Pamac freezes system while installing or removing packages
Recently Pamac started to make the whole system freeze while installing or removing packages
inxi -F                                                          ✔
  Host: julio-550xbe350xbe Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64
    Desktop: GNOME v: 42.1 Distro: Manjaro Linux
  Type: Laptop System: SAMSUNG product: 550XBE/350XBE v: P10REU
    serial: <superuser required>
  Mobo: SAMSUNG model: NP350XBE-KD1BR
    v: SGL9970A0B-C01-G001-S0001+10.0.17763 serial: <superuser required>
    UEFI: American Megatrends v: P10REU.088.200306.JJ date: 03/06/2020
  ID-1: BAT1 charge: 19.9 Wh (67.2%) condition: 29.6/43.1 Wh (68.8%)
  Info: quad core model: Intel Core i5-8265U bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 2468 min/max: 400/3900 cores: 1: 2348 2: 2358 3: 2519
    4: 2519 5: 2500 6: 2500 7: 2500 8: 2500
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] driver: i915 v: kernel
  Device-2: Silicon Motion Web Camera type: USB driver: uvcvideo
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
    compositor: gnome-shell driver: X: loaded: modesetting gpu: i915
    resolution: 1360x768~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
    v: 4.6 Mesa 22.0.3
  Device-1: Intel Cannon Point-LP High Definition Audio driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 15.0 running: yes
  Sound Server-3: PipeWire v: 0.3.51 running: yes
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    driver: ath10k_pci
  IF: wlp1s0 state: down mac: 82:e0:55:83:e7:67
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: 98:83:89:f1:2b:7b
  Device-1: Qualcomm Atheros type: USB driver: btusb
  Local Storage: total: 931.51 GiB used: 421.65 GiB (45.3%)
  ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-35Z10T0
  ID-1: / size: 906.86 GiB used: 421.65 GiB (46.5%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/sda1
  ID-1: swap-1 type: partition size: 8.8 GiB used: 3.8 MiB (0.0%)
    dev: /dev/sda3
  System Temperatures: cpu: 48.0 C pch: 44.0 C mobo: 48.0 C
  Processes: 275 Uptime: 3h 14m Memory: 7.66 GiB used: 2.13 GiB (27.8%)
  Shell: Zsh inxi: 3.3.15
A good start to find why would be the journal:
Specifically, journalctl --boot=-1 --priority=3 --catalog would show all errors or worse in the log of the current session.
If the machine freezes only while running pamac following the log with journalctl --follow could show if there is a immediate issue specificly while running pamac.
Can you describe in more detail what happens when your system freezes? is it temporary, does mouse movement still happen, can you switch to other active applications etc.
Temporary freeze, lasts for a few seconds, mouse doesn’t move while frozen, can’t open activities, can’t alt tab, the system completely freezes for a few seconds, i have just ran Pamac again and it did not freeze this time.
mai 19 16:56:39 julio-550xbe350xbe kernel: x86/cpu: SGX disabled by BIOS.
mai 19 16:56:39 julio-550xbe350xbe kernel: ACPI BIOS Error (bug): Could not res>
mai 19 16:56:39 julio-550xbe350xbe kernel: ACPI Error: Aborting method \_SB.PCI>
mai 19 16:57:06 julio-550xbe350xbe kernel: snd_hda_codec_hdmi hdaudioC0D2: Moni>
mai 19 16:57:16 julio-550xbe350xbe bluetoothd[842]: src/device.c:set_wake_allow>
mai 19 16:57:42 julio-550xbe350xbe gnome-session-binary[3150]: GLib-GIO-CRITICA>
mai 19 16:59:14 julio-550xbe350xbe gdm-password][10661]: gkr-pam: unable to loc>
mai 19 16:59:34 julio-550xbe350xbe gdm-launch-environment][918]: GLib-GObject: >
mai 19 23:58:22 julio-550xbe350xbe systemd-coredump[411751]: Failed to connect >
mai 19 23:58:24 julio-550xbe350xbe pulseaudio[12649]: Lost I/O connection in mo>
The log does not show anything that I would follow up upon for the issue experienced. Try the journalctl --follow while installing / removing a package. One possible cause could be a rebuild of a package from source (if you use the AUR) that strains the CPU. Running system monitor at the same time might give you some insight into what happens.
It froze while installing and removing packages from Manjaro’s repo
The freezes once again occurred, they occur if i do basic stuff while installing or removing packages, i start to install updates, then i opened Brave browser and it froze for a few seconds.
journalctl --follow                                              ✔
mai 20 21:55:59 julio-550xbe350xbe ananicy[865]: ioclass: file-roller[534559/534567] best-effort -> idle
mai 20 21:55:59 julio-550xbe350xbe ananicy[865]: sched: file-roller[534559/534567] normal -> idle
mai 20 21:55:59 julio-550xbe350xbe ananicy[865]: renice: file-roller[534559/534568] 0 -> 19
mai 20 21:55:59 julio-550xbe350xbe ananicy[865]: ioclass: file-roller[534559/534568] best-effort -> idle
mai 20 21:55:59 julio-550xbe350xbe ananicy[865]: sched: file-roller[534559/534568] normal -> idle
mai 20 21:55:59 julio-550xbe350xbe ananicy[865]: renice: file-roller[534559/534569] 0 -> 19
mai 20 21:55:59 julio-550xbe350xbe ananicy[865]: ioclass: file-roller[534559/534569] best-effort -> idle
mai 20 21:55:59 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:55:59 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:01 julio-550xbe350xbe systemd[33440]: Started Application launched by gnome-shell.
mai 20 21:56:04 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:04 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:08 julio-550xbe350xbe systemd[1]: fprintd.service: Deactivated successfully.
mai 20 21:56:08 julio-550xbe350xbe kernel: audit: type=1131 audit(1653094568.784:334): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:56:08 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094568.811:335): prog-id=0 op=UNLOAD
mai 20 21:56:08 julio-550xbe350xbe audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:56:08 julio-550xbe350xbe audit: BPF prog-id=0 op=UNLOAD
mai 20 21:56:09 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:09 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:14 julio-550xbe350xbe dbus-daemon[859]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.225' (uid=1000 pid=535719 comm="pamac-manager --updates")
mai 20 21:56:14 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:14 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:14 julio-550xbe350xbe systemd[1]: Starting Pamac Daemon...
mai 20 21:56:15 julio-550xbe350xbe kernel: audit: type=1130 audit(1653094575.001:336): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:56:15 julio-550xbe350xbe audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:56:15 julio-550xbe350xbe dbus-daemon[859]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
mai 20 21:56:15 julio-550xbe350xbe systemd[1]: Started Pamac Daemon.
mai 20 21:56:15 julio-550xbe350xbe pamac-manager[535719]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
mai 20 21:56:15 julio-550xbe350xbe pamac-manager[535719]: flatpak_plugin.vala:330: refreshing flathub appstream data
mai 20 21:56:18 julio-550xbe350xbe pamac-manager[535719]: libostree pull from 'flathub' for appstream2/x86_64 complete
                                                          security: GPG: summary+commit
                                                          security: SIGN: disabled http: TLS
                                                          non-delta: meta: 4 content: 1
                                                          transfer: secs: 2 size: 5,3 MB
mai 20 21:56:18 julio-550xbe350xbe pamac-manager[535719]: /var/tmp/flatpak-cache-KK7HM1/repo-8iTZHa: Pulled appstream2/x86_64 from flathub
mai 20 21:56:18 julio-550xbe350xbe dbus-daemon[859]: [system] Activating via systemd: service name='org.freedesktop.Flatpak.SystemHelper' unit='flatpak-system-helper.service' requested by ':1.225' (uid=1000 pid=535719 comm="pamac-manager --updates")
mai 20 21:56:18 julio-550xbe350xbe systemd[1]: Starting flatpak system helper...
mai 20 21:56:18 julio-550xbe350xbe dbus-daemon[859]: [system] Successfully activated service 'org.freedesktop.Flatpak.SystemHelper'
mai 20 21:56:18 julio-550xbe350xbe systemd[1]: Started flatpak system helper.
