Screen resolution not proposed
Hello, i’ve a problem with my screen resolution, I would like 2560x1440@75hz but the maximum resolution offered by kde is 1980x1080@60hz. it seems that my screen is well detected in xorg.log
My system:
  Kernel: 5.16.9-3-MANJARO-ARM-KHADAS aarch64 bits: 64 compiler: gcc v: 11.2.0
    parameters: root=PARTUUID=e4b5a702-02 rootdelay=5 rootflags=data=writeback
    rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0
    fsck.fix=yes fsck.repair=yes net.ifnames=0 quiet splash
    plymouth.ignore-serial-consoles
  Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
    Distro: Manjaro ARM base: Arch Linux
  Type: ARM System: Ugoos AM6 Plus details: N/A
  RAM: total: 3.61 GiB used: 2.17 GiB (60.1%)
  RAM Report:
    missing: Required tool dmidecode not installed. Check --recommends
  Info: model: N/A variant-1: cortex-a73 variant-2: cortex-a53 bits: 64
    type: MCP AMP arch: ARMv8 family: 8 model-id: 0 stepping: 4
  Topology: variant: cpus: 1x cores: 2 min/max: 100/1992 variant: cpus: 1x
    cores: 4 min/max: 100/1908 smt: <unsupported> cache: N/A
  Speed (MHz): avg: 1936 high: 1992 min/max: 100/1992:1908 scaling:
    driver: cpufreq-dt governor: performance cores: 1: 1992 2: 1992 3: 1908
    4: 1908 5: 1908 6: 1908 bogomips: N/A
  Features: aes asimd cpuid crc32 evtstrm fp pmull sha1 sha2
  Type: spectre_v1 mitigation: __user pointer sanitization
  Type: spectre_v2 status: Vulnerable
  Device-1: meson-g12a-vpu driver: meson_drm v: kernel bus-ID: N/A
    chip-ID: amlogic:ff900000 class-ID: vpu
  Device-2: meson-g12a-mali driver: panfrost v: kernel bus-ID: N/A
    chip-ID: amlogic:ffe40000 class-ID: gpu
  Device-3: meson-g12a-dw-hdmi driver: meson_dw_hdmi v: kernel bus-ID: N/A
    chip-ID: amlogic:ff600000 class-ID: hdmi-tx
  Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
    loaded: modesetting display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
    s-diag: 581mm (22.9")
  Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 70
    size: 697x392mm (27.4x15.4") diag: 800mm (31.5")
  OpenGL: renderer: Mali-G52 (Panfrost) v: 3.1 Mesa 21.3.7
    direct render: Yes
  Device-1: meson-g12a-dw-hdmi driver: meson_dw_hdmi v: kernel bus-ID: N/A
  Device-2: axg-sound-card driver: axg_sound_card bus-ID: N/A
    chip-ID: amlogic:sound class-ID: sound
  Sound Server-1: ALSA v: k5.16.9-3-MANJARO-ARM-KHADAS running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.47 running: yes
  Device-1: meson-g12a-dwmac driver: meson8b_dwmac v: N/A port: N/A
    bus-ID: N/A chip-ID: amlogic:ff3f0000 class-ID: ethernet
  IF: eth0 state: down mac: <filter>
  Device-2: pwm-clock driver: pwm_clock v: N/A port: N/A bus-ID: N/A
    chip-ID: pwm-clock:wifi32k class-ID: wifi32k
  IF-ID-1: wlan0 state: up mac: <filter>
  Device-1: meson-gx-uart driver: meson_uart bus-ID: N/A
    chip-ID: amlogic:ffd24000 class-ID: serial
  Local Storage: total: 28.91 GiB used: 6.17 GiB (21.4%)
  ID-1: /dev/mmcblk1 maj-min: 179:0 model: SLD32G size: 28.91 GiB
    block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
    rev: 0x8 scheme: MBR
  ID-1: / raw-size: 28.01 GiB size: 27.41 GiB (97.83%) used: 6.09 GiB (22.2%)
    fs: ext4 dev: /dev/mmcblk1p2 maj-min: 179:2 label: ROOT_MNJRO
    uuid: 04b7e11f-9f0d-443a-8a4a-11bbd7a3378f
  ID-2: /boot raw-size: 424 MiB size: 423.8 MiB (99.94%)
    used: 81.7 MiB (19.3%) fs: vfat dev: /dev/mmcblk1p1 maj-min: 179:1
    label: BOOT_MNJRO uuid: AD4E-FB5A
  ID-1: swap-1 type: zram size: 5.42 GiB used: 0 KiB (0.0%) priority: 100
    dev: /dev/zram0
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Hi-speed hub with single TT ports: 4 rev: 2.0
    speed: 480 Mb/s power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-1.1:3 info: Logitech USB-PS/2 Optical Mouse type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 98mA chip-ID: 046d:c03e class-ID: 0301
  Device-2: 1-1.2:4 info: USB Keyboard type: Keyboard,HID
    power: 100mA chip-ID: 1a2c:2d23 class-ID: 0300
  Hub-3: 2-0:1 info: Super-speed hub ports: 1 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 63.9 C mobo: N/A
  Processes: 203 Uptime: 45m Init: systemd v: 250 tool: systemctl Compilers:
  gcc: N/A Packages: pacman: 731 lib: 202 Shell: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.11
[dams@dams-pc ~]$
My xorg.log :
 [    11.079] (--) Log file renamed from "/var/log/Xorg.pid-432.log" to "/var/log/Xorg.0.log"
[    11.095]
X.Org X Server 1.21.1.3
