Just booted with the 5.11-rc6 kernel after updating. Everything seems ok, I’ll edit if I notice anything off.
Easy peasy lemon squeezy! Updated 4 laptops and 2 PCs with Intel and AMD video, Cinnamon DE, kernel 5.10, all via TTY. Everything’s hunky dory!
Is there a safe way to replace pulseaudio with pipewire in this update?
I had a problem with this update. This is the error message:
no se pudieron satisfacer las dependencias:
- incapaz de satisfacer la dependencia "fluidsynth=2.1.7" requerida por lib32-fluidsynth
- incapaz de satisfacer la dependencia "libinstpatch=1.1.6" requerida por lib32-libinstpatch
- incapaz de satisfacer la dependencia "libplacebo.so=104-64" requerida por mpv
What should I do to fix it?
EDIT 2: I reinstalled libplacebo and I deleted MPV. But the problem persists…
GNOME - Update went smoothly but GNOME Terminal won’t launch. I follow the guide from @Felukah and it worked. Just I had to remove (not do) step 3.
The new Papirus icons are UGLY (especially the Nautilus and Terminal ones)! Massive let down for me.
Also Telegram seems to have bugged shadow - white border / outline around the application.
I did, and it worked fine
Andreas
This update fixed my WiFi problem
gnome-terminal isn’t starting. removed and reinstalled it from pamac. Not working. Any solution?
EDIT: FIX -
install “xterm” from pamac.
edit /etc/locale.gen.
uncomment - en_US.UTF8
Then run: sudo locale-gen from xterm
Something funky with locale indeed, I have en_US.UTF-8 & nl_NL.UTF-8 installed.
For some reason after glibc update this happens:
Upgrading glibc (2.32-5 -> 2.33-3)...
Generating locales...
de_DE.UTF-8... done
en_US.UTF-8... done
Generation complete.
Upgrading gcc-libs (10.2.0-4 -> 10.2.0-6)...
Then further down:
/etc/locale.conf: line 2: warning: setlocale: LC_NUMERIC: cannot change locale (nl_NL.UTF-8)
/etc/locale.conf: line 3: warning: setlocale: LC_TIME: cannot change locale (nl_NL.UTF-8)
-> Running build hook: [plymouth]
$ cat /etc/locale.conf
LANG=en_US.utf8
LC_NUMERIC=nl_NL.UTF-8
LC_TIME=nl_NL.UTF-8
LC_COLLATE=C
LC_MONETARY=nl_NL.UTF-8
LC_PAPER=nl_NL.UTF-8
LC_MEASUREMENT=nl_NL.UTF-8
changing de_DE.UTF-8 to #de_DE.UTF-8 and #nl_NL.UTF-8 to nl_NL.UTF-8 in /etc/locale.gen & running $ sudo locale-gen solves this issue.
This seems wrong tho:
LANG=en_US.utf8
Have any pacnew files for virtmanager? I saw some go past in this update and actively processing them now.
Edit: skipped all pacnewfiles and have working QEMU/KVM virtuals
For reference, these are the ones I have as pacnew
==> pacnew file found for /etc/libvirt/nwfilter/allow-dhcp-server.xml
==> pacnew file found for /etc/libvirt/nwfilter/allow-dhcp.xml
==> pacnew file found for /etc/libvirt/qemu/networks/default.xml
Made a note to look up what to do with them this weekend.
Hi, thank you for all this.
Globally smooth but as I use PulseEffects, I discovered a partial implementation of PipeWire.
