So I’m going to see if I can find out how to set up this WiFi dongle: Volans VL-UW120 AC1200. I couldn’t get it to work when I got it initially when I bought it about years ago, but I’ll see how I go. First I need to find the latest driver…
Hello @jamesray ![]()
Nope, that is wrong. If the dongle does not work, you need first the chip id and which chipset it uses.
lsusb -vt
inxi -Nazy
Then check the ID on the internet. Lets say: https://linux-hardware.org/?view=search
There type in the vendor id and the device id (vendor:device).
If it works there on other distros, then there is a way to let it work, otherwise search on github/gitlab if there is a dkms for this. If not, then no driver is available.
EDIT: This one could probably work:
pamac build rtl8812au-dkms-git
Dont forget to install the headers. For example:
pamac install linux54-headers
Thanks @megavolt
BTW I think I posted about this in the old forum a couple of years ago, with the same RTL88x2bu chipset as shown below
$ lsusb -vt
|_ Port 2: Dev 6, If 0, Class=Vendor Specific Class, Driver=, 480M
ID 0bda:b812 Realtek Semiconductor Corp. RTL88x2bu [AC1200 Techkey]
$ inxi -Nazy
Device-1: Realtek RTL8111/8168/6411 PCI Express Gigabit Ethernet
# not the dongle, obviously this is the Ethernet cable
vendor: ASUStek ...
[jr@fm ~]$ yay rtl88x2bu
2 aur/rtl88x2bu-cilynx-dkms-git 5.3.1.r39.eece063-1 (+0 0.00) (Orphaned)
Kernel module for Realtek rtl88x2bu WiFi chipset
1 aur/rtl88x2bu-dkms-git 5.8.7.1.r93.f915368-1 (+19 2.08)
==> Packages to install (eg: 1 2 3, 1-3 or ^4)
Looks like aur/rtl88x2bu-dkms-git is best
End of installation output, looks like I need to install the following kernel headers:
(2/2) Install DKMS modules
==> Unable to install module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 4.19.175-1-MANJARO: Missing kernel headers.
==> Unable to install module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 5.10.15-1-MANJARO: Missing kernel headers.
==> Unable to install module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 5.4.97-1-MANJARO: Missing kernel headers.
$ yay 54
2 core/linux54-headers 5.4.105-1 (9.4 MiB 47.0 MiB)
Header files and scripts for building modules for Linux54 kernel
1 core/linux54 5.4.105-1 (82.5 MiB 142.4 MiB) (Installed: 5.4.97-1)
The Linux54 kernel and modules
==> 2
[sudo] password for jr:
resolving dependencies...
Packages (1) linux54-headers-5.4.105-1
Total Download Size: 9.45 MiB
Total Installed Size: 46.96 MiB
:: Retrieving packages...
linux54-headers-5.4.105-1-x86_64 9.4 MiB 1936 KiB/s 00:05 [#######################################################] 100%
(1/1) checking keys in keyring [#######################################################] 100%
(1/1) checking package integrity [#######################################################] 100%
(1/1) loading package files [#######################################################] 100%
(1/1) checking for file conflicts [#######################################################] 100%
(1/1) checking available disk space [#######################################################] 100%
(1/1) installing linux54-headers [#######################################################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating module dependencies...
(3/3) Install DKMS modules
==> Unable to install module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 5.4.105-1-MANJARO: Missing kernel modules tree.
[jr@fm ~]$
I have to leave this, will come back to it later.
Just trying to figure out how to solve this…
Found this:
Oops I don’t think I took in the rest of the above comment.
pamac build rtl8812au-dkms-gitDont forget to install the headers. For example:
Modifying for rtl88x2bu-dkms-git
[jr@fm ~]$ pamac build rtl88x2bu-dkms-git
Preparing...
Cloning rtl88x2bu-dkms-git build files...
Checking rtl88x2bu-dkms-git dependencies...
