Post Update KDE goes black after login attempt and locks up fully
As said after a regular update I cannot login into KDE anymore. It instantly freezes into a black screen where I cannot switch to any other console.
I can however switch to a different console and login. From there I noticed I updated from Ker 6.6.128 to 6.6.137. Could not switch back due to most drivers not working including internet.
In GRUB I had 3 older snapshots youngest was just the day before with 6.6.128 and it worked flawlessly. So I thought it’s a kernel issue or perhaps a amdgpu driver issue in the new kernel update. Just to make sure installed kernel 6.1. and 6.12. so I could test and see which kernel is stabile for regular updates. Updated Grub and because I am quite new to linux used Timeshift to set this new snapshot as the default to run from.
Reboot: Worked fine, it picked up ker 6.12. and ran smoothly. Thought to myself ok time to update everything, reboot to make sure. Lo and behold, same issue again just now on 6.12.
That burned away one of my snapshots so I only have 2 left that work, and am at an end and am asking for assistance.
How can I figure out what is causing the issue?
How can I fix it?
PS: Running KDE plasma 6.5.6. right now kernel 6.6.128-1 (this one works), amdgpu (the version that comes with kernel) on a Ryzen 5700x with a Radeon RX570
Hi @AxelAlexson, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
inxi --filter --verbosity=8 --color=0
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
I suspect this will help find your cause:
Finding errors for specific boot
journalctl --priority=warning..crit --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • the --no-pager formats the output nicely for use here, on the forum; and
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth.
More:
Note that the above text is partially pre-prepared as general instructions. Please take the time to follow the given links and learn more.
Hi,
Thank you for your guidance on how to post information correctly.
inxi gives:
  Kernel: 6.6.128-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2026-05-02_16-55-56/@/boot/vmlinuz-6.6-x86_64
    root=UUID=ae844041-08e0-4f34-91c4-b544c2247f6d quiet splash
    resume=UUID=a7cb9238-4cab-4b7f-8a86-5d86a18d4f63 udev.log_priority=3
    rootflags=defaults,discard=async,ssd,subvol=timeshift-btrfs/snapshots/2026-05-02_16-55-56/@
  Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A info: frameworks v: 6.24.0
  Type: Desktop Mobo: Gigabyte model: AX370-Gaming 5
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: F52 date: 03/22/2024
  System RAM: total: 16 GiB available: 15.53 GiB used: 10.31 GiB (66.4%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: G.Skill part-no: F4-3200C15-8GVK
    serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
    serial: N/A
  Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2200 min/max: 2200/4663 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 108833
    ht hw_pstate ibpb ibpb_exit_to_user ibrs ibs invpcid irperf lahf_lm lbrv
    lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
    rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif
    vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave
    xsavec xsaveerptr xsaveopt xsaves
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Sapphire Nitro+ driver: amdgpu
    v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20
    pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-2,DVI-D-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 0a:00.0 chip-ID: 1002:67df
    class-ID: 0300 temp: 50.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 4480x2520
    display-ID: 0
  Monitor-1: DP-2 pos: bottom-r model: HP 727pq serial: <filter> built: 2025
    res: mode: 2560x1440 hz: 120 scale: 100% (1) dpi: 109 gamma: 1.2 chroma:
    red: x: 0.682 y: 0.318 green: x: 0.255 y: 0.694 blue: x: 0.137 y: 0.051
    white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
    720x576, 720x480, 640x480, 720x400
  Monitor-2: DVI-D-1 pos: primary,top-left model: AOC 2450W serial: <filter>
    built: 2011 res: mode: 1920x1080 hz: 60 scale: 151% (1.51) to: 1271x2259
    dpi: 94 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green: x: 0.282 y: 0.608
    blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
    size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1280x720, 1024x768, 832x624, 800x600, 640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (radeonsi
    polaris10 ACO DRM 3.54 6.6.128-1-MANJARO) device-ID: 1002:67df