[    11.095] Current Operating System: Linux dams-pc 5.16.9-3-MANJARO-ARM-KHADAS #1 SMP PREEMPT Wed Feb 16 18:14:54 UTC 2022 aarch64
[    11.095] Kernel command line: root=PARTUUID=e4b5a702-02 rootdelay=5 rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 quiet splash plymouth.ignore-serial-consoles
[    11.095]
[    11.095] Current version of pixman: 0.40.0
[    11.095] 	Before reporting problems, check http://wiki.x.org
[    11.095] Markers: (--) probed, (**) from config file, (==) default setting,
[    11.095] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 14 16:06:04 2022
[    11.100] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    11.100] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    11.101] (==) No Layout section.  Using the first Screen section.
[    11.102] (==) No screen section available. Using defaults.
[    11.102] (**) |-->Screen "Default Screen Section" (0)
[    11.102] (**) |   |-->Monitor "<default monitor>"
[    11.102] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[    11.102] (**) |   |-->Device "Default Device"
[    11.102] (==) No monitor specified for screen "Default Screen Section".
[    11.102] (**) Option "AutoAddGPU" "off"
[    11.102] (**) Option "Debug" "dmabuf_capable"
[    11.102] (==) Automatically adding devices
[    11.102] (==) Automatically enabling devices
[    11.102] (**) Not automatically adding GPU devices
[    11.102] (==) Automatically binding GPU devices
[    11.102] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    11.108] (WW) The directory "/usr/share/fonts/misc" does not exist.
[    11.108] 	Entry deleted from font path.
[    11.109] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[    11.109] 	Entry deleted from font path.
[    11.109] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[    11.109] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    11.109] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    11.109] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    11.109] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    11.109] (==) FontPath set to:
[    11.109] (==) ModulePath set to "/usr/lib/xorg/modules"
[    11.109] (II) The server relies on udev to provide the list of input devices.
[    11.109] (II) Module ABI versions:
[    11.109] 	X.Org ANSI C Emulation: 0.4
[    11.109] 	X.Org Video Driver: 25.2
[    11.109] 	X.Org XInput driver : 24.4
[    11.109] 	X.Org Server Extension : 10.0
[    11.111] (++) using VT number 1
[    11.111] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    11.112] (II) xfree86: Adding drm device (/dev/dri/card0)
[    11.112] (II) Platform probe for /sys/devices/platform/soc/ff900000.vpu/drm/card0
[    11.119] (II) xfree86: Adding drm device (/dev/dri/card1)
[    11.119] (II) Platform probe for /sys/devices/platform/soc/ffe40000.gpu/drm/card1
[    11.124] (**) OutputClass "Panfrost" setting /dev/dri/card0 as PrimaryGPU
[    11.124] (II) LoadModule: "glx"
[    11.126] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    11.176] (II) Module glx: vendor="X.Org Foundation"
[    11.176] 	compiled for 1.21.1.3, module version = 1.0.0
[    11.176] 	ABI class: X.Org Server Extension, version 10.0
[    11.177] (II) LoadModule: "modesetting"
[    11.177] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    11.185] (II) Module modesetting: vendor="X.Org Foundation"
[    11.185] 	compiled for 1.21.1.3, module version = 1.21.1
[    11.185] 	Module class: X.Org Video Driver
[    11.185] 	ABI class: X.Org Video Driver, version 25.2
[    11.185] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    11.202] (II) modeset(0): using drv /dev/dri/card0
[    11.202] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    11.202] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    11.202] (II) Applying OutputClass "Panfrost" options to /dev/dri/card0
[    11.202] (**) modeset(0): Option "AccelMethod" "glamor"
[    11.202] (==) modeset(0): RGB weight 888
[    11.202] (==) modeset(0): Default visual is TrueColor
[    11.202] (II) Loading sub module "glamoregl"
[    11.202] (II) LoadModule: "glamoregl"
[    11.203] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    11.228] (II) Module glamoregl: vendor="X.Org Foundation"
[    11.228] 	compiled for 1.21.1.3, module version = 1.0.1
[    11.228] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    12.693] (II) modeset(0): glamor X acceleration enabled on Mali-G52 (Panfrost)
[    12.693] (II) modeset(0): glamor initialized
[    12.693] (==) modeset(0): VariableRefresh: disabled
