This will be a lot:
ournalctl -b0 -p4 --no-pager
Aug 04 10:43:43 x13blkr kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
Aug 04 10:43:43 x13blkr kernel: #9 #10 #11 #12 #13 #14 #15
Aug 04 10:43:43 x13blkr kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Aug 04 10:43:43 x13blkr kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG0.PEGP._DSD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Aug 04 10:43:43 x13blkr kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
Aug 04 10:43:43 x13blkr kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Aug 04 10:43:43 x13blkr kernel: pci 0000:00:07.2: DPC: RP PIO log size 0 is invalid
Aug 04 10:43:43 x13blkr kernel: pnp 00:05: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Aug 04 10:43:43 x13blkr kernel: hpet_acpi_add: no address or irqs in _CRS
Aug 04 10:43:43 x13blkr kernel: efifb: Ignoring BGRT: unexpected or invalid BMP data
Aug 04 10:43:43 x13blkr kernel: i8042: Warning: Keylock active
Aug 04 10:43:43 x13blkr kernel: usb: port power management may be unreliable
Aug 04 10:43:45 x13blkr kernel: int3472-discrete INT3472:01: INT3472 seems to have no dependents.
Aug 04 10:43:45 x13blkr kernel: int3472-discrete INT3472:06: GPIO type 0x02 unknown; the sensor may not work
Aug 04 10:43:45 x13blkr kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 04 10:43:45 x13blkr kernel: wmi_bus wmi_bus-PNP0C14:02: WQBC data block query control method not found
Aug 04 10:43:45 x13blkr kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 04 10:43:45 x13blkr kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 04 10:43:45 x13blkr kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 04 10:43:45 x13blkr kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 04 10:43:45 x13blkr kernel: acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 04 10:43:45 x13blkr kernel: acpi PNP0C14:07: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 04 10:43:45 x13blkr kernel: acpi PNP0C14:08: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 04 10:43:45 x13blkr kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcffff], which spans more than pnp 00:05 [mem 0xfedc0000-0xfedc7fff]
Aug 04 10:43:45 x13blkr kernel: caller igen6_probe+0x199/0x7d0 [igen6_edac] mapping multiple BARs
Aug 04 10:43:45 x13blkr systemd-udevd[397]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Aug 04 10:43:46 x13blkr systemd-udevd[406]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Aug 04 10:43:46 x13blkr kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-66.ucode failed with error -2
Aug 04 10:43:46 x13blkr kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-65.ucode failed with error -2
Aug 04 10:43:46 x13blkr kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Aug 04 10:43:46 x13blkr kernel: i2c i2c-11: Systems with more than 4 memory slots not supported yet, not instantiating SPD
Aug 04 10:43:46 x13blkr kernel: thermal thermal_zone8: failed to read out thermal zone (-61)
Aug 04 10:43:47 x13blkr kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: warn: FW ABI is more recent than kernel
Aug 04 10:43:49 x13blkr kernel: soundwire sdw:2:025d:1316:01: Probe not complete, timed out
Aug 04 10:43:49 x13blkr kernel: soundwire sdw:2:025d:1316:01: Update Slave status failed:-110
Aug 04 10:43:49 x13blkr kernel: soundwire sdw:1:025d:1316:01: Probe not complete, timed out
Aug 04 10:43:49 x13blkr kernel: soundwire sdw:1:025d:1316:01: Update Slave status failed:-110
Aug 04 10:43:49 x13blkr kernel: soundwire sdw:0:025d:0714:01: Probe not complete, timed out
Aug 04 10:43:49 x13blkr kernel: soundwire sdw:0:025d:0714:01: Update Slave status failed:-110
Aug 04 10:43:50 x13blkr kernel: perf uncore: Cannot find matched IMC device.
