:: installing pacman (6.1.0-5) breaks dependency 'libalpm.so=13-64' required by libpamac
hello,What is the problem?
Exatly as stated…
You can workaround it in terminal
sudo pacman -R pamac-gtk
Or it is the gtk3 version
sudo pacman -R pamac-gtk3
Then update the system
sudo pacman -Syu
Hi @AliGholipour and welcome to the Manjaro community.
At face value, libpamac requires libalpm.so=13-64
and attempting to install
pacman (6.1.0-5) breaks that dependency.
Solving any issue usually requires sufficient input from you, the user. The following articles may help you use the forum more effectively.
Cheers.
checking dependencies...
:: removing pamac-gtk3 breaks dependency 'pamac-gtk' required by manjaro-application-utility
:: removing pamac-gtk3 breaks dependency 'pamac-gtk' required by pamac-tray-icon-plasma
i can’t remove
Then add the mentioned packages to the uninstall command
The packages were removed, but the error was not fixed
Which error?
Please provide the exact commands you entered along with the output from them, otherwise it’s difficult to know exactly what you have done.
sudo pacman -Syu  ✔
core is up to date
extra is up to date
multilib is up to date
:: Replace bashrc-manjaro with core/bash? [Y/n] y
:: Replace kcolorpicker with extra/kcolorpicker-qt5? [Y/n] y
:: Replace kimageannotator with extra/kimageannotator-qt5? [Y/n] y
resolving dependencies...
I am not a magician - I cannot possibly know what your issue is without any terminal output.
Do not post images but copy paste the text from the terminal - place it inside a code fence
example
``` $ sudo pacman -Syu :: Synchronizing package databases... core is up to date extra is up to date multilib is up to date :: Starting full system upgrade... there is nothing to do ```
libpamac is part of pamac-gtk3
Obviously you have not yet removed libpamac and depended packages as you were told…
sudo pacman -Syu
Try that.
sudo pacman -R libpamac
:: removing libpamac breaks dependency 'libpamac' required by libpamac-flatpak-plugin
:: removing libpamac breaks dependency 'libpamac>=11.6.3' required by pamac-cli
:: removing libpamac breaks dependency 'libpamac' required by python-manjaro-sdk
I have to delete said packages, right?
I tried and it didn’t work
Yes. Do that.
pamac-cli and libpamac is part of pamac-gtk3
So when I say keep adding - I must include pamac-gtk3 - and adding the packages mentioned which would otherwise block removal of pamac-gtk3
Getting the picture now?
sudo pacman -R pamac-gtk3 manjaro-application-utility pamac-tray-icon-plasma libpamac-flatpak-plugin python-manjaro-sdk
I removed pamac-gtk (pamac-gtk3 was not installed)
As far as it was possible to deduce from your comment you were removing the gtk3 version
but if the gtk version is the one - please replace mentions of gtk3 with gtk
what did I say about screenshots?
Oh sorry