mai 20 21:56:18 julio-550xbe350xbe kernel: audit: type=1130 audit(1653094578.971:337): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=flatpak-system-helper comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:56:18 julio-550xbe350xbe audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=flatpak-system-helper comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:56:19 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:19 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:21 julio-550xbe350xbe flatpak-system-helper[536841]: system: Pulled appstream2/x86_64 from /var/tmp/flatpak-cache-KK7HM1/repo-8iTZHa
mai 20 21:56:24 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:24 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:28 julio-550xbe350xbe dbus-daemon[859]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.225' (uid=1000 pid=535719 comm="pamac-manager --updates")
mai 20 21:56:28 julio-550xbe350xbe audit: BPF prog-id=72 op=LOAD
mai 20 21:56:28 julio-550xbe350xbe audit: BPF prog-id=73 op=LOAD
mai 20 21:56:28 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094588.274:338): prog-id=72 op=LOAD
mai 20 21:56:28 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094588.274:339): prog-id=73 op=LOAD
mai 20 21:56:28 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094588.274:340): prog-id=74 op=LOAD
mai 20 21:56:28 julio-550xbe350xbe kernel: audit: type=1130 audit(1653094588.361:341): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:56:28 julio-550xbe350xbe audit: BPF prog-id=74 op=LOAD
mai 20 21:56:28 julio-550xbe350xbe audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:56:28 julio-550xbe350xbe systemd[1]: Starting Locale Service...
mai 20 21:56:28 julio-550xbe350xbe dbus-daemon[859]: [system] Successfully activated service 'org.freedesktop.locale1'
mai 20 21:56:28 julio-550xbe350xbe systemd[1]: Started Locale Service.
mai 20 21:56:29 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:29 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:33 julio-550xbe350xbe dbus-daemon[859]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.229' (uid=0 pid=537918 comm="/usr/lib/polkit-1/polkit-agent-helper-1 julio")
mai 20 21:56:33 julio-550xbe350xbe audit: BPF prog-id=75 op=LOAD
mai 20 21:56:33 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094593.954:342): prog-id=75 op=LOAD
mai 20 21:56:34 julio-550xbe350xbe systemd[1]: Starting Fingerprint Authentication Daemon...
mai 20 21:56:34 julio-550xbe350xbe dbus-daemon[859]: [system] Successfully activated service 'net.reactivated.Fprint'
mai 20 21:56:34 julio-550xbe350xbe systemd[1]: Started Fingerprint Authentication Daemon.
mai 20 21:56:34 julio-550xbe350xbe audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:56:34 julio-550xbe350xbe kernel: audit: type=1130 audit(1653094594.174:343): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:56:34 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:34 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:38 julio-550xbe350xbe audit[537918]: USER_AUTH pid=537918 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="julio" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
mai 20 21:56:38 julio-550xbe350xbe kernel: audit: type=1100 audit(1653094598.341:344): pid=537918 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="julio" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
mai 20 21:56:38 julio-550xbe350xbe kernel: audit: type=1101 audit(1653094598.341:345): pid=537918 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julio" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
mai 20 21:56:38 julio-550xbe350xbe audit[537918]: USER_ACCT pid=537918 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="julio" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
mai 20 21:56:38 julio-550xbe350xbe dbus-daemon[859]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.231' (uid=0 pid=537918 comm="/usr/lib/polkit-1/polkit-agent-helper-1 julio")
mai 20 21:56:38 julio-550xbe350xbe dbus-daemon[859]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
mai 20 21:56:38 julio-550xbe350xbe polkit-agent-helper-1[537918]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
mai 20 21:56:38 julio-550xbe350xbe polkitd[860]: Operator of unix-session:3 successfully authenticated as unix-user:julio to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.225 [pamac-manager --updates] (owned by unix-user:julio)
mai 20 21:56:39 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:39 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:44 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:44 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:45 julio-550xbe350xbe gnome-shell[33509]: updates_checker.vala:71: check updates
mai 20 21:56:48 julio-550xbe350xbe gnome-shell[33509]: updates_checker.vala:101: 2 updates found
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9609eb800), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d96359a790), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: == Stack trace for context 0x55d9609d0640 ==
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:193 (132cd84ebe20 @ 89)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   55d96160d898 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80dbf0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d9e0 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:222 (132cd84ebe70 @ 63)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:194 (132cd84ebe20 @ 161)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #2   55d96160d898 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80dbf0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d9e0 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:223 (132cd84ebe70 @ 86)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d9e0 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:224 (132cd84ebe70 @ 116)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d9e0 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:225 (132cd84ebe70 @ 130)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d960af7480), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:195 (132cd84ebe20 @ 205)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:196 (132cd84ebe20 @ 238)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d9e0 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:180 (132cd84ebd80 @ 118)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:213 (132cd84ebe20 @ 505)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80dde0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9639bc7a0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80dde0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d5a0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:193 (132cd84ebe20 @ 89)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80dfd0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:222 (132cd84ebe70 @ 63)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80d5a0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:194 (132cd84ebe20 @ 161)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80dfd0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:223 (132cd84ebe70 @ 86)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:224 (132cd84ebe70 @ 116)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:225 (132cd84ebe70 @ 130)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d5a0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:195 (132cd84ebe20 @ 205)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d5a0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:196 (132cd84ebe20 @ 238)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:180 (132cd84ebd80 @ 118)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80d5a0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:213 (132cd84ebe20 @ 505)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d790 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:193 (132cd84ebe20 @ 89)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80e1c0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80d790 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:194 (132cd84ebe20 @ 161)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80e1c0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d790 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:195 (132cd84ebe20 @ 205)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d790 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:196 (132cd84ebe20 @ 238)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80d790 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:213 (132cd84ebe20 @ 505)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d980 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:193 (132cd84ebe20 @ 89)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80e3b0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d963947b50), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80d980 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:194 (132cd84ebe20 @ 161)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80e3b0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d980 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:195 (132cd84ebe20 @ 205)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d980 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:196 (132cd84ebe20 @ 238)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80d980 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:213 (132cd84ebe20 @ 505)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80db70 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:193 (132cd84ebe20 @ 89)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80e5a0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80db70 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:194 (132cd84ebe20 @ 161)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80e5a0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80db70 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:195 (132cd84ebe20 @ 205)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80db70 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:196 (132cd84ebe20 @ 238)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80db70 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:213 (132cd84ebe20 @ 505)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d964910640), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d964910640), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: updates_checker.vala:101: 2 updates found
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d96383bdd0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d966e79d70), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d963aa7480), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9635d1440), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d962f9b580), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96493d510), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96493d510), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d96358e480), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d9670089d0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d962db2fb0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d963985400), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d961f1bc40), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9649e4a20), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9649e4a20), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9649e8300), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d9659fe350), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d963607330), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d966c05440), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9637c4440), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96260dc10), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96260dc10), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d960f107e0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d960b0a8b0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9625f2700), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9661e0a60), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d961c46040), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96205a840), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96205a840), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9625b2370), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d9625b5570), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9625baf00), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9625b7d90), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9625c4330), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9625b4440), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9625b4440), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:49 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:49 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: AER: Corrected error received: 0000:00:1d.1
mai 20 21:56:49 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
mai 20 21:56:49 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:   device [8086:9db1] error status/mask=00001000/00002000
mai 20 21:56:49 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:    [12] Timeout
mai 20 21:56:54 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:54 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:56:55 julio-550xbe350xbe systemd[33440]: Started Application launched by gnome-shell.
mai 20 21:56:59 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:56:59 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:03 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: AER: Corrected error received: 0000:00:1d.1
mai 20 21:57:03 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
mai 20 21:57:03 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:   device [8086:9db1] error status/mask=00001000/00002000
mai 20 21:57:03 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:    [12] Timeout
mai 20 21:57:04 julio-550xbe350xbe gnome-keyring-daemon[33452]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
mai 20 21:57:04 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: AER: Corrected error received: 0000:00:1d.1
mai 20 21:57:04 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
mai 20 21:57:04 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:   device [8086:9db1] error status/mask=00001000/00002000
mai 20 21:57:04 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:    [12] Timeout
mai 20 21:57:04 julio-550xbe350xbe systemd[1]: fprintd.service: Deactivated successfully.
