Sound Server "hanging" after upgrade
Just upgraded all packages today, now the sound doesn’t play in any application, and the request “hangs” and times out when I try and play sound, causing various apps or containers to freeze.
I booted back into a 6.1 kernel, but this had no effect on the sound server issue.
Soundcard details:
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC269VC Analog [ALC269VC Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
Here’s inxi output requested by Midarthos
  Kernel: 6.1.131-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=429febf3-f675-4d55-bd65-7a455f99ce41 rw quiet apparmor=1
    security=apparmor resume=UUID=5a52bfa4-0541-45e6-b1ea-ada17658268d
    udev.log_priority=3
  Desktop: Cinnamon v: 6.4.8 tk: GTK v: 3.24.49 wm: Muffin v: 6.4.1 tools:
    avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 3367AJ5 v: ThinkPad X131e
  Mobo: LENOVO model: 3367AJ5 serial: <superuser required>
    part-nu: LENOVO_MT_3367 uuid: <superuser required> UEFI-[Legacy]: LENOVO
    v: G8ET66WW (2.05 ) date: 09/10/2012
  ID-1: BAT1 charge: 34.9 Wh (100.0%) condition: 34.9/57.7 Wh (60.4%)
    volts: 12.5 min: 11.1 model: LGC 45N1063 type: Li-ion serial: <filter>
    status: full
  System RAM: total: 8 GiB available: 7.49 GiB used: 4.31 GiB (57.6%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Hynix/Hyundai part-no: HMT351S6EFR8C-PB serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
  Info: model: Intel Celeron 887 bits: 64 type: MCP arch: Sandy Bridge
    level: v2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
    stepping: 7 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 smt: <unsupported> cache:
    L3: 2 MiB desc: 1x2 MiB
  Speed (MHz): avg: 1497 min/max: 800/1500 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1497 2: 1497 bogomips: 5989
  Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb est flush_l1d
    fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear mmx monitor msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni
    popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tsc tsc_deadline_timer vme x2apic xsave
    xsaveopt xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Lenovo driver: i915 v: kernel arch: Gen-6 code: Sandybridge
    process: Intel 32nm built: 2011 ports: active: LVDS-1,VGA-1
    empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0106 class-ID: 0300
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 04f2:b2fe
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 869x286mm (34.21x11.26")
    s-diag: 915mm (36.02")
  Monitor-1: LVDS-1 pos: primary,bottom-r model: ChiMei InnoLux 0x1118
    built: 2011 res: mode: 1366x768 hz: 60 scale: 100% (1) dpi: 136 gamma: 1.2
    chroma: red: x: 0.588 y: 0.341 green: x: 0.322 y: 0.561 blue: x: 0.153
    y: 0.133 white: x: 0.314 y: 0.329 size: 256x144mm (10.08x5.67")
    diag: 294mm (11.6") ratio: 16:9 modes: 1366x768
  Monitor-2: VGA-1 pos: top-left model: LCDTV14 serial: <filter> built: 2008
    res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 30 gamma: 1.2 chroma: red:
    x: 0.627 y: 0.341 green: x: 0.278 y: 0.596 blue: x: 0.153 y: 0.071 white:
    x: 0.298 y: 0.298 size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3")
    ratio: 16:9 modes: 1920x1080, 1600x1200, 1280x1024, 1360x768, 1024x768,
    800x600, 640x480, 720x400
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Info: Tools: x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  API: ALSA v: k6.1.131-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: wireplumber
    status: active tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Broadcom BCM43228 802.11a/b/g/n driver: wl v: kernel modules: bcma
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:4359
    class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp9s0 state: down mac: <filter>
  Info: services: mld, NetworkManager, ntpd, wpa_supplicant
  Device-1: Broadcom BCM20702A0 driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.5:3 chip-ID: 0a5c:21f3
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 119.24 GiB used: 86.15 GiB (72.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON IT model: LCT-128M3S
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: VQN6 scheme: MBR
  ID-1: / raw-size: 111.41 GiB size: 109.1 GiB (97.93%)
    used: 86.15 GiB (79.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 429febf3-f675-4d55-bd65-7a455f99ce41
  ID-1: swap-1 type: partition size: 7.83 GiB used: 3.2 MiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
    uuid: 5a52bfa4-0541-45e6-b1ea-ada17658268d
  Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 1-1.2:3 info: SYSGRATION type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 05b8:3149 class-ID: 0300
  Hub-3: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.5:3 info: Broadcom BCM20702A0 type: Bluetooth driver: btusb
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 0a5c:21f3 class-ID: fe01 serial: <filter>
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 0000:3825 class-ID: 0301
  Device-2: 3-4:3 info: Chicony Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 256mA chip-ID: 04f2:b2fe class-ID: 0e02
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 62.0 C mobo: 0.0 C
  Fan Speeds (rpm): cpu: 512 fan-2: 512
  Packages: 1493 pm: pacman pkgs: 1483 libs: 456 tools: pamac,yay pm: flatpak
    pkgs: 0 pm: snap pkgs: 10