    memory: 7.81 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 570 Series (RADV POLARIS10) driver: mesa radv v: 26.0.2-arch1.1
    device-ID: 1002:67df surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: Sapphire driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.6.128-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
  IF: enp5s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte
    driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 06:00.0 chip-ID: 1969:e0b1 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  Device-3: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:24fd
    class-ID: 0280
  IF: wlp9s0 state: up mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-13:4 chip-ID: 8087:0a2b
    class-ID: e001
  Local Storage: total: 5.23 TiB used: 4.15 TiB (79.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 37.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1CH164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD30EURS-63R8UY0 size: 2.73 TiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
    scheme: GPT
  ID-1: / raw-size: 121.09 GiB size: 121.09 GiB (100.00%)
    used: 59.77 GiB (49.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: ae844041-08e0-4f34-91c4-b544c2247f6d
    used: 612 KiB (0.2%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 645C-9F33
  ID-3: /home raw-size: 94.73 GiB size: 94.73 GiB (100.00%)
    used: 68.86 GiB (72.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 2f1636ad-9889-49c8-87e3-96a16349b08a
  ID-4: /run/media/josts/08E80A9FE80A8AE0 raw-size: 292.27 GiB
    size: 292.27 GiB (100.00%) used: 87.22 GiB (29.8%) fs: ntfs
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: 08E80A9FE80A8AE0
  ID-5: /run/media/josts/KEWDR raw-size: 1.57 TiB size: 1.57 TiB (100.00%)
    used: 1.28 TiB (81.1%) fs: ntfs dev: /dev/sdb6 maj-min: 8:22 label: KEWDR
    uuid: F07A26F57A26B7EC
  ID-6: /run/media/josts/Kevdr raw-size: 172.36 GiB
    size: 169.47 GiB (98.32%) used: 42.02 GiB (24.8%) fs: ext4 dev: /dev/sdb5
    maj-min: 8:21 label: Kevdr uuid: d2e3de67-6eee-4a79-8ba2-57547c68deaa
  ID-7: /run/media/josts/LLC raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
    used: 2.55 TiB (93.4%) fs: ntfs dev: /dev/sdc2 maj-min: 8:34 label: LLC
    uuid: 5A601C5B601C3FE5
  ID-8: /run/media/josts/STIGHED raw-size: 169.92 GiB
    size: 169.92 GiB (100.00%) used: 78.51 GiB (46.2%) fs: ntfs
    dev: /dev/nvme0n1p5 maj-min: 259:5 label: STIGHED uuid: B23C464F3C460EB3
  ID-9: /var/cache raw-size: 121.09 GiB size: 121.09 GiB (100.00%)
  ID-10: /var/log raw-size: 121.09 GiB size: 121.09 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.77 GiB used: 47.2 MiB (0.3%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: a7cb9238-4cab-4b7f-8a86-5d86a18d4f63
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 02E9-9D97
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 710 MiB fs: ntfs label: N/A
    uuid: F26283F66283BE3B
  ID-4: /dev/sdb1 maj-min: 8:17 size: 1 KiB fs: <superuser required>
  ID-5: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: <superuser required>
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Device-1: 1-1:2 info: Wooting WootingTwoHE type: keyboard,HID
    driver: hid-generic,usbhid,xpad interfaces: 6 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
    chip-ID: 31e3:1220 class-ID: 0300 serial: <filter>
  Device-2: 1-2:3 info: ROCCAT Kone Pure Mouse type: mouse,keyboard
    driver: konepure,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 200mA chip-ID: 1e7d:2dbe class-ID: 0300
  Device-3: 1-13:4 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 5-3:2 info: HP 4-Port USB 2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 03f0:0bb2
  Device-1: 5-3.5:3 info: Realtek USB2.0 HID type: HID
    chip-ID: 0bda:1100 class-ID: 0300
  Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-8: 6-3:2 info: HP 4-Port USB 3.0 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 03f0:0fb1
  System Temperatures: cpu: 48.0 C mobo: 32.0 C gpu: amdgpu temp: 49.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0 fan-3: 660 gpu: amdgpu fan: 772
  Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.31 gpu: amdgpu watts: 40.05
  Packages: pm: pacman pkgs: 1878 libs: 527 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    2: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    3: https://manjaro.ynh.ovh/stable/$repo/$arch