[    12.693] (==) modeset(0): AsyncFlipSecondaries: disabled
[    12.693] (II) modeset(0): Output Composite-1 has no monitor section
[    12.799] (II) modeset(0): Output HDMI-1 has no monitor section
[    12.799] (II) modeset(0): EDID for output Composite-1
[    12.799] (II) modeset(0): Printing probed modes for output Composite-1
[    12.799] (II) modeset(0): Modeline "720x576i"x25.0   13.50  720 732 795 864  576 580 586 625 interlace (15.6 kHz e)
[    12.799] (II) modeset(0): Modeline "720x480i"x30.0   13.50  720 739 801 858  480 488 494 525 interlace (15.7 kHz e)
[    12.905] (II) modeset(0): EDID for output HDMI-1
[    12.905] (II) modeset(0): Manufacturer: PHL  Model: c181  Serial#: 5427
[    12.905] (II) modeset(0): Year: 2019  Week: 11
[    12.905] (II) modeset(0): EDID Version: 1.3
[    12.905] (II) modeset(0): Digital Display Input
[    12.905] (II) modeset(0): Max Image Size [cm]: horiz.: 70  vert.: 39
[    12.905] (II) modeset(0): Gamma: 2.20
[    12.905] (II) modeset(0): DPMS capabilities: Off
[    12.905] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    12.905] (II) modeset(0): First detailed timing is preferred mode
[    12.905] (II) modeset(0): redX: 0.658 redY: 0.332   greenX: 0.320 greenY: 0.620
[    12.905] (II) modeset(0): blueX: 0.148 blueY: 0.059   whiteX: 0.312 whiteY: 0.329
[    12.906] (II) modeset(0): Supported established timings:
[    12.906] (II) modeset(0): 720x400@70Hz
[    12.906] (II) modeset(0): 640x480@60Hz
[    12.906] (II) modeset(0): 640x480@67Hz
[    12.906] (II) modeset(0): 640x480@72Hz
[    12.906] (II) modeset(0): 640x480@75Hz
[    12.906] (II) modeset(0): 800x600@56Hz
[    12.906] (II) modeset(0): 800x600@60Hz
[    12.906] (II) modeset(0): 800x600@72Hz
[    12.906] (II) modeset(0): 800x600@75Hz
[    12.906] (II) modeset(0): 832x624@75Hz
[    12.906] (II) modeset(0): 1024x768@60Hz
[    12.906] (II) modeset(0): 1024x768@70Hz
[    12.906] (II) modeset(0): 1024x768@75Hz
[    12.906] (II) modeset(0): 1280x1024@75Hz
[    12.906] (II) modeset(0): Manufacturer's mask: 0
[    12.906] (II) modeset(0): Supported standard timings:
[    12.906] (II) modeset(0): #0: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[    12.906] (II) modeset(0): #1: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[    12.906] (II) modeset(0): #2: hsize: 1440  vsize 900  refresh: 60  vid: 149
[    12.906] (II) modeset(0): #3: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    12.906] (II) modeset(0): #4: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[    12.906] (II) modeset(0): #5: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[    12.906] (II) modeset(0): Supported detailed timing:
[    12.906] (II) modeset(0): clock: 241.5 MHz   Image Size:  697 x 392 mm
[    12.906] (II) modeset(0): h_active: 2560  h_sync: 2608  h_sync_end 2640 h_blank_end 2720 h_border: 0
[    12.906] (II) modeset(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1481 v_border: 0
[    12.906] (II) modeset(0): clock: 296.0 MHz   Image Size:  697 x 392 mm
[    12.906] (II) modeset(0): h_active: 2560  h_sync: 2568  h_sync_end 2600 h_blank_end 2666 h_border: 0
[    12.906] (II) modeset(0): Monitor name: PHL 328E9F
[    12.906] (II) modeset(0): Ranges: V min: 48 V max: 76 Hz, H min: 30 H max: 114 kHz, PixClock max 305 MHz
[    12.906] (II) modeset(0): clock: 148.5 MHz   Image Size:  697 x 392 mm
[    12.906] (II) modeset(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[    12.906] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[    12.906] (II) modeset(0): clock: 27.0 MHz   Image Size:  697 x 392 mm
[    12.906] (II) modeset(0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[    12.906] (II) modeset(0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[    12.906] (II) modeset(0): h_active: 720  h_sync: 732  h_sync_end 796 h_blank_end 864 h_border: 0
[    12.906] (II) modeset(0): v_active: 576  v_sync: 581  v_sync_end 586 v_blanking: 625 v_border: 0
[    12.906] (II) modeset(0): clock: 156.0 MHz   Image Size:  697 x 392 mm
[    12.906] (II) modeset(0): h_active: 1280  h_sync: 1376  h_sync_end 1512 h_blank_end 1744 h_border: 0
[    12.906] (II) modeset(0): v_active: 1440  v_sync: 1443  v_sync_end 1453 v_blanking: 1493 v_border: 0
[    12.906] (II) modeset(0): Number of EDID sections to follow: 1
[    12.906] (II) modeset(0): EDID (in hex):
[    12.906] (II) modeset(0): 	00ffffffffffff00410c81c133150000
[    12.906] (II) modeset(0): 	0b1d0103804627782a8301a855529e26