Warning: downgrading package rtl88x2bu-dkms-git (5.8.7.1.r117.fbb5f57-1 => 5.8.7.1.r93.f915368-1)
Resolving dependencies...
Checking inter-conflicts...
To install (2):
flex 2.6.4-3 core 304.4 kB
bison 3.7.3-1 core 769.5 kB
To build (1):
rtl88x2bu-dkms-git 5.8.7.1.r93.f915368-1 (5.8.7.1.r117.fbb5f57-1) AUR
Total download size: 1.1 MB
Total installed size: 3.4 MB
Edit build files : [e]
Apply transaction ? [e/y/N] y
Download of bison (3.7.3-1) started
Download of flex (2.6.4-3) started
Download of flex (2.6.4-3) finished
Download of bison (3.7.3-1) finished
Checking keyring... [2/2]
Checking integrity... [2/2]
Loading packages files... [2/2]
Checking file conflicts... [2/2]
Checking available disk space... [2/2]
Installing flex (2.6.4-3)... [1/2]
Installing bison (3.7.3-1)... [2/2]
Arming ConditionNeedsUpdate... [1/2]
Updating the info directory file... [2/2]
Building rtl88x2bu-dkms-git...
==> Making package: rtl88x2bu-dkms-git 5.8.7.1.r93.f915368-1 (Fri 02 Apr 2021 15:15:36)
==> Retrieving sources...
-> Cloning RTL88x2BU-Linux-Driver git repo...
Cloning into bare repository '/var/tmp/pamac-build-jr/rtl88x2bu-dkms-git/RTL88x2BU-Linux-Driver'...
remote: Enumerating objects: 734, done.
remote: Counting objects: 100% (734/734), done.
remote: Compressing objects: 100% (591/591), done.
remote: Total 2104 (delta 292), reused 262 (delta 141), pack-reused 1370
Receiving objects: 100% (2104/2104), 9.43 MiB | 3.27 MiB/s, done.
Resolving deltas: 100% (1068/1068), done.
RTL88x2BU-Linux-Driver ... Skipped
==> Extracting sources...
-> Creating working copy of RTL88x2BU-Linux-Driver git repo...
Cloning into 'RTL88x2BU-Linux-Driver'...
done.
==> Starting pkgver()...
==> Updated version: rtl88x2bu-dkms-git 5.8.7.1.r117.fbb5f57-1
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "rtl88x2bu-dkms-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: rtl88x2bu-dkms-git 5.8.7.1.r117.fbb5f57-1 (Fri 02 Apr 2021 15:15:49)
==> Cleaning up...
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
==> Unable to remove module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 4.19.175-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 5.4.105-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 5.10.15-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 4.9.261-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 5.4.97-1-MANJARO: Not found in dkms status output.
Reinstalling rtl88x2bu-dkms-git (5.8.7.1.r117.fbb5f57-1)... [1/1]
Install DKMS modules [2/2]
==> Unable to install module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 4.9.261-1-MANJARO: Missing kernel modules tree.
[jr@fm ~]$ pamac install linux54-headers
Preparing...
To install (2):
linux510-headers 5.10.23-1 core 9.9 MB
linux419-headers 4.19.180-1 core 9.2 MB
Total download size: 19.1 MB
Total installed size: 96.5 MB
Apply transaction ? [y/N] y
Download of linux419-headers (4.19.180-1) started
Download of linux510-headers (5.10.23-1) started
Download of linux419-headers (4.19.180-1) finished
Download of linux510-headers (5.10.23-1) finished
Installing linux510-headers (5.10.23-1)... [1/2]
Installing linux419-headers (4.19.180-1)... [2/2]
Arming ConditionNeedsUpdate... [1/3]
Updating module dependencies... [2/3]
Install DKMS modules [3/3]
==> Unable to install module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 4.19.180-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 5.10.23-1-MANJARO: Missing kernel modules tree.
[jr@fm ~]$ pamac install linux419-headers linux510-headers
Preparing...
Nothing to do.
