QDBusError - running Skrooge
Hello, I have problem with software Skrooge (v 25.10.0 - latest, based on KDE Frameworks) since latest update 2025-12-22 . It shows this error at start of the Skrooge and the software crashes, it does not start at all.
##WARNING: Failed to register with host portal QDBusError(“org.freedesktop.portal.Error.Failed”, “Could not register app ID: Connection already associated with an application ID”)*
journalctl -xe | grep skrooge
pro 31 10:05:34 hans-ci7512 kernel: skrooge\[3157\]: segfault at 2dc ip 00007fa8a7c894eb sp 00007ffde1b693b0 error 4 in libQt6WebEngineCore.so.6.10.1\[7fa8a7b30000+a393000\]
pro 31 10:05:34 hans-ci7512 systemd-coredump\[3203\]: Process 3157 (skrooge) of user 1000 terminated abnormally with signal 11/SEGV, processing…
pro 31 10:05:36 hans-ci7512 systemd-coredump\[3204\]: Process 3157 (skrooge) of user 1000 dumped core.*
#48 *0x000055fa2bc101b7 n/a (/usr/bin/skrooge + 0x41b7)*
#51 *0x000055fa2bc10815 n/a (/usr/bin/skrooge + 0x4815)
░░ Subject: Process 3157 (skrooge) dumped core
░░ Process 3157 (skrooge) crashed and dumped core.*
Once it has crashed 2 or 3 times it actually starts after running it again yet still showing the Warning above. AI suggested that this could be due to the change frome QT 6.9 to 6.10. I am not sure and do not know what to do.
My hardware is fairly old info below. Could anyone help me, please? Or is this a bug?
inxi -Fxz
Kernel: 5.15.197-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
Desktop: Xfce v: 4.20.1 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: MICRO-STAR model: P45 Platinum (MS-7512) v: 1.0
Info: dual core model: Intel Core2 Duo E8500 bits: 64 type: MCP arch: Penryn
rev: A cache: L1: 128 KiB L2: 6 MiB
Flags-basic: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Device-1: Advanced Micro Devices \[AMD/ATI\] Cedar \[Radeon HD
5000/6000/7350/8350 Series\] vendor: PC Partner / Sapphire driver: radeon
v: kernel arch: TeraScale-2 bus-ID: 01:00.0 temp: 44.0 C
Display: x11 server: X.Org v: 21.1.21 driver: X: loaded: radeon
unloaded: modesetting dri: r600 gpu: radeon s-res: 1920x1200
resolution: 1920x1200
API: EGL v: 1.5 drivers: kms_swrast,r600,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland
API: OpenGL v: 3.1 vendor: mesa v: 25.3.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD CEDAR (DRM 2.50.0 / 5.15.197-1-MANJARO
LLVM 21.1.6)
gpu: radeontop x11: xdpyinfo,xprop
Hi @jenik, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
inxi --filter --verbosity=8 --color=0
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
That is a difficult one.
My initial check is done on KDE Plasma and it work as expected.
Next thing is to check with xfce using a virtual machine. I let you know my findings.
EDIT:
@jenik it is still difficult - as I cannot reproduce the issue in a virtual machine.
This does not imply anything - you still have an issue - it just got more difficult to point to a possible source.
Since your error message contains a reference (my formatting)
##WARNING: Failed to register with host portal\
QDBusError(“org.freedesktop.portal.Error.Failed”, \
I am thinking - my reference system (virtual machine) has the package xdg-desktop-portal-gtk and the base xdg-desktop-portal synced.
pamac search xdg-desktop-portal -r | grep -e 'Installed'
    clocksource: hpet avail: acpi_pm
    root=UUID=aaf5c39b-140c-4787-916d-d80159456cee rw quiet apparmor=1
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
    serial: <superuser required> uuid: <superuser required> Firmware: BIOS
    vendor: American Megatrends v: 1.0B1 date: 11/19/2008
  System RAM: total: 8 GiB available: 7.76 GiB used: 1.66 GiB (21.4%)
  Array-1: capacity: 8 GiB note: est. slots: 4 modules: 4 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: DIMM1 type: SDRAM detail: synchronous size: 2 GiB speed: N/A
    volts: N/A width (bits): data: 64 total: 64 manufacturer: N/A part-no: N/A
    serial: N/A
  Device-2: DIMM2 type: SDRAM detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Device-3: DIMM3 type: SDRAM detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Device-4: DIMM4 type: SDRAM detail: synchronous size: 2 GiB speed: N/A
    serial: N/A
  Info: model: Intel Core2 Duo E8500 bits: 64 type: MCP arch: Penryn level: v1
    built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
    stepping: 0xA (10) microcode: 0xA0B
  Topology: cpus: 1x dies: 1 cores: 2 smt: <unsupported> cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 2238 min/max: 2003/3166 scaling: driver: acpi-cpufreq
    governor: schedutil cores: 1: 2238 2: 2238 bogomips: 12702
  Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
    cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
    lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
    pni pse pse36 pti rep_good sep smx sse sse2 sse4_1 ssse3 syscall tm tm2
    tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
  Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT disabled
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Type: vmscape status: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Cedar [Radeon HD
    5000/6000/7350/8350 Series] vendor: PC Partner / Sapphire driver: radeon
    v: kernel arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
    built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: DVI-I-1
    empty: HDMI-A-1,VGA-1 bus-ID: 01:00.0 chip-ID: 1002:68f9 class-ID: 0300
    temp: 44.5 C
  Display: x11 server: X.Org v: 21.1.21 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: r600
    gpu: radeon display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 509x318mm (20.04x12.52")
    s-diag: 600mm (23.63") monitors: <missing: xrandr>
  Monitor-1: DVI-I-1 model: NEC 24WMGX3 serial: <filter> built: 2008
    res: 1920x1200 dpi: 94 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green:
    x: 0.294 y: 0.608 blue: x: 0.141 y: 0.075 white: x: 0.314 y: 0.329
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10
    modes: 1920x1200, 1600x1200, 1680x1050, 1400x1050, 1280x1024, 1440x900,
    1280x960, 1152x864, 1024x768, 832x624, 800x600, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: r600 x11: drv: r600
    inactive: wayland
    LLVM 21.1.6) device-ID: 1002:68f9 memory: 500 MiB unified: no
  Device-1: Intel 82801JI HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Cedar HDMI Audio [Radeon HD
    5400/6300/7300 Series] vendor: PC Partner / Sapphire driver: snd_hda_intel
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 1002:aa68 class-ID: 0403
  API: ALSA v: k5.15.197-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: e800 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Info: services: mld, NetworkManager, systemd-timesyncd
  Local Storage: total: 465.76 GiB used: 415.72 GiB (89.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
    scheme: MBR
  ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 415.72 GiB (90.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: aaf5c39b-140c-4787-916d-d80159456cee
  Hub-1: 1-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
  Device-1: 3-1:2 info: Logitech Mouse type: mouse
    chip-ID: 046d:c077 class-ID: 0301
  Hub-4: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-7: 7-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-8: 8-0:1 info: full speed or root hub ports: 2 rev: 1.1
  System Temperatures: cpu: 35.0 C mobo: 21.0 C gpu: radeon temp: 44.5 C
  Fan Speeds (rpm): cpu: 1079 fan-2: 0 fan-3: 0 fan-4: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.28 vbat: 3.28
  Packages: pm: pacman pkgs: 1341 libs: 371 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    3: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 210
  1: cpu: 8.5% command: chromium pid: 10625 mem: 218.2 MiB (2.7%)
  2: cpu: 6.0% command: chromium pid: 10570 mem: 262.0 MiB (3.2%)
  3: cpu: 5.5% command: chromium pid: 10486 mem: 154.3 MiB (1.9%)
  4: cpu: 4.3% command: chromium pid: 10453 mem: 277.9 MiB (3.4%)
  5: cpu: 3.6% command: Xorg pid: 792 mem: 88.0 MiB (1.1%)
  Memory top: 5 of 210
  1: mem: 277.9 MiB (3.4%) command: chromium pid: 10453 cpu: 4.3%
  2: mem: 262.0 MiB (3.2%) command: chromium pid: 10570 cpu: 6.0%
  3: mem: 218.2 MiB (2.7%) command: chromium pid: 10625 cpu: 8.5%
  4: mem: 154.3 MiB (1.9%) command: chromium pid: 10486 cpu: 5.5%
  5: mem: 153.9 MiB (1.9%) command: safeeyes started-by: python pid: 1332
    cpu: 0.1%
  Processes: 210 Power: uptime: 38m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.09 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 258 default: graphical tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9
    running-in: xfce4-terminal inxi: 3.3.40
Could you search for the stack trace with coredumpctl list. Browse to the end of the list. We need something still present and the PID relating to the Skrooge crash. Then with coredumpctl debug [PID] we should get a fully symbolised stack trace or at least post the output of coredumpctl info [PID]. So far it looks like a segmentation fault in libQt6WebEngineCore.so.6.10.1 but how it gets there we can’t tell.
