I have created this topic to understand what is happening, why and what to do about it.
Stable update 22-07-18 has a known issue that wxgtk2 has to be removed to allow the update. And that can only happen when programs depending on wxgtk2 are removed first.
These programs may be in the AUR or not (Hugin is not). A solution / work around is not provided, other than to rebuild the AUR program (which will very probably fail) or use an appimage. (Personally I had to remove Sooperloper and Tenacity.)
On Arch News this wxgtk2 issue is mentioned, also without a solution or workaround.
What is happening here? I would expect that before wxgtk2 is removed upstream someone somewhere would investigate the consequences. Now it seems to me that users are left in the dark without any outlook.
Can somebody e.g. from Manjaro Development explain this?
NB Please note that I do not use words like âgoodâ or âbadâ. I would like to understand what happened.
These numbers is fictive - they are only used for illustrative purpose.
98% of the packages in the Manjaro repo comes from Arch.
0.5% is an AUR package included in Manjaro - usually because it is used by a maintainer.
1.5% is software developed by Manjaro or build from source by Manjaro e.g. kernel and kernel modules, extra modules like Nvidia driver.
If a package is removed from Arch repo - it us usually demoted to AUR - my guess is that users depending on the package have the opportunity to adopt it and maintain it
When such thing happens - the package cease to exist in Manjaro unstable and subsequently stable branch.
Package got dropped from repositories. Youâre using or have installed packages (not from the repositories) requiring that package. You have issues because of that.
With the disclaimer that I am not a developer or package maintainer â I am but a lowly, lowly cook moderator â the package that replaces wxgtk2 supports all that wxgtk2 supported.
So itâs only the replacement of one package by a package with another name, and while it may be necessary to remove wxgtk2 first, it is perfectly possible to do this without removing all that depends on wxgtk2. But for that you have to read the man page for pacman.
Thereâs also an alternative series of events that might affect users who do not have any installed packages / PKGBUILDs that require wxgtk2, yet in the past they might have at one point in time.
wxgtk2 remained installed on their system, not being used by anything, yet still causes a conflict when trying to update the system, such as the Stable Updates from July 18.
I found the errant package for my situation, which was not an AUR PKGBUILD and not a unique âManjaroâ package:amule
On the computer in which I did a fresh installation of Manjaro in mid 2021, I also installed the package amule, which is from the official Arch Linux repositories.
So even for those who do not use the AUR or custom PKGBUILDs, the Stable Updates from July 18 can still cause this confusing issue. They will not be able to update their system until manually intervening and removing wxgtk2 by hand.
Here is the series of events in my situation, in which no part of the AUR was involved:
I installed Manjaro in mid 2021. Fresh system.
I installed the package amulefrom the official Arch Linux repository (not from the AUR nor from the Manjaro-specific custom built packages).
At the time, amule required wxgtk2 as a dependency.
This naturally installs wxgtk2 (since itâs a dependency).
After some time, amule (on the official Arch Linux repository) switches the dependency from wxgtk2 to wxgtk3.
However, because this is an amule package âupdateâ and not a package âremovalâ, the unneeded dependency wxgtk2remains installed on my system.
The Manjaro July 18 2022 Stable Updates are rolled out, and since much time has passed, itâs confusing (and difficult to pinpoint the cause) when the system update is aborted because of the conflict caused by the existence of wxgtk2 and the refusal to automatically remove the errant and obsolete package.
Re-read my above âseries of eventsâ and youâll see that this could have also happened on vanilla Arch Linux, since no part of the AUR was involved, nor was this due to a âcustomâ Manjaro package.
Nothing needed to be ârebuiltâ nor re-installed. If during the update of amule the package wxgtk2 was automatically removed (since itâs no longer needed as a dependency), there would have been no hiccups later on.
Iâm aware that you can configure Pamac (and likewise pacman) to automatically remove unneeded/unshared dependencies upon the removal of a parent package; however, I am not aware of any configuration in which this behavior can be applied to parent package updates.
It may have in fact become an âorphanâ package, but so are make, patch, autoconf, and automake, which I obviously want to keep. Itâs for this reason that I wonât just purge orphan packages if there are no issues.
Of course, the situation with wxgtk2 did eventually become an issue, but thereâs no way I could have predicted that many months ago.
I believe that the logic behind âauto-remove unneeded/unshared dependenciesâ when uninstalling a package should also apply to package updates as well.
After all, one can mimic the above logic by first removing and then installing a package whenever there is an updated version. It would be tedious and redundant, of course.
Hereâs how it theoretically would have unfolded in regards to amule:
amule 2.3.3-1 is installed. It pulls in wxgtk2 as a dependency
I notice that amule 2.3.3-2 is available as an update
However, I decide to first uninstallamule, in which wxgtk2 is auto-removed (since it was pulled in as a dependency of amule and no other packages require it)
Now I install amule, which happens to be version 2.3.3-2
I basically âupdatedâ amule, yet wxgtk2 was auto-removed because of my âintermediaryâ step of first uninstalling amule
I donât see why the same above process cannot happen streamlined with package updates, and why itâs only triggered by package removals.
These are all part of base-devel group so I donât see a point having them installed as dependencies. If you ever want to change that just reinstall them: pacman -S base-devel --asexplicit
Probably because Arch is KISS. Also, I guess, you could argue then, why even have any orphans at all, pacman should take care of everything.
The bottom line is: wxgtk2 needs wxgtk-common, which was replaced (+conflicts) by wxwidgets-common. And it (wxgtk-common) couldnât be removed because other packages (wxgtk2) still needs it.
And you canât just automatically remove everything that still depends on wxgtk-common (that would be like doing pacman -Rsc).
The bottom bottom line: They wanted to remove wxgtk2. If they wanted to keep it, they could just rename it, same as wxwidgets-gtk3, and change depends from wxgtk-common to wxwidgets-common.
The issue still is that temporary removing wxgtk2 with âpacman -R wxgtk2â doesnât cure the matter, since wxgtk2 cannot be installed anymore after the Jul 18th update is applied. So your apps that use wxgtk2 and had to be deinstalled, too, are no longer re-installable afterwards. For me these apps are mission critical and thus I cannot apply the update. Would be great if someone knows a work around of some sort.
BTW: In the update there is no such package as `wxwidgets-common listed. So it cannot be excluded, but it seems to come as some other dependency.
Itâs removed permanently. Just like an old kernel or python2 or whatever.
Find a flatpak/snap/appimage/container of your apps. Or find an alternative way; there is wxgtk2 in AUR for example, that installs in /opt. Find a way to compile your apps against that.
For example the AUR sooperlooper package does not compile anymore because there is still a dependency on wxgtk2. The maintainer of the aur sooperlooper-git made it compile with wxgtk3. There are a lot of warnings, but it runs.
I understand that it is needed to remove old stuff that conflicts or poses a security threat, but if there is no conflict, and size certainly isnât an issue also, where is the point here? Just for sake for new, render elder apps unusable?
Snap - thanks, but âno thank youâ for any who is security savy.
If your truecrypt containers do not work with a distribution anymore, it is not just a little replaceable something, but a crucial matter - at least for me. The veracrypt approach wonât help, since it is not proven to be free of backdoors and brute password attacks tools exists.
âAny concerns with VeraCrypt are even worse for TrueCrypt (which is abandoned).â
Itâs been abandoned for over eight years.
What is with this loyalty to abandoned software which had its own security concerns, of which open-source developers addressed these very issues when they forked it into VeraCrypt?
