Hello,
Recently, I have moved from Windows to Linux Manjaro.
I can’t connect via wifi after installing this distribution on Linux. The error message is “No Wifi adapter found”.
It would be appreciated if you could help
Thank you very much
Best regards
Saber
inix - Fza :
Kernel: 5.19.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=22db7d62-a17e-4d4d-9436-2b30fa71fd30 rw quiet splash apparmor=1
security=apparmor resume=UUID=07a2f062-62e8-41d3-94ad-f59438ab7057
udev.log_priority=3
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: LENOVO product: 82SJ v: IdeaPad 5 Pro 14ARH7
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 Pro 14ARH7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: J8CN26WW date: 05/20/2022
ID-1: BAT1 charge: 52.6 Wh (93.1%) condition: 56.5/56.5 Wh (100.0%)
volts: 13.1 min: 11.5 model: 0x53 0x75 0x6E 0x77 0x6F 0x64 0x 0x4C 0x32
0x30 0x44 0x33 0x50 0x5650 type: Li-ion serial: <filter> status: charging
cycles: 3
Info: model: AMD Ryzen 5 6600HS Creator Edition bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6
(7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1589 high: 1600 min/max: 1600/4563 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 1600
3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600
12: 1470 bogomips: 79081
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 42.0 C
Device-2: Luxvisions Innotech Integrated RGB Camera type: USB
driver: uvcvideo bus-ID: 5-1:2 chip-ID: 30c9:0057 class-ID: fe01
serial: <filter>
Display: wayland server: X org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0931 built: 2020 res: 2240x1400
dpi: 188 gamma: 1.2 size: 302x189mm (11.89x7.44") diag: 356mm (14")
ratio: 16:10 modes: max: 2240x1400 min: 640x480
OpenGL: renderer: AMD YELLOW_CARP (LLVM 14.0.6 DRM 3.47
5.19.16-2-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp6x v: kernel
alternate: snd_pci_acp3x,snd_rn_pci_acp3x,snd_pci_acp5x,snd_acp_pci,snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.19.16-2-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Realtek vendor: Lenovo driver: N/A modules: wl pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:b852
class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 3-1:4 chip-ID: 0bda:8153 class-ID: 0000
serial: <filter>
IF: enp4s0f4u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 13.73 GiB (2.9%)
model: MZVL2512HCJQ-00BL2 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: CL1QGXA7 temp: 39.9 C scheme: GPT