Btw, i can’t reproduce the issue either.
thank you for help. I hope I understand correctly.
Wed 2025-12-31 12:28:09 CET   2565 1000 1000 SIGSEGV present  /usr/bin/skrooge                 7.5M
[hans@hans-ci7512 ~]$ coredumpctl debug 2565
           PID: 2565 (skrooge)
           UID: 1000 (hans)
           GID: 1000 (hans)
        Signal: 11 (SEGV)
     Timestamp: Wed 2025-12-31 12:28:07 CET (50min ago)
  Command Line: skrooge
    Executable: /usr/bin/skrooge
 Control Group: /user.slice/user-1000.slice/session-2.scope
          Unit: session-2.scope
         Slice: user-1000.slice
       Session: 2
     Owner UID: 1000 (hans)
       Boot ID: 61cbcbf8dad84f47874fa69d525c558e
    Machine ID: 95904b0969474157ba4e829bfa194ef2
      Hostname: hans-ci7512
       Storage: /var/lib/systemd/coredump/core.skrooge.1000.61cbcbf8dad84f47874fa69d525c558e.2565.1767180487000000.zst (present)
  Size on Disk: 7.5M
       Message: Process 2565 (skrooge) of user 1000 dumped core.
                Stack trace of thread 2565:
                #0  0x00007f77099a74eb n/a (libQt6WebEngineCore.so.6 + 0x2144eb)
                #1  0x00007f770ce20529 n/a (libQt6WebEngineCore.so.6 + 0x368d529)
                #2  0x00007f770ce18a7b n/a (libQt6WebEngineCore.so.6 + 0x3685a7b)
                #3  0x00007f770ce30ac4 n/a (libQt6WebEngineCore.so.6 + 0x369dac4)
                #4  0x00007f77102b7218 n/a (libQt6WebEngineCore.so.6 + 0x6b24218)
                #5  0x00007f770b0cdfd4 n/a (libQt6WebEngineCore.so.6 + 0x193afd4)
                #6  0x00007f770f174cf2 n/a (libQt6WebEngineCore.so.6 + 0x59e1cf2)
                #7  0x00007f770f17667e n/a (libQt6WebEngineCore.so.6 + 0x59e367e)
                #8  0x00007f770f17499c n/a (libQt6WebEngineCore.so.6 + 0x59e199c)
                #9  0x00007f770f179fa2 n/a (libQt6WebEngineCore.so.6 + 0x59e6fa2)
                #10 0x00007f770f17d812 n/a (libQt6WebEngineCore.so.6 + 0x59ea812)
                #11 0x00007f770f17667e n/a (libQt6WebEngineCore.so.6 + 0x59e367e)
                #12 0x00007f770f16e1d1 n/a (libQt6WebEngineCore.so.6 + 0x59db1d1)
                #13 0x00007f770f16eecc n/a (libQt6WebEngineCore.so.6 + 0x59dbecc)
                #14 0x00007f770f16f01e n/a (libQt6WebEngineCore.so.6 + 0x59dc01e)
                #15 0x00007f770b042b2e n/a (libQt6WebEngineCore.so.6 + 0x18afb2e)
                #16 0x00007f770f196bdd n/a (libQt6WebEngineCore.so.6 + 0x5a03bdd)
                #17 0x00007f770e7f16be n/a (libQt6WebEngineCore.so.6 + 0x505e6be)
                #18 0x00007f770e8191d7 n/a (libQt6WebEngineCore.so.6 + 0x50861d7)
                #19 0x00007f770e81a113 n/a (libQt6WebEngineCore.so.6 + 0x5087113)
                #20 0x00007f770997e2aa n/a (libQt6WebEngineCore.so.6 + 0x1eb2aa)
                #21 0x00007f7716f56936 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1c4936)
                #22 0x00007f7717dca1c0 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x1021c0)
                #23 0x00007f7716efc958 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x16a958)
                #24 0x00007f7716efcd30 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x16ad30)
                #25 0x00007f77171dce18 n/a (libQt6Core.so.6 + 0x44ae18)
                #26 0x00007f7708f88f8d n/a (libglib-2.0.so.0 + 0x5ef8d)
                #27 0x00007f7708f8a657 n/a (libglib-2.0.so.0 + 0x60657)
                #28 0x00007f7708f8a865 g_main_context_iteration (libglib-2.0.so.0 + 0x60865)
                #29 0x00007f77171da152 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x448152)
                #30 0x00007f7716efa14d _ZN16QCoreApplication13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE14QDeadlineTimer (libQt6Core.so.6 + 0x16814d)
                #31 0x00007f77188233ef n/a (libskgbasegui.so.2 + 0x543ef)
                #32 0x00007f77186275d2 _ZN11SKGDocument11stepForwardEiRK7QString (libskgbasemodeler.so.2 + 0x2e5d2)
                #33 0x00007f771874efbf _ZN15SKGDocumentBank7migrateERb (libskgbankmodeler.so.2 + 0xa1fbf)
                #34 0x00007f77186355c9 _ZN11SKGDocument4loadERK7QStringS2_bb (libskgbasemodeler.so.2 + 0x3c5c9)
                #35 0x00007f76d697b966 n/a (skg_file.so + 0xe966)
                #36 0x00007f7716f56994 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1c4994)
                #37 0x00007f7717dca1c0 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x1021c0)
                #38 0x00007f7716efc958 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x16a958)
                #39 0x00007f7716efcd30 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x16ad30)
                #40 0x00007f77171dce18 n/a (libQt6Core.so.6 + 0x44ae18)
                #41 0x00007f7708f88f8d n/a (libglib-2.0.so.0 + 0x5ef8d)
                #42 0x00007f7708f8a657 n/a (libglib-2.0.so.0 + 0x60657)
                #43 0x00007f7708f8a865 g_main_context_iteration (libglib-2.0.so.0 + 0x60865)
                #44 0x00007f77171da152 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x448152)
                #45 0x00007f7716efa14d _ZN16QCoreApplication13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE14QDeadlineTimer (libQt6Core.so.6 + 0x16814d)
                #46 0x00007f76d615680b n/a (skg_monthly.so + 0xb80b)
                #47 0x00007f771882f1c9 _ZN12SKGMainPanel16processArgumentsERK5QListI7QStringE (libskgbasegui.so.2 + 0x601c9)
                #48 0x00005591fd3941b7 n/a (/usr/bin/skrooge + 0x41b7)
                #49 0x00007f7716911635 n/a (libc.so.6 + 0x27635)
                #50 0x00007f77169116e9 __libc_start_main (libc.so.6 + 0x276e9)
                #51 0x00005591fd394815 n/a (/usr/bin/skrooge + 0x4815)
                Stack trace of thread 2566:
                #0  0x00007f7716989002 n/a (libc.so.6 + 0x9f002)
                #1  0x00007f771697d16c n/a (libc.so.6 + 0x9316c)
                #2  0x00007f771697d1b4 n/a (libc.so.6 + 0x931b4)
                #3  0x00007f77169f79f6 ppoll (libc.so.6 + 0x10d9f6)
                #4  0x00007f7708f8a784 n/a (libglib-2.0.so.0 + 0x60784)
                #5  0x00007f7708f8a865 g_main_context_iteration (libglib-2.0.so.0 + 0x60865)
                #6  0x00007f77171da152 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x448152)
                #7  0x00007f7716f07786 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x175786)
                #8  0x00007f771702241e _ZN7QThread4execEv (libQt6Core.so.6 + 0x29041e)
                #9  0x00007f771686003e n/a (libQt6DBus.so.6 + 0x3703e)
                #10 0x00007f77170c1899 n/a (libQt6Core.so.6 + 0x32f899)
                #11 0x00007f771698098b n/a (libc.so.6 + 0x9698b)
                #12 0x00007f7716a049cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 2567:
                #3  0x00007f77169f74ae __poll (libc.so.6 + 0x10d4ae)
                #4  0x00007f77041f920b n/a (libxcb.so.1 + 0xd20b)