[jr@fm ~]$
Similar error, however a different module, and the solution doesn’t seem to help:
BTW, WiFi still isn’t working.
[jr@fm ~]$ pamac build rtl8812au-dkms-git
Preparing...
Cloning rtl8812au-dkms-git build files...
Checking rtl8812au-dkms-git dependencies...
To build (1):
rtl8812au-dkms-git 5.9.3.2.r8.gb95e750-1 AUR
Building rtl8812au-dkms-git...
==> Making package: rtl8812au-dkms-git 5.9.3.2.r8.gb95e750-1 (Fri 02 Apr 2021 15:38:01)
-> Cloning rtl8812au-5.9.3.2 git repo...
Cloning into bare repository '/var/tmp/pamac-build-jr/rtl8812au-dkms-git/rtl8812au-5.9.3.2'...
remote: Enumerating objects: 771, done.
remote: Counting objects: 100% (771/771), done.
remote: Compressing objects: 100% (437/437), done.
remote: Total 771 (delta 334), reused 765 (delta 328), pack-reused 0
Receiving objects: 100% (771/771), 2.72 MiB | 2.42 MiB/s, done.
Resolving deltas: 100% (334/334), done.
-> Found dkms.conf
rtl8812au-5.9.3.2 ... Skipped
dkms.conf ... Passed
-> Creating working copy of rtl8812au-5.9.3.2 git repo...
Cloning into 'rtl8812au-5.9.3.2'...
done.
==> Updated version: rtl8812au-dkms-git 5.9.3.2.r9.gd1bf6df-1
==> Creating package "rtl8812au-dkms-git"...
==> Finished making: rtl8812au-dkms-git 5.9.3.2.r9.gd1bf6df-1 (Fri 02 Apr 2021 15:38:10)
==> Cleaning up...
Installing rtl8812au-dkms-git (5.9.3.2.r9.gd1bf6df-1)... [1/1]
==> Unable to install module rtl8812au/5.9.3.2.r9.gd1bf6df for kernel 4.9.261-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl8812au/5.9.3.2.r9.gd1bf6df for kernel 4.19.175-1-MANJARO: Missing kernel headers.
==> Unable to install module rtl8812au/5.9.3.2.r9.gd1bf6df for kernel 5.4.97-1-MANJARO: Missing kernel headers.
==> Unable to install module rtl8812au/5.9.3.2.r9.gd1bf6df for kernel 5.10.23-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl8812au/5.9.3.2.r9.gd1bf6df for kernel 5.10.15-1-MANJARO: Missing kernel headers.
==> Unable to install module rtl8812au/5.9.3.2.r9.gd1bf6df for kernel 4.19.180-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl8812au/5.9.3.2.r9.gd1bf6df for kernel 5.4.105-1-MANJARO: Missing kernel modules tree.
[jr@fm ~]$ modinfo rtl8812au-dkms-git
modinfo: ERROR: Module rtl8812au-dkms-git not found.
[jr@fm ~]$ modinfo rtl88x2bu-dkms-git
modinfo: ERROR: Module rtl88x2bu-dkms-git not found.
[jr@fm ~]$
[jr@fm ~]$ yay rtl8822bu
4 aur/rtl8822bu 1-1 (+1 0.02)
wireless lan driver for realtek devices like GigaBlue WLAN Stick 1200MBit Dual Band USB 3.0
3 aur/rtl8822bu-dkms-raspberrypi 1.1-1 (+2 0.02)
Kernel module for Edimax EW7822ULC USB3 and Asus AC53 Nano USB 802.11ac adapter. (for raspberrypi)
2 aur/rtl8822bu-git r51.9438d45-1 (+4 0.02) (Orphaned)
Driver for the Realtek 822bu chipset.
1 aur/rtl8822bu-dkms-git 20180723-12 (+23 1.21)
Kernel module for Edimax EW7822ULC USB3, Asus AC53 Nano USB 802.11ac and TP-Link Archer T4U adapter.
