I still have a problem opening anything to do with wine.
(After this update I have wine 6.6-1, wine-gecko 2.47.2-1, wine-mono 6.1.1-1 and winetricks 20210206-1)
For example:
winecfg
produces the following-
0034:err:module:find_forwarded_export function not found for forward 'shcore.SHCreateStreamOnFileW' used by L"C:\\windows\\system32\\shlwapi.dll". If you are using builtin L"shlwapi.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'shcore.SHDeleteKeyW' used by L"C:\\windows\\system32\\shlwapi.dll". If you are using builtin L"shlwapi.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CoCreateInstance' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CoTaskMemFree' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CoUninitialize' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CreateStreamOnHGlobal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.PropVariantClear' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CLSIDFromString' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CoTaskMemAlloc' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HBITMAP_UserFree' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HBITMAP_UserMarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HBITMAP_UserSize' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HBITMAP_UserUnmarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HICON_UserFree' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HICON_UserMarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HICON_UserSize' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HICON_UserUnmarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HPALETTE_UserFree' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HPALETTE_UserMarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HPALETTE_UserSize' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HPALETTE_UserUnmarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.PropVariantCopy' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.StringFromGUID2' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CLIPFORMAT_UserFree' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CLIPFORMAT_UserMarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CLIPFORMAT_UserSize' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CLIPFORMAT_UserUnmarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CoGetMalloc' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CoTaskMemRealloc' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.CreateErrorInfo' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.GetErrorInfo' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HACCEL_UserFree' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HACCEL_UserMarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HACCEL_UserSize' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HACCEL_UserUnmarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HDC_UserFree' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HDC_UserMarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HDC_UserSize' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HDC_UserUnmarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HWND_UserFree' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HWND_UserMarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HWND_UserSize' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.HWND_UserUnmarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.SetErrorInfo' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.WdtpInterfacePointer_UserMarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.WdtpInterfacePointer_UserSize' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
0034:err:module:find_forwarded_export function not found for forward 'combase.WdtpInterfacePointer_UserUnmarshal' used by L"C:\\windows\\system32\\ole32.dll". If you are using builtin L"ole32.dll", try using the native one instead.
wine: Call from 7BC2B840 to unimplemented function userenv.dll.CreateEnvironmentBlock, aborting
wine: Unimplemented function userenv.dll.CreateEnvironmentBlock called at address 7BC2B840 (thread 003c), starting debugger...
wine: Call from 7BC2B840 to unimplemented function combase.dll.CoInitializeEx, aborting
wine: Unimplemented function combase.dll.CoInitializeEx called at address 7BC2B840 (thread 0034), starting debugger...
then sits doing nothing but system activity shows-
winecfg.exe
winedbg
winemenubuilder
wineboot.exe
winedbg
wineserver
after ctrl-c
0054:err:module:DelayLoadFailureHook failed to delay load comctl32.dll.InitCommonControlsEx
wine: Call from 7B010FB6 to unimplemented function comctl32.dll.InitCommonControlsEx, aborting
0080:fixme:console:default_ctrl_handler Terminating process 20 on event 0
[donald@mainframe ~]$ 007c:err:ntdll:RtlpWaitForCriticalSection section 7BC60360 "../wine/dlls/ntdll/loader.c: loader_section" wait timed out in thread 007c, blocked by 0078, retrying (60 sec)
and I still have -
winecfg.exe
winedbg
wineserver
running.
Any help would be appreciated. Thanks
