Hello.
I experience exactly the same problem while browsing either on Chromium or Firefox.
If it can help, I was on Mint before and same problem.
I have a Windows partition too, and no problem, but it’s Windows ![]()
Cheers,
Ben
Hello.
Cheers,
Ben
Found the solution and posted on the original thread.
This thread can be removed
Hello kornifex
I experienced same issue and I think I have found the solution.
I have a swap partition, but it was not in use. Since the system is not swapping, the memory is full and it freezes.
The Manjaro wiki page about swap helped me, especially the section “using a swap partition”.
Hoping this helps.
Regards,
Benoît
