Yes install of 5.10 kernel resolved the problem:
sudo mhwd-kernel -i linux510
Thank you for the quick answer.
Unfortunately Iām already running the 5.10 kernel. Must be something else then.
Tony
Seems so, could post output of:
systemctl status lightdm > when failed to start
mhwd-kernel -li > List installed kernels
Best regards
Philip
Hi
Thank you for your help
outputs:
Manjaro Linux 5.10.2-2-MANJARO (fe-tchavei) (tty3)
sudo systemctl status lightdm.service
Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Mon 2021-01-04 11:53:10 WET: 45s ago
Docs: man:lightdm(1)
Process: 1113 ExecStart=/usr/bin/lightdm (code-exited, status=1/FAILURE) Main PID: 1113 (code=exited, status=1/FAILURE)
jan 04 11:53:10 fe-tchavei systemd(1]: lightdm.service: Scheduled restart job, restart counter is at 5.
jan 04 11:53:10 fe-tchavei systemd[1]: Stopped Light Display Manager.
jan 04 11:53:10 fe-tchavei systemd[1]: lightdm.service: Start request repeated too quickly.
jan 04 11:53:10 fe-tchavei systemd[1]: lightdm.service: Failed with result 'exit-code'.
jan 04 11:53:10 fe-tchavei systemd[1]: Failed to start Light Display Manager.
mhwd-kernel -li
outputs:
Currently running: 5.10.2-2-MANJARO (linux510)
* linux510
* linux54
Thx
Tony
Strange had the exact same issue with 5.9 but not with 5.10
Same result with 5.4? @tchavei
Just rebooted into 5.4⦠Surprisingly booted without any issues. Seems itās somehow related to 5.10.2
Since I only reboot like once a month, I can live with the manual lighdm.service restart but itās awkward.
Thx
Tony
Last thing output of since you have not entered your hardware in the profile:
Always read the first post. ![]()
I read about a lot of people having troubles with the latest stable update. Since I didnāt have the time to install it:
Is it advised to wait for another week/month/whatever because this update somehow will made easier or will it keep this way and I have to do it anyway?
Iād rather be thankful if I could avoid unnecessary difficulties (I still wake up screaming when I remember the latest Nvidia updates I did recentlyā¦
I had the same issue after update, video-nvidia-450xx driver (the most recent available for my GPU - GeForce 1060) disappeared after update (so I had the same āAfter Updateā as in your image) and I could not find any way to fix this, I tried a lot of things from this topic, compiling the driver on my own by following the instructions listed in the pinned post, etc. but nothing worked.
I then performed a clean installed from the newest manjaro iso published yesterday (manjaro-xfce-20.2.1-210103-linux59.iso), installed kernel 5.4, and compiled on my computer the 450 driver (I had to remove two nvidia packages which created conflicts in order to be able to compile without errors), and now it works: Iām finally able to run linux 5.4 with video-nvidia-450xx driver.
Edit: In order to ignore nvidia driver updates and to keep the 450 driver I installed myself, I added the line IgnorePkg = lib32-nvidia-utils lib32-opencl-nvidia mhwd-nvidia opencl-nvidia in file /etc/pacman.conf.
Later on Iām gonna try to switch to linux 5.10 and compile drivers again for that kernel, but Iāll wait for it to be flagged LTS first.
The problem in question is solved by reinstalling the mhwd-db package, so no need for manual compilation.
If you really need access to your data you could create a Mint/Ubuntu/whatever stick and try to boot from that. This should at least give you the possibility to copy your data etc.
Am wondering the exact same thing. Installed manjaro on my work computer and do not have time to troubleshoot this for the next couple of days. Seeing all the posts, it seems I will run into trouble with my hybrid intel/nvidia card on lenovo thinkpad p1⦠Love the work put into manjaro and probably difficult to troubleshoot the current update, especially for noobs. I just want to point out that this is not a manjaro thing and can happen with any kernel upgrades, I had also drivers breakage on linux mint⦠therefore always backup critical data!
Edits: also wondering if I would just save time by downloading the new iso and slap it on my thinkpad. I have fiddled with this hybrid drivers for a while and generally it is painfulā¦
After updating this a.m., I completely lost wi-fi. After researching several pages on and off the forum and wiki , I finally resolved the issue by replacing broadcom-wl with the broadcom-wl-dkms package, which also required confirmation that the headers had been updated. Thanks to these forum posts for guidance:
Thatās what I did, but it also has been a nightmare since permissions are messed up as well⦠Iām halfway the recover process since itās taking a bit longer than Iād like to but at least my data is there.
