I don’t have a functional WiFi connection after the latest stable update. KDE shows it as connected with an exclamation mark. I can ping my router, but I can’t access the web. Downgrading NetworkManager restores the functionality. System specs can be found below.
Kernel: 5.4.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=a5710dc2-1637-47f9-a1be-a92a8d28f0aa ro scsi_mod.use_blk_mq=1
resume=UUID=a5710dc2-1637-47f9-a1be-a92a8d28f0aa resume_offset=15566848
quiet nmi_watchdog=0
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Hewlett-Packard product: HP EliteBook Folio 9470m
v: A1029D1102 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 18DF v: KBC Version 62.19 serial: <filter>
UEFI: Hewlett-Packard v: 68IBD Ver. F.73 date: 04/12/2019
ID-1: BAT0 charge: 9.7 Wh condition: 14.2/14.2 Wh (100%) volts: 15.1/14.8
model: Hewlett-Packard Primary type: Li-ion serial: <filter>
status: Discharging
Info: Dual Core model: Intel Core i5-3427U bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18366
Speed: 798 MHz min/max: 800/1200 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
4: 798
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Chicony HP HD Webcam [Fixed] type: USB driver: uvcvideo
bus ID: 1-1.3:3 chip ID: 04f2:b346 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.3.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1e20
Sound Server: ALSA v: k5.4.89-1-MANJARO
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: 3.2.6-k port: 2080 bus ID: 00:19.0 chip ID: 8086:1502
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel
port: ef80 bus ID: 03:00.0 chip ID: 8086:088e
IF-ID-1: wwp0s26u1u5i6 state: down mac: <filter>
Local Storage: total: 342.81 GiB used: 196.73 GiB (57.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 223.57 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 6A
ID-2: /dev/sdb maj-min: 8:16 vendor: Vaseky model: V800 128G
size: 119.24 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 7A
ID-1: / raw size: 64 GiB size: 62.5 GiB (97.65%) used: 52.34 GiB (83.8%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw size: 512.6 MiB size: 511.6 MiB (99.80%)
used: 14.8 MiB (2.9%) fs: vfat dev: /dev/sda4 maj-min: 8:4
Kernel: swappiness: 5 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 52.0 C mobo: 0.0 C
Processes: 188 Uptime: 16m wakeups: 1 Memory: 15.51 GiB
used: 2.17 GiB (14.0%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: pacman: 1693 lib: 496 flatpak: 0 Shell: Bash
v: 5.1.0 running in: yakuake inxi: 3.2.02
Thanks for your support.