==> 1 4
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:2] rtl8822bu-1-1 rtl8822bu-dkms-git-20180723-12
:: Downloaded PKGBUILD (1/2): rtl8822bu
:: Downloaded PKGBUILD (2/2): rtl8822bu-dkms-git
2 rtl8822bu (Build Files Exist)
1 rtl8822bu-dkms-git (Build Files Exist)
==> Diffs to show?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
:: (1/2) Parsing SRCINFO: rtl8822bu
:: (2/2) Parsing SRCINFO: rtl8822bu-dkms-git
==> Making package: rtl8822bu-dkms 1-2 (Fri 02 Apr 2021 15:44:14)
-> Downloading master.zip...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 129 100 129 0 0 318 0 --:--:-- --:--:-- --:--:-- 318
100 3840k 0 3840k 0 0 1592k 0 --:--:-- 0:00:02 --:--:-- 2482k
-> Found dkms.conf
==> Validating source files with md5sums...
master.zip ... FAILED
==> ERROR: One or more files did not pass the validity check!
error downloading sources: rtl8822bu
==> 1
[Aur:1] rtl8822bu-dkms-git-20180723-12
==> Packages to cleanBuild?
:: PKGBUILD up to date, Skipping (1/1): rtl8822bu-dkms-git
==> Diffs to show?
:: (1/1) Parsing SRCINFO: rtl8822bu-dkms-git
==> Making package: rtl8822bu-dkms-git 20180723-12 (Fri 02 Apr 2021 15:45:08)
-> Cloning rtl8822bu git repo...
Cloning into bare repository '/home/jr/.cache/yay/rtl8822bu-dkms-git/rtl8822bu'...
remote: Enumerating objects: 8, done.
remote: Counting objects: 100% (8/8), done.
remote: Compressing objects: 100% (8/8), done.
remote: Total 2345 (delta 0), reused 2 (delta 0), pack-reused 2337
Receiving objects: 100% (2345/2345), 8.31 MiB | 3.52 MiB/s, done.
Resolving deltas: 100% (1437/1437), done.
-> Found dkms.conf
rtl8822bu ... Skipped
==> Making package: rtl8822bu-dkms-git 20180723-12 (Fri 02 Apr 2021 15:45:13)
-> Updating rtl8822bu git repo...
Fetching origin
-> Found dkms.conf
-> Creating working copy of rtl8822bu git repo...
Cloning into 'rtl8822bu'...
done.
==> Starting prepare()...
==> Sources are ready.
==> Making package: rtl8822bu-dkms-git 20180723-12 (Fri 02 Apr 2021 15:45:16)
==> WARNING: Using existing $srcdir/ tree
==> Creating package "rtl8822bu-dkms-git"...
-> Adding install file...
==> Finished making: rtl8822bu-dkms-git 20180723-12 (Fri 02 Apr 2021 15:45:23)
==> Cleaning up...
-> Found git repo: github.com/Mephysto666/rtl8822bu.git
loading packages...
Packages (1) rtl8822bu-dkms-git-20180723-12
Total Installed Size: 22.78 MiB
(1/1) checking keys in keyring [#######################################################################################] 100%
(1/1) checking package integrity [#######################################################################################] 100%
(1/1) loading package files [#######################################################################################] 100%
(1/1) checking for file conflicts [#######################################################################################] 100%
(1/1) checking available disk space [#######################################################################################] 100%
(1/1) installing rtl8822bu-dkms-git [#######################################################################################] 100%
Creating symlink /var/lib/dkms/rtl8822bu/20180723/source ->
/usr/src/rtl8822bu-20180723
DKMS: add completed.
Error! echo
Your kernel headers for kernel 5.4.97-1-MANJARO cannot be found at
/usr/lib/modules/5.4.97-1-MANJARO/build or /usr/lib/modules/5.4.97-1-MANJARO/source.
You can use the --kernelsourcedir option to tell DKMS where it's located.
error: command failed to execute correctly
(1/2) Arming ConditionNeedsUpdate...