mai 20 21:57:04 julio-550xbe350xbe audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:57:04 julio-550xbe350xbe kernel: audit: type=1131 audit(1653094624.788:346): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:57:04 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094624.828:347): prog-id=0 op=UNLOAD
mai 20 21:57:04 julio-550xbe350xbe audit: BPF prog-id=0 op=UNLOAD
mai 20 21:57:05 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:05 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:06 julio-550xbe350xbe gnome-shell[539122]: libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
mai 20 21:57:07 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: AER: Corrected error received: 0000:00:1d.1
mai 20 21:57:07 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
mai 20 21:57:07 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:   device [8086:9db1] error status/mask=00001000/00002000
mai 20 21:57:07 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:    [12] Timeout
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: sched: file-roller[534559/534569] normal -> idle
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539076] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539087] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539099] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539100] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539101] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539102] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539103] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539104] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539105] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539106] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539107] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539108] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539109] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539110] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539112] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539113] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539114] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539115] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539116] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539117] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539118] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539119] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539120] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539121] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539130] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539095/539095] 0 -> -3
mai 20 21:57:09 julio-550xbe350xbe ananicy[865]: renice: brave[539096/539096] 0 -> -3
mai 20 21:57:10 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:10 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:12 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: AER: Corrected error received: 0000:00:1d.1
mai 20 21:57:12 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
mai 20 21:57:12 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:   device [8086:9db1] error status/mask=00001000/00002000
mai 20 21:57:12 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:    [12] Timeout
mai 20 21:57:14 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:14 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:14 julio-550xbe350xbe ananicy[865]: renice: brave[539098/539098] 0 -> -3
mai 20 21:57:14 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539122] 0 -> -3
mai 20 21:57:14 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539144] 19 -> -3
mai 20 21:57:14 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539145] 0 -> -3
mai 20 21:57:14 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539146] 0 -> -3
mai 20 21:57:14 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539147] 0 -> -3
mai 20 21:57:14 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539148] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539149] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539150] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539151] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539153] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539154] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539155] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539156] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539157] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539163] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539164] 19 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539165] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539166] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539167] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539168] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539169] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539122/539170] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539124/539124] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539124/539125] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539124/539126] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539124/539127] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539124/539128] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539124/539129] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539124/539131] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539124/539132] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539124/539133] 0 -> -3
mai 20 21:57:15 julio-550xbe350xbe ananicy[865]: renice: brave[539124/539134] 0 -> -3
mai 20 21:57:18 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: AER: Corrected error received: 0000:00:1d.1
mai 20 21:57:18 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
mai 20 21:57:18 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:   device [8086:9db1] error status/mask=00001000/00002000
mai 20 21:57:18 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:    [12] Timeout
mai 20 21:57:18 julio-550xbe350xbe kernel: audit: type=1131 audit(1653094635.905:348): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:57:15 julio-550xbe350xbe audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:57:19 julio-550xbe350xbe audit: BPF prog-id=0 op=UNLOAD
mai 20 21:57:19 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094639.415:349): prog-id=0 op=UNLOAD
mai 20 21:57:19 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094639.415:350): prog-id=0 op=UNLOAD
mai 20 21:57:19 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094639.415:351): prog-id=0 op=UNLOAD
mai 20 21:57:15 julio-550xbe350xbe systemd[1]: systemd-localed.service: Deactivated successfully.
mai 20 21:57:19 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:19 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539204] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539205] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539206] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539207] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539208] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539209] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539210] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539211] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539076/539212] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539076/540230] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539158/539158] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539158/539159] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539158/539160] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539158/539161] 0 -> -3
mai 20 21:57:20 julio-550xbe350xbe ananicy[865]: renice: brave[539158/539162] 0 -> -3
mai 20 21:57:21 julio-550xbe350xbe gnome-shell[539076]: [539076:539076:0520/215721.562170:ERROR:network_service_instance_impl.cc(978)] Network service crashed, restarting service.
mai 20 21:57:24 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:24 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[539076/540309] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[539158/540290] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540231] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540233] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540235] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540237] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540238] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540241] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540232] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540234] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540236] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540239] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540240] 0 -> -3
mai 20 21:57:25 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540242] 0 -> -3
mai 20 21:57:29 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: AER: Corrected error received: 0000:00:1d.1
mai 20 21:57:29 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
mai 20 21:57:29 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:   device [8086:9db1] error status/mask=00001000/00002000
mai 20 21:57:29 julio-550xbe350xbe kernel: pcieport 0000:00:1d.1:    [12] Timeout
mai 20 21:57:29 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:29 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540333] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540366] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540372] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540376] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540380] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540382] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540231/540384] 10 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540331] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540365] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540369] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540373] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540377] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540385] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540232/540387] 10 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540304] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540305] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540306] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540307] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540308] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540332] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540367] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540371] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540375] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540378] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540386] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540303/540388] 10 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540359] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540360] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540361] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540362] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540363] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540364] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540368] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540370] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540374] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540379] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540381] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540358/540383] 10 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540406] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540407] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540408] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540409] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540410] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540413] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540414] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540415] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540416] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540417] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540418] 0 -> -3
mai 20 21:57:30 julio-550xbe350xbe ananicy[865]: renice: brave[540405/540419] 10 -> -3
mai 20 21:57:33 julio-550xbe350xbe gnome-shell[539122]: [539122:539122:0520/215733.310739:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
mai 20 21:57:34 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:34 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:35 julio-550xbe350xbe ananicy[865]: renice: brave[540411/540411] 0 -> -3
mai 20 21:57:38 julio-550xbe350xbe gnome-shell[539122]: [539122:539122:0520/215738.427598:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
mai 20 21:57:39 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:39 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:40 julio-550xbe350xbe gnome-shell[539122]: [539122:539122:0520/215740.329584:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
mai 20 21:57:40 julio-550xbe350xbe gnome-shell[33509]: updates_checker.vala:71: check updates
mai 20 21:57:41 julio-550xbe350xbe dbus-daemon[859]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.244' (uid=1000 pid=541588 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
mai 20 21:57:41 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094661.259:352): prog-id=76 op=LOAD
mai 20 21:57:41 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094661.259:353): prog-id=77 op=LOAD
mai 20 21:57:41 julio-550xbe350xbe kernel: audit: type=1334 audit(1653094661.259:354): prog-id=78 op=LOAD
mai 20 21:57:41 julio-550xbe350xbe kernel: audit: type=1130 audit(1653094661.315:355): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:57:41 julio-550xbe350xbe audit: BPF prog-id=76 op=LOAD
mai 20 21:57:41 julio-550xbe350xbe audit: BPF prog-id=77 op=LOAD
mai 20 21:57:41 julio-550xbe350xbe audit: BPF prog-id=78 op=LOAD
mai 20 21:57:41 julio-550xbe350xbe audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mai 20 21:57:41 julio-550xbe350xbe dbus-daemon[859]: [system] Successfully activated service 'org.freedesktop.locale1'
mai 20 21:57:41 julio-550xbe350xbe systemd[1]: Starting Locale Service...
mai 20 21:57:41 julio-550xbe350xbe systemd[1]: Started Locale Service.