I see people had luck booting other kernels, I tried 5.8 and 5.9 and same issue for me.
Was wondering about kernels. Can I install 5.4 lts before it runs the updates? Its been a while I have used manjaro and read somewhere that pamac does updates before new installs to avoid package breakage. But not 100% sureā¦
Use sudo mkinitcpio -P for rebuilding all initramfs images.
As for the other hooks that were scheduled after that and were missed - those could pose a problemā¦
Well, I also did this update yesterday evening. Until now I had about 8-10 crashes of X. Either resulting in a kill of my login session, or freezing of the X session. When it does freeze I can get back to login (lightdm) with SysRQ + REI (no SUB neededd)
And I start to believe thereās a pattern, theres always some DRM stuff in the first place, when X crashes.
Theres always some DRM stuff, followed by a coredump with some warning. In the log from
journalctl --system I was directly droped out of my session to lightdm (no manuall REI was needed)
If already searched the thread for some similar incidents but couldnāt find any.
Jan 04 22:38:09 x570 kernel: [drm:gfx_v9_0_priv_reg_irq [amdgpu]] *ERROR* Illegal register access in command stream
Jan 04 22:38:09 x570 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=13792039, emitted seq=13792042
Jan 04 22:38:09 x570 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process vlc pid 104959 thread vlc:cs0 pid 104975
Jan 04 22:38:09 x570 kernel: amdgpu 0000:08:00.0: amdgpu: GPU reset begin!
Jan 04 22:38:09 x570 kernel: [drm] free PSP TMR buffer
Jan 04 22:38:09 x570 kernel: amdgpu 0000:08:00.0: amdgpu: GPU reset succeeded, trying to resume
Jan 04 22:38:09 x570 kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
Jan 04 22:38:09 x570 kernel: [drm] PSP is resuming...
Jan 04 22:38:09 x570 kernel: [drm] reserve 0x400000 from 0xf47fc00000 for PSP TMR
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: RAS: optional ras ta ucode is not available
Jan 04 22:38:10 x570 kernel: [drm] kiq ring mec 2 pipe 1 q 0
Jan 04 22:38:10 x570 kernel: ------------[ cut here ]------------
Jan 04 22:38:10 x570 kernel: WARNING: CPU: 3 PID: 80696 at drivers/gpu/drm/amd/amdgpu/../display/dc/core/dc.c:866 dc_commit_state+0x8ca/0x990 [amdgpu]
Jan 04 22:38:10 x570 kernel: Modules linked in: md4 cmac nls_utf8 cifs libarc4 dns_resolver fscache libdes mousedev input_leds joydev squashfs rfkill loop nct6775 hwmon_vid nls_iso8859_1 nls_cp437 vfat fat wmi_bmof snd_hda_codec_realtek amdgpu snd_hda_codec_generic ledtrig_audio snd_hda_codec_hdmi edac_mce_amd snd_hda>
Jan 04 22:38:10 x570 kernel: CPU: 3 PID: 80696 Comm: kworker/3:10 Tainted: G OE 5.9.16-1-MANJARO #1
Jan 04 22:38:10 x570 kernel: Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./X570 Pro4, BIOS P3.20 08/11/2020
Jan 04 22:38:10 x570 kernel: Workqueue: events drm_sched_job_timedout [gpu_sched]
Jan 04 22:38:10 x570 kernel: RIP: 0010:dc_commit_state+0x8ca/0x990 [amdgpu]
Jan 04 22:38:10 x570 kernel: Code: 2d fe ff ff e8 c6 d2 f7 f2 e9 23 fe ff ff be 01 00 00 00 e8 d8 a8 41 f3 e9 ee fc ff ff 80 b8 78 03 00 00 00 0f 84 5c fe ff ff <0f> 0b e9 55 fe ff ff 49 8b 85 98 02 00 00 48 8b 58 10 48 8b 43 08
Jan 04 22:38:10 x570 kernel: RSP: 0018:ffff9ec6836cfc78 EFLAGS: 00010202
