ProtonVPN " Unknown error occurred"
Hello
When I want to login to protonvpn it fails and says " Unknown error occurred. If the issue persists, please contact support. "
How can I fix this?
Do as instructed
Attempt to login from terminal - it may yield more information
$ protonvpn-cli login <username>
Enter your Proton VPN password:
Successful login.
Hi @ILYAJR,
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Please also try and launch the application from a terminal, and provide any and all output it gives here.
it says " zsh: parse error near `\n’ "
Most likely because you have used copy/paste to fill in the password
\n is a newline char - it is invalid in password input
it shows up when I enter the username
Then you have other problems and this is just a symptom - don’t ask me what it is because I don’t know.
If I am not mistaken - you have entered <username> and the < and > are pipe chars - remove them
ksnip_20220526-170936
Tested with bash and zsh - no issues
Screenshot
ksnip_20220526-170626
What if you try with an incorrect username on purpose?
Does it still spit out the same error about ‘\n’?
So for example, type it in exactly like this:
protonvpn-cli login iamafakeperson
