I don’t think it’s a hardware problem, since a live cd works fine…? Heat wouldn’t make much sense either since it happens right on startup. Although something of note is that the laptop heats up quite a lot when the red curtain shows up, so I might be wrong.
I’m sorry if I’m a little incompetent, I’m not very familiar with this part of Linux.
I’ll try out adding that to the kernel paramters (in grub I’m assuming) to see what happens.
I went ahead and got both of these out of the way since I was already in a chroot.
journalctl --dmesg --boot -1
This spat out a long log list that start all had dates from Mar 10th. After scrolling for a few minutes, the date never changed. I’m probably doing something wrong.
cat /var/log/Xorg.*.log
[ 4.300] (--) Log file renamed from "/var/log/Xorg.pid-590.log" to "/var/log/Xorg.0.log"
[ 4.301]
X.Org X Server 1.21.1.3
[ 4.301] Current Operating System: Linux apple 5.15.25-1-MANJARO #1 SMP PREEMPT Wed Feb 23 14:44:03 UTC 2022 x86_64
[ 4.301] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=91f959a6-50ba-47d8-8e86-2fca1f3bef1c rw quiet apparmor=1 security=apparmor resume=UUID=24ef93f0-0e49-454d-a60e-73a5d8718d67 udev.log_priority=3
[ 4.301]
[ 4.302] Current version of pixman: 0.40.0
[ 4.302] Before reporting problems, check http://wiki.x.org
[ 4.302] Markers: (--) probed, (**) from config file, (==) default setting,
[ 4.302] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Mar 11 07:24:08 2022
[ 4.302] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 4.302] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 4.303] (==) No Layout section. Using the first Screen section.
[ 4.303] (==) No screen section available. Using defaults.
[ 4.303] (**) |-->Screen "Default Screen Section" (0)
[ 4.303] (**) | |-->Monitor "<default monitor>"
[ 4.304] (==) No monitor specified for screen "Default Screen Section".
[ 4.304] (==) Automatically adding devices
[ 4.304] (==) Automatically enabling devices
[ 4.304] (==) Automatically adding GPU devices
[ 4.304] (==) Automatically binding GPU devices
[ 4.304] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 4.304] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 4.304] Entry deleted from font path.
[ 4.304] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 4.304] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 4.304] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 4.304] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 4.304] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 4.304] (II) The server relies on udev to provide the list of input devices.
[ 4.304] (II) Module ABI versions:
[ 4.304] X.Org ANSI C Emulation: 0.4
[ 4.304] X.Org Video Driver: 25.2
[ 4.304] X.Org XInput driver : 24.4
[ 4.304] X.Org Server Extension : 10.0
[ 4.305] (++) using VT number 1
[ 4.305] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 4.306] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 4.306] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 4.326] (--) PCI:*(0@0:2:0) 8086:0d26:106b:0147 rev 8, Mem @ 0xa0000000/4194304, 0x90000000/268435456, I/O @ 0x00003000/64, BIOS @ 0x????????/131072
[ 4.326] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 4.326] (II) LoadModule: "glx"
[ 4.327] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 4.331] (II) Module glx: vendor="X.Org Foundation"
[ 4.331] compiled for 1.21.1.3, module version = 1.0.0
[ 4.331] ABI class: X.Org Server Extension, version 10.0
[ 4.331] (==) Matched modesetting as autoconfigured driver 0
[ 4.331] (==) Matched fbdev as autoconfigured driver 1
[ 4.331] (==) Matched vesa as autoconfigured driver 2
[ 4.331] (==) Assigned the driver to the xf86ConfigLayout
[ 4.331] (II) LoadModule: "modesetting"
[ 4.332] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 4.333] (II) Module modesetting: vendor="X.Org Foundation"
[ 4.333] compiled for 1.21.1.3, module version = 1.21.1
[ 4.333] Module class: X.Org Video Driver
[ 4.333] ABI class: X.Org Video Driver, version 25.2
[ 4.333] (II) LoadModule: "fbdev"
[ 4.333] (WW) Warning, couldn't open module fbdev
[ 4.333] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 4.333] (II) LoadModule: "vesa"