                #5  0x00007f77041faf3d xcb_wait_for_event (libxcb.so.1 + 0xef3d)
                #6  0x00007f76f07e2ca9 n/a (libQt6XcbQpa.so.6 + 0x53ca9)
                #7  0x00007f77170c1899 n/a (libQt6Core.so.6 + 0x32f899)
                #8  0x00007f771698098b n/a (libc.so.6 + 0x9698b)
                #9  0x00007f7716a049cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 2577:
                #2  0x00007f771697d7dc n/a (libc.so.6 + 0x937dc)
                #3  0x00007f771697fe9e pthread_cond_wait (libc.so.6 + 0x95e9e)
                #4  0x00007f76cd82e96e n/a (libgallium-25.3.1-arch1.2.so + 0x5e296e)
                #5  0x00007f76cd7e3d3d n/a (libgallium-25.3.1-arch1.2.so + 0x597d3d)
                #6  0x00007f76cd82e89d n/a (libgallium-25.3.1-arch1.2.so + 0x5e289d)
                #7  0x00007f771698098b n/a (libc.so.6 + 0x9698b)
                #8  0x00007f7716a049cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 2579:
                #4  0x00007f770d654d5e n/a (libQt6WebEngineCore.so.6 + 0x3ec1d5e)
                #5  0x00007f770e84f2d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                #6  0x00007f771698098b n/a (libc.so.6 + 0x9698b)
                #7  0x00007f7716a049cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 2585:
                #3  0x00007f77169edd8f wait4 (libc.so.6 + 0x103d8f)
                #4  0x00007f770e86df90 n/a (libQt6WebEngineCore.so.6 + 0x50daf90)
                #5  0x00007f770e86e2e5 n/a (libQt6WebEngineCore.so.6 + 0x50db2e5)
                #6  0x00007f770e870710 n/a (libQt6WebEngineCore.so.6 + 0x50dd710)
                #7  0x00007f770e84f2d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                Stack trace of thread 2589:
                #4  0x00007f770e84eeec n/a (libQt6WebEngineCore.so.6 + 0x50bbeec)
                #5  0x00007f770e87f49c n/a (libQt6WebEngineCore.so.6 + 0x50ec49c)
                #6  0x00007f770e7f5456 n/a (libQt6WebEngineCore.so.6 + 0x5062456)
                #7  0x00007f770e82e9b4 n/a (libQt6WebEngineCore.so.6 + 0x509b9b4)
                #8  0x00007f770e82f23d n/a (libQt6WebEngineCore.so.6 + 0x509c23d)
                #9  0x00007f770e82f3f0 n/a (libQt6WebEngineCore.so.6 + 0x509c3f0)
                #10 0x00007f770e84f2d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                Stack trace of thread 2591:
                #7  0x00007f770e793eaa n/a (libQt6WebEngineCore.so.6 + 0x5000eaa)
                #8  0x00007f770e818505 n/a (libQt6WebEngineCore.so.6 + 0x5085505)
                #9  0x00007f770e7cbf0b n/a (libQt6WebEngineCore.so.6 + 0x5038f0b)
                #10 0x00007f770e838b8d n/a (libQt6WebEngineCore.so.6 + 0x50a5b8d)
                #11 0x00007f770e84f2d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                #12 0x00007f771698098b n/a (libc.so.6 + 0x9698b)
                #13 0x00007f7716a049cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 2592:
                #8  0x00007f770e82f1fd n/a (libQt6WebEngineCore.so.6 + 0x509c1fd)
                #9  0x00007f770e82f38b n/a (libQt6WebEngineCore.so.6 + 0x509c38b)
                Stack trace of thread 2595:
                #4  0x00007f770e856c12 n/a (libQt6WebEngineCore.so.6 + 0x50c3c12)
                Stack trace of thread 2596:
                Stack trace of thread 2597:
                #5  0x00007f770feca5a4 n/a (libQt6WebEngineCore.so.6 + 0x67375a4)
                #6  0x00007f770e84f2d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                Stack trace of thread 2568:
                #0  0x00007f7716a0272d syscall (libc.so.6 + 0x11872d)
                #1  0x00007f7708fb982e g_cond_wait (libglib-2.0.so.0 + 0x8f82e)
                #2  0x00007f7708f501cd n/a (libglib-2.0.so.0 + 0x261cd)
                #3  0x00007f7708f5023d g_async_queue_pop (libglib-2.0.so.0 + 0x2623d)
                #4  0x00007f76f0ed851c n/a (libpangoft2-1.0.so.0 + 0xc51c)
                #5  0x00007f7708fc18bc n/a (libglib-2.0.so.0 + 0x978bc)
                Stack trace of thread 2569:
                #3  0x00007f7708fc2487 n/a (libglib-2.0.so.0 + 0x98487)
                #4  0x00007f7708fc18bc n/a (libglib-2.0.so.0 + 0x978bc)
                #5  0x00007f771698098b n/a (libc.so.6 + 0x9698b)
                #6  0x00007f7716a049cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 2570:
                #6  0x00007f7708f8a8b2 n/a (libglib-2.0.so.0 + 0x608b2)
                #7  0x00007f7708fc18bc n/a (libglib-2.0.so.0 + 0x978bc)
                Stack trace of thread 2571:
                #5  0x00007f7708f8aa17 g_main_loop_run (libglib-2.0.so.0 + 0x60a17)
                #6  0x00007f770780a2e4 n/a (libgio-2.0.so.0 + 0x11a2e4)
                Stack trace of thread 2572:
                #3  0x00007f77169800a8 pthread_cond_timedwait (libc.so.6 + 0x960a8)
                #4  0x00007f77170c5dc5 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x333dc5)
                #5  0x00007f7717020e69 n/a (libQt6Core.so.6 + 0x28ee69)
                #6  0x00007f77170c1899 n/a (libQt6Core.so.6 + 0x32f899)
                Stack trace of thread 2573:
                Stack trace of thread 2578:
                Stack trace of thread 2586:
                #3  0x00007f7716a04cb5 epoll_wait (libc.so.6 + 0x11acb5)
                #4  0x00007f770e87b2f2 n/a (libQt6WebEngineCore.so.6 + 0x50e82f2)
                #5  0x00007f770e87b5b0 n/a (libQt6WebEngineCore.so.6 + 0x50e85b0)
                #6  0x00007f770e818505 n/a (libQt6WebEngineCore.so.6 + 0x5085505)
                #7  0x00007f770e7cbf0b n/a (libQt6WebEngineCore.so.6 + 0x5038f0b)
                #8  0x00007f770e837676 n/a (libQt6WebEngineCore.so.6 + 0x50a4676)
                #9  0x00007f770e824d9d n/a (libQt6WebEngineCore.so.6 + 0x5091d9d)
                #10 0x00007f770e838d28 n/a (libQt6WebEngineCore.so.6 + 0x50a5d28)
                Stack trace of thread 2593:
                Stack trace of thread 2594:
                Stack trace of thread 2600:
                Stack trace of thread 2601:
                Stack trace of thread 2599:
                #9  0x00007f7710abdf6e n/a (libQt6WebEngineCore.so.6 + 0x732af6e)
                Stack trace of thread 2588:
                Stack trace of thread 2587:
                Stack trace of thread 2598:
                #0  0x00007f77169a3c3a n/a (libc.so.6 + 0xb9c3a)
                #1  0x00007f770e88cbc5 n/a (libQt6WebEngineCore.so.6 + 0x50f9bc5)
                #2  0x00007f770e8888aa n/a (libQt6WebEngineCore.so.6 + 0x50f58aa)
                #3  0x00007f770e8889c7 n/a (libQt6WebEngineCore.so.6 + 0x50f59c7)
                #4  0x00007f7710932abb n/a (libQt6WebEngineCore.so.6 + 0x719fabb)
                #5  0x00007f77109bcadd n/a (libQt6WebEngineCore.so.6 + 0x7229add)
                #6  0x00007f7710cccc68 n/a (libQt6WebEngineCore.so.6 + 0x7539c68)
