Sound doesn't work on startup
manjaro kde sound doesn’t work on startup or wake from sleep until i reconnect the headset 3-4 times or execute sudo alsactl restore
inxi →
  Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=edf1fd96-32cf-4167-b3ec-fc5c0406d7fa rw quiet apparmor=1
  Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Dell product: Inspiron 5502 v: N/A
  Mobo: Dell model: 0HWH1N v: A00 serial: <superuser required> UEFI: Dell
    v: 1.8.0 date: 10/01/2021
  ID-1: BAT0 charge: 42.9 Wh (80.9%) condition: 53.0/53.0 Wh (100.0%)
    volts: 16.3 min: 15.0 model: SMP DELL 9077G0A type: Li-poly serial: <filter>
    status: Discharging
  RAM: total: 7.5 GiB used: 2.58 GiB (34.4%)
  RAM Report:
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x88
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 1100 high: 1183 min/max: 400/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1183 2: 1050 3: 1167
    4: 1181 5: 1169 6: 898 7: 1018 8: 1139 bogomips: 22120
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
    driver: i915 v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
    class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX330] driver: nvidia v: 495.44
    alternate: nouveau,nvidia_drm bus-ID: 0000:2b:00.0 chip-ID: 10de:1d16
    class-ID: 0302
  Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 3-6:4 chip-ID: 0bda:5538 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.5
    direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:2c:00.0
    chip-ID: 168c:003e class-ID: 0280
  IF: wlp44s0 state: up mac: <filter>
  Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
    chip-ID: 0cf3:e007 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 23.26 GiB (4.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
    model: KBG40ZNS512G NVMe KIOXIA 512GB size: 476.94 GiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: 10410106 temp: 71.8 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 23.26 GiB (5.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: edf1fd96-32cf-4167-b3ec-fc5c0406d7fa
    label: NO_LABEL uuid: 3C92-37FE
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:2
    info: SHARKOON 2.4GHz Wireless rechargeable vertical mouse [More&Better]
    type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
  Device-2: 3-5:3 info: Shenzhen Goodix FingerPrint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 27c6:538d class-ID: ff00
  Device-3: 3-6:4 info: Realtek Integrated_Webcam_HD type: Video
  Device-4: 3-10:5 info: Qualcomm Atheros type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e007
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 49.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 3229
  Processes: 246 Uptime: 29m wakeups: 1757 Init: systemd v: 249
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1254 lib: 337
  flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole
  inxi: 3.3.10
Decide what sound server you want to use.
In case you go with pulse, also check this
thanks a lot this fixed a really big issue. i went with pipewire and just installed the manjaro-pipewire package and its fixed stuff.
inxi -
Screenshot_20211219_002514
(pulseaudio not running now).
just one question that was it some issue from manjaro side cause i never made both run at the same time and cause problems??