Jan 04 22:38:10 x570 kernel: RAX: ffff90c395ac4400 RBX: ffff90bd8be00690 RCX: 0000000000000003
Jan 04 22:38:10 x570 kernel: RDX: 00000000000015f8 RSI: 0000000000000e6e RDI: 000076599206285b
Jan 04 22:38:10 x570 kernel: RBP: 0000000000000000 R08: ffff9ec6836cfbcc R09: ffff9ec6836cfb40
Jan 04 22:38:10 x570 kernel: R10: 0000000000000002 R11: 0000000000000000 R12: ffff90bd8be01ec8
Jan 04 22:38:10 x570 kernel: R13: ffff90c3f9010000 R14: ffff90bd8be01ec8 R15: ffff90bd8be00000
Jan 04 22:38:10 x570 kernel: FS: 0000000000000000(0000) GS:ffff90c4106c0000(0000) knlGS:0000000000000000
Jan 04 22:38:10 x570 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jan 04 22:38:10 x570 kernel: CR2: 00007f9e69189010 CR3: 00000005f20da000 CR4: 00000000003506e0
Jan 04 22:38:10 x570 kernel: Call Trace:
Jan 04 22:38:10 x570 kernel: dm_resume+0x3c8/0x530 [amdgpu]
Jan 04 22:38:10 x570 kernel: amdgpu_device_ip_resume_phase2+0x52/0xb0 [amdgpu]
Jan 04 22:38:10 x570 kernel: amdgpu_device_gpu_recover.cold+0x95b/0xef0 [amdgpu]
Jan 04 22:38:10 x570 kernel: amdgpu_job_timedout+0x121/0x140 [amdgpu]
Jan 04 22:38:10 x570 kernel: drm_sched_job_timedout+0x64/0xe0 [gpu_sched]
Jan 04 22:38:10 x570 kernel: process_one_work+0x1da/0x3d0
Jan 04 22:38:10 x570 kernel: worker_thread+0x4d/0x3d0
Jan 04 22:38:10 x570 kernel: ? rescuer_thread+0x410/0x410
Jan 04 22:38:10 x570 kernel: kthread+0x142/0x160
Jan 04 22:38:10 x570 kernel: ? __kthread_bind_mask+0x60/0x60
Jan 04 22:38:10 x570 kernel: ret_from_fork+0x22/0x30
Jan 04 22:38:10 x570 kernel: ---[ end trace 206b302260ae1455 ]---
Jan 04 22:38:10 x570 kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring comp_1.0.0 uses VM inv ng 1 on hub 0
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Jan 04 22:38:10 x570 kernel: [drm] recover vram bo from shadow start
Jan 04 22:38:10 x570 kernel: [drm] recover vram bo from shadow done
Jan 04 22:38:10 x570 kernel: [drm] Skip scheduling IBs!
Jan 04 22:38:10 x570 kernel: amdgpu 0000:08:00.0: amdgpu: GPU reset(2) succeeded!
Jan 04 22:38:10 x570 kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to initialize parser -125!
Jan 04 22:38:10 x570 audit[28653]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=28653 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
Jan 04 22:38:10 x570 kernel: audit: type=1701 audit(1609796290.908:259): auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=28653 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
Jan 04 22:38:10 x570 audit: BPF prog-id=25 op=LOAD
Jan 04 22:38:10 x570 audit: BPF prog-id=26 op=LOAD
Jan 04 22:38:10 x570 kernel: audit: type=1334 audit(1609796290.922:260): prog-id=25 op=LOAD
Jan 04 22:38:10 x570 kernel: audit: type=1334 audit(1609796290.922:261): prog-id=26 op=LOAD
Jan 04 22:38:10 x570 systemd[1]: Started Process Core Dump (PID 107114/UID 0).
Jan 04 22:38:10 x570 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-107114-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 04 22:38:10 x570 kernel: audit: type=1130 audit(1609796290.925:262): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-107114-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 04 22:38:11 x570 systemd-coredump[107115]: Process 28653 (Xorg) of user 0 dumped core.