                #7  0x00007f7710ccd518 n/a (libQt6WebEngineCore.so.6 + 0x753a518)
                #8  0x00007f770da83c90 n/a (libQt6WebEngineCore.so.6 + 0x42f0c90)
                #9  0x00007f770b0c0610 n/a (libQt6WebEngineCore.so.6 + 0x192d610)
                #10 0x00007f770f174cf2 n/a (libQt6WebEngineCore.so.6 + 0x59e1cf2)
                #12 0x00007f770f17499c n/a (libQt6WebEngineCore.so.6 + 0x59e199c)
                #13 0x00007f770f179fa2 n/a (libQt6WebEngineCore.so.6 + 0x59e6fa2)
                #14 0x00007f770f17d812 n/a (libQt6WebEngineCore.so.6 + 0x59ea812)
                #15 0x00007f770f17667e n/a (libQt6WebEngineCore.so.6 + 0x59e367e)
                #16 0x00007f770f16e1d1 n/a (libQt6WebEngineCore.so.6 + 0x59db1d1)
                #17 0x00007f770f16eecc n/a (libQt6WebEngineCore.so.6 + 0x59dbecc)
                #18 0x00007f770f16f01e n/a (libQt6WebEngineCore.so.6 + 0x59dc01e)
                #19 0x00007f770b042b2e n/a (libQt6WebEngineCore.so.6 + 0x18afb2e)
                #20 0x00007f770f196bdd n/a (libQt6WebEngineCore.so.6 + 0x5a03bdd)
                #21 0x00007f770e7f16be n/a (libQt6WebEngineCore.so.6 + 0x505e6be)
                #22 0x00007f770e8191d7 n/a (libQt6WebEngineCore.so.6 + 0x50861d7)
                #23 0x00007f770e81a113 n/a (libQt6WebEngineCore.so.6 + 0x5087113)
                #24 0x00007f770e793cbe n/a (libQt6WebEngineCore.so.6 + 0x5000cbe)
                #25 0x00007f770e818505 n/a (libQt6WebEngineCore.so.6 + 0x5085505)
                #26 0x00007f770e7cbf0b n/a (libQt6WebEngineCore.so.6 + 0x5038f0b)
                #27 0x00007f770e838b8d n/a (libQt6WebEngineCore.so.6 + 0x50a5b8d)
                #28 0x00007f770e84f2d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                #29 0x00007f771698098b n/a (libc.so.6 + 0x9698b)
                #30 0x00007f7716a049cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 2590:
                #9  0x00007f770cb0e792 n/a (libQt6WebEngineCore.so.6 + 0x337b792)
                Stack trace of thread 2602:
                #8  0x00007f770e838b8d n/a (libQt6WebEngineCore.so.6 + 0x50a5b8d)
                #9  0x00007f770e84f2d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                #10 0x00007f771698098b n/a (libc.so.6 + 0x9698b)
                #11 0x00007f7716a049cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 2603:
                #8  0x00007f770e82f27d n/a (libQt6WebEngineCore.so.6 + 0x509c27d)
                #9  0x00007f770e82f3e0 n/a (libQt6WebEngineCore.so.6 + 0x509c3e0)
Failed to invoke gdb: No such file or directory
thank you.
xdg-desktop-portal-gtk  1.15.3-1 [Installed]                               extra
xdg-desktop-portal  1.20.3-2 [Installed]                                   extra
Ok, so the trace isn’t symbolised - i probably can’t recall everything we need for this. At least you need to have gdb installed. Anyway what i see is that this must be a bug either in the application (more likely) or in some Qt library (less likely). I would try to produce a symbolised stack trace and with this create a bug report, see Contact - Skrooge (if the trace doesn’t symbolise use what you have)
I don’t think there is anything else that could be done about it.
Hmm - I took at look at what libQt6WebEngineCore provides, and according to documentation
This is a snapshot of the integration of Chromium into Qt.
– Qt WebEngine Core | Qt WebEngine | Qt 6.10.1
The following is pure speculation - it is only a train of thoughts
As it is integration of chromium, it must be redistribution parts of chromium as part the library, thus the thought becomes - what if - the error is caused by the parts the originates at the Chromium project - https://chromium.org - if that is so we have no idea what causes the issue.
This make me speculate if the segfault would also happen if you closed the chromium browser before launching skrooge?
According to the trace it is a bug in libQt6WebEngineCore only we don’t see where exactly because of the missing symbols. On the other hand, if this would be so then a lot of other applications would be impacted too. :thinking:
I have no experience using gdb and symbols, but since the version is the same across upstream Arch Linux and all Manjaro branches.
Debugging/Getting traces - ArchWiki
Fresh started OS, no chromium running yet the Skrooge crashes. Usually after a few crashes it runs everytime till restart.
Gdb installed, debug info, there is termination info at the end:
coredumpctl debug 1810
           PID: 1810 (skrooge)
           UID: 1000 (hans)
           GID: 1000 (hans)
        Signal: 11 (SEGV)
     Timestamp: Wed 2025-12-31 14:32:59 CET (9min ago)
       Session: 2
       Boot ID: 316bc7484e8947e5a076df61018ba8c3
       Storage: /var/lib/systemd/coredump/core.skrooge.1000.316bc7484e8947e5a076df61018ba8c3.1810.1767187979000000.zst (present)
  Size on Disk: 7.7M
       Message: Process 1810 (skrooge) of user 1000 dumped core.
                Stack trace of thread 1810:
                #0  0x00007f6ae3d184eb n/a (libQt6WebEngineCore.so.6 + 0x2144eb)
                #1  0x00007f6ae7191529 n/a (libQt6WebEngineCore.so.6 + 0x368d529)
                #2  0x00007f6ae7189a7b n/a (libQt6WebEngineCore.so.6 + 0x3685a7b)
                #3  0x00007f6ae71a1ac4 n/a (libQt6WebEngineCore.so.6 + 0x369dac4)
                #4  0x00007f6aea628218 n/a (libQt6WebEngineCore.so.6 + 0x6b24218)
                #5  0x00007f6ae543efd4 n/a (libQt6WebEngineCore.so.6 + 0x193afd4)
                #6  0x00007f6ae94e5cf2 n/a (libQt6WebEngineCore.so.6 + 0x59e1cf2)
                #7  0x00007f6ae94e767e n/a (libQt6WebEngineCore.so.6 + 0x59e367e)
                #8  0x00007f6ae94e599c n/a (libQt6WebEngineCore.so.6 + 0x59e199c)
                #9  0x00007f6ae94eafa2 n/a (libQt6WebEngineCore.so.6 + 0x59e6fa2)
                #10 0x00007f6ae94ee812 n/a (libQt6WebEngineCore.so.6 + 0x59ea812)
                #11 0x00007f6ae94e767e n/a (libQt6WebEngineCore.so.6 + 0x59e367e)
                #12 0x00007f6ae94df1d1 n/a (libQt6WebEngineCore.so.6 + 0x59db1d1)
                #13 0x00007f6ae94dfecc n/a (libQt6WebEngineCore.so.6 + 0x59dbecc)
                #14 0x00007f6ae94e001e n/a (libQt6WebEngineCore.so.6 + 0x59dc01e)
                #15 0x00007f6ae53b3b2e n/a (libQt6WebEngineCore.so.6 + 0x18afb2e)
                #16 0x00007f6ae9507bdd n/a (libQt6WebEngineCore.so.6 + 0x5a03bdd)
                #17 0x00007f6ae8b626be n/a (libQt6WebEngineCore.so.6 + 0x505e6be)
                #18 0x00007f6ae8b8a1d7 n/a (libQt6WebEngineCore.so.6 + 0x50861d7)
                #19 0x00007f6ae8b8b113 n/a (libQt6WebEngineCore.so.6 + 0x5087113)
                #20 0x00007f6ae3cef2aa n/a (libQt6WebEngineCore.so.6 + 0x1eb2aa)
                #21 0x00007f6af12c7936 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1c4936)