[    12.906] (II) modeset(0): 	0f5054bfef00d1c0b300950081808140
[    12.906] (II) modeset(0): 	81c001010101565e00a0a0a029503020
[    12.906] (II) modeset(0): 	3500b9882100001ea073006aa0a02950
[    12.906] (II) modeset(0): 	08203500b9882100001a000000fc0050
[    12.906] (II) modeset(0): 	484c203332384539460a2020000000fd
[    12.906] (II) modeset(0): 	00304c1e721e000a20202020202001de
[    12.906] (II) modeset(0): 	020327f14b101f051404130312021101
[    12.906] (II) modeset(0): 	230907078301000065030c001000681a
[    12.906] (II) modeset(0): 	00000101304c00023a801871382d4058
[    12.906] (II) modeset(0): 	2c4500b9882100001e8c0ad08a20e02d
[    12.906] (II) modeset(0): 	10103e9600b988210000188c0ad09020
[    12.906] (II) modeset(0): 	4031200c405500b98821000018f03c00
[    12.906] (II) modeset(0): 	d051a0355060883a00b9882100001c00
[    12.906] (II) modeset(0): 	0000000000000000000000000000003c
[    12.906] (II) modeset(0): Printing probed modes for output HDMI-1
[    12.906] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    12.906] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    12.906] (II) modeset(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[    12.906] (II) modeset(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[    12.906] (II) modeset(0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    12.906] (II) modeset(0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[    12.906] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    12.906] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    12.906] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    12.906] (II) modeset(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[    12.906] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[    12.906] (II) modeset(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    12.906] (II) modeset(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    12.906] (II) modeset(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    12.906] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    12.906] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    12.906] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    12.906] (II) modeset(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    12.906] (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    12.906] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    12.906] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    12.907] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    12.907] (II) modeset(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    12.907] (II) modeset(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    12.907] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    12.907] (II) modeset(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    12.907] (II) modeset(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    12.907] (II) modeset(0): Output Composite-1 connected
[    12.907] (II) modeset(0): Output HDMI-1 connected
[    12.907] (II) modeset(0): Using sloppy heuristic for initial modes
[    12.907] (II) modeset(0): Output Composite-1 using initial mode 720x576i +0+0
[    12.907] (II) modeset(0): Output HDMI-1 using initial mode 720x576 +0+0
[    12.907] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    12.907] (==) modeset(0): DPI set to (96, 96)
[    12.907] (II) Loading sub module "fb"
[    12.907] (II) LoadModule: "fb"
[    12.907] (II) Module "fb" already built-in
[    13.007] (==) modeset(0): Backing store enabled
[    13.007] (==) modeset(0): Silken mouse enabled
[    13.018] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    13.018] (==) modeset(0): DPMS enabled
[    13.018] (WW) modeset(0): Option "PrimaryGPU" is not used
[    13.019] (II) modeset(0): [DRI2] Setup complete
[    13.019] (II) modeset(0): [DRI2]   DRI driver: meson
[    13.019] (II) modeset(0): [DRI2]   VDPAU driver: meson
[    13.019] (II) Initializing extension Generic Event Extension
[    13.019] (II) Initializing extension SHAPE
[    13.019] (II) Initializing extension MIT-SHM
[    13.019] (II) Initializing extension XInputExtension
[    13.021] (II) Initializing extension XTEST
[    13.022] (II) Initializing extension BIG-REQUESTS
[    13.022] (II) Initializing extension SYNC
[    13.022] (II) Initializing extension XKEYBOARD
[    13.022] (II) Initializing extension XC-MISC
[    13.023] (II) Initializing extension SECURITY
[    13.023] (II) Initializing extension XFIXES
[    13.023] (II) Initializing extension RENDER