[ 4.333] (WW) Warning, couldn't open module vesa
[ 4.333] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 4.333] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 4.339] (II) modeset(0): using drv /dev/dri/card0
[ 4.339] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 4.339] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 4.339] (==) modeset(0): RGB weight 888
[ 4.339] (==) modeset(0): Default visual is TrueColor
[ 4.339] (II) Loading sub module "glamoregl"
[ 4.339] (II) LoadModule: "glamoregl"
[ 4.339] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 4.344] (II) Module glamoregl: vendor="X.Org Foundation"
[ 4.344] compiled for 1.21.1.3, module version = 1.0.1
[ 4.344] ABI class: X.Org ANSI C Emulation, version 0.4
[ 4.369] (II) modeset(0): glamor X acceleration enabled on Mesa DRI Intel(R) Iris(R) Pro Graphics P5200 (HSW GT3)
[ 4.369] (II) modeset(0): glamor initialized
[ 4.369] (==) modeset(0): VariableRefresh: disabled
[ 4.369] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 4.370] (II) modeset(0): Output eDP-1 has no monitor section
[ 4.370] (II) modeset(0): Output DP-1 has no monitor section
[ 4.372] (II) modeset(0): Output HDMI-1 has no monitor section
[ 4.372] (II) modeset(0): Output DP-2 has no monitor section
[ 4.374] (II) modeset(0): Output HDMI-2 has no monitor section
[ 4.376] (II) modeset(0): Output HDMI-3 has no monitor section
[ 4.377] (II) modeset(0): EDID for output eDP-1
[ 4.377] (II) modeset(0): Manufacturer: APP Model: a02e Serial#: 0
[ 4.377] (II) modeset(0): Year: 2015 Week: 4
[ 4.377] (II) modeset(0): EDID Version: 1.4
[ 4.377] (II) modeset(0): Digital Display Input
[ 4.377] (II) modeset(0): 8 bits per channel
[ 4.377] (II) modeset(0): Digital interface is DisplayPort
[ 4.377] (II) modeset(0): Max Image Size [cm]: horiz.: 33 vert.: 21
[ 4.377] (II) modeset(0): Gamma: 2.20
[ 4.377] (II) modeset(0): No DPMS capabilities specified
[ 4.377] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 4.377] (II) modeset(0): First detailed timing is preferred mode
[ 4.377] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 4.377] (II) modeset(0): redX: 0.653 redY: 0.334 greenX: 0.300 greenY: 0.620
[ 4.377] (II) modeset(0): blueX: 0.146 blueY: 0.050 whiteX: 0.312 whiteY: 0.329
[ 4.377] (II) modeset(0): Manufacturer's mask: 0
[ 4.377] (II) modeset(0): Supported detailed timing:
[ 4.377] (II) modeset(0): clock: 337.8 MHz Image Size: 331 x 207 mm
[ 4.377] (II) modeset(0): h_active: 2880 h_sync: 2928 h_sync_end 2960 h_blank_end 3040 h_border: 0
[ 4.377] (II) modeset(0): v_active: 1800 v_sync: 1803 v_sync_end 1809 v_blanking: 1852 v_border: 0
[ 4.377] (II) modeset(0): Monitor name: Color LCD
[ 4.377] (II) modeset(0): EDID (in hex):
[ 4.377] (II) modeset(0): 00ffffffffffff0006102ea000000000
[ 4.377] (II) modeset(0): 04190104a5211578026fb1a7554c9e25
[ 4.377] (II) modeset(0): 0c505400000001010101010101010101
[ 4.377] (II) modeset(0): 010101010101ef8340a0b00834703020
[ 4.377] (II) modeset(0): 36004bcf1000001a000000fc00436f6c
[ 4.377] (II) modeset(0): 6f72204c43440a202020000000100000
[ 4.377] (II) modeset(0): 00000000000000000000000000000010
[ 4.377] (II) modeset(0): 000000000000000000000000000000d0
[ 4.377] (II) modeset(0): Printing probed modes for output eDP-1
[ 4.377] (II) modeset(0): Modeline "2880x1800"x60.0 337.75 2880 2928 2960 3040 1800 1803 1809 1852 +hsync -vsync (111.1 kHz eP)
[ 4.377] (II) modeset(0): Modeline "2880x1620"x60.0 396.25 2880 3096 3408 3936 1620 1623 1628 1679 -hsync +vsync (100.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "2880x1620"x60.0 303.75 2880 2928 2960 3040 1620 1623 1628 1666 +hsync -vsync (99.9 kHz d)
[ 4.377] (II) modeset(0): Modeline "2560x1600"x60.0 348.50 2560 2760 3032 3504 1600 1603 1609 1658 -hsync +vsync (99.5 kHz d)
[ 4.377] (II) modeset(0): Modeline "2560x1600"x60.0 268.50 2560 2608 2640 2720 1600 1603 1609 1646 +hsync -vsync (98.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "2560x1440"x120.0 638.25 2560 2780 3064 3568 1440 1441 1444 1491 doublescan -hsync +vsync (178.9 kHz d)