==> Unable to install module rtl8822bu/20180723 for kernel 5.4.97-1-MANJARO: Missing kernel headers.
==> Unable to install module rtl8822bu/20180723 for kernel 5.10.23-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl8822bu/20180723 for kernel 4.19.175-1-MANJARO: Missing kernel headers.
==> Unable to install module rtl8822bu/20180723 for kernel 5.4.105-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl8822bu/20180723 for kernel 5.10.15-1-MANJARO: Missing kernel headers.
==> Unable to install module rtl8822bu/20180723 for kernel 4.19.180-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl8822bu/20180723 for kernel 4.9.261-1-MANJARO: Missing kernel modules tree.
[jr@fm ~]$
This error is a bit more helpful, i.e.:
Error! echo
[jr@fm ~]$ yay linux54-rt-rtl88x2bu
no packages match search
[jr@fm ~]$ yay linux54-rt-rtl8822bu
[jr@fm ~]$
linux510-headers, linux54-headers, and linux419-headers are all installed…
Oops, I thought the -rt above stood for Realtek!
Locating paths to kernel headers…
[jr@fm ~]$ mhwd-kernel -li
Currently running: 5.4.97-1-MANJARO (linux54)
* linux419
* linux510
* linux54
Not sure how to do that yet.
BTW, there’s this but I don’t think that package will help:
[jr@fm ~]$ yay linux54-rtl
1 extra/linux54-rtl8723bu 20210302-5 (11.0 MiB 11.1 MiB) [linux54-extramodules]
A kernel module for Realtek 8723bu network cards
I tried installing it anyway, but this isn’t surprising:
(1/1) installing linux54-rtl8723bu [#######################################################################################] 100%
>>> The module rtl8723bu conflicts with rtl8xxxu.
>>> rtl8xxxu has been blacklisted using \`/etc/modprobe.d/blacklist_rtlxxxu.conf\`
modprobe: ERROR: could not insert '8723bu': Invalid argument
(2/2) Updating module dependencies...
[jr@fm ~]$
I don’t expect that 8723bu will work with 8822bu.
It works on two distros (evidently GitHub Flavoured Markdown doesn’t work for tables on Discourse):
|HWid|Type|Vendor / Model|Probes|System|Last Status|
|97bb7 »|desktop|ASUSTek /
P8H77-M PRO|21|[image] ROSA R9-R11|works|[image]
Requires additional driver from https://github.com/EntropicEffect/rtl8822bu.|
|3189e »|mini
tower|HP /
339A|2|[image] Parrot 4.10|works|[image]
Only with downloaded DKMS-drivers: https://github.com/cilynx/rtl88x2bu|
Still trying to hack on a solution:
1 aur/rtl88x2bu-dkms-git 5.8.7.1.r93.f915368-1 (+19 2.06) (Installed: 5.8.7.1.r117.fbb5f57-1)
==> 2
[Aur:1] rtl88x2bu-cilynx-dkms-git-5.3.1.r39.eece063-1
:: Downloaded PKGBUILD (1/1): rtl88x2bu-cilynx-dkms-git
1 rtl88x2bu-cilynx-dkms-git (Build Files Exist)
==> Diffs to show?
:: (1/1) Parsing SRCINFO: rtl88x2bu-cilynx-dkms-git
==> Making package: rtl88x2bu-cilynx-dkms-git 5.3.1.r39.eece063-1 (Fri 02 Apr 2021 16:24:14)
-> Cloning rtl88x2bu-cilynx git repo...
Cloning into bare repository '/home/jr/.cache/yay/rtl88x2bu-cilynx-dkms-git/rtl88x2bu-cilynx'...
remote: Enumerating objects: 68, done.
remote: Counting objects: 100% (68/68), done.
remote: Compressing objects: 100% (55/55), done.
remote: Total 830 (delta 33), reused 29 (delta 13), pack-reused 762
Receiving objects: 100% (830/830), 3.67 MiB | 3.91 MiB/s, done.