Aug 04 10:43:51 x13blkr kernel: dell_smm_hwmon: unable to get SMM Dell signature
Aug 04 10:43:52 x13blkr kernel: kauditd_printk_skb: 18 callbacks suppressed
Aug 04 10:43:52 x13blkr kernel: sof_sdw sof_sdw: snd_soc_register_card failed -517
Aug 04 10:43:52 x13blkr kernel: sd 0:0:0:0: [sda] No Caching mode page found
Aug 04 10:43:52 x13blkr kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Aug 04 10:43:54 x13blkr sddm[450]: Could not setup default cursor
Aug 04 10:43:54 x13blkr systemd[650]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Aug 04 10:43:54 x13blkr systemd[650]: Failed to start Update XDG user dir configuration.
Aug 04 10:43:55 x13blkr sddm-greeter[659]: QFont::fromString: Invalid description '(empty)'
Aug 04 10:43:55 x13blkr sddm-greeter[659]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffcc00f4fe0), parent's thread is QThread(0x55624c923470), current thread is QThread(0x55624ca43aa0)
Aug 04 10:43:55 x13blkr sddm-greeter[659]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Aug 04 10:43:55 x13blkr upowerd[695]: energy_full (54.227250) is greater than energy_full_design (54.134850)
Aug 04 10:43:55 x13blkr sddm-greeter[659]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Aug 04 10:43:55 x13blkr sddm-greeter[659]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Aug 04 10:43:55 x13blkr sddm-greeter[659]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Aug 04 10:43:55 x13blkr sddm-greeter[659]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Aug 04 10:43:55 x13blkr sddm-greeter[659]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.17'
Aug 04 10:43:57 x13blkr kernel: kauditd_printk_skb: 16 callbacks suppressed
Aug 04 10:44:04 x13blkr sddm-helper[704]: [PAM] authenticate: Authentication failure
Aug 04 10:44:04 x13blkr sddm[450]: Authentication error: "Authentication failure"
Aug 04 10:44:04 x13blkr sddm[450]: Auth: sddm-helper exited with 1
Aug 04 10:44:09 x13blkr klauncher[771]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Aug 04 10:44:09 x13blkr kcminit_startup[775]: QDBusConnection: error: could not send signal to service "" path "//home/bauthier/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/bauthier/.kde4/share/config/kdeglobals
Aug 04 10:44:10 x13blkr kwin_x11[786]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Aug 04 10:44:10 x13blkr kwin_x11[786]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Aug 04 10:44:10 x13blkr kwin_x11[786]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Aug 04 10:44:10 x13blkr ksmserver[836]: Qt: Session management error: networkIdsList argument is NULL
Aug 04 10:44:10 x13blkr kwin_x11[786]: kwin_core: XCB error: 10 (BadAccess), sequence: 815, resource id: 1942, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Aug 04 10:44:10 x13blkr kded5[783]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
Aug 04 10:44:10 x13blkr org_kde_powerdevil[866]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Aug 04 10:44:10 x13blkr kded5[783]: kscreen.kded: PowerDevil SuspendSession action not available!
Aug 04 10:44:10 x13blkr org_kde_powerdevil[866]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Aug 04 10:44:10 x13blkr plasmashell[870]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Aug 04 10:44:10 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Aug 04 10:44:10 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Aug 04 10:44:11 x13blkr plasmashell[870]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Aug 04 10:44:11 x13blkr plasmashell[870]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x560740399340)
Aug 04 10:44:11 x13blkr plasmashell[870]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x56073fe2aa50)
Aug 04 10:44:11 x13blkr plasmashell[870]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x56073fe2aaa0)
Aug 04 10:44:11 x13blkr plasmashell[870]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x560740399390)
Aug 04 10:44:11 x13blkr plasmashell[870]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x56073fe2aaa0)
Aug 04 10:44:11 x13blkr plasmashell[870]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x560740339e70)
Aug 04 10:44:11 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Aug 04 10:44:11 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Aug 04 10:44:11 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Aug 04 10:44:11 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Aug 04 10:44:11 x13blkr plasmashell[870]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Aug 04 10:44:11 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Aug 04 10:44:11 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2113, resource id: 4194347, major code: 18 (ChangeProperty), minor code: 0