[    13.023] (II) Initializing extension RANDR
[    13.024] (II) Initializing extension COMPOSITE
[    13.024] (II) Initializing extension DAMAGE
[    13.024] (II) Initializing extension MIT-SCREEN-SAVER
[    13.024] (II) Initializing extension DOUBLE-BUFFER
[    13.025] (II) Initializing extension RECORD
[    13.025] (II) Initializing extension DPMS
[    13.025] (II) Initializing extension Present
[    13.025] (II) Initializing extension DRI3
[    13.025] (II) Initializing extension X-Resource
[    13.026] (II) Initializing extension XVideo
[    13.026] (II) Initializing extension XVideo-MotionCompensation
[    13.026] (II) Initializing extension GLX
[    13.043] (II) AIGLX: Loaded and initialized meson
[    13.043] (II) GLX: Initialized DRI2 GL provider for screen 0
[    13.043] (II) Initializing extension XFree86-VidModeExtension
[    13.043] (II) Initializing extension XFree86-DGA
[    13.044] (II) Initializing extension XFree86-DRI
[    13.044] (II) Initializing extension DRI2
[    13.045] (II) modeset(0): Damage tracking initialized
[    13.045] (II) modeset(0): Setting screen physical size to 190 x 152
[    13.139] (II) config/udev: Adding input device meson-ir (/dev/input/event4)
[    13.140] (**) meson-ir: Applying InputClass "libinput keyboard catchall"
[    13.140] (**) meson-ir: Applying InputClass "system-keyboard"
[    13.140] (II) LoadModule: "libinput"
[    13.140] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    13.153] (II) Module libinput: vendor="X.Org Foundation"
[    13.153] 	compiled for 1.21.1.3, module version = 1.2.1
[    13.153] 	Module class: X.Org XInput Driver
[    13.153] 	ABI class: X.Org XInput driver, version 24.4
[    13.153] (II) Using input driver 'libinput' for 'meson-ir'
[    13.153] (**) meson-ir: always reports core events
[    13.153] (**) Option "Device" "/dev/input/event4"
[    13.170] (II) event4  - meson-ir: is tagged by udev as: Keyboard Pointingstick
[    13.171] (II) event4  - meson-ir: device is a pointer
[    13.171] (II) event4  - meson-ir: device is a keyboard
[    13.171] (II) event4  - meson-ir: device removed
[    13.310] (II) libinput: meson-ir: needs a virtual subdevice
[    13.310] (**) Option "config_info" "udev:/sys/devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4/event4"
[    13.310] (II) XINPUT: Adding extended input device "meson-ir" (type: MOUSE, id 6)
[    13.310] (**) Option "AccelerationScheme" "none"
[    13.310] (**) meson-ir: (accel) selected scheme none/0
[    13.310] (**) meson-ir: (accel) acceleration factor: 2.000
[    13.310] (**) meson-ir: (accel) acceleration threshold: 4
[    13.311] (II) event4  - meson-ir: is tagged by udev as: Keyboard Pointingstick
[    13.312] (II) event4  - meson-ir: device is a pointer
[    13.312] (II) event4  - meson-ir: device is a keyboard
[    13.314] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/event0)
[    13.314] (**) Logitech USB-PS/2 Optical Mouse: Applying InputClass "libinput pointer catchall"
[    13.314] (II) Using input driver 'libinput' for 'Logitech USB-PS/2 Optical Mouse'
[    13.314] (**) Logitech USB-PS/2 Optical Mouse: always reports core events
[    13.314] (**) Option "Device" "/dev/input/event0"
[    13.382] (II) event0  - Logitech USB-PS/2 Optical Mouse: is tagged by udev as: Mouse
[    13.382] (II) event0  - Logitech USB-PS/2 Optical Mouse: device set to 400 DPI
[    13.382] (II) event0  - Logitech USB-PS/2 Optical Mouse: device is a pointer
[    13.382] (II) event0  - Logitech USB-PS/2 Optical Mouse: device removed
[    13.460] (**) Option "config_info" "udev:/sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C03E.0001/input/input0/event0"
[    13.460] (II) XINPUT: Adding extended input device "Logitech USB-PS/2 Optical Mouse" (type: MOUSE, id 7)
[    13.460] (**) Option "AccelerationScheme" "none"
[    13.460] (**) Logitech USB-PS/2 Optical Mouse: (accel) selected scheme none/0
[    13.460] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration factor: 2.000
[    13.460] (**) Logitech USB-PS/2 Optical Mouse: (accel) acceleration threshold: 4
[    13.532] (II) event0  - Logitech USB-PS/2 Optical Mouse: is tagged by udev as: Mouse
[    13.532] (II) event0  - Logitech USB-PS/2 Optical Mouse: device set to 400 DPI
[    13.532] (II) event0  - Logitech USB-PS/2 Optical Mouse: device is a pointer
[    13.533] (II) config/udev: Adding input device Logitech USB-PS/2 Optical Mouse (/dev/input/mouse0)
[    13.534] (II) No input driver specified, ignoring this device.
