[Question] Change kernel on manjaro ARM
Hi all !
I’m new using Manjaro on an ARM device (rpi4). I like a lot the Sway Edition. I am not doing important things on this device so I switch to testing branch. I would also change the kernel to the latest stable (I have read that new drivers and incoming with 5.10 are very awesome), but I can’t find how to do it. Do you have any idea ?
I hope that my question is clear and well put. Thanks for your answers !
Welcome @pouja
No I am not really sure what you are asking but believe you want to install the latest 5.10-rc4 which is now in the testing branch.
To switch to the testing branch and update the pacman database:
sudo pacman-mirrors --api --set-branch testing
sudo pacman -Syy
To install the latest 5.10-rc4 kernel / kernel-headers and raspberry pi bootloader packages:
sudo pacman -S linux-rpi4-rc linux-rpi4-rc-headers raspberrypi-bootloader raspberrypi-bootloader-x
This is what I was looking for ! Just a last question, you may have the answer :slight_smile:
Now the mainline kernel is the 5.10rc, when it’s gonna be the 5.11rc, should I manually update again ?
You will be notified when there is an update via the Package Manager but I post in this thread as soon as I push the latest to the unstable branch if you won’t to upgrade sooner.
https://forum.manjaro.org/t/new-raspberry-pi-kernels-related-packages/4721/152
In about a month when it makes it out of the -rc stage it will be moved to the linux-rpi4-mainline package so when it does you will have to install the linux-rpi4-mainline package if you still want to follow the 5.10 kernel.
Ok thanks, should I also install linux-rpi4-mainline-headers raspberrypi-bootloader raspberrypi-bootloader-x then ?
For right now on the testing branch install:
@Darksky
RC5 Kernel just got released. manjaro repos are updating when hexxeh rpi firmware has updated on github right?
regards
The kernel and firmware get released when I compile and build the packages and push them.This occurs when the RPi people push their new kernel and firmware to their respective repo’s.
They released their new versions this mouring and I had everything compiled and packages built but I had to go to town as it is grocery shopping day for me. So I was not able to test and push the packages until I got back home.
I post all new kernel related packages here when they are ready. Also grab the 2 new bootloader packages and install them also.
https://forum.manjaro.org/t/new-raspberry-pi-kernels-related-packages/4721/173
