Slow wired internet speed
Hey guys, i just switched to 6.1.31 kernel and now sometimes when i boot my system i have a really slow internet speed. Usually it’s about 90-100 mbit/s and when this happening it’s about 8-12 mbit/s. I’ve never noticed it with 5.15 kernel and i have a windows on my second SSD there wasn’t any issue. Also when i reboot my PC about 2 times - it fixes.
Any suggestions how can i fix this please?
Hi @say8hi,
Sounds like a driver to me.
You’ve been here before, so I don’t know why your inxi data isn’t here, but I’m going to ask you for it from both the 5.15 kernel as well as the 6.1 kernel. Also, have you tested with a newer kernel than 6.1?
Please also see below, the commands for inxi and everything’s there.
Hey, thanks for your fast response. No, i haven’t tried a newer kernel i just use the newest with LTS everytime.
$ inxi
CPU: quad core AMD Ryzen 3 3300X (-MT MCP-) speed/min/max: 2485/2200/3800 MHz
Kernel: 6.1.31-2-MANJARO x86_64 Up: 9m Mem: 4325.3/15939.3 MiB (27.1%)
Storage: 1.36 TiB (38.9% used) Procs: 296 Shell: Bash inxi: 3.3.27
Well, 5.15 is also LTS and will be supported until at least October 2026, so you could still use that without a worry. Or at least until a kernel is released that doesn’t have this…problem.
The reason we ask for
Is because it contains a lo_ more information than the one you provided, while still removing any personally identifiable information. And when I say a lot more, I mean a lot. Information required to help you, which your output doesn’t give. As example, here’s mine, so you can see:
$ inxi --admin --verbosity=7 --filter --no-host --width        1 ↵
Kernel: 6.3.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 info: cairo-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z370 HD3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z370 HD3-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F5 date: 10/30/2017
System RAM: available: 15.58 GiB used: 7.34 GiB (47.1%)
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF2
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 3 MiB desc: 12x256 KiB
L3: 144 MiB desc: 12x12 MiB
Speed (MHz): avg: 4112 high: 4312 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 4298 2: 4300 3: 4300
4: 4300 5: 4296 6: 3200 7: 4312 8: 4300 9: 4253 10: 3200 11: 4297 12: 4295
bogomips: 76831
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Gigabyte driver: nvidia
v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1401 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1080 s-dpi: 97 s-size: 1341x283mm (52.80x11.14")
s-diag: 1371mm (53.96")
Monitor-1: DVI-I-1 pos: right res: 2560x1080 hz: 60 dpi: 97
size: 673x284mm (26.5x11.18") diag: 730mm (28.76") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 2560x1080 hz: 60 dpi: 97
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX
960/PCIe/SSE2 direct-render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
API: ALSA v: k6.3.5-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 0a5c:21e8
Local Storage: total: 8.41 TiB used: 4.76 TiB (56.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 27.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM000-1F2168
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CC54 scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST5000VX0011-1T317X
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: VN02 scheme: GPT
ID-1: / raw-size: 224.58 GiB size: 220 GiB (97.96%) used: 91 GiB (41.4%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3
maj-min: 259:3 label: N/A uuid: D563-DAB7
ID-3: /mnt/4tb_backup raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 1.86 TiB (51.9%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: 4TB uuid: c47c5a52-db30-4aef-bcbc-af35b7b021fd
ID-4: /mnt/5TB raw-size: 4.55 TiB size: 4.51 TiB (99.19%)
used: 2.81 TiB (62.4%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: 5TB uuid: 953836d8-e355-4c6d-ac1a-0914b8414f50
ID-5: /mnt/minikeeper/www raw-size: N/A size: 109.73 GiB
used: 5.43 GiB (5.0%) fs: fuse.sshfs
remote: mirdarthos@10.0.0.254:/var/www/html
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 7.81 GiB used: 695 MiB (8.7%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 1b3f894f-5481-4241-ace5-c129a0cdb412
Device-1: 1-4:2 info: ROCCAT Kone EMP type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:2e24 class-ID: 0300
Device-2: 1-8:3 info: Corsair K68 RGB Mechanical Gaming Keyboard
type: keyboard,HID driver: usbfs interfaces: 2 rev: 2.0
chip-ID: 1b1c:1b4f class-ID: 0300 serial: <filter>
Device-3: 1-9:4 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
System Temperatures: cpu: 29.0 C mobo: N/A gpu: nvidia temp: 30 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 75%
Processes: 355 Uptime: 4d 20h 1m wakeups: 29 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1928 pm: pacman pkgs: 1927 libs: 456 tools: pamac pm: appimage
pkgs: 1 Shell: Zsh v: 5.9 running-in: yakuake inxi: 3.3.27
Please read thorough this, it should help you:
Try another kernel, albeit only temporarily. The issue might not be present in a newer one, or it might.
Ok, thank you, then i’ll just use 5.15 kernel and i’ll read this tutorials.