[ 4.377] (II) modeset(0): Modeline "2560x1440"x120.0 469.12 2560 2584 2600 2640 1440 1441 1444 1481 doublescan +hsync -vsync (177.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "2560x1440"x60.0 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync (89.5 kHz d)
[ 4.377] (II) modeset(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz d)
[ 4.377] (II) modeset(0): Modeline "2048x1536"x60.0 266.95 2048 2200 2424 2800 1536 1537 1540 1589 -hsync +vsync (95.3 kHz d)
[ 4.377] (II) modeset(0): Modeline "1920x1440"x60.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "1856x1392"x60.0 218.30 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.4 kHz d)
[ 4.377] (II) modeset(0): Modeline "1792x1344"x60.0 204.80 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "2048x1152"x120.0 406.50 2048 2220 2444 2840 1152 1153 1156 1193 doublescan -hsync +vsync (143.1 kHz d)
[ 4.377] (II) modeset(0): Modeline "2048x1152"x120.0 302.50 2048 2072 2088 2128 1152 1153 1156 1185 doublescan +hsync -vsync (142.2 kHz d)
[ 4.377] (II) modeset(0): Modeline "2048x1152"x59.9 197.00 2048 2184 2400 2752 1152 1155 1160 1195 -hsync +vsync (71.6 kHz d)
[ 4.377] (II) modeset(0): Modeline "2048x1152"x59.9 156.75 2048 2096 2128 2208 1152 1155 1160 1185 +hsync -vsync (71.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz d)
[ 4.377] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 4.377] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 4.377] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 4.377] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 4.377] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 4.377] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 4.377] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 4.377] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 4.377] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 4.377] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 4.377] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 4.377] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 4.377] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 4.377] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 4.377] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 4.377] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 4.377] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 4.377] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 4.377] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 4.377] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 4.377] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 4.377] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 4.377] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 4.377] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 4.377] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 4.377] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 4.377] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 4.377] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 4.377] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 4.377] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 4.377] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 4.377] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 4.377] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 4.377] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 4.377] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 4.377] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 4.377] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 4.377] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 4.377] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 4.377] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 4.377] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 4.377] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 4.377] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 4.377] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 4.378] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 4.378] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 4.378] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 4.378] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 