mai 20 21:57:44 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:44 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:44 julio-550xbe350xbe gnome-shell[539076]: [539076:539076:0520/215744.940559:ERROR:object_proxy.cc(623)] Failed to call method: org.freedesktop.ScreenSaver.GetActive: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NotSupported: This method is not implemented
mai 20 21:57:45 julio-550xbe350xbe gnome-shell[539076]: [539076:539076:0520/215744.948787:ERROR:object_proxy.cc(623)] Failed to call method: org.gnome.ScreenSaver.GetActive: object_path= /: org.freedesktop.DBus.Error.UnknownMethod: O objeto não existe no caminho “/”
mai 20 21:57:49 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:49 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d963947b50), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: clutter_text_get_editable: assertion 'CLUTTER_IS_TEXT (self)' failed
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: == Stack trace for context 0x55d9609d0640 ==
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d9672482a8 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:205 (132cd84ebe20 @ 371)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #1   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80da00 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d9672482a8 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:206 (132cd84ebe20 @ 396)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d9672482a8 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:208 (132cd84ebe20 @ 421)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248360 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:222 (132cd84ebe70 @ 63)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #1   55d9672482a8 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:209 (132cd84ebe20 @ 455)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #2   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80da00 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248360 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:223 (132cd84ebe70 @ 86)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: clutter_text_get_text: assertion 'CLUTTER_IS_TEXT (self)' failed
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248360 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:224 (132cd84ebe70 @ 116)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248360 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:225 (132cd84ebe70 @ 130)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248360 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:180 (132cd84ebd80 @ 118)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #1   55d9672482a8 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:213 (132cd84ebe20 @ 505)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80dbf0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: clutter_text_set_text: assertion 'CLUTTER_IS_TEXT (self)' failed
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d1b0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:222 (132cd84ebe70 @ 63)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80dbf0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d1b0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:223 (132cd84ebe70 @ 86)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d1b0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:224 (132cd84ebe70 @ 116)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d1b0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:225 (132cd84ebe70 @ 130)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d964910640), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:54 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d1c0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:180 (132cd84ebd80 @ 118)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:205 (132cd84ebe20 @ 371)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80d830 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80dde0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:206 (132cd84ebe20 @ 396)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:208 (132cd84ebe20 @ 421)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80ccb0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:222 (132cd84ebe70 @ 63)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #1   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:209 (132cd84ebe20 @ 455)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80d830 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80dde0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80ccb0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:223 (132cd84ebe70 @ 86)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80ccb0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:224 (132cd84ebe70 @ 116)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80ccb0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:225 (132cd84ebe70 @ 130)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80ccc0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:180 (132cd84ebd80 @ 118)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #1   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:213 (132cd84ebe20 @ 505)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80def0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80dfd0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d4d0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:222 (132cd84ebe70 @ 63)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80def0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80dfd0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d4d0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:223 (132cd84ebe70 @ 86)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d4d0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:224 (132cd84ebe70 @ 116)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d4d0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:225 (132cd84ebe70 @ 130)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d4e0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:180 (132cd84ebd80 @ 118)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80e0e0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80e1c0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9609eb800), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: == Stack trace for context 0x55d9609d0640 ==
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:208 (132cd84ebe20 @ 421)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80e0e0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80e1c0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d6c0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:222 (132cd84ebe70 @ 63)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #1   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:209 (132cd84ebe20 @ 455)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80e0e0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80e1c0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d6c0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:223 (132cd84ebe70 @ 86)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d6c0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:224 (132cd84ebe70 @ 116)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d6c0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:225 (132cd84ebe70 @ 130)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d96359a790), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d6d0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:180 (132cd84ebd80 @ 118)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #1   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:213 (132cd84ebe20 @ 505)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:205 (132cd84ebe20 @ 371)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #1   7ffcae80e2d0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80e3b0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #0   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:206 (132cd84ebe20 @ 396)
mai 20 21:57:55 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d8b0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:222 (132cd84ebe70 @ 63)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d960af7480), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:56 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80e2d0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:57:56 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80e3b0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:57:56 julio-550xbe350xbe gnome-shell[33509]: == Stack trace for context 0x55d9609d0640 ==
mai 20 21:57:56 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d8b0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:223 (132cd84ebe70 @ 86)
mai 20 21:57:56 julio-550xbe350xbe gnome-shell[33509]: #1   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:209 (132cd84ebe20 @ 455)
mai 20 21:57:56 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d8b0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:224 (132cd84ebe70 @ 116)
mai 20 21:57:56 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d8b0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:225 (132cd84ebe70 @ 130)
mai 20 21:57:56 julio-550xbe350xbe gnome-shell[33509]: #0   7ffcae80d8c0 b   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:180 (132cd84ebd80 @ 118)
mai 20 21:57:56 julio-550xbe350xbe gnome-shell[33509]: #1   55d967248218 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:213 (132cd84ebe20 @ 505)
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9639bc7a0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d964910640), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: updates_checker.vala:101: 0 updates found
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d962f9b580), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96493d510), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d96383bdd0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d966e79d70), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d963aa7480), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9635d1440), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96493d510), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d961f1bc40), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9649e4a20), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d96358e480), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d9670089d0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d962db2fb0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d963985400), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9649e4a20), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9637c4440), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96260dc10), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9649e8300), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d9659fe350), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d963607330), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d966c05440), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96260dc10), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d961c46040), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96205a840), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d960f107e0), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d960b0a8b0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9625f2700), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9661e0a60), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d96205a840), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9625c4330), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9625b4440), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9625b2370), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d9625b5570), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9625baf00), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9625b7d90), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:54 julio-550xbe350xbe gnome-shell[33509]: Object St.Label (0x55d9625b4440), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:57:59 julio-550xbe350xbe touchegg.desktop[33847]: Error connecting to Touchégg daemon: Could not connect: Connection refused
mai 20 21:57:59 julio-550xbe350xbe touchegg.desktop[33847]: Reconnecting in 5 seconds...
When I run updates (just tested in a VM) I see a difference in logging output.
These lines below are in your log but not in mine witch leads me to wonder about extensions, the logs indicates gnome-shell has a issue with the pamac-updates extension.
your output
mai 20 21:56:45 julio-550xbe350xbe gnome-shell[33509]: updates_checker.vala:71: check updates
mai 20 21:56:48 julio-550xbe350xbe gnome-shell[33509]: updates_checker.vala:101: 2 updates found
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object St.Icon (0x55d9609eb800), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: Object .Gjs_ui_popupMenu_PopupSubMenuMenuItem (0x55d96359a790), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: == Stack trace for context 0x55d9609d0640 ==
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:193 (132cd84ebe20 @ 89)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   55d96160d898 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #2   7ffcae80dbf0 b   self-hosted:1175 (23381c6b0a10 @ 454)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #0   55d96160d9e0 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:222 (132cd84ebe70 @ 63)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #1   55d96160d928 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:194 (132cd84ebe20 @ 161)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #2   55d96160d898 i   /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js:235 (132cd84ebf10 @ 44)
mai 20 21:56:49 julio-550xbe350xbe gnome-shell[33509]: #3   7ffcae80dbf0 b   self-hosted:1175 (23381c6b0a10 @ 454)
Does
  • disabling all extensions
  • Logging out and in
  • install /remove a package
produce the same freeze behavior?
What is the output of
pamac search pamac ?
Yes it does, disabling all extensions still provoke the freezes, i checked the CPU usage and it wasn’t high at all, but Pamac makes my system freeze for some reason.
pamac search pamac                                               ✔
libpamac-nosnap                                   1:11.2.0-1              AUR
    Library for Pamac package manager based on
    libalpm - flatpak support enabled
libpamac-git                                      1.3.0.r0.g269b2e4-1     AUR
    libalpm - git version
libpamac-full-dev                                 11.1.0beta2-1           AUR
    libalpm - flatpak and snap support enabled -
    development version
libpamac-full                                     1:11.2.0-5              AUR
libpamac-flatpak                                  11.1.0-1                AUR
libpamac-aur                                      11.3.0-0                AUR
    Pamac package manager library based on
    libalpm
archlinux-appstream-data-pamac                    1:20220512-1            AUR
    Arch Linux application database for
    AppStream-based software centers (Fixed for
    pamac-aur and pamac-all packages)
libpamac-snap-plugin                  [Instalado] 11.3.0-1                extra
    Snap plugin for Pamac
libpamac-flatpak-plugin               [Instalado] 11.3.0-1                extra
    Flatpak plugin for Pamac
libpamac                              [Instalado] 11.3.0-1                extra
    libalpm
pamac-zsh-completions                             0.7-1                   AUR
    ZSH completions for pamac
pamac-tray-icon-plasma                            0.1.3-1                 AUR
    Pamac tray icon for plasma users
pamac-tray-icon-plasma                            0.1.2-4                 extra
pamac-nosnap                                      10.3.0-2                AUR
    A Gtk3 frontend for libalpm (with AUR,
    flatpak, appindicator)
pamac-flatpak-gnome                               10.2.0-1                AUR
    Flatpak, AppIndicator support, and GNOME
    integration)
pamac-flatpak                                     10.2.0-1                AUR
    Flatpak and AppIndicator support)
pamac-classic                                     7.3.0-2                 AUR
    A Gtk3 frontend for libalpm - classic version
pamac-aur-git                                     10.4.0.r0.gc7db90d-1    AUR
    A Gtk3 frontend for libalpm - git version
pamac-aur                                         10.4.0-0                AUR
    A Gtk3 frontend, Package Manager based on
    libalpm with AUR and Appstream support
pamac-appstream-hook                              1-1                     AUR
    Pacman hook for cleaning up Appstream data
    from tags that Pamac can't handle.
pamac-all-git                                     1:10.2.2.r1.g125033f-1  AUR
    A Gtk3 frontend for libalpm (everything in
    one package - snap, flatpak, appindicator)
pamac-all                                         10.3.0-5                AUR
pamac-gtk                             [Instalado] 10.4.0-1                extra
    A Package Manager based on libalpm with AUR
pamac-gnome-integration               [Instalado] 10.4.0-1                extra
    Pamac gnome integration
pamac-cli                             [Instalado] 10.4.0-1                extra
The installed pamac components are all the right versions for stable so that looks alright.