I didn’t want to go to pulseeffects-legacy, thus had to:
[2021-02-09T20:18:59+0100] [ALPM] installed gnome-settings-daemon (3.38.1-1)
[2021-02-09T20:16:54+0100] [ALPM] installed sof-firmware (1.6.1-1)
[2021-02-09T20:16:27+0100] [ALPM] installed libgweather (3.36.1-1)
[2021-02-09T20:15:26+0100] [ALPM] installed lib32-fluidsynth (2.1.7-1)
[2021-02-09T20:15:26+0100] [ALPM] installed lib32-sdl2 (2.0.14-1)
[2021-02-09T20:15:26+0100] [ALPM] installed lib32-libpulse (14.2-2)
[2021-02-09T20:15:26+0100] [ALPM] installed lib32-libasyncns (0.8+3+g68cd5af-2)
[2021-02-09T20:15:26+0100] [ALPM] installed lib32-libinstpatch (1.1.6-1)
[2021-02-09T20:12:38+0100] [ALPM] installed lib32-portaudio (1:19.6.0-4)
[2021-02-09T19:56:37+0100] [ALPM] installed gst-plugin-pipewire (1:0.3.21-1)
[2021-02-09T19:56:37+0100] [ALPM] installed manjaro-pipewire (20210109-1)
[2021-02-09T19:56:37+0100] [ALPM] installed pipewire-jack (1:0.3.21-1)
[2021-02-09T19:56:37+0100] [ALPM] installed pipewire-alsa (1:0.3.21-1)
[2021-02-09T19:56:37+0100] [ALPM] installed wireplumber (0.3.0-1)
[2021-02-09T19:56:37+0100] [ALPM] installed libpipewire02 (0.2.7-1)
[2021-02-09T19:56:37+0100] [ALPM] installed pipewire-pulse (1:0.3.21-1)
[2021-02-09T19:54:57+0100] [ALPM] removed pulseaudio (14.2-2)
[2021-02-09T19:54:57+0100] [ALPM] removed pulseaudio-alsa (1:1.2.2-2)
[2021-02-09T19:54:57+0100] [ALPM] removed libgweather (3.36.1-1)
[2021-02-09T19:54:56+0100] [ALPM] removed gnome-settings-daemon (3.38.1-1)
[2021-02-09T19:54:53+0100] [ALPM] removed eolie (0.9.101-1)
[2021-02-09T19:54:52+0100] [ALPM] removed pulseaudio-bluetooth (14.2-2)
[2021-02-09T19:54:52+0100] [ALPM] removed xfce4-pulseaudio-plugin (0.4.3-1.1)
[2021-02-09T19:54:51+0100] [ALPM] removed pulseaudio-ctl (1.67-1)
[2021-02-09T19:54:51+0100] [ALPM] removed pulseaudio-zeroconf (14.2-2)
[2021-02-09T19:54:51+0100] [ALPM] removed sof-firmware (1.6.1-1)
[2021-02-09T19:54:51+0100] [ALPM] removed pavucontrol (1:4.0-2)
[2021-02-09T19:54:50+0100] [ALPM] removed pulseaudio-lirc (14.2-2)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-libinstpatch (1.1.6-1)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-libasyncns (0.8+3+g68cd5af-2)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-libpulse (14.2-2)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-libcanberra-pulse (0.30+2+gc0620e4-3)
[2021-02-09T19:54:50+0100] [ALPM] removed pulseaudio-equalizer (14.2-2)
[2021-02-09T19:54:50+0100] [ALPM] removed pulseaudio-jack (14.2-2)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-sdl2 (2.0.14-1)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-portaudio (1:19.6.0-4)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-fluidsynth (2.1.7-1)
[2021-02-09T19:54:50+0100] [ALPM] removed pulseaudio-rtp (14.2-2)
[2021-02-09T19:54:50+0100] [ALPM] removed manjaro-pulse (20210109-1)
[2021-02-09T19:54:50+0100] [ALPM] removed xfce4-volumed-pulse (0.2.3-1)
As you can see is was sloppy.
Would have been better if informed or scripted !
Does the talk about pulseaudio mean that it’s become outdated generally and we should replace it with something else? Or is this just about pulseeffects?
I mean I have pulseaudio installed, but not pulseeffects and not pipewire.
Is there a reason for downgrading VIVALDI ?
Yesterday we got V3.6.2165.36-1. (SAFETY )
And now .34.
Testing and unstable are still at .36.
Vivaldi Homepage too.
Edit: stable-staging is still at .34. Maybe copy old over new version?
stable-staging feels often a little bit forgotten …
This update made OpenShot from the official repo work much better, thanks!
No issues found running Cinnamon and the 5.10 kernel
Gnome, Update:
All German language files are gone - everything is now English again (bevor was german). In the settings, no languages are displayed at all anymore.
Telegram also starts in English again and the chat background is default again.
After the installation of Gnome, about three weeks ago, the system constantly hung or froze. After deleting a few extensions, it suddenly worked.
I thought I’d look for another distro - but stayed after the crashes stopped. Now this…
Thanks for the update and the
work!
Got it working. Removed Scale Display setting. Changed Video driver to virtio and 3d. Also made a few modifications on Display Spice… Type: Spice Server, Listen Type: None, and OpenGL to Auto. Hope this helps someone.
Your german locale ended up on my machine
- Go to Manjaro Settings,
- Add your language back in the regional settings,
- Log off / log in
should solve it
All good on my end, except for the well-known issue “Gnome Terminal won’t load after update”.
FIXED: Sometimes the updates overwrite the locale settings and need to be regenerated.
Once again, thanks Manjaro team for another great rollout!
Danke, Du hast mich eben davor bewahrt, GNOME zu installieren …
Thanks, you just saved me from installing GNOME …