Resolving deltas: 100% (297/297), done.
rtl88x2bu-cilynx ... Skipped
==> Making package: rtl88x2bu-cilynx-dkms-git 5.3.1.r39.eece063-1 (Fri 02 Apr 2021 16:24:18)
-> Updating rtl88x2bu-cilynx git repo...
Fetching origin
-> Creating working copy of rtl88x2bu-cilynx git repo...
Cloning into 'rtl88x2bu-cilynx'...
done.
==> Updated version: rtl88x2bu-cilynx-dkms-git 5.3.1.r41.c1a5dab-1
==> Making package: rtl88x2bu-cilynx-dkms-git 5.3.1.r41.c1a5dab-1 (Fri 02 Apr 2021 16:24:21)
==> Creating package "rtl88x2bu-cilynx-dkms-git"...
==> Finished making: rtl88x2bu-cilynx-dkms-git 5.3.1.r41.c1a5dab-1 (Fri 02 Apr 2021 16:24:28)
==> Cleaning up...
-> Found git repo: github.com/cilynx/rtl88x2BU_WiFi_linux_v5.3.1_27678.20180430_COEX20180427-5959.git
loading packages...
Packages (1) rtl88x2bu-cilynx-dkms-git-5.3.1.r41.c1a5dab-1
(1/1) installing rtl88x2bu-cilynx-dkms-git [#######################################################################################] 100%
==> Unable to install module rtl88x2bu/5.3.1.r41.c1a5dab for kernel 4.19.180-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl88x2bu/5.3.1.r41.c1a5dab for kernel 4.9.261-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl88x2bu/5.3.1.r41.c1a5dab for kernel 5.4.97-1-MANJARO: Missing kernel headers.
==> Unable to install module rtl88x2bu/5.3.1.r41.c1a5dab for kernel 5.4.105-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl88x2bu/5.3.1.r41.c1a5dab for kernel 5.10.23-1-MANJARO: Missing kernel modules tree.
==> Unable to install module rtl88x2bu/5.3.1.r41.c1a5dab for kernel 4.19.175-1-MANJARO: Missing kernel headers.
==> Unable to install module rtl88x2bu/5.3.1.r41.c1a5dab for kernel 5.10.15-1-MANJARO: Missing kernel headers.
[jr@fm ~]$
[jr@fm ~]$ sudo pacman -S $(pacman -Qsq "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
warning: linux419-headers-4.19.180-1 is up to date -- reinstalling
warning: linux510-headers-5.10.23-1 is up to date -- reinstalling
warning: linux54-headers-5.4.105-1 is up to date -- reinstalling
Packages (3) linux419-headers-4.19.180-1 linux510-headers-5.10.23-1 linux54-headers-5.4.105-1
Total Installed Size: 139.02 MiB
Net Upgrade Size: 0.00 MiB
(3/3) checking keys in keyring [#######################################################################################] 100%
(3/3) checking package integrity [#######################################################################################] 100%
(3/3) loading package files [#######################################################################################] 100%
(3/3) checking for file conflicts [#######################################################################################] 100%
(3/3) checking available disk space [#######################################################################################] 100%
(1/2) Remove upgraded DKMS modules
==> Unable to remove module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 4.19.180-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl8822bu/20180723 for kernel 5.10.23-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl88x2bu/5.3.1.r41.c1a5dab for kernel 4.19.180-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl8812au/5.9.3.2.r9.gd1bf6df for kernel 5.10.23-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl8812au/5.9.3.2.r9.gd1bf6df for kernel 4.19.180-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl8822bu/20180723 for kernel 5.4.105-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl8812au/5.9.3.2.r9.gd1bf6df for kernel 5.4.105-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl8822bu/20180723 for kernel 4.19.180-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl88x2bu/5.3.1.r41.c1a5dab for kernel 5.4.105-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl88x2bu/5.3.1.r41.c1a5dab for kernel 5.10.23-1-MANJARO: Not found in dkms status output.