[    13.534] (II) This device may have been added with another device file.
[    13.535] (II) config/udev: Adding input device USB USB Keyboard (/dev/input/event1)
[    13.535] (**) USB USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    13.535] (**) USB USB Keyboard: Applying InputClass "system-keyboard"
[    13.535] (II) Using input driver 'libinput' for 'USB USB Keyboard'
[    13.535] (**) USB USB Keyboard: always reports core events
[    13.535] (**) Option "Device" "/dev/input/event1"
[    13.537] (II) event1  - USB USB Keyboard: is tagged by udev as: Keyboard
[    13.537] (II) event1  - USB USB Keyboard: device is a keyboard
[    13.538] (II) event1  - USB USB Keyboard: device removed
[    13.590] (**) Option "config_info" "udev:/sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:1A2C:2D23.0002/input/input1/event1"
[    13.590] (II) XINPUT: Adding extended input device "USB USB Keyboard" (type: KEYBOARD, id 8)
[    13.590] (**) Option "xkb_layout" "fr"
[    13.630] (II) event1  - USB USB Keyboard: is tagged by udev as: Keyboard
[    13.631] (II) event1  - USB USB Keyboard: device is a keyboard
[    13.633] (II) config/udev: Adding input device USB USB Keyboard Consumer Control (/dev/input/event2)
[    13.633] (**) USB USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    13.633] (**) USB USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[    13.633] (II) Using input driver 'libinput' for 'USB USB Keyboard Consumer Control'
[    13.633] (**) USB USB Keyboard Consumer Control: always reports core events
[    13.633] (**) Option "Device" "/dev/input/event2"
[    13.635] (II) event2  - USB USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    13.635] (II) event2  - USB USB Keyboard Consumer Control: device is a keyboard
[    13.636] (II) event2  - USB USB Keyboard Consumer Control: device removed
[    13.710] (II) libinput: USB USB Keyboard Consumer Control: needs a virtual subdevice
[    13.710] (**) Option "config_info" "udev:/sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:1A2C:2D23.0003/input/input2/event2"
[    13.710] (II) XINPUT: Adding extended input device "USB USB Keyboard Consumer Control" (type: MOUSE, id 9)
[    13.710] (**) Option "AccelerationScheme" "none"
[    13.710] (**) USB USB Keyboard Consumer Control: (accel) selected scheme none/0
[    13.710] (**) USB USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[    13.710] (**) USB USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[    13.713] (II) event2  - USB USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    13.713] (II) event2  - USB USB Keyboard Consumer Control: device is a keyboard
[    13.715] (II) config/udev: Adding input device USB USB Keyboard System Control (/dev/input/event3)
[    13.715] (**) USB USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[    13.715] (**) USB USB Keyboard System Control: Applying InputClass "system-keyboard"
[    13.715] (II) Using input driver 'libinput' for 'USB USB Keyboard System Control'
[    13.715] (**) USB USB Keyboard System Control: always reports core events
[    13.715] (**) Option "Device" "/dev/input/event3"
[    13.717] (II) event3  - USB USB Keyboard System Control: is tagged by udev as: Keyboard
[    13.717] (II) event3  - USB USB Keyboard System Control: device is a keyboard
[    13.718] (II) event3  - USB USB Keyboard System Control: device removed
[    13.790] (**) Option "config_info" "udev:/sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:1A2C:2D23.0003/input/input3/event3"
[    13.790] (II) XINPUT: Adding extended input device "USB USB Keyboard System Control" (type: KEYBOARD, id 10)
[    13.790] (**) Option "xkb_layout" "fr"
[    13.793] (II) event3  - USB USB Keyboard System Control: is tagged by udev as: Keyboard
[    13.793] (II) event3  - USB USB Keyboard System Control: device is a keyboard
[    13.802] (**) meson-ir: Applying InputClass "libinput keyboard catchall"
[    13.802] (**) meson-ir: Applying InputClass "system-keyboard"
[    13.802] (II) Using input driver 'libinput' for 'meson-ir'
[    13.802] (**) meson-ir: always reports core events
[    13.802] (**) Option "Device" "/dev/input/event4"
[    13.802] (II) libinput: meson-ir: is a virtual subdevice
[    13.802] (**) Option "config_info" "udev:/sys/devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4/event4"
[    13.802] (II) XINPUT: Adding extended input device "meson-ir" (type: KEYBOARD, id 11)
[    13.802] (**) Option "xkb_layout" "fr"
[    13.803] (**) USB USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    13.803] (**) USB USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[    13.803] (II) Using input driver 'libinput' for 'USB USB Keyboard Consumer Control'
[    13.803] (**) USB USB Keyboard Consumer Control: always reports core events
[    13.803] (**) Option "Device" "/dev/input/event2"
[    13.803] (II) libinput: USB USB Keyboard Consumer Control: is a virtual subdevice
[    13.803] (**) Option "config_info" "udev:/sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:1A2C:2D23.0003/input/input2/event2"
[    13.803] (II) XINPUT: Adding extended input device "USB USB Keyboard Consumer Control" (type: KEYBOARD, id 12)
[    13.803] (**) Option "xkb_layout" "fr"
[    14.047] (II) modeset(0): Disabling kernel dirty updates, not required.
[    17.966] (II) modeset(0): EDID vendor "PHL", prod id 49537
[    17.966] (II) modeset(0): Using EDID range info for horizontal sync
[    17.966] (II) modeset(0): Using EDID range info for vertical refresh
[    17.966] (II) modeset(0): Printing DDC gathered Modelines:
[    17.966] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync +vsync (88.8 kHz eP)
[    17.966] (II) modeset(0): Modeline "2560x1440"x0.0  296.00  2560 2568 2600 2666  1440 1443 1448 1481 +hsync -vsync (111.0 kHz e)
[    17.966] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    17.966] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    17.966] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    17.966] (II) modeset(0): Modeline "1280x1440"x0.0  156.00  1280 1376 1512 1744  1440 1443 1453 1493 -hsync +vsync (89.4 kHz e)
[    17.967] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    17.967] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[    17.967] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    17.967] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    17.967] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    17.967] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    17.967] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    17.967] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    17.967] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    17.967] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    17.967] (II) modeset(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    17.967] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    17.967] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    17.967] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    17.967] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    17.967] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    17.967] (II) modeset(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    17.967] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    17.967] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    17.967] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    17.967] (II) modeset(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[    17.967] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    17.967] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[    18.214] (II) modeset(0): EDID vendor "PHL", prod id 49537
[    18.214] (II) modeset(0): Using hsync ranges from config file
[    18.214] (II) modeset(0): Using vrefresh ranges from config file
[    18.214] (II) modeset(0): Printing DDC gathered Modelines:
[    18.214] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync +vsync (88.8 kHz eP)
[    18.215] (II) modeset(0): Modeline "2560x1440"x0.0  296.00  2560 2568 2600 2666  1440 1443 1448 1481 +hsync -vsync (111.0 kHz e)
[    18.215] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    18.215] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    18.215] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    18.215] (II) modeset(0): Modeline "1280x1440"x0.0  156.00  1280 1376 1512 1744  1440 1443 1453 1493 -hsync +vsync (89.4 kHz e)
[    18.215] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    18.215] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[    18.215] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    18.215] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    18.215] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    18.215] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    18.215] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    18.215] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    18.215] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    18.215] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    18.215] (II) modeset(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    18.215] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    18.215] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    18.215] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    18.215] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    18.215] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    18.215] (II) modeset(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    18.215] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    18.215] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    18.215] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    18.215] (II) modeset(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[    18.215] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    18.215] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[    20.804] (II) modeset(0): EDID vendor "PHL", prod id 49537