It is good to know that extensions do not seem to interfere.
I’m not sure how to proceed with information gathering, the errors in the log are not something I’m able to diagnose. I’ve tagged the post with the pamac tag and set the category to #support:gnome, I hope a more knowledgeable user is able to help you further.
I can confirm this Pamac Error:
pamac upgrade freeze the system and the oom-killer sometimes kills my gnome session. If there are few or none packages to upgrade, everything seems ok. Only with a lot of updates this problems arise:
  • There are a lot (> 30) of pamac processes
  • All RAM and swap will be consumed by the pamac processes, htop shows a gradual increase in mem usage over ~~ 3 Minutes until the oom-killer kicks in.
  • there was plenty (~~ >8 GB) of ram free before the pamac run.
  • pacman however seems to work fine.
I observed this behavior on two laptops for ~ two months now.
Is there anything i can do to advance on this?
relevant part from syslog:
Aug 08 08:48:02 HannahArendt kernel: pamac invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=200
Aug 08 08:48:02 HannahArendt kernel: CPU: 3 PID: 113466 Comm: pamac Tainted: G           OE     5.15.57-2-MANJARO #1 492c965633a7c68a3c162e8c09928a07b31913dc
Aug 08 08:48:02 HannahArendt kernel: Hardware name: LENOVO 20HQS08X2B/20HQS08X2B, BIOS N1MET64W (1.49 ) 10/14/2020
Aug 08 08:48:02 HannahArendt kernel: Call Trace:
Aug 08 08:48:02 HannahArendt kernel:  <TASK>
Aug 08 08:48:02 HannahArendt kernel:  dump_stack_lvl+0x45/0x63
Aug 08 08:48:02 HannahArendt kernel:  dump_header+0x4a/0x215
Aug 08 08:48:02 HannahArendt kernel:  oom_kill_process.cold+0xb/0x10
Aug 08 08:48:02 HannahArendt kernel:  out_of_memory+0x27a/0x520
Aug 08 08:48:02 HannahArendt kernel:  __alloc_pages_slowpath.constprop.0+0xb67/0xd30
Aug 08 08:48:02 HannahArendt kernel:  __alloc_pages+0x20f/0x240
Aug 08 08:48:02 HannahArendt kernel:  pagecache_get_page+0x1e7/0x540
Aug 08 08:48:02 HannahArendt kernel:  filemap_fault+0x1ba/0xa50
Aug 08 08:48:02 HannahArendt kernel:  ? filemap_map_pages+0x138/0x680
Aug 08 08:48:02 HannahArendt kernel:  __do_fault+0x33/0x120
Aug 08 08:48:02 HannahArendt kernel:  __handle_mm_fault+0xd83/0x1550
Aug 08 08:48:02 HannahArendt kernel:  handle_mm_fault+0xd1/0x2c0
Aug 08 08:48:02 HannahArendt kernel:  do_user_addr_fault+0x1c6/0x6a0
Aug 08 08:48:02 HannahArendt kernel:  exc_page_fault+0x71/0x180
Aug 08 08:48:02 HannahArendt kernel:  asm_exc_page_fault+0x21/0x30
Aug 08 08:48:02 HannahArendt kernel: RIP: 0033:0x7f058d0ba171
Aug 08 08:48:02 HannahArendt kernel: Code: Unable to access opcode bytes at RIP 0x7f058d0ba147.
Aug 08 08:48:02 HannahArendt kernel: RSP: 002b:00007fff60606ac0 EFLAGS: 00010206
Aug 08 08:48:02 HannahArendt kernel: RAX: 0000564937d2afc0 RBX: 0000000000000040 RCX: 0000000000000001
Aug 08 08:48:02 HannahArendt kernel: RDX: 00007f058cf96bc0 RSI: 0000564923a2b010 RDI: 0000000000000007
Aug 08 08:48:02 HannahArendt kernel: RBP: 0000000000000004 R08: 00007f058cf96bc0 R09: 0000000000000020
Aug 08 08:48:02 HannahArendt kernel: R10: 0000564937d292f0 R11: cd0175247b29bfc6 R12: 0000564926307fa0
Aug 08 08:48:02 HannahArendt kernel: R13: 0000000000000006 R14: 0000564937d2a600 R15: 0000564937d2a8a0
Aug 08 08:48:02 HannahArendt kernel:  </TASK>
Aug 08 08:48:02 HannahArendt kernel: Mem-Info:
Aug 08 08:48:02 HannahArendt kernel: active_anon:1818688 inactive_anon:1438990 isolated_anon:0
                                      active_file:47 inactive_file:37 isolated_file:0
                                      unevictable:119 dirty:0 writeback:0
                                      slab_reclaimable:22505 slab_unreclaimable:65376
                                      mapped:5522 shmem:67405 pagetables:17247 bounce:0
                                      kernel_misc_reclaimable:0
                                      free:34623 free_pcp:0 free_cma:0
Aug 08 08:48:02 HannahArendt kernel: Node 0 active_anon:7274752kB inactive_anon:5755960kB active_file:188kB inactive_file:148kB unevictable:476kB isolated(anon):0kB isolated(file):0kB mapped:22088kB dirty:0kB writeback:0kB shmem:269620kB shmem_thp: 0kB shmem_pmdmapped: >
Aug 08 08:48:02 HannahArendt kernel: Node 0 DMA free:13312kB min:64kB low:80kB high:96kB reserved_highatomic:0KB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15912kB managed:15360kB mlocked:0kB bounce:0kB f>
Aug 08 08:48:02 HannahArendt kernel: lowmem_reserve[]: 0 1154 15703 15703 15703
Aug 08 08:48:02 HannahArendt kernel: Node 0 DMA32 free:63048kB min:4964kB low:6204kB high:7444kB reserved_highatomic:0KB active_anon:412040kB inactive_anon:562504kB active_file:68kB inactive_file:0kB unevictable:0kB writepending:0kB present:1267324kB managed:1201784kB m>
Aug 08 08:48:02 HannahArendt kernel: lowmem_reserve[]: 0 0 14548 14548 14548
Aug 08 08:48:02 HannahArendt kernel: Node 0 Normal free:62132kB min:62552kB low:78188kB high:93824kB reserved_highatomic:0KB active_anon:6862712kB inactive_anon:5193456kB active_file:0kB inactive_file:396kB unevictable:476kB writepending:0kB present:15228928kB managed:1>
Aug 08 08:48:02 HannahArendt kernel: lowmem_reserve[]: 0 0 0 0 0
Aug 08 08:48:02 HannahArendt kernel: Node 0 DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 1*1024kB (U) 2*2048kB (UM) 2*4096kB (M) = 13312kB
Aug 08 08:48:02 HannahArendt kernel: Node 0 DMA32: 322*4kB (UME) 218*8kB (UME) 141*16kB (UME) 153*32kB (UE) 248*64kB (UME) 237*128kB (UME) 24*256kB (UM) 1*512kB (E) 0*1024kB 0*2048kB 0*4096kB = 63048kB
Aug 08 08:48:02 HannahArendt kernel: Node 0 Normal: 719*4kB (UME) 607*8kB (UME) 317*16kB (UME) 82*32kB (UME) 452*64kB (UME) 151*128kB (ME) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 63684kB
Aug 08 08:48:02 HannahArendt kernel: Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
Aug 08 08:48:02 HannahArendt kernel: Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
Aug 08 08:48:02 HannahArendt kernel: 80709 total pagecache pages
Aug 08 08:48:02 HannahArendt kernel: 13143 pages in swap cache
Aug 08 08:48:02 HannahArendt kernel: Swap cache stats: add 2926526, delete 2914776, find 287396/419445
Aug 08 08:48:02 HannahArendt kernel: Free swap  = 0kB
Aug 08 08:48:02 HannahArendt kernel: Total swap = 8290300kB
Aug 08 08:48:02 HannahArendt kernel: 4128041 pages RAM
Aug 08 08:48:02 HannahArendt kernel: 0 pages HighMem/MovableOnly
Aug 08 08:48:02 HannahArendt kernel: 97544 pages reserved
Aug 08 08:48:02 HannahArendt kernel: 0 pages cma reserved
Aug 08 08:48:02 HannahArendt kernel: 0 pages hwpoisoned
Aug 08 08:48:02 HannahArendt kernel: Tasks state (memory values in pages):
Aug 08 08:48:02 HannahArendt kernel: [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
Aug 08 08:48:02 HannahArendt kernel: [    262]     0   262    12246      138   106496      308          -250 systemd-journal
Aug 08 08:48:02 HannahArendt kernel: [    263]     0   263     8227       31    86016      718         -1000 systemd-udevd
Aug 08 08:48:02 HannahArendt kernel: [    354]   976   354    22438        3    77824      238             0 systemd-timesyn
Aug 08 08:48:02 HannahArendt kernel: [    364]    81   364     3323      653    61440      331          -900 dbus-daemon
Aug 08 08:48:02 HannahArendt kernel: [    367]   102   367    78749      744   110592      515             0 polkitd
Aug 08 08:48:02 HannahArendt kernel: [    371]     0   371    12260      112    86016      201             0 systemd-logind
Aug 08 08:48:02 HannahArendt kernel: [    384]     0   384   120430      672   167936      522             0 NetworkManager
Aug 08 08:48:02 HannahArendt kernel: [    406]     0   406    79069      272   122880      398             0 ModemManager
Aug 08 08:48:02 HannahArendt kernel: [    410]     0   410     7111      145    90112      562             0 cupsd
Aug 08 08:48:02 HannahArendt kernel: [    412]     0   412     2196        0    53248      182         -1000 sshd