    1: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    3: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    4: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    6: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    7: https://manjaro.ynh.ovh/stable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
  CPU top: 5 of 255
  1: cpu: 200% command: ps pid: 5987 mem: 3.58 MiB (0.0%)
  2: cpu: 38.4% command: pipewire pid: 1738 mem: 12.9 MiB (0.1%)
  3: cpu: 28.8% command: firefox pid: 5537 mem: 476.9 MiB (6.2%)
  4: cpu: 11.9% command: firefox pid: 5712 mem: 236.7 MiB (3.0%)
  5: cpu: 10.5% command: gnome-terminal-server pid: 5962
    mem: 53.7 MiB (0.7%)
  Memory top: 5 of 255
  1: mem: 545.4 MiB (7.1%) command: Discord pid: 3583 cpu: 3.0%
  2: mem: 476.9 MiB (6.2%) command: firefox pid: 5537 cpu: 28.8%
  3: mem: 446.6 MiB (5.8%) command: brave pid: 1917 cpu: 0.5%
  4: mem: 420.7 MiB (5.4%) command: pamac-manager pid: 4043 cpu: 0.1%
  5: mem: 236.7 MiB (3.0%) command: firefox pid: 5712 cpu: 11.9%
  Processes: 255 Power: uptime: 12h 57m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 2.98 GiB services: csd-power,upowerd
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: gnome-terminal inxi: 3.3.37
Pactl output requested by nikgnomic:
Card #0
	Driver: module-alsa-card.c
	Owner Module: 6
	Properties:
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xf1710000 irq 30"
		device.bus_path = "pci-0000:00:1b.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "1e20"
		device.product.name = "7 Series/C216 Chipset Family High Definition Audio Controller"
		device.string = "0"
		device.description = "Built-in Audio"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	Profiles:
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 32833, available: yes)
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 39268, available: yes)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 39333, available: yes)
		output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
		output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: yes)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
	Active Profile: output:analog-stereo+input:analog-stereo
	Ports:
		analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, availability unknown)
			Properties:
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo
		analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, not available)
			Properties:
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, available)
			Properties:
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
Hi @alias, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
Please post more information about audio cards and playback devices
pactl list cards
aplay -l
You have both pipewire and pulseaudio active, so you should remove one. The usual recommendation is to keep pipewire. You should install the full manjaro-pipewire metapackage, as that will automatically remove pulseaudio and replace old pulseaudio packages with their pipewire equivalents:
sudo pacman -Syu manjaro-pipewire
This solution worked in another topic 4 days ago:
Details of the manjaro-pipewire package:
pamac info manjaro-pipewire
Version               : 20231009-1
Description           : Manjaro meta package for complete PipeWire support.
URL                   : https://wiki.archlinux.org/title/PipeWire
Licenses              : GPL
Repository            : extra
Installed Size        : 1.6 kB
Groups                : --
Depends On            : gst-plugin-pipewire pipewire pipewire-alsa pipewire-pulse
Optional Dependencies : easyeffects: advanced equalizer and effects
                        pipewire-jack: Jack support
                        pipewire-v4l2: V4L2 interceptor
                        pipewire-x11-bell: X11 bell
                        pipewire-zeroconf: Zeroconf support
                        realtime-privileges: Realtime privileges for users
Required By           : --
Optional For          : --
Provides              : --
Replaces              : --
Conflicts With        : manjaro-pulse pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf
Packager              : Mark Wagie <mark@manjaro.org>
Build Date            : Tue 10 Oct 2023 11:27:33
Install Date          : Fri 17 Nov 2023 16:49:01
Install Reason        : Explicitly installed
Validated By          : Signature
Backup files          : --
Scotty,
Thanks heaps. Can confirm this fixed the issue, just a note, I had to do a manual “pacman -Rs manjaro-pulse” to make it work.
I actually had in my notes (that I forgot to refer to) for replacing pulse with pipewire:
This first command will remove pulseaudio including configuration files and unnecessary dependencies:
pamac remove -on manjaro-pulse
or
sudo pacman -Rns manjaro-pulse
I guess I should have referred to those notes before I posted, but it is also useful to have confirmation from another user that running the command to uninstall manjaro-pulse is actually required.
Awful sound quality - #11 by LordTermor
what inxi indicates as running two servers at once is not it is in fact. Inxi just shows that both pulseaudio and pipewire process are running. But it’s perfectly ok since pipewire process is not a sound server actually. It’s video server used by DE for dealing with screen recording and so. PipeWire’s sound server process is called pipewire-pulse.
[/quote]
I can also confirm, that this command works.