Stack trace of thread 28653:
#0 0x00007f4649eea615 raise (libc.so.6 + 0x3d615)
#1 0x00007f4649ed3862 abort (libc.so.6 + 0x26862)
#2 0x0000556bb85996ea OsAbort (Xorg + 0x14a6ea)
#3 0x0000556bb859b1b1 FatalError (Xorg + 0x14c1b1)
#4 0x0000556bb85a0e09 n/a (Xorg + 0x151e09)
#5 0x00007f4649eea6a0 __restore_rt (libc.so.6 + 0x3d6a0)
#6 0x00007f4649eea615 raise (libc.so.6 + 0x3d615)
#7 0x00007f4649ed3862 abort (libc.so.6 + 0x26862)
#8 0x00007f4649f2c5e8 __libc_message (libc.so.6 + 0x7f5e8)
#9 0x00007f4649f3427a malloc_printerr (libc.so.6 + 0x8727a)
#10 0x00007f4649f37894 _int_malloc (libc.so.6 + 0x8a894)
#11 0x00007f4649f39ad5 __libc_calloc (libc.so.6 + 0x8cad5)
#12 0x00007f464821ad42 n/a (radeonsi_dri.so + 0x8b5d42)
#13 0x00007f464821c41d n/a (radeonsi_dri.so + 0x8b741d)
#14 0x00007f4647aa09d9 n/a (radeonsi_dri.so + 0x13b9d9)
#15 0x00007f4647aa0a00 n/a (radeonsi_dri.so + 0x13ba00)
#16 0x00007f464a3c8e4a n/a (libgbm.so.1 + 0x5e4a)
#17 0x00007f464a3cc23b gbm_bo_create (libgbm.so.1 + 0x923b)
#18 0x00007f464a3e8715 n/a (amdgpu_drv.so + 0x9715)
#19 0x00007f464a3f562f n/a (amdgpu_drv.so + 0x1662f)
#20 0x00007f464a3f06ad n/a (amdgpu_drv.so + 0x116ad)
#21 0x0000556bb85cd740 n/a (Xorg + 0x17e740)
#22 0x00007f464953ba90 n/a (libglx.so + 0x10a90)
#23 0x0000556bb85ba7c0 AbortDDX (Xorg + 0x16b7c0)
#24 0x0000556bb859b25c FatalError (Xorg + 0x14c25c)
#25 0x0000556bb85a0e09 n/a (Xorg + 0x151e09)
#26 0x00007f4649eea6a0 __restore_rt (libc.so.6 + 0x3d6a0)
#27 0x00007f46488dd288 n/a (radeonsi_dri.so + 0xf78288)
#28 0x00007f464824f88d n/a (radeonsi_dri.so + 0x8ea88d)
#29 0x00007f4648222b6a n/a (radeonsi_dri.so + 0x8bdb6a)
#30 0x00007f464822de64 n/a (radeonsi_dri.so + 0x8c8e64)
#31 0x00007f464822e200 n/a (radeonsi_dri.so + 0x8c9200)
#32 0x00007f464822e771 n/a (radeonsi_dri.so + 0x8c9771)
#33 0x00007f464825018a n/a (radeonsi_dri.so + 0x8eb18a)
#34 0x00007f46482503cf n/a (radeonsi_dri.so + 0x8eb3cf)
#35 0x00007f464821b755 n/a (radeonsi_dri.so + 0x8b6755)
#36 0x00007f464821c41d n/a (radeonsi_dri.so + 0x8b741d)
#37 0x00007f4647ab136f n/a (radeonsi_dri.so + 0x14c36f)
#38 0x00007f4647ab15de n/a (radeonsi_dri.so + 0x14c5de)
#39 0x00007f4647ab459a n/a (radeonsi_dri.so + 0x14f59a)
#40 0x00007f4647c6679d n/a (radeonsi_dri.so + 0x30179d)
#41 0x00007f4647c6684e n/a (radeonsi_dri.so + 0x30184e)
#42 0x00007f464919d292 n/a (libglamoregl.so + 0x1d292)
#43 0x00007f46491a3240 n/a (libglamoregl.so + 0x23240)
#44 0x00007f464918b9b8 glamor_create_pixmap (libglamoregl.so + 0xb9b8)
#45 0x00007f464a3f9ae5 n/a (amdgpu_drv.so + 0x1aae5)
#46 0x0000556bb84bf4ce n/a (Xorg + 0x704ce)
#47 0x0000556bb8489195 n/a (Xorg + 0x3a195)
#48 0x00007f4649ed5152 __libc_start_main (libc.so.6 + 0x28152)
#49 0x0000556bb84895de _start (Xorg + 0x3a5de)
Stack trace of thread 28654:
#0 0x00007f4649da26a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
#1 0x00007f4647e52bdc n/a (radeonsi_dri.so + 0x4edbdc)
#2 0x00007f4647e513a8 n/a (radeonsi_dri.so + 0x4ec3a8)
#3 0x00007f4649d9c3e9 start_thread (libpthread.so.0 + 0x93e9)
#4 0x00007f4649fad293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 28668:
Stack trace of thread 28659:
Stack trace of thread 28658:
Stack trace of thread 28655:
Stack trace of thread 28657:
Stack trace of thread 28656:
Stack trace of thread 28663:
Stack trace of thread 28661:
Stack trace of thread 28662:
Stack trace of thread 28664:
Stack trace of thread 28669:
#0 0x00007f4649fa7d5d syscall (libc.so.6 + 0xfad5d)
#1 0x00007f46481c9ffe n/a (radeonsi_dri.so + 0x864ffe)
#2 0x00007f464824f191 n/a (radeonsi_dri.so + 0x8ea191)
#3 0x00007f46482012dd n/a (radeonsi_dri.so + 0x89c2dd)
#4 0x00007f4648203bc1 n/a (radeonsi_dri.so + 0x89ebc1)
#5 0x00007f46484dc9ca n/a (radeonsi_dri.so + 0xb779ca)
#6 0x00007f46484ea9a5 n/a (radeonsi_dri.so + 0xb859a5)
#7 0x00007f46484f065e n/a (radeonsi_dri.so + 0xb8b65e)
#8 0x00007f464823bd17 n/a (radeonsi_dri.so + 0x8d6d17)
#9 0x00007f464820ac33 n/a (radeonsi_dri.so + 0x8a5c33)
#10 0x00007f46484e11af n/a (radeonsi_dri.so + 0xb7c1af)
#11 0x00007f46484db4a8 n/a (radeonsi_dri.so + 0xb764a8)
#12 0x00007f46484e234c n/a (radeonsi_dri.so + 0xb7d34c)
#13 0x00007f4647e52c98 n/a (radeonsi_dri.so + 0x4edc98)
#14 0x00007f4647e513a8 n/a (radeonsi_dri.so + 0x4ec3a8)
#15 0x00007f4649d9c3e9 start_thread (libpthread.so.0 + 0x93e9)
#16 0x00007f4649fad293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 28667:
Stack trace of thread 28665:
Stack trace of thread 28666:
Stack trace of thread 28660:
Jan 04 22:38:11 x570 systemd[1]: systemd-coredump@1-107114-0.service: Succeeded.
Jan 04 22:38:11 x570 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-107114-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 04 22:38:11 x570 kernel: audit: type=1131 audit(1609796291.778:263): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-107114-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 04 22:38:11 x570 org.a11y.Bus[48868]: X connection to :0.0 broken (explicit kill or server shutdown).
Jan 04 22:38:11 x570 kernel: audit: type=1113 audit(1609796291.795:264): pid=28732 uid=0 auid=1000 ses=5 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=x570 addr=? terminal=/dev/tty7 res=success'
Jan 04 22:38:11 x570 audit[28732]: USER_LOGOUT pid=28732 uid=0 auid=1000 ses=5 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=x570 addr=? terminal=/dev/tty7 res=success'
Jan 04 22:38:11 x570 kernel: audit: type=1106 audit(1609796291.802:265): pid=28732 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? ter>
Jan 04 22:38:11 x570 kernel: audit: type=1104 audit(1609796291.805:266): pid=28732 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:11 x570 audit[28732]: USER_END pid=28732 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:11 x570 audit[28732]: CRED_DISP pid=28732 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:11 x570 polkitd[728]: Unregistered Authentication Agent for unix-session:5 (system bus name :1.72, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8) (disconnected from bus)
Jan 04 22:38:11 x570 lightdm[28732]: pam_unix(lightdm:session): session closed for user unicorn
Jan 04 22:38:11 x570 systemd-logind[732]: Session 5 logged out. Waiting for processes to exit.