Aug 08 08:48:02 HannahArendt kernel: [    415]     0   415    59672      107    98304      234             0 gdm
Aug 08 08:48:02 HannahArendt kernel: [    430]   972   430    61068      216   106496     1151             0 colord
Aug 08 08:48:02 HannahArendt kernel: [    588]     0   588     2974      138    69632      121             0 bluetoothd
Aug 08 08:48:02 HannahArendt kernel: [    602]     0   602    59491      102   102400      234             0 accounts-daemon
Aug 08 08:48:02 HannahArendt kernel: [    656]     0   656     3881      158    77824      165             0 wpa_supplicant
Aug 08 08:48:02 HannahArendt kernel: [    712]     0   712    39822       93    73728       87             0 mbim-proxy
Aug 08 08:48:02 HannahArendt kernel: [    741]     0   741    58487      380    86016      189             0 upowerd
Aug 08 08:48:02 HannahArendt kernel: [    748]   133   748    38505       22    65536       59             0 rtkit-daemon
Aug 08 08:48:02 HannahArendt kernel: [   1051]     0  1051   418465      572   483328     1739             0 gdm-session-wor
Aug 08 08:48:02 HannahArendt kernel: [   1080]  1000  1080     4706      227    73728      446           100 systemd
Aug 08 08:48:02 HannahArendt kernel: [   1093]  1000  1093   292724       64   180224     1097           100 (sd-pam)
Aug 08 08:48:02 HannahArendt kernel: [   1105]  1000  1105    83093      868   143360     2359           200 python3
Aug 08 08:48:02 HannahArendt kernel: [   1106]  1000  1106   181161        0   131072      667           200 syncthing
Aug 08 08:48:02 HannahArendt kernel: [   1113]  1000  1113   115165      170   118784      279           200 gnome-keyring-d
Aug 08 08:48:02 HannahArendt kernel: [   1123]  1000  1123     2755      494    65536      264           200 dbus-daemon
Aug 08 08:48:02 HannahArendt kernel: [   1140]  1000  1140    39674        0    73728      170             0 gdm-wayland-ses
Aug 08 08:48:02 HannahArendt kernel: [   1143]  1000  1143    75491        0   163840      706             0 gnome-session-b
Aug 08 08:48:02 HannahArendt kernel: [   1190]  1000  1190    21980        0    69632      114           200 gnome-session-c
Aug 08 08:48:02 HannahArendt kernel: [   1192]  1000  1192   131032      226   176128      730           200 gnome-session-b
Aug 08 08:48:02 HannahArendt kernel: [   1206]  1000  1206  1747760    45692  5779456    17936           200 gnome-shell
Aug 08 08:48:02 HannahArendt kernel: [   1273]  1000  1273    60268      143    94208      246           200 gvfsd
Aug 08 08:48:02 HannahArendt kernel: [   1278]  1000  1278    94775       11    94208      175           200 gvfsd-fuse
Aug 08 08:48:02 HannahArendt kernel: [   1285]  1000  1285    77006       70    90112      169           200 at-spi-bus-laun
Aug 08 08:48:02 HannahArendt kernel: [   1292]  1000  1292     2151       78    61440       93           200 dbus-daemon
Aug 08 08:48:02 HannahArendt kernel: [   1298]  1000  1298    58078       64    73728       83           200 xdg-permission-
Aug 08 08:48:02 HannahArendt kernel: [   1303]  1000  1303   282265      559   258048      892           200 gnome-shell-cal
Aug 08 08:48:02 HannahArendt kernel: [   1309]  1000  1309   254310      535   282624     2776           200 evolution-sourc
Aug 08 08:48:02 HannahArendt kernel: [   1314]  1000  1314   603838     1012   344064     2001           200 pulseaudio
Aug 08 08:48:02 HannahArendt kernel: [   1318]  1000  1318   173847     1843   311296     3640           200 goa-daemon
Aug 08 08:48:02 HannahArendt kernel: [   1321]  1000  1321    39040      286    69632      164           200 dconf-service
Aug 08 08:48:02 HannahArendt kernel: [   1326]  1000  1326    40752      620    81920      266           200 gvfsd-metadata
Aug 08 08:48:02 HannahArendt kernel: [   1334]  1000  1334   126066      270   159744      406           200 gvfs-udisks2-vo
Aug 08 08:48:02 HannahArendt kernel: [   1338]  1000  1338    78004      218   106496      309           200 goa-identity-se
Aug 08 08:48:02 HannahArendt kernel: [   1341]     0  1341    98293      113   131072      522             0 udisksd
Aug 08 08:48:02 HannahArendt kernel: [   1360]  1000  1360   581862     4147   462848     5270           200 evolution-calen
Aug 08 08:48:02 HannahArendt kernel: [   1393]  1000  1393    58466      190    90112      122           200 gvfs-goa-volume
Aug 08 08:48:02 HannahArendt kernel: [   1398]  1000  1398   335728     2936   385024     2868           200 evolution-addre
Aug 08 08:48:02 HannahArendt kernel: [   1403]  1000  1403    58191       87    86016      121           200 gvfs-mtp-volume
Aug 08 08:48:02 HannahArendt kernel: [   1407]  1000  1407    59216        0    94208      300           200 gsettings-helpe
Aug 08 08:48:02 HannahArendt kernel: [   1408]  1000  1408    79251       84   114688      251           200 gvfs-afc-volume
Aug 08 08:48:02 HannahArendt kernel: [   1455]  1000  1455   662824      669   225280      714           200 gjs
Aug 08 08:48:02 HannahArendt kernel: [   1457]  1000  1457    40237       58    73728      204           200 at-spi2-registr
Aug 08 08:48:02 HannahArendt kernel: [   1472]  1000  1472    77824      479   110592      834           200 ibus-daemon
Aug 08 08:48:02 HannahArendt kernel: [   1476]  1000  1476    76774       46    94208      170           200 gsd-a11y-settin
Aug 08 08:48:02 HannahArendt kernel: [   1484]  1000  1484   186612      429   245760     1256           200 gsd-color
Aug 08 08:48:02 HannahArendt kernel: [   1487]  1000  1487    88792       44   135168      358           200 gsd-datetime
Aug 08 08:48:02 HannahArendt kernel: [   1490]  1000  1490    77865      138   102400      214           200 gsd-housekeepin
Aug 08 08:48:02 HannahArendt kernel: [   1491]  1000  1491    95089      227   188416     1265           200 gsd-keyboard
Aug 08 08:48:02 HannahArendt kernel: [   1492]  1000  1492   245845      619   225280     1128           200 gsd-media-keys
Aug 08 08:48:02 HannahArendt kernel: [   1493]  1000  1493   161845      502   204800     1245           200 gsd-power
Aug 08 08:48:02 HannahArendt kernel: [   1495]  1000  1495    61901      148   122880      286           200 gsd-print-notif
Aug 08 08:48:02 HannahArendt kernel: [   1496]  1000  1496   113557       64   110592      197           200 gsd-rfkill
Aug 08 08:48:02 HannahArendt kernel: [   1500]  1000  1500    58192       93    81920      210           200 gsd-screensaver
Aug 08 08:48:02 HannahArendt kernel: [   1502]  1000  1502   114632      264   110592      210           200 gsd-sharing
Aug 08 08:48:02 HannahArendt kernel: [   1506]  1000  1506    96523       33   102400      273           200 gsd-smartcard
Aug 08 08:48:02 HannahArendt kernel: [   1507]  1000  1507    78858       37   110592      289           200 gsd-sound
Aug 08 08:48:02 HannahArendt kernel: [   1510]  1000  1510    96079       44   110592      225           200 gsd-usb-protect
Aug 08 08:48:02 HannahArendt kernel: [   1516]  1000  1516    95259      185   188416     1396           200 gsd-wacom
Aug 08 08:48:02 HannahArendt kernel: [   1571]  1000  1571    58457        0    81920      232           200 ibus-dconf
Aug 08 08:48:02 HannahArendt kernel: [   1572]  1000  1572    96725      198   196608     2930           200 ibus-extension-
Aug 08 08:48:02 HannahArendt kernel: [   1574]  1000  1574   679234      515   237568      839           200 gjs
Aug 08 08:48:02 HannahArendt kernel: [   1576]  1000  1576    95413       25   172032      697           200 gsd-printer
Aug 08 08:48:02 HannahArendt kernel: [   1580]  1000  1580    58421       59    81920      186           200 ibus-portal
Aug 08 08:48:02 HannahArendt kernel: [   1596]  1000  1596   345630      548   425984     3676           200 evolution-alarm
Aug 08 08:48:02 HannahArendt kernel: [   1606]  1000  1606    62497      382   200704     1910           200 msm_notifier