Aug 04 10:44:11 x13blkr kwin_x11[786]: kwin_core: XCB error: 152 (BadDamage), sequence: 2123, resource id: 14680107, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Aug 04 10:44:11 x13blkr plasmashell[870]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Aug 04 10:44:11 x13blkr plasmashell[870]: org.kde.plasma.pulseaudio: No object for name "auto_null.monitor"
Aug 04 10:44:13 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2727, resource id: 44040310, major code: 18 (ChangeProperty), minor code: 0
Aug 04 10:44:13 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2732, resource id: 44040311, major code: 18 (ChangeProperty), minor code: 0
Aug 04 10:44:13 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Aug 04 10:44:13 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3081, resource id: 14680283, major code: 3 (GetWindowAttributes), minor code: 0
Aug 04 10:44:19 x13blkr kernel: kauditd_printk_skb: 13 callbacks suppressed
Aug 04 10:44:21 x13blkr plasmashell[870]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x56074101cd50) QQmlContext(0x5607407090c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 04 10:44:21 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Aug 04 10:44:21 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Aug 04 10:44:21 x13blkr plasmashell[870]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Aug 04 10:44:21 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Aug 04 10:44:21 x13blkr plasmashell[870]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5607410f9f00) QQmlContext(0x5607407090c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 04 10:44:28 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString
Aug 04 10:44:31 x13blkr kernel: kauditd_printk_skb: 1 callbacks suppressed
Aug 04 10:45:15 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 22889, resource id: 44040408, major code: 14 (GetGeometry), minor code: 0
Aug 04 10:45:15 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 22890, resource id: 44040408, major code: 14 (GetGeometry), minor code: 0
Aug 04 10:45:15 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 22891, resource id: 44040408, major code: 14 (GetGeometry), minor code: 0
Aug 04 10:45:15 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 22892, resource id: 44040408, major code: 14 (GetGeometry), minor code: 0
Aug 04 10:45:15 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 22893, resource id: 44040408, major code: 14 (GetGeometry), minor code: 0
Aug 04 10:46:52 x13blkr systemd-udevd[359]: sdw:0:025d:0714:01: Worker [396] processing SEQNUM=4502 killed
Aug 04 10:47:46 x13blkr kernel: INFO: task systemd-udevd:396 blocked for more than 122 seconds.
Aug 04 10:47:46 x13blkr kernel: Not tainted 5.15.57-2-MANJARO #1
Aug 04 10:47:46 x13blkr kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 04 10:48:47 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53563, resource id: 14685186, major code: 3 (GetWindowAttributes), minor code: 0
Aug 04 10:48:47 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 53564, resource id: 14685186, major code: 14 (GetGeometry), minor code: 0
Aug 04 10:48:47 x13blkr systemsettings[1747]: QFSFileEngine::open: No file name specified
Aug 04 10:48:47 x13blkr systemsettings[1747]: kf.coreaddons.desktopparser: Error: Failed to open ""
Aug 04 10:48:47 x13blkr systemsettings[1747]: QFileDevice::seek: IODevice is not open
Aug 04 10:48:47 x13blkr systemsettings[1747]: kf.coreaddons: "Could not load plugin from kcm_pulseaudio: The shared library was not found."
Aug 04 10:48:47 x13blkr systemsettings[1747]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Aug 04 10:48:47 x13blkr systemsettings[1747]: org.kde.plasma.pulseaudio: No object for name "auto_null.monitor"
Aug 04 10:48:56 x13blkr systemsettings[1747]: org.kde.plasma.pulseaudio: No object for name "auto_null"
Aug 04 10:48:56 x13blkr systemsettings[1747]: org.kde.plasma.pulseaudio: No object for name "auto_null.monitor"
Aug 04 10:48:56 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55484, resource id: 71303327, major code: 18 (ChangeProperty), minor code: 0
Aug 04 10:48:56 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55502, resource id: 44040447, major code: 18 (ChangeProperty), minor code: 0
Aug 04 10:49:49 x13blkr kernel: INFO: task systemd-udevd:396 blocked for more than 245 seconds.
Aug 04 10:49:49 x13blkr kernel: Not tainted 5.15.57-2-MANJARO #1
Aug 04 10:49:49 x13blkr kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 04 10:51:52 x13blkr kernel: INFO: task systemd-udevd:396 blocked for more than 368 seconds.
