KDE Plasma. I have a laptop as the main screen and a second monitor and all has run well for many months.
Recently when I start the laptop the wallpaper on the plug in monitor appears half on one screen and half on the other. It I open the web browser which is set to the second monitor that opens correctly. I haven’t altered anything.
Any ideas please?
I have two screen shots of the problem, how do I post them up please?
Hi @heppy, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Hope this is what you want
Kernel: 5.10.161-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d75e5371-b9a2-4008-8d0a-fb9951bb6e65 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
v: 068F130000204710000620100 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 166F v: 09.4C serial: <superuser required>
BIOS: Insyde v: F.66 date: 01/24/2013
ID-1: BAT0 charge: 41.5 Wh (100.0%) condition: 41.5/41.5 Wh (100.0%)
volts: 12.3 min: 10.8 model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/M235
serial: <filter> charge: 5% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 5.75 GiB used: 3.27 GiB (56.8%)
Info: model: Intel Pentium B960 bits: 64 type: MCP arch: Sandy Bridge
level: v2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 841 high: 885 min/max: 800/2200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 885 2: 798 bogomips: 8783
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb est flush_l1d
fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni
popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tsc tsc_deadline_timer vme x2apic xsave
xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
prctl and seccomp
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-6
process: Intel 32nm built: 2011 ports: active: LVDS-1,VGA-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0106 class-ID: 0300
Device-2: Primax webcam type: USB driver: uvcvideo bus-ID: 2-1.5:5
chip-ID: 0461:4de7 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3936x1050 s-dpi: 96 s-size: 1038x277mm (40.87x10.91")
s-diag: 1074mm (42.3")
Monitor-1: LVDS-1 pos: primary,bottom-r model: LG Display 0x02f2
built: 2010 res: 1366x768 hz: 60 dpi: 101 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1366x768
Monitor-2: VGA-1 pos: top-left model: LE22A3 serial: <filter> built: 2007
res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2 size: 473x296mm (18.62x11.65")
diag: 552mm (21.7") ratio: 16:10 modes: max: 1680x1050 min: 720x400
API: OpenGL v: 3.3 Mesa 22.3.1 renderer: Mesa Intel HD Graphics 2000 (SNB
GT1) direct render: Yes
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound API: ALSA v: k5.10.161-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Ralink RT5390 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard
U98Z077.00 Half-size Mini driver: rt2800pci v: 2.3.0 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 1814:5390 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Local Storage: total: 63.15 GiB used: 41.52 GiB (65.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A60G
size: 55.9 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: BBF0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Sony model: Storage Media
size: 7.25 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVD RW AD-7740H rev: 1.80
dev-links: cdrom
ID-1: / raw-size: 55.9 GiB size: 54.72 GiB (97.89%) used: 39.18 GiB (71.6%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: d75e5371-b9a2-4008-8d0a-fb9951bb6e65
ID-2: /home/<filter>/pCloudDrive raw-size: N/A size: 7 GiB
used: 2.34 GiB (33.4%) fs: fuse source: ERR-102
ID-1: /dev/sdb1 maj-min: 8:17 size: 2.28 GiB fs: iso9660
ID-2: /dev/sdb2 maj-min: 8:18 size: 4.1 MiB fs: vfat label: ESP
uuid: 8D6C-A9F8
ID-3: /dev/sdb3 maj-min: 8:19 size: 4.97 GiB fs: ext4 label: writable
uuid: 01b4f95a-b64f-48de-be4a-0bca123707dd
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 2-1.1:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 2-1.1.2:6 info: China Resource Semico USB Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 1a2c:0c23 class-ID: 0300
Device-2: 2-1.1.3:7 info: Canon PIXMA iP3600 Printer type: Printer
driver: usblp interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 04a9:10ca class-ID: 0701 serial: <filter>
Device-3: 2-1.1.4:8 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-4: 2-1.2:4 info: Sony Storage Media type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 054c:05ba class-ID: 0806 serial: <filter>
Device-5: 2-1.5:5 info: Primax webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0461:4de7
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 193 Uptime: 5m wakeups: 3 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1435 libs: 409 tools: pamac pm: appimage pkgs: 0 pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Hopefully screen shots
‘Screenshot, 2023-01-12 20:05:20 - Paste.Pics’
‘Screenshot, 2023-01-12 20:10:13 - Paste.Pics’
I was going to ask: what have you tried to fix it?
Because I initially overlooked this:
not even tried?
just straight up asked?
I have found out if I use the Shutdown button rather than OK or the timer the screens load correctly on startup. Does that help?
Also found out if I turn Compositor off that also cures the problem. Obviously I also lose hot corners.
Humble apologies this was obviously a dumb question from an Oldie
Hi @heppy,
There is no such thing as a dumb question.
Unfortunately, I do not know what the cause can be. Except checking in System Settiings → Hardware → Display and Monitor → Display Configuration:
https://i.imgur.com/heWtctb.png
This is a screenshot from my setup, maybe it helps. Hope it does.
Thanks for the reply. I have tried altering display setting but no difference.
Looks like I shall just have to live with it and remember to use the Shutdown button. Just odd as I have been using Manjaro for a couple of years and the problem has only just occurred.
Thanks anyway.
If it worked before, as you say, try a bit older kernel, maybe? Or a newer one? Or something.
Thanks again, I think I will just leave as is, I’m very good at messing things up.
Myself as well.
The important thing is just to learn something from the experience. Whether that something is how to recover from a disaster, or how to avoid it, or what to actually do is irrelevant.
For example, due to the many posts regarding specifically this here, on the forum, as well ass a recommendation by none other than @philm himself, as well as some personal experience, I’ve learned that using pamac to upgrade, instead of pacman is better. Especially for newcomers. Why would I say this? Because it takes care of a lot mor things that you’ve got to do manually if you use pacman. If you want to use pacman, then go right ahead. But then be aware of my point above, ‘is all I’m sayin’.
Edit:
If you want to switch kernels, I recommend looking at the Wiki for instructions:
I see you’re using 5.10:
So perhaps try 5.4 as it was the LTS just before 5.10, or even 5.15 since it’s the one just after 5.10.