                #22 0x00007f6af213b1c0 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x1021c0)
                #23 0x00007f6af126d958 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x16a958)
                #24 0x00007f6af126dd30 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x16ad30)
                #25 0x00007f6af154de18 n/a (libQt6Core.so.6 + 0x44ae18)
                #26 0x00007f6ae32f9f8d n/a (libglib-2.0.so.0 + 0x5ef8d)
                #27 0x00007f6ae32fb657 n/a (libglib-2.0.so.0 + 0x60657)
                #28 0x00007f6ae32fb865 g_main_context_iteration (libglib-2.0.so.0 + 0x60865)
                #29 0x00007f6af154b152 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x448152)
                #30 0x00007f6af126b14d _ZN16QCoreApplication13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE14QDeadlineTimer (libQt6Core.so.6 + 0x16814d)
                #31 0x00007f6af2b943ef n/a (libskgbasegui.so.2 + 0x543ef)
                #32 0x00007f6af29985d2 _ZN11SKGDocument11stepForwardEiRK7QString (libskgbasemodeler.so.2 + 0x2e5d2)
                #33 0x00007f6af2abffbf _ZN15SKGDocumentBank7migrateERb (libskgbankmodeler.so.2 + 0xa1fbf)
                #34 0x00007f6af29a65c9 _ZN11SKGDocument4loadERK7QStringS2_bb (libskgbasemodeler.so.2 + 0x3c5c9)
                #35 0x00007f6ab8cef966 n/a (skg_file.so + 0xe966)
                #36 0x00007f6af12c7994 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1c4994)
                #37 0x00007f6af213b1c0 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x1021c0)
                #38 0x00007f6af126d958 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x16a958)
                #39 0x00007f6af126dd30 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x16ad30)
                #40 0x00007f6af154de18 n/a (libQt6Core.so.6 + 0x44ae18)
                #41 0x00007f6ae32f9f8d n/a (libglib-2.0.so.0 + 0x5ef8d)
                #42 0x00007f6ae32fb657 n/a (libglib-2.0.so.0 + 0x60657)
                #43 0x00007f6ae32fb865 g_main_context_iteration (libglib-2.0.so.0 + 0x60865)
                #44 0x00007f6af154b152 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x448152)
                #45 0x00007f6af126b14d _ZN16QCoreApplication13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE14QDeadlineTimer (libQt6Core.so.6 + 0x16814d)
                #46 0x00007f6ab84ca80b n/a (skg_monthly.so + 0xb80b)
                #47 0x00007f6af2ba01c9 _ZN12SKGMainPanel16processArgumentsERK5QListI7QStringE (libskgbasegui.so.2 + 0x601c9)
                #48 0x00005605630be1b7 n/a (/usr/bin/skrooge + 0x41b7)
                #49 0x00007f6af0c82635 n/a (libc.so.6 + 0x27635)
                #50 0x00007f6af0c826e9 __libc_start_main (libc.so.6 + 0x276e9)
                #51 0x00005605630be815 n/a (/usr/bin/skrooge + 0x4815)
                Stack trace of thread 1812:
                #0  0x00007f6af0cfa002 n/a (libc.so.6 + 0x9f002)
                #1  0x00007f6af0cee16c n/a (libc.so.6 + 0x9316c)
                #2  0x00007f6af0cee1b4 n/a (libc.so.6 + 0x931b4)
                #3  0x00007f6af0d684ae __poll (libc.so.6 + 0x10d4ae)
                #4  0x00007f6ade56a20b n/a (libxcb.so.1 + 0xd20b)
                #5  0x00007f6ade56bf3d xcb_wait_for_event (libxcb.so.1 + 0xef3d)
                #6  0x00007f6acab53ca9 n/a (libQt6XcbQpa.so.6 + 0x53ca9)
                #7  0x00007f6af1432899 n/a (libQt6Core.so.6 + 0x32f899)
                #8  0x00007f6af0cf198b n/a (libc.so.6 + 0x9698b)
                #9  0x00007f6af0d759cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 1813:
                #0  0x00007f6af0d7372d syscall (libc.so.6 + 0x11872d)
                #1  0x00007f6ae332a82e g_cond_wait (libglib-2.0.so.0 + 0x8f82e)
                #2  0x00007f6ae32c11cd n/a (libglib-2.0.so.0 + 0x261cd)
                #3  0x00007f6ae32c123d g_async_queue_pop (libglib-2.0.so.0 + 0x2623d)
                #4  0x00007f6acb24951c n/a (libpangoft2-1.0.so.0 + 0xc51c)
                #5  0x00007f6ae33328bc n/a (libglib-2.0.so.0 + 0x978bc)
                #6  0x00007f6af0cf198b n/a (libc.so.6 + 0x9698b)
                #7  0x00007f6af0d759cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 1814:
                #3  0x00007f6ae3333487 n/a (libglib-2.0.so.0 + 0x98487)
                #4  0x00007f6ae33328bc n/a (libglib-2.0.so.0 + 0x978bc)
                #5  0x00007f6af0cf198b n/a (libc.so.6 + 0x9698b)
                #6  0x00007f6af0d759cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 1816:
                #3  0x00007f6af0d689f6 ppoll (libc.so.6 + 0x10d9f6)
                #4  0x00007f6ae32fb784 n/a (libglib-2.0.so.0 + 0x60784)
                #5  0x00007f6ae32fba17 g_main_loop_run (libglib-2.0.so.0 + 0x60a17)
                #6  0x00007f6ae1b7b2e4 n/a (libgio-2.0.so.0 + 0x11a2e4)
                #7  0x00007f6ae33328bc n/a (libglib-2.0.so.0 + 0x978bc)
                Stack trace of thread 1817:
                #2  0x00007f6af0cee7dc n/a (libc.so.6 + 0x937dc)
                #3  0x00007f6af0cf10a8 pthread_cond_timedwait (libc.so.6 + 0x960a8)
                #4  0x00007f6af1436dc5 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x333dc5)
                #5  0x00007f6af1391e69 n/a (libQt6Core.so.6 + 0x28ee69)
                #6  0x00007f6af1432899 n/a (libQt6Core.so.6 + 0x32f899)
                #7  0x00007f6af0cf198b n/a (libc.so.6 + 0x9698b)
                #8  0x00007f6af0d759cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 1822:
                #4  0x00007f6ae79c5d5e n/a (libQt6WebEngineCore.so.6 + 0x3ec1d5e)
                #5  0x00007f6ae8bc02d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                Stack trace of thread 1828:
                #3  0x00007f6af0d5ed8f wait4 (libc.so.6 + 0x103d8f)
                #4  0x00007f6ae8bdef90 n/a (libQt6WebEngineCore.so.6 + 0x50daf90)
                #5  0x00007f6ae8bdf2e5 n/a (libQt6WebEngineCore.so.6 + 0x50db2e5)
                #6  0x00007f6ae8be1710 n/a (libQt6WebEngineCore.so.6 + 0x50dd710)
                #7  0x00007f6ae8bc02d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                Stack trace of thread 1829:
                #3  0x00007f6af0d75cb5 epoll_wait (libc.so.6 + 0x11acb5)
                #4  0x00007f6ae8bec2f2 n/a (libQt6WebEngineCore.so.6 + 0x50e82f2)
                #5  0x00007f6ae8bec5b0 n/a (libQt6WebEngineCore.so.6 + 0x50e85b0)
                #6  0x00007f6ae8b89505 n/a (libQt6WebEngineCore.so.6 + 0x5085505)
                #7  0x00007f6ae8b3cf0b n/a (libQt6WebEngineCore.so.6 + 0x5038f0b)
                #8  0x00007f6ae8ba8676 n/a (libQt6WebEngineCore.so.6 + 0x50a4676)
                #9  0x00007f6ae8b95d9d n/a (libQt6WebEngineCore.so.6 + 0x5091d9d)
                #10 0x00007f6ae8ba9d28 n/a (libQt6WebEngineCore.so.6 + 0x50a5d28)
                #11 0x00007f6ae8bc02d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                #12 0x00007f6af0cf198b n/a (libc.so.6 + 0x9698b)