[    20.804] (II) modeset(0): Using hsync ranges from config file
[    20.804] (II) modeset(0): Using vrefresh ranges from config file
[    20.804] (II) modeset(0): Printing DDC gathered Modelines:
[    20.804] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync +vsync (88.8 kHz eP)
[    20.804] (II) modeset(0): Modeline "2560x1440"x0.0  296.00  2560 2568 2600 2666  1440 1443 1448 1481 +hsync -vsync (111.0 kHz e)
[    20.804] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    20.804] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    20.804] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    20.804] (II) modeset(0): Modeline "1280x1440"x0.0  156.00  1280 1376 1512 1744  1440 1443 1453 1493 -hsync +vsync (89.4 kHz e)
[    20.804] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    20.804] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[    20.804] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    20.804] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    20.804] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    20.804] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    20.804] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    20.804] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    20.804] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    20.804] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    20.804] (II) modeset(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    20.804] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    20.804] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    20.804] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    20.804] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    20.804] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    20.804] (II) modeset(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    20.804] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    20.804] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    20.804] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    20.804] (II) modeset(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[    20.804] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    20.804] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[    20.869] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    20.928] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.015] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.017] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[    21.318] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.381] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.397] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.416] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.431] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.448] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.465] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.481] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.499] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.514] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.531] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.557] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.563] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.582] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.598] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.615] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.633] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.649] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.668] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.682] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.698] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.715] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.745] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.769] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.784] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.798] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.814] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.832] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.848] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.865] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.882] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.898] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.914] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.931] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.948] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.965] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.982] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    21.998] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.015] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.031] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.048] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.064] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.081] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.097] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.114] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.131] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.147] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.164] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.181] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.198] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.215] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.231] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.248] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.264] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.281] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.298] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.315] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.331] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.348] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.364] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.381] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.397] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.414] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.431] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.448] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.464] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.481] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.498] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.515] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.531] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.548] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.565] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.581] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.598] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.637] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.648] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.664] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.682] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.698] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.715] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.731] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.748] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.765] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.781] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.799] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.815] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.832] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.851] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.864] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.896] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.916] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.933] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.952] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.967] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    