4.378] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 4.378] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 4.378] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 4.378] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 4.378] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 4.378] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 4.378] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 4.378] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 4.378] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 4.378] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 4.378] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 4.378] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 4.378] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 4.378] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 4.378] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 4.378] (II) modeset(0): EDID for output DP-1
[ 4.379] (II) modeset(0): EDID for output HDMI-1
[ 4.379] (II) modeset(0): EDID for output DP-2
[ 4.381] (II) modeset(0): EDID for output HDMI-2
[ 4.383] (II) modeset(0): EDID for output HDMI-3
[ 4.383] (II) modeset(0): Output eDP-1 connected
[ 4.383] (II) modeset(0): Output DP-1 disconnected
[ 4.383] (II) modeset(0): Output HDMI-1 disconnected
[ 4.383] (II) modeset(0): Output DP-2 disconnected
[ 4.383] (II) modeset(0): Output HDMI-2 disconnected
[ 4.383] (II) modeset(0): Output HDMI-3 disconnected
[ 4.383] (II) modeset(0): Using exact sizes for initial modes
[ 4.383] (II) modeset(0): Output eDP-1 using initial mode 2880x1800 +0+0
[ 4.383] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 4.383] (==) modeset(0): DPI set to (96, 96)
[ 4.383] (II) Loading sub module "fb"
[ 4.383] (II) LoadModule: "fb"
[ 4.383] (II) Module "fb" already built-in
[ 4.396] (==) modeset(0): Backing store enabled
[ 4.396] (==) modeset(0): Silken mouse enabled
[ 4.473] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 4.473] (==) modeset(0): DPMS enabled
[ 4.473] (II) modeset(0): [DRI2] Setup complete
[ 4.473] (II) modeset(0): [DRI2] DRI driver: i965
[ 4.473] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 4.473] (II) Initializing extension Generic Event Extension
[ 4.473] (II) Initializing extension SHAPE
[ 4.474] (II) Initializing extension MIT-SHM
[ 4.474] (II) Initializing extension XInputExtension
[ 4.474] (II) Initializing extension XTEST
[ 4.474] (II) Initializing extension BIG-REQUESTS
[ 4.474] (II) Initializing extension SYNC
[ 4.474] (II) Initializing extension XKEYBOARD
[ 4.474] (II) Initializing extension XC-MISC
[ 4.474] (II) Initializing extension SECURITY
[ 4.475] (II) Initializing extension XFIXES
[ 4.475] (II) Initializing extension RENDER
[ 4.475] (II) Initializing extension RANDR
[ 4.475] (II) Initializing extension COMPOSITE
[ 4.475] (II) Initializing extension DAMAGE
[ 4.475] (II) Initializing extension MIT-SCREEN-SAVER
[ 4.475] (II) Initializing extension DOUBLE-BUFFER
[ 4.475] (II) Initializing extension RECORD
[ 4.475] (II) Initializing extension DPMS
[ 4.476] (II) Initializing extension Present
[ 4.476] (II) Initializing extension DRI3
[ 4.476] (II) Initializing extension X-Resource
[ 4.476] (II) Initializing extension XVideo
[ 4.476] (II) Initializing extension XVideo-MotionCompensation
[ 4.476] (II) Initializing extension GLX
[ 4.478] (II) AIGLX: Loaded and initialized i965
[ 4.478] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 4.478] (II) Initializing extension XFree86-VidModeExtension
[ 4.478] (II) Initializing extension XFree86-DGA
[ 4.479] (II) Initializing extension XFree86-DRI
[ 4.479] (II) Initializing extension DRI2
[ 4.479] (II) modeset(0): Damage tracking initialized
[ 4.479] (II) modeset(0): Setting screen physical size to 762 x 476
[ 4.519] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 4.519] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 4.519] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 4.519] (**) Power Button: Applying InputClass "system-keyboard"
[ 4.519] (II) LoadModule: "libinput"
[ 4.519] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 4.522] (II) Module libinput: vendor="X.Org Foundation"