                #13 0x00007f6af0d759cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 1831:
                #3  0x00007f6af0cf0e9e pthread_cond_wait (libc.so.6 + 0x95e9e)
                #4  0x00007f6ae8bbfeec n/a (libQt6WebEngineCore.so.6 + 0x50bbeec)
                #5  0x00007f6ae8bf049c n/a (libQt6WebEngineCore.so.6 + 0x50ec49c)
                #6  0x00007f6ae8b66456 n/a (libQt6WebEngineCore.so.6 + 0x5062456)
                #7  0x00007f6ae8b9f9b4 n/a (libQt6WebEngineCore.so.6 + 0x509b9b4)
                #8  0x00007f6ae8ba01fd n/a (libQt6WebEngineCore.so.6 + 0x509c1fd)
                #9  0x00007f6ae8ba038b n/a (libQt6WebEngineCore.so.6 + 0x509c38b)
                #10 0x00007f6ae8bc02d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                #11 0x00007f6af0cf198b n/a (libc.so.6 + 0x9698b)
                #12 0x00007f6af0d759cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 1832:
                #8  0x00007f6ae8ba023d n/a (libQt6WebEngineCore.so.6 + 0x509c23d)
                #9  0x00007f6ae8ba03f0 n/a (libQt6WebEngineCore.so.6 + 0x509c3f0)
                Stack trace of thread 1834:
                #7  0x00007f6ae8b04eaa n/a (libQt6WebEngineCore.so.6 + 0x5000eaa)
                #8  0x00007f6ae8b89505 n/a (libQt6WebEngineCore.so.6 + 0x5085505)
                #9  0x00007f6ae8b3cf0b n/a (libQt6WebEngineCore.so.6 + 0x5038f0b)
                #10 0x00007f6ae8ba9b8d n/a (libQt6WebEngineCore.so.6 + 0x50a5b8d)
                Stack trace of thread 1835:
                Stack trace of thread 1811:
                #5  0x00007f6ae32fb865 g_main_context_iteration (libglib-2.0.so.0 + 0x60865)
                #6  0x00007f6af154b152 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x448152)
                #7  0x00007f6af1278786 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x175786)
                #8  0x00007f6af139341e _ZN7QThread4execEv (libQt6Core.so.6 + 0x29041e)
                #9  0x00007f6af0bd103e n/a (libQt6DBus.so.6 + 0x3703e)
                #10 0x00007f6af1432899 n/a (libQt6Core.so.6 + 0x32f899)
                Stack trace of thread 1836:
                Stack trace of thread 1838:
                #4  0x00007f6ae8bc7c12 n/a (libQt6WebEngineCore.so.6 + 0x50c3c12)
                Stack trace of thread 1839:
                Stack trace of thread 1815:
                #6  0x00007f6ae32fb8b2 n/a (libglib-2.0.so.0 + 0x608b2)
                Stack trace of thread 1842:
                #9  0x00007f6aeae2ef6e n/a (libQt6WebEngineCore.so.6 + 0x732af6e)
                Stack trace of thread 1843:
                Stack trace of thread 1818:
                Stack trace of thread 1844:
                Stack trace of thread 1820:
                #4  0x00007f6aa982e96e n/a (libgallium-25.3.1-arch1.2.so + 0x5e296e)
                #5  0x00007f6aa97e3d3d n/a (libgallium-25.3.1-arch1.2.so + 0x597d3d)
                #6  0x00007f6aa982e89d n/a (libgallium-25.3.1-arch1.2.so + 0x5e289d)
                Stack trace of thread 1846:
                #8  0x00007f6ae8ba027d n/a (libQt6WebEngineCore.so.6 + 0x509c27d)
                #9  0x00007f6ae8ba03e0 n/a (libQt6WebEngineCore.so.6 + 0x509c3e0)
                Stack trace of thread 1845:
                #8  0x00007f6ae8ba9b8d n/a (libQt6WebEngineCore.so.6 + 0x50a5b8d)
                #9  0x00007f6ae8bc02d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                #10 0x00007f6af0cf198b n/a (libc.so.6 + 0x9698b)
                #11 0x00007f6af0d759cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 1821:
                Stack trace of thread 1837:
                Stack trace of thread 1840:
                #5  0x00007f6aea23b5a4 n/a (libQt6WebEngineCore.so.6 + 0x67375a4)
                #6  0x00007f6ae8bc02d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                Stack trace of thread 1830:
                Stack trace of thread 1841:
                #0  0x00007f6af0d14c3a n/a (libc.so.6 + 0xb9c3a)
                #1  0x00007f6ae8bfdbc5 n/a (libQt6WebEngineCore.so.6 + 0x50f9bc5)
                #2  0x00007f6ae8bf98aa n/a (libQt6WebEngineCore.so.6 + 0x50f58aa)
                #3  0x00007f6ae8bf99c7 n/a (libQt6WebEngineCore.so.6 + 0x50f59c7)
                #4  0x00007f6aeaca3abb n/a (libQt6WebEngineCore.so.6 + 0x719fabb)
                #5  0x00007f6aead2dadd n/a (libQt6WebEngineCore.so.6 + 0x7229add)
                #6  0x00007f6aeb03dc68 n/a (libQt6WebEngineCore.so.6 + 0x7539c68)
                #7  0x00007f6aeb03e518 n/a (libQt6WebEngineCore.so.6 + 0x753a518)
                #8  0x00007f6ae7df4c90 n/a (libQt6WebEngineCore.so.6 + 0x42f0c90)
                #9  0x00007f6ae5431610 n/a (libQt6WebEngineCore.so.6 + 0x192d610)
                #10 0x00007f6ae94e5cf2 n/a (libQt6WebEngineCore.so.6 + 0x59e1cf2)
                #12 0x00007f6ae94e599c n/a (libQt6WebEngineCore.so.6 + 0x59e199c)
                #13 0x00007f6ae94eafa2 n/a (libQt6WebEngineCore.so.6 + 0x59e6fa2)
                #14 0x00007f6ae94ee812 n/a (libQt6WebEngineCore.so.6 + 0x59ea812)
                #15 0x00007f6ae94e767e n/a (libQt6WebEngineCore.so.6 + 0x59e367e)
                #16 0x00007f6ae94df1d1 n/a (libQt6WebEngineCore.so.6 + 0x59db1d1)
                #17 0x00007f6ae94dfecc n/a (libQt6WebEngineCore.so.6 + 0x59dbecc)
                #18 0x00007f6ae94e001e n/a (libQt6WebEngineCore.so.6 + 0x59dc01e)
                #19 0x00007f6ae53b3b2e n/a (libQt6WebEngineCore.so.6 + 0x18afb2e)
                #20 0x00007f6ae9507bdd n/a (libQt6WebEngineCore.so.6 + 0x5a03bdd)
                #21 0x00007f6ae8b626be n/a (libQt6WebEngineCore.so.6 + 0x505e6be)
                #22 0x00007f6ae8b8a1d7 n/a (libQt6WebEngineCore.so.6 + 0x50861d7)
                #23 0x00007f6ae8b8b113 n/a (libQt6WebEngineCore.so.6 + 0x5087113)
                #24 0x00007f6ae8b04cbe n/a (libQt6WebEngineCore.so.6 + 0x5000cbe)
                #25 0x00007f6ae8b89505 n/a (libQt6WebEngineCore.so.6 + 0x5085505)
                #26 0x00007f6ae8b3cf0b n/a (libQt6WebEngineCore.so.6 + 0x5038f0b)
                #27 0x00007f6ae8ba9b8d n/a (libQt6WebEngineCore.so.6 + 0x50a5b8d)
                #28 0x00007f6ae8bc02d5 n/a (libQt6WebEngineCore.so.6 + 0x50bc2d5)
                #29 0x00007f6af0cf198b n/a (libc.so.6 + 0x9698b)
                #30 0x00007f6af0d759cc n/a (libc.so.6 + 0x11a9cc)
                Stack trace of thread 1833:
                #9  0x00007f6ae6e7f792 n/a (libQt6WebEngineCore.so.6 + 0x337b792)
GNU gdb (GDB) 16.3
Copyright (C) 2024 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
    <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /usr/bin/skrooge...
This GDB supports auto-downloading debuginfo from the following URLs:
  <https://debuginfod.archlinux.org>
Enable debuginfod for this session? (y or [n]) y
Debuginfod has been enabled.