Jan 04 22:38:11 x570 audit: BPF prog-id=26 op=UNLOAD
Jan 04 22:38:11 x570 audit: BPF prog-id=25 op=UNLOAD
Jan 04 22:38:11 x570 kernel: audit: type=1334 audit(1609796291.862:267): prog-id=26 op=UNLOAD
Jan 04 22:38:11 x570 kernel: audit: type=1334 audit(1609796291.862:268): prog-id=25 op=UNLOAD
Jan 04 22:38:11 x570 rtkit-daemon[28316]: Successfully made thread 107124 of process 107124 owned by '1000' high priority at nice level -11.
Jan 04 22:38:11 x570 rtkit-daemon[28316]: Supervising 1 threads of 1 processes of 1 users.
Jan 04 22:38:12 x570 rtkit-daemon[28316]: Supervising 1 threads of 1 processes of 1 users.
Jan 04 22:38:12 x570 rtkit-daemon[28316]: Successfully made thread 107133 of process 107124 owned by '1000' RT at priority 5.
Jan 04 22:38:12 x570 rtkit-daemon[28316]: Supervising 2 threads of 1 processes of 1 users.
Jan 04 22:38:12 x570 rtkit-daemon[28316]: Successfully made thread 107137 of process 107124 owned by '1000' RT at priority 5.
Jan 04 22:38:12 x570 rtkit-daemon[28316]: Supervising 3 threads of 1 processes of 1 users.
Jan 04 22:38:12 x570 dbus-daemon[724]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.567' (uid=1000 pid=107124 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo" label="unconfined")
Jan 04 22:38:12 x570 systemd[1]: Condition check resulted in Bluetooth service being skipped.
Jan 04 22:38:12 x570 rtkit-daemon[28316]: Successfully made thread 107143 of process 107124 owned by '1000' RT at priority 5.
Jan 04 22:38:12 x570 audit[107164]: CRED_ACQ pid=107164 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:12 x570 lightdm[107164]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=969) by (uid=0)
Jan 04 22:38:12 x570 systemd[1]: Created slice User Slice of UID 969.
Jan 04 22:38:12 x570 systemd[1]: Starting User Runtime Directory /run/user/969...
Jan 04 22:38:12 x570 systemd-logind[732]: New session c6 of user lightdm.
Jan 04 22:38:12 x570 systemd[1]: Finished User Runtime Directory /run/user/969.
Jan 04 22:38:12 x570 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 04 22:38:12 x570 systemd[1]: Starting User Manager for UID 969...
Jan 04 22:38:12 x570 dbus-daemon[724]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.573' (uid=0 pid=107168 comm="(systemd) " label="unconfined")
Jan 04 22:38:12 x570 dbus-daemon[724]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 04 22:38:12 x570 systemd[107168]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 04 22:38:12 x570 audit[107168]: USER_ACCT pid=107168 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 04 22:38:12 x570 audit[107168]: CRED_ACQ pid=107168 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jan 04 22:38:12 x570 systemd[107168]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Jan 04 22:38:12 x570 systemd[107168]: pam_unix(systemd-user:session): session opened for user lightdm(uid=969) by (uid=0)
Jan 04 22:38:12 x570 systemd[107168]: pam_env(systemd-user:session): deprecated reading of user environment enabled
Jan 04 22:38:12 x570 audit[107168]: USER_START pid=107168 uid=0 auid=969 ses=9 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 04 22:38:12 x570 audit: BPF prog-id=27 op=LOAD
Jan 04 22:38:12 x570 audit: BPF prog-id=27 op=UNLOAD
Jan 04 22:38:13 x570 systemd-xdg-autostart-generator[107176]: Configuration file /etc/xdg/autostart/msm_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jan 04 22:38:13 x570 systemd[107168]: Queued start job for default target Main User Target.
Jan 04 22:38:13 x570 systemd[107168]: -.slice: Failed to migrate controller cgroups from /user.slice/user-969.slice/user@969.service, ignoring: Permission denied
Jan 04 22:38:13 x570 systemd[107168]: Created slice User Application Slice.
Jan 04 22:38:13 x570 systemd[107168]: Reached target Paths.
Jan 04 22:38:13 x570 systemd[107168]: Reached target Timers.
Jan 04 22:38:13 x570 systemd[107168]: Starting D-Bus User Message Bus Socket.
Jan 04 22:38:13 x570 systemd[107168]: Listening on GnuPG network certificate management daemon.