[ 4.522] compiled for 1.21.1.3, module version = 1.2.1
[ 4.522] Module class: X.Org XInput Driver
[ 4.522] ABI class: X.Org XInput driver, version 24.4
[ 4.522] (II) Using input driver 'libinput' for 'Power Button'
[ 4.522] (**) Power Button: always reports core events
[ 4.522] (**) Option "Device" "/dev/input/event3"
[ 4.525] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 4.525] (II) event3 - Power Button: device is a keyboard
[ 4.526] (II) event3 - Power Button: device removed
[ 4.574] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 4.574] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 4.574] (**) Option "xkb_layout" "us"
[ 4.575] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 4.575] (II) event3 - Power Button: device is a keyboard
[ 4.576] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[ 4.576] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 4.576] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 4.576] (**) Video Bus: Applying InputClass "system-keyboard"
[ 4.576] (II) Using input driver 'libinput' for 'Video Bus'
[ 4.576] (**) Video Bus: always reports core events
[ 4.576] (**) Option "Device" "/dev/input/event12"
[ 4.578] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 4.578] (II) event12 - Video Bus: device is a keyboard
[ 4.578] (II) event12 - Video Bus: device removed
[ 4.641] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12/event12"
[ 4.641] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 4.641] (**) Option "xkb_layout" "us"
[ 4.641] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 4.642] (II) event12 - Video Bus: device is a keyboard
[ 4.642] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 4.642] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 4.642] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 4.642] (**) Power Button: Applying InputClass "system-keyboard"
[ 4.642] (II) Using input driver 'libinput' for 'Power Button'
[ 4.642] (**) Power Button: always reports core events
[ 4.642] (**) Option "Device" "/dev/input/event1"
[ 4.643] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 4.643] (II) event1 - Power Button: device is a keyboard
[ 4.643] (II) event1 - Power Button: device removed
[ 4.667] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 4.667] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 4.667] (**) Option "xkb_layout" "us"
[ 4.668] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 4.668] (II) event1 - Power Button: device is a keyboard
[ 4.669] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 4.669] (II) No input driver specified, ignoring this device.
[ 4.669] (II) This device may have been added with another device file.
[ 4.669] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 4.669] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 4.669] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 4.669] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 4.669] (II) Using input driver 'libinput' for 'Sleep Button'
[ 4.669] (**) Sleep Button: always reports core events
[ 4.669] (**) Option "Device" "/dev/input/event2"
[ 4.670] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 4.670] (II) event2 - Sleep Button: device is a keyboard
[ 4.670] (II) event2 - Sleep Button: device removed
[ 4.707] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 4.707] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 4.707] (**) Option "xkb_layout" "us"
[ 4.708] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 4.708] (II) event2 - Sleep Button: device is a keyboard
[ 4.709] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event13)
[ 4.709] (II) No input driver specified, ignoring this device.
[ 4.709] (II) This device may have been added with another device file.
[ 4.709] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event14)
[ 4.709] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event15)
[ 4.709] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event16)
[ 4.710] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event17)
[ 4.710] (II) No input driver specified, ignoring this device.
[ 4.710] (II) This device may have been added with another device file.