There is what you wanted to see:
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    root=UUID=e4499118-f0ba-4296-83d7-7addc7079e1f rw rootflags=subvol=@ quiet
    apparmor=1 security=apparmor
    resume=UUID=bf2e3d9d-e484-4950-a960-d50b6ddab3a9 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 info: latte-dock
  Type: Desktop Mobo: Gigabyte model: B450M S2H v: x.x
    serial: <superuser required> UEFI-[Legacy]: American Megatrends v: F50
    date: 11/27/2019
  System RAM: available: 15.57 GiB used: 5.33 GiB (34.3%)
  Info: model: AMD Ryzen 3 3300X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
    L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 2448 high: 3575 min/max: 2200/3800 boost: disabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3575 2: 2908
    3: 2053 4: 2056 5: 2395 6: 2200 7: 2200 8: 2200 bogomips: 60709
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia
    status: current (as of 2023-05) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.0
    chip-ID: 10de:1c82 class-ID: 0300
  Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
    s-diag: 610mm (24")
  Monitor-1: HDMI-0 res: 1920x1080 dpi: 93 size: 522x294mm (20.55x11.57")
    diag: 599mm (23.59") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX 1050
    Ti/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
    bus-ID: 0a:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
    lanes: 1 port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.36 TiB used: 543.89 GiB (38.9%)
    model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 55.9 C scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS250G2B0A
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 90WD scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DL002-9TT153
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CC3C scheme: GPT
  ID-1: / raw-size: 215.69 GiB size: 215.69 GiB (100.00%)
    used: 116.09 GiB (53.8%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: e4499118-f0ba-4296-83d7-7addc7079e1f
  ID-2: /home raw-size: 215.69 GiB size: 215.69 GiB (100.00%)
  ID-3: /mnt/D-disk raw-size: 491.27 GiB size: 491.27 GiB (100.00%)
    used: 427.79 GiB (87.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: a70848de-ddca-48cf-b97e-1fc72310da75
  ID-4: /var/cache raw-size: 215.69 GiB size: 215.69 GiB (100.00%)
  ID-5: /var/log raw-size: 215.69 GiB size: 215.69 GiB (100.00%)
  ID-1: swap-1 type: partition size: 17.2 GiB used: 10.8 MiB (0.1%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
    uuid: bf2e3d9d-e484-4950-a960-d50b6ddab3a9
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: 224F-2567
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 150.25 GiB fs: ntfs label: N/A
    uuid: 01D701FA93C63050
  ID-4: /dev/sda4 maj-min: 8:4 size: 520 MiB fs: ntfs label: N/A
    uuid: 01D701FA96065C50
  ID-5: /dev/sda5 maj-min: 8:5 size: 75 GiB fs: ntfs label: GWin
    uuid: 8012E89312E88F88
  ID-6: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
  ID-7: /dev/sdb3 maj-min: 8:19 size: 418.32 GiB fs: ntfs
    label: \xd0\x9d\xd0\xbe\xd0\xb2\xd1\x8b\xd0\xb9 \xd1\x82\xd0\xbe\xd0\xbc
    uuid: 64121A62121A398E
  Device-1: 3-1:2 info: Logitech G102/G203 LIGHTSYNC Gaming Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
  Device-2: 3-3:3 info: ROYUAN Akko Multi-modes Keyboard-B type: keyboard,HID
    lanes: 1 mode: 1.1 power: 498mA chip-ID: 3151:4003 class-ID: 0300
  System Temperatures: cpu: 49.9 C mobo: N/A
  Processes: 303 Uptime: 30m wakeups: 0 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1839
  pm: pacman pkgs: 1822 libs: 465 tools: pamac pm: flatpak pkgs: 0 pm: snap
  pkgs: 17 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
IIRC that driver did tend to have problem(s). I might be wrong, but that it what I remember, based on a website that I can’t find now. But according to this page_:
r8169 is an in-tree kernel driver that supports a few Ethernet adapters including R8168.
r8168 module built from source provided by Realtek.
So in effect, r8168 is different (newer) from the one you’re using. So trying it might bed worth while, and it can be found in the AUR:
$ pamac search 8168
r8168-dkms        8.051.02-2   AUR
A kernel module for Realtek 8168 network cards (DKMS version)
So it can be installed using:
pamac build r8168-dkms
But now we have to stop the other one from being loaded. Luckily the instructions are printed for us in the terminal. Just run the following:
echo "blacklist r8169" | sudo tee /etc/modprobe.d/r8169.conf
To start using it, simply reboot. If it works, then cool, that’s what we hope for!
If it doesn’t, simply remove the installed drivers:
pamac remove r8168-dkms
And remove the other driver module from the blacklist:
sudo rm /etc/modprobe.d/r8169.conf
…followed by a reboot.
Hope this helps!
Unfortunately it didn’t helped :frowning:
Bummer. But check the other kernel(s) as well, and if something changes, then switch, if not you’re good to go for a while yet.
:wink:
Ok, thanks for your help anyway. I really appreciate it.
Sorry I wasn’t able to do more, perhaps someone else can, but we’ve reached the limit of my knowledge.
Sometimes I also notice a similar degradation. My solution was always rebooting the router. Windows is not involved. When you have that issue again, please test the local network like that:
To test the local network, you would need a second computer. That way, we can exclude that the problem is the router.
I have pretty much the same motherboard and also vendor: Gigabyte driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/sDevice-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet and have had no issue’s with any kernel. As was suggested try rebooting the router and check if something has gotten changed with the network settings.
I’ve just rebooted my router when got low speed and it got fixed.
If r8168 driver is installed using Manjaro Hardware Detection or Manjaro Settings Manager
it should install linux61-r8168 and linux61-headers and blacklist r8169 driver (/etc/modprobe.d/r8169_blacklist.conf)
sudo mhwd -i --pci network-r8168
Or Manjaro Settings Manager > Hardware Configuration
manjaro-settings-manager -m msm_mhwd
mhwd-r8168
Note: some Manjaro kernel modules for r8169 (and headers) are being moved from community repository to extra
packages.manjaro.org/?query=r8168
Sorry for a long response, i’ve installed it and it didn’t fixed the problem