Aug 04 10:51:52 x13blkr kernel: Not tainted 5.15.57-2-MANJARO #1
Aug 04 10:51:52 x13blkr kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 04 10:52:15 x13blkr plasmashell[870]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x560740c62e10) QQmlContext(0x5607407090c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 04 10:52:15 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Aug 04 10:52:15 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Aug 04 10:53:55 x13blkr kernel: INFO: task systemd-udevd:396 blocked for more than 491 seconds.
Aug 04 10:53:55 x13blkr kernel: Not tainted 5.15.57-2-MANJARO #1
Aug 04 10:53:55 x13blkr kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 04 10:55:58 x13blkr kernel: INFO: task systemd-udevd:396 blocked for more than 614 seconds.
Aug 04 10:55:58 x13blkr kernel: Not tainted 5.15.57-2-MANJARO #1
Aug 04 10:55:58 x13blkr kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 04 10:58:01 x13blkr kernel: INFO: task systemd-udevd:396 blocked for more than 737 seconds.
Aug 04 10:58:01 x13blkr kernel: Not tainted 5.15.57-2-MANJARO #1
Aug 04 10:58:01 x13blkr kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 04 11:00:04 x13blkr kernel: INFO: task systemd-udevd:396 blocked for more than 860 seconds.
Aug 04 11:00:04 x13blkr kernel: Not tainted 5.15.57-2-MANJARO #1
Aug 04 11:00:04 x13blkr kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 04 11:01:09 x13blkr plasmashell[870]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x560740c727f0) QQmlContext(0x5607407090c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 04 11:01:09 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Aug 04 11:01:09 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Aug 04 11:01:09 x13blkr plasmashell[870]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Aug 04 11:02:06 x13blkr kernel: INFO: task systemd-udevd:396 blocked for more than 983 seconds.
Aug 04 11:02:06 x13blkr kernel: Not tainted 5.15.57-2-MANJARO #1
Aug 04 11:02:06 x13blkr kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 04 11:04:09 x13blkr kernel: INFO: task systemd-udevd:396 blocked for more than 1105 seconds.
Aug 04 11:04:09 x13blkr kernel: Not tainted 5.15.57-2-MANJARO #1
Aug 04 11:04:09 x13blkr kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 04 11:06:12 x13blkr kernel: INFO: task systemd-udevd:396 blocked for more than 1228 seconds.
Aug 04 11:06:12 x13blkr kernel: Not tainted 5.15.57-2-MANJARO #1
Aug 04 11:06:12 x13blkr kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 04 11:10:20 x13blkr plasmashell[870]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5607414e40e0) QQmlContext(0x5607407090c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Aug 04 11:10:20 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Aug 04 11:10:20 x13blkr plasmashell[870]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Aug 04 11:10:20 x13blkr plasmashell[870]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Aug 04 11:10:25 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50602, resource id: 44040490, major code: 15 (QueryTree), minor code: 0
Aug 04 11:10:31 x13blkr kwin_x11[786]: kwin_core: XCB error: 152 (BadDamage), sequence: 52880, resource id: 14704190, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Aug 04 11:10:31 x13blkr kwin_x11[786]: kwin_core: XCB error: 152 (BadDamage), sequence: 52888, resource id: 14704190, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Aug 04 11:10:31 x13blkr kwin_x11[786]: kwin_core: XCB error: 3 (BadWindow), sequence: 52889, resource id: 14704188, major code: 129 (SHAPE), minor code: 6 (Input)
Aug 04 11:10:31 x13blkr kwin_x11[786]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52890, resource id: 14704188, major code: 2 (ChangeWindowAttributes), minor code: 0
dmesg:
dmesg | grep -i audio
[ 0.145842] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 5.549625] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 5.549851] sof-audio-pci-intel-tgl 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
[ 5.549864] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
[ 5.550005] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 6.407832] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 6.436891] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[ 6.498429] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 4
[ 6.500300] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 6.500302] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:18:0
[ 6.500303] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 6.500305] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ 6.615237] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 6.615240] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:18:0
[ 6.615242] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: FW ABI is more recent than kernel
