Problem with reboot to Windows 10
Problems with second screen
Reboot in Manjaro
So, once upon a time I wanted to reboot into Manjaro, and after booting into Manjaro I got on the second screen resolution 640x480. It was terrible. Then I tried to change resolution in settings but there wasn’t options to choose another resolutions.
Reboot in Windows 10
I rebooted into Windows 10. I got the same idea, that was on Manjaro, I couldn’t change resolutions. I tried to reboot my PC and tried to replug HDMI cable to my second screen. But it doesn’t help.
P.S.
I found solution to this problem. But it’s very tedious, you need to do a lot of shenanigans to solve this.
Hi @UeberTimaeus, and welcome!
This isn’t normal behaviour. However, I can only imagine how tedious.
The only reason I can think of for something like this. is that your Linux (Manjaro) system does not have write permissions to be able to save the configuration.
Which begs two questions:
  1. How did you install your system(s): and
  2. on what file systems is it installed?
So it should be kind of obvious that more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
grafik