==> Unable to remove module rtl88x2bu/5.8.7.1.r117.fbb5f57 for kernel 5.10.23-1-MANJARO: Not found in dkms status output.
(2/2) Save Linux kernel modules
(1/3) reinstalling linux419-headers [#######################################################################################] 100%
(2/3) reinstalling linux510-headers [#######################################################################################] 100%
(3/3) reinstalling linux54-headers [#######################################################################################] 100%
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Install DKMS modules
(4/4) Restore Linux kernel modules
==> Warning:
-> Kernel has been updated. Modules of the current kernel
-> have been backed up so you can continue to use your
-> computer. However, the new kernel will only work
-> at next boot.
[jr@fm ~]$
Until this point I hadn’t run a system update…
(10/36) Updating module dependencies...
(11/36) Install DKMS modules
==> dkms install --no-depmod -m rtl88x2bu -v 5.8.7.1.r117.fbb5f57 -k 4.19.180-1-MANJARO
==> dkms install --no-depmod -m rtl8822bu -v 20180723 -k 5.10.23-1-MANJARO
==> dkms install --no-depmod -m rtl88x2bu -v 5.3.1.r41.c1a5dab -k 4.19.180-1-MANJARO
Error! Module version v5.3.1_27678.20180430_COEX20180427-5959 for 88x2bu.ko.xz
is not newer than what is already found in kernel 4.19.180-1-MANJARO (v5.8.7.2_36899.20200819_COEX20191120-7777).
You may override by specifying --force.
==> dkms install --no-depmod -m rtl8812au -v 5.9.3.2.r9.gd1bf6df -k 5.10.23-1-MANJARO
==> dkms install --no-depmod -m rtl88x2bu -v 5.8.7.1.r117.fbb5f57 -k 5.4.105-1-MANJARO
==> dkms install --no-depmod -m rtl8812au -v 5.9.3.2.r9.gd1bf6df -k 4.19.180-1-MANJARO
==> dkms install --no-depmod -m rtl8822bu -v 20180723 -k 5.4.105-1-MANJARO
is not newer than what is already found in kernel 5.4.105-1-MANJARO (v5.8.7.2_36899.20200819_COEX20191120-7777).
==> dkms install --no-depmod -m rtl8812au -v 5.9.3.2.r9.gd1bf6df -k 5.4.105-1-MANJARO
==> dkms install --no-depmod -m rtl8822bu -v 20180723 -k 4.19.180-1-MANJARO
==> dkms install --no-depmod -m rtl88x2bu -v 5.3.1.r41.c1a5dab -k 5.4.105-1-MANJARO
==> dkms install --no-depmod -m rtl88x2bu -v 5.3.1.r41.c1a5dab -k 5.10.23-1-MANJARO
Error! Bad return status for module build on kernel: 5.10.23-1-MANJARO (x86_64)
Consult /var/lib/dkms/rtl88x2bu/5.3.1.r41.c1a5dab/build/make.log for more information.
==> Warning, `dkms install --no-depmod -m rtl88x2bu -v 5.3.1.r41.c1a5dab -k 5.10.23-1-MANJARO' returned 10
==> dkms install --no-depmod -m rtl88x2bu -v 5.8.7.1.r117.fbb5f57 -k 5.10.23-1-MANJARO
==> depmod 5.4.105-1-MANJARO
==> depmod 5.10.23-1-MANJARO
==> depmod 4.19.180-1-MANJARO
(12/36) Restarting cronie for libc upgrade...
(13/36) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
-> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
==> Starting build: 4.19.180-1-MANJARO
I should remove the drivers that I don’t need.
After the system upgrade and reboot it works!
Wow, after all that, it looks like what did the trick was to do a full system upgrade (which should’ve been obvious), and then run pamac build rtl8822bu-dkms-git and install the headers with sudo pacman -Syu $(pacman -Qsq "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ') and then reboot, I just did that in a different order which seems like the reason why I got errors with dkms removing modules and installing them, with errors for missing kernel modules tree.