    4: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    5: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    6: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    7: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 420
  1: cpu: 9.7% command: firefox pid: 9499 mem: 1199.5 MiB (7.5%)
  2: cpu: 6.1% command: rawtherapee pid: 29229 mem: 1234.6 MiB (7.7%)
  3: cpu: 3.0% command: kwin_wayland pid: 1036 mem: 348.0 MiB (2.1%)
  4: cpu: 2.7% command: firefox pid: 42987 mem: 609.1 MiB (3.8%)
  5: cpu: 2.1% command: firefox pid: 19567 mem: 332.6 MiB (2.0%)
  Memory top: 5 of 420
  1: mem: 1234.6 MiB (7.7%) command: rawtherapee pid: 29229 cpu: 6.1%
  2: mem: 1199.5 MiB (7.5%) command: firefox pid: 9499 cpu: 9.7%
  3: mem: 782.2 MiB (4.9%) command: firefox pid: 9971 cpu: 0.5%
  4: mem: 774.9 MiB (4.8%) command: firefox pid: 12271 cpu: 0.6%
  5: mem: 629.2 MiB (3.9%) command: firefox pid: 16373 cpu: 0.9%
  Processes: 420 Power: uptime: 1h 59m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.9 running-in: konsole inxi: 3.3.40
As for the journal: (LC_ALL=C did not translate into English all “Neveljavni argument” == “Invalid argument”. If there are any others left untranslated do tell)
LC_ALL=C journalctl --priority=warning..crit --no-pager --boot=-2                                                          ✔
May 12 14:11:39 Nuit kernel: pci 0000:06:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
May 12 14:11:39 Nuit kernel: ata1.00: supports DRM functions and may not be fully accessible
May 12 14:11:39 Nuit kernel: wmi_bus wmi_bus-PNP0C14:01: WQAA data block query control method not found
May 12 14:11:39 Nuit kernel: nvme nvme0: missing or invalid SUBNQN field.
May 12 14:11:39 Nuit kernel: usb: port power management may be unreliable
May 12 14:11:39 Nuit kernel: hid-generic 0003:31E3:1220.0001: offset (0) exceeds report_count (0)
May 12 14:11:39 Nuit kernel: hid-generic 0003:31E3:1220.0001: No inputs registered, leaving
May 12 14:11:39 Nuit systemd-modules-load[478]: Failed to find module 'ntsync'
May 12 14:11:40 Nuit kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20230628/utaddress-204)
May 12 14:11:40 Nuit kernel: input input9: unable to receive magic message: -32
May 12 14:11:40 Nuit kernel: Bluetooth: hci0: Reading supported features failed (-16)
May 12 14:11:40 Nuit kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
May 12 14:11:40 Nuit kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 0
May 12 14:11:40 Nuit kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
May 12 14:11:41 Nuit systemd-journald[477]: File /var/log/journal/8055a0268bcb4cf7877d1d7f43a04cee/system.journal corrupted or uncleanly shut down, renaming and replacing.
May 12 14:11:41 Nuit bluetoothd[743]: Failed to set default system config for hci0
May 12 14:11:42 Nuit kernel: ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
May 12 14:11:42 Nuit NetworkManager[741]: <warn>  [1778587902.2995] device (54:08:3B:C4:1D:7B): error setting IPv4 forwarding to '0': Neveljavni argument
May 12 14:11:42 Nuit NetworkManager[741]: <warn>  [1778587902.3000] device (44:55:C4:7D:5A:24): error setting IPv4 forwarding to '0': Neveljavni argument
May 12 14:11:42 Nuit NetworkManager[741]: <warn>  [1778587902.3804] device (p2p-dev-wlp9s0): error setting IPv4 forwarding to '0': Vir začasno ni na razpolago
May 12 14:11:46 Nuit kernel: input input9: unable to receive magic message: -32
May 12 14:11:46 Nuit dbus-broker-launch[739]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
May 12 14:11:47 Nuit dbus-broker-launch[917]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
May 12 14:11:47 Nuit dbus-broker-launch[917]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
May 12 14:11:47 Nuit dbus-broker-launch[917]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
May 12 14:11:47 Nuit kernel: sddm-greeter-qt[914]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
May 12 14:11:47 Nuit sddm-greeter-qt6[914]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
May 12 14:11:48 Nuit sddm-greeter-qt6[914]: Member contentWidth of the object PopupList_QMLTYPE_151 overrides a member of the base object. Consider renaming it or adding final or override specifier
May 12 14:11:48 Nuit sddm-greeter-qt6[914]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.22'
May 12 14:11:58 Nuit sddm-greeter-qt6[914]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
May 12 14:11:58 Nuit kernel: input input9: unable to receive magic message: -32
May 12 14:11:58 Nuit NetworkManager[741]: <warn>  [1778587918.8520] device (wlp9s0): no secrets: No agents were available for this request.
