in âunknown hostâ error, as if my /etc/hosts
is completely ignored by system.
upd: I checked /etc/nsswitch.conf
file and see the following line:
hosts: mymachines mdns4_minimal [NOTFOUND=return] resolve [!UNAVAIL=return] files myhostname dns
Is it correct? My colleague has hosts: files mdns4_minimal [NOTFOUND=return] dns
in Ubuntu and his /etc/hosts
works fine
upd2: I guess there might be an issue with me naming my local domains with .local
suffix
this
You can change the order if you like. Itâs your system.
Thank you for the reply. However I still donât undertand the reason behind such change. Why would âfilesâ be not the first entry? /etc/hosts
is historically used to overwrite other data, so it should be first, right?
mymachines
seems perfectly reasonable as first entry nowadays
Iâve had mdns4 lookups after files (or resolve
in my case as itâs supposed to âsupport /etc/hosts
internally but with cachingâ) since I set up my installation years ago
hosts: mymachines resolve [!UNAVAIL=return] files mdns4_minimal [NOTFOUND=return] myhostname dns
Because I got lost in the KDE appearance settings (strange combinations of green and blue) I ran a virtual machine with the latest 21.2rc1 image and copied the settings from there. Maybe it can help others too:
global theme: breath; appl.style: breeze; plasma: breath dark; colors: breath light; windows decorations, icons, cursors, splash: breeze.
This should be addressed in 21.1.2-2 @ScottM. Please review and give feedback.
Manjaro stable branch now has alsa-ucm-conf v1.2.6.3-0 that has patched /usr/share/alsa/ucm2/sof-soundwire/soundwire.conf
Manjaro - Branch Compare - alsa-ucm-conf
fresh manjaro kde install has this issue where both pulseaudio
and pipewire
are running at the same time causing many problems. also sof-firmware
package should be installed by default.
very nice themeâs âeaster eggâ!
Along the same lines as âtoggle your plasma themeâ so the Dolphin icon follows the Accent Color⊠âtoggle your App Launcherâ (via Show Alternatives) so the Manjaro M
follows the Accent Color!
@philm Yes, 21.1.2-2 fixed both the resume-from-suspend and TTY switching problems for me. Thank you!
OMG! This must be the issue I had with this update as well. I have several vagrant VMs I use for development work. All have dummy domains ending with .local and pointed to VM ips in /etc/hosts and after this update none of the domains would resolve.
I spent the entirety of yesterday trying to figure out why, and finally just moved to a different distro (Endeavour) where they work.
Using .local is probably a bad practice as itâs used by other things but, gee wiz, shouldnât /etc/hosts be the final authority on where domains resolve?!
This is a known problem with all DEs that PipeWire can be enabled and started after an update
Users can either disable and mask Pipewire services to continue using PulseAudio
(KDE dependencies do not allow for uninstalling pipewire)
Or install manjaro-pipewire
which includes pw-pulse
to replace pulseaudio
also
sof-firmware
Sound Open Firmware drivers are only required for Intel systems that require IntelÂź HD Audio IntelÂź Smart Sound Technology on proprietary OS
I cannot update the system. It gets stuck at the level
ï î° ï ~ î° sudo pacman -Syu îČ 1 â îČ 19m 50s ï
[sudo] Mot de passe de doudou :
erreur : erreur GPGME : Pas de données
:: Synchronisation des bases de donnĂ©es de paquetsâŠ
core 168,9 KiB 23,4 KiB/s 00:07 [####################################################] 100%
extra 1918,1 KiB 16,8 KiB/s 01:54 [####################################################] 100%
community 6,8 MiB 28,9 KiB/s 04:00 [####################################################] 100%
multilib 176,5 KiB 55,6 KiB/s 00:03 [####################################################] 100%
erreur : la synchronisation de toutes les bases de données a échoué (base de données non valide ou corrompue (signature PGP))
ï î° ï ~ î°
Thank you very much! It worked !
Same problem for me, plus shortcuts like alt+f+4 stopped working for me.
However, when editing the shortcuts though the settings, I noticed that all of these were changed - including the super+ shortcuts!
I disabled/changed them, and it all works again, as previously!
Wouldâve loved a heads up about such changes in the changelog though