To make this setting permanent, add 'set debuginfod enabled on' to .gdbinit.
Reading symbols from /home/hans/.cache/debuginfod_client/73edd8409c07532583a0a3438e7715510edc0c0d/debuginfo...
warning: Can't open file /memfd:xshmfence (deleted) during file-backed mapping note processing
warning: Can't open file /dev/shm/.org.chromium.Chromium.DXNW1J (deleted) during file-backed mapping note processing
warning: Can't open file /dev/shm/.org.chromium.Chromium.FU5HUt (deleted) during file-backed mapping note processing
warning: Can't open file /dev/shm/.org.chromium.Chromium.U4qXed (deleted) during file-backed mapping note processing
warning: Can't open file /dev/shm/.org.chromium.Chromium.AoZFhi (deleted) during file-backed mapping note processing
warning: Can't open file /dev/shm/.org.chromium.Chromium.OZxFWZ (deleted) during file-backed mapping note processing
warning: Can't open file /memfd:xorg (deleted) during file-backed mapping note processing
warning: Can't open file /dev/shm/.org.chromium.Chromium.JcUzsY (deleted) during file-backed mapping note processing
[New LWP 1810]
[New LWP 1812]
[New LWP 1813]
[New LWP 1814]
[New LWP 1816]
[New LWP 1817]
[New LWP 1822]
[New LWP 1828]
[New LWP 1829]
[New LWP 1831]
[New LWP 1832]
[New LWP 1834]
[New LWP 1835]
[New LWP 1811]
[New LWP 1836]
[New LWP 1838]
[New LWP 1839]
[New LWP 1815]
[New LWP 1842]
[New LWP 1843]
[New LWP 1818]
[New LWP 1844]
[New LWP 1820]
[New LWP 1846]
[New LWP 1845]
--Type <RET> for more, q to quit, c to continue without paging--c
[New LWP 1821]
[New LWP 1837]
[New LWP 1840]
[New LWP 1830]
[New LWP 1841]
[New LWP 1833]
Downloading 1,26 G separate debug info for /usr/lib/libQt6WebEngineCore.so.6
[################        ]  10% (1,26 G)^CCancelling download of separate debug info for /usr/lib/libQt6WebEngineCore.so.6...
Downloading 5,15 M separate debug info for /usr/lib/libsqlcipher.so.0
Downloading 4,99 M separate debug info for /usr/lib/libKF6IconThemes.so.6
Downloading 251,74 K separate debug info for /usr/lib/libEGL.so.1
Downloading 4,72 M separate debug info for /usr/lib/libglib-2.0.so.0
Downloading 65,06 K separate debug info for /usr/lib/libOpenGL.so.0
Downloading 221,83 K separate debug info for /usr/lib/libmd4c.so.0
Downloading 194,53 K separate debug info for /usr/lib/libz.so.1
Downloading 22,42 M separate debug info for /usr/lib/libicui18n.so.78
Downloading 9,98 M separate debug info for /usr/lib/libicuuc.so.78
Downloading 400,58 K separate debug info for /usr/lib/libdouble-conversion.so.3
Downloading 43,14 M separate debug info for /usr/lib/libQt6QmlModels.so.6
Downloading 7,79 M separate debug info for /usr/lib/libQt6QmlMeta.so.6
Downloading 46,86 M separate debug info for /usr/lib/libQt6Network.so.6
Downloading 28,70 M separate debug info for /usr/lib/libQt6OpenGL.so.6
Downloading 14,94 M separate debug info for /usr/lib/libKF6KIOGui.so.6
Downloading 28,48 M separate debug info for /usr/lib/libKF6KIOWidgets.so.6
Downloading 2,27 M separate debug info for /usr/lib/libKF6IconWidgets.so.6
Downloading 3,43 M separate debug info for /usr/lib/libKF6Bookmarks.so.6
Downloading 189,54 K separate debug info for /usr/lib/libcanberra.so.0
Downloading 5,16 M separate debug info for /usr/lib/libKF6GlobalAccel.so.6
Downloading 3,07 M separate debug info for /usr/lib/libKF6Codecs.so.6
Downloading 4,57 M separate debug info for /usr/lib/libQt6WebChannel.so.6
Downloading 14,90 M separate debug info for /usr/lib/libQt6Positioning.so.6
Downloading 841,73 K separate debug info for /usr/lib/libsmime3.so
Downloading 4,93 M separate debug info for /usr/lib/libnss3.so
Downloading 10,58 M separate debug info for /usr/lib/libgio-2.0.so.0
Downloading 1,74 M separate debug info for /usr/lib/libgobject-2.0.so.0
Downloading 2,10 M separate debug info for /usr/lib/libjpeg.so.8
Downloading 2,14 M separate debug info for /usr/lib/libopus.so.0
Downloading 15,05 M separate debug info for /usr/lib/libavformat.so.62
Downloading 2,92 M separate debug info for /usr/lib/libavutil.so.60
Downloading 45,04 K separate debug info for /usr/lib/libXcomposite.so.1
Downloading 532,13 K separate debug info for /usr/lib/libXext.so.6
Downloading 385,41 K separate debug info for /usr/lib/libexpat.so.1
Downloading 2,99 M separate debug info for /usr/lib/libwebp.so.7
Downloading 404,05 K separate debug info for /usr/lib/libsnappy.so.1
Downloading 3,41 M separate debug info for /usr/lib/libxml2.so.16
Downloading 1,22 M separate debug info for /usr/lib/liblcms2.so.2
Downloading 1,43 M separate debug info for /usr/lib/libtiff.so.6
Downloading 518,88 K separate debug info for /usr/lib/libxkbfile.so.1
Downloading 10,86 M separate debug info for /usr/lib/libKF6Service.so.6
Downloading 140,88 K separate debug info for /usr/lib/libacl.so.1
Downloading 14,48 M separate debug info for /usr/lib/libcrypto.so.3
Downloading 6,10 M separate debug info for /usr/lib/libKF6Archive.so.6
Downloading 99,69 K separate debug info for /usr/lib/libcap.so.2
Downloading 1,70 M separate debug info for /usr/lib/libpcre2-8.so.0
Downloading 1,76 M separate debug info for /usr/lib/libgssapi_krb5.so.2
Downloading 7,41 M separate debug info for /usr/lib/libKF6WindowSystem.so.6
Downloading 9,12 M separate debug info for /usr/lib/libKF6JobWidgets.so.6
Downloading 449,00 K separate debug info for /usr/lib/qt6/plugins/platforms/libqxcb.so
Downloading 17,34 M separate debug info for /usr/lib/qt6/plugins/platforms/../../../libQt6XcbQpa.so.6
Downloading 43,61 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxcb-cursor.so.0
Downloading 41,77 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxcb-icccm.so.4
Downloading 37,68 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxcb-image.so.0
Downloading 159,27 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxcb-randr.so.0
Downloading 30,50 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxcb-render-util.so.0
Downloading 27,33 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxcb-shape.so.0
Downloading 57,62 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxcb-sync.so.1
Downloading 72,90 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxcb-xfixes.so.0
Downloading 288,78 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxcb-xkb.so.1
Downloading 108,50 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libSM.so.6
Downloading 300,93 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libICE.so.6
Downloading 390,67 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxcb-xinput.so.0
Downloading 123,31 K separate debug info for /usr/lib/qt6/plugins/platforms/../../../libxkbcommon-x11.so.0
Downloading 30,59 K separate debug info for /usr/lib/libxcb-util.so.1
Downloading 67,45 K separate debug info for /usr/lib/libuuid.so.1
Downloading 5,70 M separate debug info for /usr/lib/qt6/plugins/platformthemes/libqgtk3.so
Downloading 23,53 M separate debug info for /usr/lib/qt6/plugins/platformthemes/../../../libgtk-3.so.0
Downloading 3,58 M separate debug info for /usr/lib/qt6/plugins/platformthemes/../../../libgdk-3.so.0
Downloading 38,09 K separate debug info for /usr/lib/libcairo-gobject.so.2
Downloading 506,30 K separate debug info for /usr/lib/libatk-1.0.so.0
Downloading 3,18 M separate debug info for /usr/lib/libepoxy.so.0
Downloading 1,43 M separate debug info for /usr/lib/libXi.so.6
Downloading 609,91 K separate debug info for /usr/lib/libatk-bridge-2.0.so.0
Downloading 277,83 K separate debug info for /usr/lib/libcloudproviders.so.0
Downloading 3,25 M separate debug info for /usr/lib/libtinysparql-3.0.so.0
Downloading 7,23 K separate debug info for /usr/lib/libwayland-egl.so.1
Downloading 178,98 K separate debug info for /usr/lib/libXcursor.so.1
Downloading 43,90 K separate debug info for /usr/lib/libXinerama.so.1