Jan 04 22:38:13 x570 systemd[107168]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 04 22:38:13 x570 systemd[107168]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jan 04 22:38:13 x570 systemd[107168]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jan 04 22:38:13 x570 systemd[107168]: Listening on GnuPG cryptographic agent and passphrase cache.
Jan 04 22:38:13 x570 systemd[107168]: Listening on p11-kit server.
Jan 04 22:38:13 x570 systemd[107168]: Listening on Multimedia System.
Jan 04 22:38:13 x570 systemd[107168]: Listening on Sound System.
Jan 04 22:38:13 x570 systemd[107168]: Listening on D-Bus User Message Bus Socket.
Jan 04 22:38:13 x570 systemd[107168]: Reached target Sockets.
Jan 04 22:38:13 x570 systemd[107168]: Reached target Basic System.
Jan 04 22:38:13 x570 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 04 22:38:13 x570 systemd[1]: Started User Manager for UID 969.
Jan 04 22:38:13 x570 systemd[107168]: Starting Update XDG user dir configuration...
Jan 04 22:38:13 x570 systemd[1]: Started Session c6 of user lightdm.
Jan 04 22:38:13 x570 systemd[107168]: xdg-user-dirs-update.service: Succeeded.
Jan 04 22:38:13 x570 systemd[107168]: Finished Update XDG user dir configuration.
Jan 04 22:38:13 x570 systemd[107168]: Reached target Main User Target.
Jan 04 22:38:13 x570 systemd[107168]: Startup finished in 124ms.
Jan 04 22:38:13 x570 audit[107164]: USER_START pid=107164 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:13 x570 systemd[107168]: Started D-Bus User Message Bus.
Jan 04 22:38:13 x570 dbus-daemon[107196]: [session uid=969 pid=107196] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=969 pid=107179 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Jan 04 22:38:13 x570 systemd[107168]: Starting Accessibility services bus...
Jan 04 22:38:13 x570 dbus-daemon[107196]: [session uid=969 pid=107196] Successfully activated service 'org.a11y.Bus'
Jan 04 22:38:13 x570 systemd[107168]: Started Accessibility services bus.
Jan 04 22:38:13 x570 dbus-daemon[107196]: [session uid=969 pid=107196] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=969 pid=107179 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Jan 04 22:38:13 x570 systemd[107168]: Starting Virtual filesystem service...
Jan 04 22:38:13 x570 dbus-daemon[107196]: [session uid=969 pid=107196] Successfully activated service 'org.gtk.vfs.Daemon'
Jan 04 22:38:13 x570 systemd[107168]: Started Virtual filesystem service.
Jan 04 22:38:13 x570 polkitd[728]: <no filename>:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
Jan 04 22:38:13 x570 polkitd[728]: <no filename>:4: subject=[Subject pid=107179 user='lightdm' groups=lightdm seat='seat0' session='c6' local=true active=true]
Jan 04 22:38:13 x570 at-spi-bus-launcher[107203]: dbus-daemon[107203]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=969 pid=107179 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Jan 04 22:38:13 x570 at-spi-bus-launcher[107203]: dbus-daemon[107203]: Successfully activated service 'org.a11y.atspi.Registry'
Jan 04 22:38:13 x570 at-spi-bus-launcher[107226]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 04 22:38:16 x570 lightdm[107223]: gkr-pam: unable to locate daemon control file
Jan 04 22:38:16 x570 audit[107223]: USER_AUTH pid=107223 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 lightdm[107223]: gkr-pam: stashed password to try later in open session
Jan 04 22:38:16 x570 dbus-daemon[724]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.576' (uid=0 pid=107223 comm="lightdm --session-child 12 19 " label="unconfined")
Jan 04 22:38:16 x570 kernel: kauditd_printk_skb: 10 callbacks suppressed
Jan 04 22:38:16 x570 kernel: audit: type=1100 audit(1609796296.222:279): pid=107223 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 kernel: audit: type=1101 audit(1609796296.225:280): pid=107223 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 audit[107223]: USER_ACCT pid=107223 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 dbus-daemon[724]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 04 22:38:16 x570 lightdm[107223]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 04 22:38:16 x570 systemd[1]: Stopping Session c6 of user lightdm.
