Can you now perform the update?
No,I can’t
sudo pacman -R pamac-gtk3 manjaro-application-utility pamac-tray-icon-plasma libpamac-flatpak-plugin python-manjaro-sdk
error: target not found: pamac-gtk3
error: target not found: manjaro-application-utility
error: target not found: pamac-tray-icon-plasma
Look, I think it’s done right
All you did was to repeat the earlier command to remove those applications,
Do you remember how to update a Manjaro system?
Yes XD
Then, please share the output from the update command if it fails again.
Otherwise, enjoy Manjaro.
Cheers.
sudo pacman -Syu
core is up to date
extra is up to date
multilib is up to date
:: Replace bashrc-manjaro with core/bash? [Y/n] y
:: Replace kcolorpicker with extra/kcolorpicker-qt5? [Y/n] y
:: Replace kimageannotator with extra/kimageannotator-qt5? [Y/n] y
resolving dependencies...
:: installing pacman (6.1.0-5) breaks dependency 'libalpm.so=13-64' required by libpamac
I can Fix ittttt
sudo -Rdd libpamac
Even if you seem now to have found a solution working for you, it is worth noting, this indicates a badly maintained system. Bad and unsynced mirrors, system not updated, broken update or something like that.
The version combination stated in the first post is in theory impossible (and that is why it errors out). It is the current version of the lib and an old version of the program. My guess is, you did not update in quite some time, and then you did a partial update updating only one package or the lib. That puts you in a totally unsupported state and is not the way to go on a rolling distribution, hopefully you now understand why.
i had exact same issue when i switched from stable to testing to get plasma6 but it was easily solved by removing the conflicting packages.