May 12 14:11:58 Nuit NetworkManager[741]: <warn>  [1778587918.8522] device (wlp9s0): Activation: failed for connection 'AML5'
May 12 14:11:59 Nuit systemd-journald[477]: File /var/log/journal/8055a0268bcb4cf7877d1d7f43a04cee/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
May 12 14:11:59 Nuit kernel: input input9: unable to receive magic message: -32
May 12 14:11:59 Nuit dbus-broker-launch[1046]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
May 12 14:11:59 Nuit dbus-broker-launch[1046]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
May 12 14:11:59 Nuit dbus-broker-launch[1046]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
May 12 14:11:59 Nuit /usr/lib/xdg-desktop-portal[1069]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
May 12 14:12:00 Nuit kwin_wayland[1062]: Atomic modeset test failed! Neveljavni argument
May 12 14:12:00 Nuit kwin_wayland[1062]: Applying output configuration failed!
May 12 14:12:00 Nuit kwin_wayland[1062]: XKB: Multiple definitions of group 0 name in map 'basic'; Using 'Slovenian', ignoring 'Serbian (Latin)'
May 12 14:12:00 Nuit kded6[1226]: QDBusObjectPath: invalid path "/modules/wpad-detector"
May 12 14:12:00 Nuit kded6[1226]: The kded module name "wpad-detector" is invalid!
May 12 14:12:00 Nuit kded6[1226]: QDBusObjectPath: invalid path "/modules/oom-notifier"
May 12 14:12:00 Nuit kded6[1226]: The kded module name "oom-notifier" is invalid!
May 12 14:12:00 Nuit kded6[1226]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
May 12 14:12:00 Nuit kded6[1226]: The kded module name "plasma-session-shortcuts" is invalid!
May 12 14:12:00 Nuit plasmashell[1291]: Could not find required file "mainscript" for package "/usr/share/plasma/plasmoids/org.kde.plasma.icontasks/" should be QList("ui/main.qml")
May 12 14:12:01 Nuit kded6[1226]: Failed to connect to Bolt manager DBus interface:
May 12 14:12:01 Nuit kconf_update[1447]: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
May 12 14:12:01 Nuit kconf_update[1447]: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
May 12 14:12:01 Nuit kwalletd6[1455]: g_dbus_proxy_get_object_path: assertion 'G_IS_DBUS_PROXY (proxy)' failed
May 12 14:12:01 Nuit kded6[1226]: PendingCall Error: "The name is not activatable"
May 12 14:12:02 Nuit org_kde_powerdevil[1364]: [  1364] Watching for DPMS state changes unimplemented
May 12 14:12:02 Nuit kwin_wayland[1062]: Atomic modeset test failed! Neveljavni argument
May 12 14:12:02 Nuit kwin_wayland[1062]: Applying output configuration failed!
Mind you the: Inxi data is from this session that works. I am not sure how to copy and post the exact data from the one that does not, since Ihave no internet in that instance.
Thank you.
You are more than welcome!
Unfortunaly I do not see any problems. However, that doesn’t mean much, and I’m pretty sure someone else will. So I’d say just hang tight.
Hope you manage!
So, your first step now is to learn how to perform a rollback without losing a snapshot!
:footprints:
This is covered in the Timeshift manual.
After booting into a (writable) snapshot, it is absolutely essential that you create a new snapshot before you begin any experimenting.
You will find a wealth of useful information in the forum if you search for “Snapshot” or “Rollback.”
I don’t know what has happened - but there is something strange going on with Plasma using sddm.
Buildiso creates unusable ISOs after latest update - #13 by linux-aarhus
Now I cannot say that switching to plasma-login-manager will solve your specific issue - especially I don’t know the effect if you are using X11 - but I think it is worth a try.
When you have signed on to a TTY console run the following commands
sudo pacman -Syu plasma-login-manager
sudo systemctl enable plasmalogin --force
reboot
Excellent idea and doing so right away :smiley:
Was switching from SDDM to plasma-login-manager effective at solving your problem? I just want to know because I’m experiencing the same problem and if it worked for you, then we can provide this as a solution for others!
Thanks.
