Problem with 6.5 kernel and r8168 module
Apologies. I’m totally new to this forum and wasn’t sure how things work, so I wrote a reply here, then realized that my problem happened with the update from Sept. 13, deleted here, and then realized that the post from the 13th was already closed. I didn’t have time until today, though.
Here’s the previously deleted post…
I have trouble with the r8168 driver since I installed the latest updates.
uname -a
Linux studio 6.5.3-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Sep 13 12:21:35 UTC 2023 x86_64 GNU/Linux
sudo modprobe r8168
modprobe: ERROR: could not insert 'r8168': Unknown symbol in module, or unknown parameter (see dmesg)
dmesg:
r8168: version magic '6.5.1-1-MANJARO SMP preempt mod_unload ' should be '6.5.3-1-MANJARO SMP preempt mod_unload '
Do you really need the r8168 module? It’s an out-of-tree module from Realtek themselves. Chances are that you’re better off using the in-tree r8169 driver.
Just uninstall linux65-r8168 and make sure you remove the blacklist on r8169 under /etc/modprobe.d. Then reboot, and r8169 should automatically be loaded.
Thanks a million! That did it.
Funny, though, when I go to the “Hardware configuration” panel in the Manjaro section of KDE system settings, the suggested driver is r8186.
lspci output:
Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 16)
Oh well. It’s working again, main thing in my book. Thanks!
Also, thanks for moving this to the right place.
Yes, many people have in the past reported problems with r8169, which is why Manjaro defaults to supplying and recommending the r8168 driver from Realtek, but this should actually be changed, because this issue is already several years old, and it only really applies anymore to people who have very old hardware. Even my own system here, which is over 4 years old already, is using r8169 without any problems. :wink:
I think I had a similar problem with my device.
There was roughly 6 months where 8168 was the better choice but since kernel 6 (rough estimate), the 8169 module works perfectly.
I reported issue with network-r8168 driver in [Testing Update] 2023-09-11
linux515-r8168 and linux61-r8168 (8.051.02-1) packages fail to load r8168 driver
Latest version (8.051.02-2) also fails to load r8168 driver linux61-r8168 and linux65-r8168
    vendor: ASUSTeK P8 series driver: N/A modules: r8169, r8168 pcie: gen: 1
Users in a similar situation can load r8169 driver without rebooting to reinstate network connection
sudo modprobe r8169
and then use mhwd to uninstall all kernel modules and remove r8169 blacklist
sudo mhwd -r pci network-r8168
Users who need a working r8168 driver can install dkms and AUR driver r8168-dkms
pamac install dkms; pamac build r8168
and blacklist r8169
sudo tee /etc/modprobe.d/blacklist-r8169.conf <<< 'blacklist r8169'
We should stop using the Realtek r8168 driver by default for RTL8111/8168/8411
I just Timeshiftereded back becauseafter update restart no internet
[Stable Update] 2023-09-18 - Kernels, Mesa, Pipewire, Systemd, LibreOffice, KDE, Thunderbird
[Stable Update] 2024-03-13 - Plasma 5.27.11, Firefox, Thunderbird, AMDVLK, Qemu
[Stable Update] 2023-11-06 - Kernels, Gnome 45.1, Plasma 5.27.9, Firefox, Thunderbird, Pipewire
[Stable Update] 2023-10-04 - Kernels, Systemd, LibreOffice, NVIDIA, Mesa, GNOME, AMDVLK
[Stable Update] 2024-01-02 - Kernels, Systemd, Qemu, Plasma-Mobile, Deepin
[Stable Update] 2024-03-06 - Kernels, Systemd, KDE Gear, Qt, GNOME, Firefox, Thunderbird
[Stable Update] 2023-11-28 - Kernels, Firefox, Appstream 1.0, Blender 4.0, Cinnamon
[Stable Update] 2023-12-13 - Kernels, Blender, KDE Gear, Pamac 11.7, Python, Haskell
[Stable Update] 2023-12-01 - Kernels, NVIDIA, Thunderbird, Deepin, PipeWire 1.0, QEMU
[Stable Update] 2024-01-13 - Kernels, Systemd, Qt5, Mesa, Dbus, Firefox, Thunderbird
[Stable Update] 2024-02-21 - Kernels, KDE, VirtualBox, Calamares, ROCm, Firefox, Thunderbird
[Stable Update] 2023-10-09 - Mesa, Grub, GlibC, Thunderbird, KDE Frameworks Renaming
[Stable Update] 2023-10-13 - Pipewire, Mattermost, Qt5, Haskell, Python
[Stable Update] 2023-11-13 - Kernels, KDE Gear, LibreOffice, LXQt, Pipewire, Phosh, Firefox, Thunderbird
[Stable Update] 2023-11-21 - Systemd, Gamescope-Plus, KDE Frameworks, Wine, Pipewire, Thunderbird
[Stable Update] 2023-12-15 - Kernels, Blender, Thunderbird, Xorg-Server, Xwayland, Warzone2100
[Stable Update] 2023-12-23 - Kernels, Grub, Mate, Deepin, Cinnamon, ICU, KDE Frameworks
[Stable Update] 2023-12-10 - Kernels, Plasma, Phosh, Systemd, Cinnamon, Gnome, libpamac