22.984] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.000] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.013] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.033] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.049] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.066] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.083] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.100] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.116] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.133] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.149] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.167] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.184] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.201] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.216] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.233] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.250] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.267] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.283] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.300] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.318] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.335] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.350] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.367] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.383] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.401] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.415] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.433] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.471] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.484] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.502] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.516] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.535] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.550] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.567] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.584] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.603] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.623] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.632] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.650] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.668] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.684] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.699] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.715] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.733] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.748] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.765] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.783] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.798] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.826] (WW) modeset(0): flip queue retry
[    23.827] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.834] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.857] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.905] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.936] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.955] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    23.977] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.005] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.037] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.080] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.107] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.118] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.133] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.150] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.166] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.184] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.202] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.217] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.235] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.249] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.263] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.282] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.298] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.317] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.333] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.349] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.366] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.383] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.402] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.416] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.433] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.450] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.466] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.483] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.499] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.516] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.532] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.551] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.569] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.588] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.600] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.618] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.634] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.650] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.667] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.684] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.700] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.716] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.733] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.749] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.766] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.783] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.799] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.816] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.833] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.849] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.866] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.882] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.899] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.916] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.934] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.949] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.965] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.981] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    24.998] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.014] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.033] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.051] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.067] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.084] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.100] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.117] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.132] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.149] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.165] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.182] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.199] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.216] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.233] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.249] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.267] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.284] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.299] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.315] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.332] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.350] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.367] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.382] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.399] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.414] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.432] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.448] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.465] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.481] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.500] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.516] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.534] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.549] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.566] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.582] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.600] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.618] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
[    25.633] (WW) modeset(0): Present-flip: queue flip during flip on CRTC 0 failed: Invalid argument
and my xrandr output:
[dams@dams-pc ~]$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 3840 x 2160
Composite-1 connected (normal left inverted right x axis y axis)
   720x576i      50.00
   720x480i      59.94
HDMI-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 697mm x 392mm
   1920x1080     60.00*   50.00    59.94
   1920x1080i    60.00    50.00    59.94
   1680x1050     59.88
   1280x1024     75.02    60.02
   1440x900      59.90
   1280x960      60.00
   1280x720      60.00    50.00    59.94
   1024x768      75.03    70.07    60.00
   832x624       74.55
   800x600       72.19    75.00    60.32    56.25
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    66.67
[dams@dams-pc ~]$
if anyone can help me ?
Thank
Hi @Dams2000, and welcome!
In order for us or anyone for that matter, to be able to provide assitance, more information is necessary. To that end, please see:
xrandr
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Hope you manage!