[ 4.710] (II) config/udev: Adding input device Apple Inc. Apple Internal Keyboard / Trackpad (/dev/input/event11)
[ 4.710] (**) Apple Inc. Apple Internal Keyboard / Trackpad: Applying InputClass "evdev keyboard catchall"
[ 4.710] (**) Apple Inc. Apple Internal Keyboard / Trackpad: Applying InputClass "libinput keyboard catchall"
[ 4.710] (**) Apple Inc. Apple Internal Keyboard / Trackpad: Applying InputClass "system-keyboard"
[ 4.710] (II) Using input driver 'libinput' for 'Apple Inc. Apple Internal Keyboard / Trackpad'
[ 4.710] (**) Apple Inc. Apple Internal Keyboard / Trackpad: always reports core events
[ 4.710] (**) Option "Device" "/dev/input/event11"
[ 4.712] (II) event11 - Apple Inc. Apple Internal Keyboard / Trackpad: is tagged by udev as: Keyboard
[ 4.712] (II) event11 - Apple Inc. Apple Internal Keyboard / Trackpad: device is a keyboard
[ 4.713] (II) event11 - Apple Inc. Apple Internal Keyboard / Trackpad: device removed
[ 4.747] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.1/0003:05AC:0274.0004/input/input11/event11"
[ 4.747] (II) XINPUT: Adding extended input device "Apple Inc. Apple Internal Keyboard / Trackpad" (type: KEYBOARD, id 10)
[ 4.747] (**) Option "xkb_layout" "us"
[ 4.749] (II) event11 - Apple Inc. Apple Internal Keyboard / Trackpad: is tagged by udev as: Keyboard
[ 4.749] (II) event11 - Apple Inc. Apple Internal Keyboard / Trackpad: device is a keyboard
[ 4.749] (II) config/udev: Adding input device bcm5974 (/dev/input/event7)
[ 4.749] (**) bcm5974: Applying InputClass "evdev touchpad catchall"
[ 4.749] (**) bcm5974: Applying InputClass "libinput touchpad catchall"
[ 4.749] (**) bcm5974: Applying InputClass "touchpad"
[ 4.749] (II) Using input driver 'libinput' for 'bcm5974'
[ 4.749] (**) bcm5974: always reports core events
[ 4.749] (**) Option "Device" "/dev/input/event7"
[ 4.751] (II) event7 - bcm5974: is tagged by udev as: Touchpad
[ 4.752] (II) event7 - bcm5974: device is a touchpad
[ 4.753] (II) event7 - bcm5974: device removed
[ 4.827] (**) Option "Tapping" "on"
[ 4.827] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.2/input/input7/event7"
[ 4.827] (II) XINPUT: Adding extended input device "bcm5974" (type: TOUCHPAD, id 11)
[ 4.828] (**) Option "AccelerationScheme" "none"
[ 4.828] (**) bcm5974: (accel) selected scheme none/0
[ 4.828] (**) bcm5974: (accel) acceleration factor: 2.000
[ 4.828] (**) bcm5974: (accel) acceleration threshold: 4
[ 4.830] (II) event7 - bcm5974: is tagged by udev as: Touchpad
[ 4.831] (II) event7 - bcm5974: device is a touchpad
[ 4.832] (II) config/udev: Adding input device bcm5974 (/dev/input/mouse1)
[ 4.832] (**) bcm5974: Applying InputClass "touchpad"
[ 4.832] (II) Using input driver 'libinput' for 'bcm5974'
[ 4.832] (**) bcm5974: always reports core events
[ 4.832] (**) Option "Device" "/dev/input/mouse1"
[ 4.897] (II) mouse1 - not using input device '/dev/input/mouse1'.
[ 4.897] (EE) libinput: bcm5974: Failed to create a device for /dev/input/mouse1
[ 4.897] (EE) PreInit returned 2 for "bcm5974"
[ 4.897] (II) UnloadModule: "libinput"
[ 4.898] (II) config/udev: Adding input device Broadcom Corp. Bluetooth USB Host Controller (/dev/input/event5)
[ 4.898] (**) Broadcom Corp. Bluetooth USB Host Controller: Applying InputClass "evdev keyboard catchall"
[ 4.898] (**) Broadcom Corp. Bluetooth USB Host Controller: Applying InputClass "libinput keyboard catchall"
[ 4.898] (**) Broadcom Corp. Bluetooth USB Host Controller: Applying InputClass "system-keyboard"
[ 4.898] (II) Using input driver 'libinput' for 'Broadcom Corp. Bluetooth USB Host Controller'
[ 4.898] (**) Broadcom Corp. Bluetooth USB Host Controller: always reports core events