Downloading 713,45 K separate debug info for /usr/lib/libatspi.so.0
Downloading 537,60 K separate debug info for /usr/lib/libjson-glib-1.0.so.0
Downloading 5,30 M separate debug info for /usr/lib/libsqlite3.so.0
Downloading 39,54 K separate debug info for /usr/lib/gtk-3.0/modules/libxapp-gtk3-module.so
Downloading 883,37 K separate debug info for /usr/lib/libxapp.so.1
Downloading 320,05 K separate debug info for /usr/lib/libgnomekbdui.so.8
Downloading 60,72 K separate debug info for /usr/lib/libgnomekbd.so.8
Downloading 464,27 K separate debug info for /usr/lib/libxklavier.so.16
Downloading 61,68 K separate debug info for /usr/lib/gtk-3.0/modules/libcanberra-gtk-module.so
Downloading 42,19 K separate debug info for /usr/lib/libcanberra-gtk3.so.0
Downloading 734,05 K separate debug info for /usr/lib/gio/modules/libgvfsdbus.so
Downloading 693,32 K separate debug info for /usr/lib/gvfs/libgvfscommon.so
Downloading 765,41 K separate debug info for /usr/lib/qt6/plugins/platforminputcontexts/libcomposeplatforminputcontextplugin.so
Downloading 1,20 M separate debug info for /usr/lib/qt6/plugins/imageformats/libqsvg.so
Downloading 1,21 M separate debug info for /usr/lib/qt6/plugins/imageformats/libqpdf.so
Downloading 28,39 M separate debug info for /usr/lib/qt6/plugins/imageformats/../../../libQt6Pdf.so.6
Downloading 1,08 M separate debug info for /usr/lib/qt6/plugins/imageformats/libqtiff.so
Downloading 1000,42 K separate debug info for /usr/lib/qt6/plugins/imageformats/libqico.so
Downloading 1,17 M separate debug info for /usr/lib/qt6/plugins/imageformats/libqwebp.so
Downloading 909,43 K separate debug info for /usr/lib/qt6/plugins/imageformats/libqwbmp.so
Downloading 971,55 K separate debug info for /usr/lib/qt6/plugins/imageformats/libqgif.so
Downloading 982,19 K separate debug info for /usr/lib/qt6/plugins/imageformats/libqjp2.so
Downloading 1,31 M separate debug info for /usr/lib/qt6/plugins/imageformats/../../../libjasper.so.7
Downloading 952,00 K separate debug info for /usr/lib/qt6/plugins/imageformats/libqmng.so
Downloading 1,29 M separate debug info for /usr/lib/qt6/plugins/imageformats/../../../libmng.so.2
Downloading 1,19 M separate debug info for /usr/lib/qt6/plugins/imageformats/libqjpeg.so
Downloading 1,06 M separate debug info for /usr/lib/qt6/plugins/imageformats/libqtga.so
Downloading 1,05 M separate debug info for /usr/lib/qt6/plugins/imageformats/libqicns.so
Downloading 3,38 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_search.so
Downloading 4,85 M separate debug info for /usr/lib/libskgbankgui.so.2
Downloading 3,98 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_bank.so
Downloading 1,41 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_delete.so
Downloading 3,59 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_scheduled.so
Downloading 7,18 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_operation.so
Downloading 3,39 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_importexport.so
Downloading 4,60 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_unit.so
Downloading 1,90 M separate debug info for /usr/lib/libKF6NewStuffWidgets.so.6
Downloading 19,75 M separate debug info for /usr/lib/libKF6NewStuffCore.so.6
Downloading 2,72 M separate debug info for /usr/lib/libKF6I18nQml.so.6
Downloading 22,65 M separate debug info for /usr/lib/libKF6Attica.so.6
Downloading 19,16 M separate debug info for /usr/lib/libKF6Syndication.so.6
Downloading 4,29 M separate debug info for /usr/lib/libKF6Package.so.6
Downloading 2,14 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_file.so
Downloading 2,96 M separate debug info for /usr/lib/libKF6Wallet.so.6
Downloading 2,73 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_advice.so
Downloading 2,66 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_bookmark.so
Downloading 1,93 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_print.so
Downloading 3,04 M separate debug info for /usr/lib/qt6/plugins/printsupport/libcupsprintersupport.so
Downloading 37,45 K separate debug info for /usr/lib/qt6/plugins/printsupport/../../../libcups.so.2
Downloading 125,55 K separate debug info for /usr/lib/libavahi-common.so.3
Downloading 192,25 K separate debug info for /usr/lib/libavahi-client.so.3
Downloading 2,78 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_categories.so
Downloading 2,27 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_debug.so
Downloading 2,62 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_properties.so
Downloading 3,12 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_dashboard.so
Downloading 4,98 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_report.so
Downloading 2,65 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_calculator.so
Downloading 2,65 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_payee.so
Downloading 3,46 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_budget.so
Downloading 1,33 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_selectall.so
Downloading 2,55 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_monthly.so
Downloading 1,38 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_highlight.so
Downloading 2,42 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_undoredo.so
Downloading 1,92 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skg_statistic.so
Downloading 2,42 M separate debug info for /usr/lib/qt6/plugins/skg_gui/skrooge_tracker.so
Downloading 2,38 M separate debug info for /usr/lib/qt6/plugins/xcbglintegrations/libqxcb-glx-integration.so
Downloading 275,62 K separate debug info for /usr/lib/qt6/plugins/xcbglintegrations/../../../libxcb-glx.so.0
Downloading 69,34 K separate debug info for /usr/lib/libXxf86vm.so.1
Downloading 25,20 K separate debug info for /usr/lib/libxcb-present.so.0
Downloading 441,02 M separate debug info for /usr/lib/libLLVM.so.21.1
Downloading 137,61 K separate debug info for /usr/lib/libsensors.so.5
Downloading 11,27 K separate debug info for /usr/lib/libxshmfence.so.1
Downloading 159,33 K separate debug info for /usr/lib/libdrm_amdgpu.so.1
Downloading 925,95 K separate debug info for /usr/lib/libelf.so.1
Downloading 326,18 K separate debug info for /usr/lib/libdrm_intel.so.1
Downloading 610,80 K separate debug info for /usr/lib/libedit.so.0
Downloading 114,30 K separate debug info for /usr/lib/libpciaccess.so.0
Downloading 1,70 M separate debug info for /usr/lib/libncursesw.so.6
Downloading 6,84 M separate debug info for /usr/lib/qt6/plugins/kf6/ktexttemplate/ktexttemplate_defaulttags.so
Downloading 2,19 M separate debug info for /usr/lib/qt6/plugins/kf6/ktexttemplate/ktexttemplate_loadertags.so
Downloading 3,20 M separate debug info for /usr/lib/qt6/plugins/kf6/ktexttemplate/ktexttemplate_defaultfilters.so
Downloading 2,46 M separate debug info for /usr/lib/qt6/plugins/kf6/ktexttemplate/grantlee_skgfilters.so
Downloading 1,72 M separate debug info for /usr/lib/qt6/plugins/sqldrivers/libskgsqlcipher.so
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
Core was generated by `/usr/bin/skrooge'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0  0x00007f6ae3d184eb in ?? () from /usr/lib/libQt6WebEngineCore.so.6
[Current thread is 1 (Thread 0x7f6acb115980 (LWP 1810))]
It was downloading a lot of files during the debug? It is stored somewhere? I am just asking because of used space thats all. Thank you.
This is normal, it should fetch the symbols, however “n/a” means it didn’t find it. The files should be temporary, i think. I can’t really recall although i created a report for Qt creator not that long ago and the attached stack trace is symbolised but i don’t know how i did it exactly or what needs to be installed. (elfutils, debuginfod:frowning_face:)