Jan 04 22:38:16 x570 lightdm[107164]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Jan 04 22:38:16 x570 audit[107164]: USER_END pid=107164 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 audit[107164]: CRED_DISP pid=107164 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 systemd[1]: session-c6.scope: Succeeded.
Jan 04 22:38:16 x570 systemd[1]: Stopped Session c6 of user lightdm.
Jan 04 22:38:16 x570 kernel: audit: type=1106 audit(1609796296.438:281): pid=107164 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 kernel: audit: type=1104 audit(1609796296.438:282): pid=107164 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 systemd-logind[732]: Removed session c6.
Jan 04 22:38:16 x570 audit[107223]: CRED_ACQ pid=107223 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 lightdm[107223]: pam_unix(lightdm:session): session opened for user unicorn(uid=1000) by (uid=0)
Jan 04 22:38:16 x570 kernel: audit: type=1103 audit(1609796296.442:283): pid=107223 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 kernel: audit: type=1006 audit(1609796296.442:284): pid=107223 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=10 res=1
Jan 04 22:38:16 x570 systemd-logind[732]: New session 10 of user unicorn.
Jan 04 22:38:16 x570 systemd[1]: Started Session 10 of user unicorn.
Jan 04 22:38:16 x570 lightdm[107223]: pam_env(lightdm:session): deprecated reading of user environment enabled
Jan 04 22:38:16 x570 lightdm[107223]: gkr-pam: unlocked login keyring
Jan 04 22:38:16 x570 audit[107223]: USER_START pid=107223 uid=0 auid=1000 ses=10 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jan 04 22:38:16 x570 audit[107223]: USER_LOGIN pid=107223 uid=0 auid=1000 ses=10 subj==unconfined msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=x570 addr=? terminal=/dev/tty7 res=success'
Jan 04 22:38:16 x570 kernel: audit: type=1105 audit(1609796296.458:285): pid=107223 uid=0 auid=1000 ses=10 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="unicorn" exe="/usr/bin/lightdm" hostname=? addr=? te>
Jan 04 22:38:16 x570 kernel: audit: type=1112 audit(1609796296.458:286): pid=107223 uid=0 auid=1000 ses=10 subj==unconfined msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=x570 addr=? terminal=/dev/tty7 res=success'
Jan 04 22:38:17 x570 polkitd[728]: Registered Authentication Agent for unix-session:10 (system bus name :1.585 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Jan 04 22:38:17 x570 NetworkManager[725]: <info> [1609796297.9508] agent-manager: agent[f600b7733a27df05,:1.586/org.freedesktop.nm-applet/1000]: agent registered
Jan 04 22:38:18 x570 dbus-daemon[724]: [system] Activating via systemd: service name='org.blueman.Mechanism' unit='blueman-mechanism.service' requested by ':1.587' (uid=1000 pid=107350 comm="/usr/bin/python /usr/bin/blueman-applet " label="unconfined")
Jan 04 22:38:18 x570 systemd[1]: Starting Bluetooth management mechanism...
Jan 04 22:38:18 x570 blueman-mechanism[107428]: Unable to init server: Could not connect: Connection refused
Jan 04 22:38:18 x570 blueman-mechani[107428]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
Jan 04 22:38:18 x570 dbus-daemon[724]: [system] Successfully activated service 'org.blueman.Mechanism'
Jan 04 22:38:18 x570 systemd[1]: Started Bluetooth management mechanism.
Jan 04 22:38:18 x570 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Hey PalmettoPenguin, thank your for posting a solution. I have the same problem, but I donāt understand what you did exactly. Only installing ābroadcom-wl-dkmsā doesnāt solve it for me.
What do you mean by āconfirmation that the headers had been updatedā? Do I need to run this command sudo pacman -S $(pacman -Qsq "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ') ? I have no idea what that command does.
Thank you!
I did!
But didnāt pay attention to stuff I donāt use ⦠like Python
Didnāt click that itās dependency for other stuff. Like dependency for dependency for protontricks and probably also for Steam (weirdly steam doesnāt mark it as dependency, but fails to do stuff without it or it being broken/missing). In the end the thing I had to reinstall was python-vdf (dependency for protontricks; also in AUR, and reinstalling protontricks didnāt auto reinstall this piece.). Anyway now everything works and got Horizon Zero Dawn also to run ⦠great success! ![]()