Aug 08 08:48:02 HannahArendt kernel: [   1610]  1000  1610    58219        0    81920      305           200 gsd-disk-utilit
Aug 08 08:48:02 HannahArendt kernel: [   1674]  1000  1674   150243     1216   471040     4999           200 Xwayland
Aug 08 08:48:02 HannahArendt kernel: [   1688]  1000  1688    40043      152    77824      117           200 ibus-engine-sim
Aug 08 08:48:02 HannahArendt kernel: [   1782]  1000  1782   206956      393   507904     3893           200 gsd-xsettings
Aug 08 08:48:02 HannahArendt kernel: [   1801]  1000  1801    58255      147   167936     1692           200 ibus-x11
Aug 08 08:48:02 HannahArendt kernel: [   1832]  1000  1832    80921      198   114688      267           200 gvfsd-trash
Aug 08 08:48:02 HannahArendt kernel: [   1840]  1000  1840   155452      326   159744      404           200 xdg-desktop-por
Aug 08 08:48:02 HannahArendt kernel: [   1844]  1000  1844   133308       90   122880      121           200 xdg-document-po
Aug 08 08:48:02 HannahArendt kernel: [   1849]  1000  1849      667        0    40960       28           200 fusermount3
Aug 08 08:48:02 HannahArendt kernel: [   1853]  1000  1853   168466      533   270336     5467           200 xdg-desktop-por
Aug 08 08:48:02 HannahArendt kernel: [   1874]  1000  1874    96055      281   192512     1693           200 xdg-desktop-por
Aug 08 08:48:02 HannahArendt kernel: [   1880]  1000  1880     9542       51    81920      361           200 pipewire
Aug 08 08:48:02 HannahArendt kernel: [   1881]  1000  1881     4521       22    57344      304           200 pipewire-media-
Aug 08 08:48:02 HannahArendt kernel: [   1919]  1000  1919      666       16    45056       16           200 autossh
Aug 08 08:48:02 HannahArendt kernel: [  12714]  1000 12714     1499       39    45056       90           200 ssh-agent
Aug 08 08:48:02 HannahArendt kernel: [  15051]  1000 15051   131805      412   114688      228           200 sshfs
Aug 08 08:48:02 HannahArendt kernel: [  15324]  1000 15324   290346      484   356352     4256           200 gnome-calendar
Aug 08 08:48:02 HannahArendt kernel: [  15338]  1000 15338   104597     1734   266240     4901           200 python3
Aug 08 08:48:02 HannahArendt kernel: [  15339]  1000 15339   117893      161   233472     3626           200 seahorse
Aug 08 08:48:02 HannahArendt kernel: [  15410]  1000 15410    11999       25    81920      205           200 obexd
Aug 08 08:48:02 HannahArendt kernel: [  15445]  1000 15445   172794     1355   286720     1194           200 tracker-miner-f
Aug 08 08:48:02 HannahArendt kernel: [  15465]  1000 15465    38886       54    73728       60           200 gpg-agent
Aug 08 08:48:02 HannahArendt kernel: [  15491]  1000 15491    58257       88    90112      101           200 flatpak-session
Aug 08 08:48:02 HannahArendt kernel: [  15495]  1000 15495     1877        0    57344       92           200 p11-kit-server
Aug 08 08:48:02 HannahArendt kernel: [  21440]  1000 21440    61931        0   106496      408           200 gvfsd-http
Aug 08 08:48:02 HannahArendt kernel: [  21624]  1000 21624    97408       58   122880      354           200 gvfsd-network
Aug 08 08:48:02 HannahArendt kernel: [  21642]  1000 21642    79314        0   118784      368           200 gvfsd-dnssd
Aug 08 08:48:02 HannahArendt kernel: [  30363]     0 30363    59148      156    94208      143             0 power-profiles-
Aug 08 08:48:02 HannahArendt kernel: [  45172]  1000 45172   199050     6702   307200     4453           200 syncthing
Aug 08 08:48:02 HannahArendt kernel: [  82628]  1000 82628    94422      244    90112      117           200 sshfs
Aug 08 08:48:02 HannahArendt kernel: [  88260]  1000 88260  1139208    41504  4071424    47468           200 firefox
Aug 08 08:48:02 HannahArendt kernel: [  88332]  1000 88332    63483      159   364544     2112           200 Socket Process
Aug 08 08:48:02 HannahArendt kernel: [  88353]  1000 88353   625689     4086   761856     3735           200 Privileged Cont
Aug 08 08:48:02 HannahArendt kernel: [  88399]  1000 88399  7059383    17703  1748992    15545           200 WebExtensions
Aug 08 08:48:02 HannahArendt kernel: [  88459]  1000 88459    63935      282   126976     2228           200 python
Aug 08 08:48:02 HannahArendt kernel: [  89486]  1000 89486   131922      203   593920     2899           200 RDD Process
Aug 08 08:48:02 HannahArendt kernel: [  89505]  1000 89505   118668      206   495616     2867           200 Utility Process
Aug 08 08:48:02 HannahArendt kernel: [ 106824]  1000 106824   723843     1662   401408     3067           200 gjs
Aug 08 08:48:02 HannahArendt kernel: [ 107077]  1000 107077     3643      103    65536      176           200 ssh
Aug 08 08:48:02 HannahArendt kernel: [ 107081]  1000 107081   111533      541   184320     1718           200 gvfsd-dav
Aug 08 08:48:02 HannahArendt kernel: [ 107177]  1000 107177   629485     3815   765952     6904           200 Isolated Web Co
Aug 08 08:48:02 HannahArendt kernel: [ 107367]  1000 107367   445303   106019  2424832   158375           200 pamac-manager
Aug 08 08:48:02 HannahArendt kernel: [ 107795]  1000 107795   205841      270  1089536   112816           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 108045]  1000 108045   161134     4276   311296     1460           200 gnome-terminal-
Aug 08 08:48:02 HannahArendt kernel: [ 108067]  1000 108067     2100       95    53248      139           200 bash
Aug 08 08:48:02 HannahArendt kernel: [ 108455]     0 108455    49969      182   110592       64             0 thermald
Aug 08 08:48:02 HannahArendt kernel: [ 108540]  1000 108540     2529      540    61440       95           200 man
Aug 08 08:48:02 HannahArendt kernel: [ 108548]  1000 108548     1818       73    49152        0           200 less
Aug 08 08:48:02 HannahArendt kernel: [ 108555]  1000 108555     2100      186    61440       43           200 bash
Aug 08 08:48:02 HannahArendt kernel: [ 111077]     0 111077   200757    19341   458752    10504             0 pamac-daemon
Aug 08 08:48:02 HannahArendt kernel: [ 113082]     0 113082    38982       47    65536       76             0 gpg-agent
Aug 08 08:48:02 HannahArendt kernel: [ 113235]  1000 113235   182633    85686  1175552    42620           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113236]  1000 113236   182653    83832  1179648    44495           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113242]  1000 113242   178570    83490  1142784    40703           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113248]  1000 113248   181332    88612  1163264    38355           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113252]  1000 113252   166623   111262  1048576     1120           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113259]  1000 113259   180424    89657  1167360    36407           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113266]  1000 113266   168114    72576  1056768    41159           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113274]  1000 113274   173739    81447  1101824    37933           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113284]  1000 113284   174632    81840  1114112    38416           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113288]  1000 113288   170818    81783  1081344    34662           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113296]  1000 113296   181854    86323  1167360    41180           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113300]  1000 113300   178976    83972  1150976    40643           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113307]  1000 113307   182647    94616  1183744    33691           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113313]  1000 113313   182636    86906  1167360    41402           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113322]  