Hey guys, installed manjaro a few days wanting to stop the distro-hopping that has cursed me the past 6 years of my linux journey. Everything worked out pretty nice, i have configured it to my liking, but I have one problem. Every time when the machine boots I will get no audio for around ~5 minutes, at which point the sound will automatically come back and work fine for the rest of the session, without any problems. There’s a lot of sound topics on the forums, but i dont think ive encountered this, its quite peculiar. Do we know what could cause this, or how we can fix it? Thanks.
(Im guessing i should provide logs, but i dont see a template anywhere, quite new to the forum site, so please let me know what i should provide, to help you guys out)
Edit(Include Logs):
Output of inxi --full --admin --filter --width
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=46369e0b-406b-4945-99f7-78840c1d7abf rw rootflags=subvol=@ quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASRock model: B450 Gaming K4 serial: <superuser required>
UEFI: American Megatrends v: P5.10 date: 08/04/2021
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2317 high: 3758 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 2200 5: 2200 6: 2199 7: 2200 8: 2199 9: 2200 10: 3758 11: 2150
12: 2100 bogomips: 86439
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 0a:00.0 chip-ID: 10de:2187
class-ID: 0300
Device-2: Aveo USB2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 1871:0143
class-ID: 0102
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: Unknown-1 mapped: DP-0 res: 1920x1080 dpi: 80
size: 608x348mm (23.94x13.7") modes: 1920x1080
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650
SUPER/PCIe/SSE2 memory: 3.91 GiB
API: Vulkan v: 1.3.274 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 SUPER driver: nvidia v: 545.29.06 device-ID: 10de:2187
surfaces: xcb,xlib
Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
bus-ID: 0a:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Aveo USB2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
class-ID: 0102
Device-4: Razer USA Seiren Mini driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:3
chip-ID: 1532:0531 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: proton0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Local Storage: total: 1.58 TiB used: 222.74 GiB (13.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 041 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A02 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: DT 101 II
size: 7.47 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP
ID-1: / raw-size: 231.91 GiB size: 231.91 GiB (100.00%)
used: 37.05 GiB (16.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 231.91 GiB size: 231.91 GiB (100.00%)
ID-4: /var/log raw-size: 231.91 GiB size: 231.91 GiB (100.00%)
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 42 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 23%
Processes: 391 Uptime: 7m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 6.9 GiB (44.4%) Init: systemd v: 254
Packages: 1469 pm: pacman pkgs: 1463 libs: 424 tools: pamac,yay pm: flatpak
pkgs: 6 Shell: fish v: 3.6.4 running-in: tmux: inxi: 3.3.31
Output of sudo dmesg --level emerg,alert,crit,err,warn
[ 2.603937] nvme nvme0: missing or invalid SUBNQN field.
[ 4.110582] hid-generic 0003:1532:0531.0001: No inputs registered, leaving
[ 4.433567] nvidia: loading out-of-tree module taints kernel.
[ 4.433591] nvidia: module license 'NVIDIA' taints kernel.
[ 4.433592] Disabling lock debugging due to kernel taint
[ 4.433597] nvidia: module license taints kernel.
[ 4.998201] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu Nov 16 01:59:08 UTC 2023
[ 5.271251] nvidia-gpu 0000:0a:00.3: i2c timeout error e0000000
[ 5.271258] ucsi_ccg 1-0008: i2c_transfer failed -110
[ 5.271260] ucsi_ccg 1-0008: ucsi_ccg_init failed - -110
[ 5.271263] ucsi_ccg: probe of 1-0008 failed with error -110
[ 5.734382] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 6.159750] sd 8:0:0:0: [sdc] No Caching mode page found
[ 6.159752] sd 8:0:0:0: [sdc] Assuming drive cache: write through
[ 9.407034] usb 5-1: 3:1: cannot set freq 48000 to ep 0x84
[ 9.482941] usb 5-1: Warning! Unlikely big volume range (=8191), cval->res is probably wrong.
[ 9.482945] usb 5-1: [3] FU [Mic Capture Volume] ch = 1, val = 0/8191/1
[ 9.999569] Xorg[619]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 16.542112] systemd-journald[320]: File /var/log/journal/9603191f6cdb47ebba21b046b907248c/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Output of journalctl --catalog --priority=3 --boot=-1
Jan 11 19:48:10 manjaro-plasma kernel: hid-generic 0003:1532:0531.0001: No inputs registered, leaving
Jan 11 19:48:11 manjaro-plasma kernel:
Jan 11 19:48:11 manjaro-plasma kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu No>
Jan 11 19:48:11 manjaro-plasma kernel: nvidia-gpu 0000:0a:00.3: i2c timeout error e0000000
Jan 11 19:48:11 manjaro-plasma kernel: ucsi_ccg 3-0008: i2c_transfer failed -110
Jan 11 19:48:11 manjaro-plasma kernel: ucsi_ccg 3-0008: ucsi_ccg_init failed - -110
I dont know if there is any audio specific log/command so please let me know, so that i can post that too.
