When I go to resize windows, especially in the Edge browser, or Discord, there is a lag in resizing, since I updated to gnome 45. Can someone Help me
Hi johnnywilly16,
Iām afraid that āit gets very strangeā and āeverything is weirdā wonāt help anyone diagnose your issue.
Please read the following Tutorials to better understand how to use this forum more effectively:
Cheers.
Have you checked for incompatible GNOME extensions as recommended in the Stable Update post?
It is recommended to remove all third-party extensions before updating, then install the compatible versions after updating and rebooting.
AllMost extensions in the Manjaro repos are already updated.
Itās not the extension because all the ones I use are updated
lags when resizing windows continue
sorry for the bad english but theres a video , this what happen when i resize window youtu.be/h2gtJsiLpwM
While the apology is appreciated, it isnāt necessary. You could use a translator, if that helps, or use your native language.
The point was that more information is usually needed to understand your issue, and find a remedy. The links I gave explain this in more detail (you could translate those also).
Without enough information we would need to play a game of 1000 questions, which often wastes a lot of time. Iām sure you understand.
Gnome 45 does not support any addons, widgets, themes, etc, if they were made for a previous version of Gnome. Itās recommended to uninstall anything that wasnāt specifically made for Gnome 45, before the recent upgrade; as @MrLavender has already mentioned above. Most everything in the official Manjaro repos has already been updated for Gnome 45 compatibility.
Now, itās possible what youāre seeing is a result of an incompatible ⦠something ⦠that you should remove, and replace with an updated version, if it exists.
Have you seen the video I attached? I donāt have anything incompatible with the system
Yes, I have seen it, and it seems to be a screen tearing issue. Thatās all I can say about that. If you provide some system information, someone might be able to help more. The links I gave earlier explain how to find and present that information.
what information do you need ?
You could start with the first command given in the āHow to Find System Informationā tutorial (linked earlier), and post the output from that.
but WHAT information do you need theres all kind informationā¦
Itās the first command listed, as I said. Look under Global Information.
Hereās a tutorial I missed. It will help you format information in posts:
Iām not going to give my sensitive information to you. especially the golbal ones, Iām going to format my computer and see if it comes back, and thanks for the suggestion āif manjaro is for meā, yes it is for me because I like it. THANK YOU
This command filters out personally identifiable information, when using the inxi
command:
Nobody suggested formatting your computer.
āIs Manjaro For Youā ā is often given when a User seems unable or unwilling to help us to help them; sometimes at the risk of offending egos. I like Manjaro too.
Well, Iām unwilling to help any further. Good luck.
If you were perhaps very specific in helping or really wanted to give the right commands I would be grateful, good luck to you too! first starts complaining about my English and then recommends that I stop using manjaro
I did neither. Good luck.
inxi -Fazy
Is a common request here on the forums and filters out sensitive information by design.
If you dont want to share the output of things like inxi
it will be very difficult to help you.
oh ok i will share then
Kernel: 6.5.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.5-x86_64
root=UUID=2315f61e-8dab-48d5-a35e-d53b6f42abb5 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor
resume=UUID=7d32354d-20a9-4ddc-8379-762883175f15 udev.log_priority=3
Desktop: GNOME v: 45.0 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
Type: Desktop Mobo: BIOSTAR model: H310MHP serial: <superuser required>
UEFI: American Megatrends v: 5.12 date: 05/31/2019
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
desc: 1x9 MiB
Speed (MHz): avg: 3900 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 3900 2: 3900 3: 3900 4: 3900 5: 3900 6: 3900
bogomips: 34814
disabled
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU116 [GeForce GTX 1660] driver: nvidia v: 535.129.03
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2184 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-0 pos: primary,left res: 1920x1080 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-2: HDMI-0 pos: right res: 1920x1080 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.129.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1660/PCIe/SSE2
memory: 5.86 GiB
Device-1: Intel 200 Series PCH HD Audio vendor: Biostar Microtech Intl Corp
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:1aeb class-ID: 0403
Device-3: Logitech [] driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 046d:0acb
class-ID: 0300 serial: <filter>
Device-4: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
Device-5: [] driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 3142:5060
class-ID: 0300
API: ALSA v: k6.5.9-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.83 status: off tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 990.11 GiB used: 256.68 GiB (25.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000VM002-1ET162
tech: HDD rpm: 5900 serial: <filter> fw-rev: SC12 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: N/A size: 58.59 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 2.00 scheme: MBR
ID-1: / raw-size: 914.07 GiB size: 914.07 GiB (100.00%)
used: 230.84 GiB (25.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 584 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 914.07 GiB size: 914.07 GiB (100.00%)
ID-4: /var/log raw-size: 914.07 GiB size: 914.07 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.14 GiB used: 1 MiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 92.0 C mobo: N/A gpu: nvidia temp: 57 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 314 Uptime: 1h 4m wakeups: 0 Memory: total: 16 GiB
available: 15.58 GiB used: 8.57 GiB (55.0%) Init: systemd v: 254
Packages: 1275 pm: pacman pkgs: 1236 libs: 338 tools: gnome-software,pamac
pm: flatpak pkgs: 28 pm: snap pkgs: 11 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.31
Looks like the BIOS is out of date, but if my quick search was correct the updates are pretty inconsequential. (one is just for a new logo and the other is āAdded XMP profile info in main setup pageā)
Is this nvidia otherwise working as expected?
Maybe we can also look at mhwd:
mhwd -l -li
