The actual problem :
I have a huion tablet (2020 Kamvas 22), and everything works, except for it maps the tablet area across all screens, the usual shortcut (meta ctrl number) didn’t work to remap it to a screen and the graphic tablet settings dont do anything either. So following this redit post i tried using the newset drivers possible https://www.reddit.com/r/huion/comments/hiz1u6/my_experience_with_the_kamvas_13_2020_on_linux/
But when I tried to install the git version of this driver :
AUR (en) - digimend-kernel-drivers-dkms-git / GitHub - DIGImend/digimend-kernel-drivers: DIGImend graphics tablet drivers for the Linux kernel
it either failed on Missing kernel modules tree or make[1]: *** No rule to make target 'modules'.. I do have the linux-headers installed for my kernel (I did restart after installing the linux510 headers)
pacman -Q | grep headers
linux-api-headers 5.8-1
linux510-headers 5.10.7-3
I am not sure what I am doing wrong …
Wollie
23 January 2021 16:43
2
Make sure you are really running kernel 5.10.
Try
sudo pacman -Syu dkms base-devel --needed
Kernel should be correct
uname -r
5.10.2-2-MANJARO
It tries to install them for 5.4 as well … ?
This time it ran better ?
makepkg -scri
==> Making package: digimend-kernel-drivers-dkms-git 10.r0.gec5c16d-1 (Sa 23 Jan 2021 18:49:00 CET)
==> Retrieving sources...
-> Updating digimend-kernel-drivers git repo...
Fetching origin
==> Validating source files with md5sums...
digimend-kernel-drivers ... Skipped
==> Extracting sources...
-> Creating working copy of digimend-kernel-drivers git repo...
Cloning into 'digimend-kernel-drivers'...
done.
==> Starting pkgver()...
==> WARNING: A package has already been built, installing existing package...
==> Installing package digimend-kernel-drivers-dkms-git with pacman -U...
loading packages...
warning: digimend-kernel-drivers-dkms-git-10.r0.gec5c16d-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) digimend-kernel-drivers-dkms-git-10.r0.gec5c16d-1
Total Installed Size: 0,19 MiB
Net Upgrade Size: 0,00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [#######################################] 100%
(1/1) checking package integrity [#######################################] 100%
(1/1) loading package files [#######################################] 100%
(1/1) checking for file conflicts [#######################################] 100%
(1/1) checking available disk space [#######################################] 100%
(1/1) Remove upgraded DKMS modules
==> dkms remove --no-depmod -m digimend-kernel-drivers -v 10.r0.gec5c16d -k 5.10.7-3-MANJARO
==> Unable to remove module digimend-kernel-drivers/10.r0.gec5c16d for kernel 5.4.89-1-MANJARO: Not found in dkms st
atus output.
(1/1) reinstalling digimend-kernel-drivers-dkms-git [#######################################] 100%
(1/3) Reloading device manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Install DKMS modules
==> dkms install --no-depmod -m digimend-kernel-drivers -v 10.r0.gec5c16d -k 5.10.7-3-MANJARO
==> depmod 5.10.7-3-MANJARO
==> Unable to install module digimend-kernel-drivers/10.r0.gec5c16d for kernel 5.4.89-1-MANJARO: Missing kernel head
ers.
==> Cleaning up...
pobrn
23 January 2021 16:54
4
The dkms alpm hook will try to install the module for all kernel version available, so you should install the headers for all installed kernel versions to avoid build failures.
I am not sure how to install multiple versions, running sudo pacman -S linux-header just reinstalls them
pobrn
23 January 2021 16:56
6
sudo pacman -Syu linux54-headers linux510-headers, etc. If you use a metapackage, like linux-latest, etc., then use linux-latest-headers.
Wollie
23 January 2021 16:57
7
Or
sudo pacman -S $(ls /boot | awk -F "-" '/^linux/ { print $1"-headers" }')
This should cover all needed headers.
system
Closed
7 February 2021 16:58
8