[ 4.898] (**) Option "Device" "/dev/input/event5"
[ 4.899] (II) event5 - Broadcom Corp. Bluetooth USB Host Controller: is tagged by udev as: Keyboard
[ 4.899] (II) event5 - Broadcom Corp. Bluetooth USB Host Controller: device is a keyboard
[ 4.899] (II) event5 - Broadcom Corp. Bluetooth USB Host Controller: device removed
[ 4.921] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:05AC:8290.0001/input/input5/event5"
[ 4.921] (II) XINPUT: Adding extended input device "Broadcom Corp. Bluetooth USB Host Controller" (type: KEYBOARD, id 12)
[ 4.921] (**) Option "xkb_layout" "us"
[ 4.922] (II) event5 - Broadcom Corp. Bluetooth USB Host Controller: is tagged by udev as: Keyboard
[ 4.922] (II) event5 - Broadcom Corp. Bluetooth USB Host Controller: device is a keyboard
[ 4.923] (II) config/udev: Adding input device Broadcom Corp. Bluetooth USB Host Controller (/dev/input/event6)
[ 4.923] (**) Broadcom Corp. Bluetooth USB Host Controller: Applying InputClass "evdev pointer catchall"
[ 4.923] (**) Broadcom Corp. Bluetooth USB Host Controller: Applying InputClass "libinput pointer catchall"
[ 4.923] (II) Using input driver 'libinput' for 'Broadcom Corp. Bluetooth USB Host Controller'
[ 4.923] (**) Broadcom Corp. Bluetooth USB Host Controller: always reports core events
[ 4.923] (**) Option "Device" "/dev/input/event6"
[ 4.978] (II) event6 - Broadcom Corp. Bluetooth USB Host Controller: is tagged by udev as: Mouse
[ 4.978] (II) event6 - Broadcom Corp. Bluetooth USB Host Controller: device is a pointer
[ 4.979] (II) event6 - Broadcom Corp. Bluetooth USB Host Controller: device removed
[ 5.054] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/0003:05AC:8290.0002/input/input6/event6"
[ 5.054] (II) XINPUT: Adding extended input device "Broadcom Corp. Bluetooth USB Host Controller" (type: MOUSE, id 13)
[ 5.054] (**) Option "AccelerationScheme" "none"
[ 5.054] (**) Broadcom Corp. Bluetooth USB Host Controller: (accel) selected scheme none/0
[ 5.054] (**) Broadcom Corp. Bluetooth USB Host Controller: (accel) acceleration factor: 2.000
[ 5.054] (**) Broadcom Corp. Bluetooth USB Host Controller: (accel) acceleration threshold: 4
[ 5.112] (II) event6 - Broadcom Corp. Bluetooth USB Host Controller: is tagged by udev as: Mouse
[ 5.112] (II) event6 - Broadcom Corp. Bluetooth USB Host Controller: device is a pointer
[ 5.112] (II) config/udev: Adding input device Broadcom Corp. Bluetooth USB Host Controller (/dev/input/mouse0)
[ 5.112] (II) No input driver specified, ignoring this device.
[ 5.112] (II) This device may have been added with another device file.
[ 5.113] (II) config/udev: Adding input device HDA Intel PCH SPDIF (/dev/input/event10)
[ 5.113] (II) No input driver specified, ignoring this device.
[ 5.113] (II) This device may have been added with another device file.
[ 5.113] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event8)
[ 5.113] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event9)
[ 5.113] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 6.373] (II) modeset(0): EDID vendor "APP", prod id 41006
[ 6.373] (II) modeset(0): Printing DDC gathered Modelines:
[ 6.373] (II) modeset(0): Modeline "2880x1800"x0.0 337.75 2880 2928 2960 3040 1800 1803 1809 1852 +hsync -vsync (111.1 kHz eP)
[ 7.273] (II) modeset(0): EDID vendor "APP", prod id 41006
[ 7.273] (II) modeset(0): Printing DDC gathered Modelines:
[ 7.273] (II) modeset(0): Modeline "2880x1800"x0.0 337.75 2880 2928 2960 3040 1800 1803 1809 1852 +hsync -vsync (111.1 kHz eP)
[ 52.771] (EE) event7 - bcm5974: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.20.0/touchpad-jumping-cursors.html for details
[ 53.136] (EE) event7 - bcm5974: kernel bug: Touch jump detected and discarded.