1000 113322   181553    90158  1171456    37048           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113331]  1000 113331   172669    85025  1097728    33277           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113338]  1000 113338   180621    98733  1155072    27496           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113344]  1000 113344   164270    77911  1024000    31968           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113347]  1000 113347   158042    75176   974848    28620           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113356]  1000 113356   156574    73098   962560    29173           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113359]  1000 113359   164801    83004  1024000    27425           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113371]  1000 113371   157420    74149   974848    29016           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113384]  1000 113384   153975    71787   946176    27914           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113391]  1000 113391   165379    81798  1040384    29201           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113398]  1000 113398   165646    85952  1044480    25316           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113405]  1000 113405   154153    71209   950272    28684           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113411]  1000 113411   161706    83178  1007616    24140           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113419]  1000 113419   159829    81675   991232    23866           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113424]  1000 113424   164295    81771  1028096    28143           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113432]  1000 113432   151816    72395   925696    25134           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113437]  1000 113437   160458    81145  1003520    25059           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113445]  1000 113445   152986    73305   933888    25373           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113453]  1000 113453   162483    83726  1011712    24368           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113461]  1000 113461   166788    81621  1052672    30802           200 pamac
Aug 08 08:48:02 HannahArendt kernel: [ 113466]  1000 113466   154158    75571   950272    24312           200 pamac
Aug 08 08:48:02 HannahArendt kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/user@1000.service/session.slice/dbus.service,task=pamac-manager,pid=107367,uid=1000
Aug 08 08:48:02 HannahArendt kernel: Out of memory: Killed process 107367 (pamac-manager) total-vm:1781212kB, anon-rss:416184kB, file-rss:0kB, shmem-rss:7892kB, UID:1000 pgtables:2368kB oom_score_adj:200
Aug 08 08:48:02 HannahArendt kernel: rfkill: input handler enabled
Aug 08 08:48:02 HannahArendt gnome-session-binary[1192]: WARNING: Lost name on bus: org.gnome.SessionManager
Aug 08 08:48:02 HannahArendt gnome-session[1192]: gnome-session-binary[1192]: WARNING: Lost name on bus: org.gnome.SessionManager
Aug 08 08:48:01 HannahArendt systemd[1080]: dbus.service: A process of this unit has been killed by the OOM killer.
Aug 08 08:48:02 HannahArendt gvfsd[1273]: A connection to the bus can't be made
Aug 08 08:48:01 HannahArendt systemd[1]: user@1000.service: A process of this unit has been killed by the OOM killer.
Aug 08 08:48:02 HannahArendt systemd[1080]: org.gnumdk.PowerProfileSelector.service: Consumed 1min 42.028s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: gnome-keyring-daemon.service: Consumed 4.572s CPU time.
Aug 08 08:48:02 HannahArendt tracker-miner-f[15445]: Owner of volume monitor org.gtk.vfs.UDisks2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Aug 08 08:48:02 HannahArendt systemd[1080]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
Aug 08 08:48:02 HannahArendt systemd[1080]: xdg-permission-store.service: Failed with result 'exit-code'.
Aug 08 08:48:02 HannahArendt tracker-miner-f[15445]: Owner of volume monitor org.gtk.vfs.GoaVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Aug 08 08:48:02 HannahArendt tracker-miner-f[15445]: Owner of volume monitor org.gtk.vfs.MTPVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Aug 08 08:48:02 HannahArendt tracker-miner-f[15445]: Owner of volume monitor org.gtk.vfs.AfcVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Aug 08 08:48:02 HannahArendt gvfs-goa-volume[1393]: The peer-to-peer connection failed: Verbindung ist geschlossen. Falling back to the session bus. Your application is probably missing --filesystem=xdg-run/gvfsd privileges.
Aug 08 08:48:02 HannahArendt evolution-addre[1398]: Error setting property 'ConnectionStatus' on interface org.gnome.evolution.dataserver.Source: Verbindung ist geschlossen (g-io-error-quark, 18)
Aug 08 08:48:02 HannahArendt systemd[1080]: at-spi-dbus-bus.service: Consumed 2.274s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
Aug 08 08:48:02 HannahArendt gvfsd[21624]: A connection to the bus can't be made
Aug 08 08:48:02 HannahArendt gvfsd[21440]: A connection to the bus can't be made
Aug 08 08:48:02 HannahArendt gvfsd[1832]: A connection to the bus can't be made
Aug 08 08:48:02 HannahArendt gvfsd[107081]: A connection to the bus can't be made
Aug 08 08:48:02 HannahArendt systemd[1080]: gvfs-metadata.service: Consumed 1.243s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: evolution-addressbook-factory.service: Consumed 7.854s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: gvfs-afc-volume-monitor.service: Consumed 3.215s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: org.freedesktop.IBus.session.GNOME.service: Killing process 1583 (gdbus) with signal SIGKILL.
Aug 08 08:48:02 HannahArendt systemd[1080]: org.freedesktop.IBus.session.GNOME.service: Killing process 1690 (gdbus) with signal SIGKILL.
Aug 08 08:48:02 HannahArendt systemd[1080]: evolution-source-registry.service: Consumed 7.513s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Aug 08 08:48:02 HannahArendt systemd[1080]: xdg-desktop-portal.service: Consumed 3.889s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: xdg-desktop-portal-gnome.service: Consumed 8.576s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: xdg-desktop-portal-gtk.service: Consumed 3.618s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
Aug 08 08:48:02 HannahArendt systemd[1080]: obex.service: Main process exited, code=exited, status=1/FAILURE
Aug 08 08:48:02 HannahArendt systemd[1080]: obex.service: Failed with result 'exit-code'.
Aug 08 08:48:02 HannahArendt systemd[1080]: flatpak-session-helper.service: Main process exited, code=exited, status=1/FAILURE
Aug 08 08:48:02 HannahArendt systemd[1080]: gnome-terminal-server.service: Consumed 4.124s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: org.gnome.SettingsDaemon.A11ySettings.service: Consumed 1.350s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: org.gnome.SettingsDaemon.Datetime.service: Consumed 1.397s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: org.gnome.SettingsDaemon.Housekeeping.service: Consumed 8.376s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: org.gnome.SettingsDaemon.Rfkill.service: Consumed 2.088s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: org.gnome.SettingsDaemon.ScreensaverProxy.service: Consumed 2.992s CPU time.
Aug 08 08:48:02 HannahArendt systemd[1080]: org.gnome.SettingsDaemon.Smartcard.service: Consumed 1.430s CPU time.
inxi -F
  Host: HannahArendt Kernel: 5.15.59-1-MANJARO arch: x86_64 bits: 64
    Desktop: GNOME v: 42.3.1 Distro: Manjaro Linux
  Type: Laptop System: LENOVO product: 20HQS08X2B v: ThinkPad X1 Carbon 5th
    serial: <superuser required>
  Mobo: LENOVO model: 20HQS08X2B v: SDK0J40697 WIN
    serial: <superuser required> UEFI: LENOVO v: N1MET64W (1.49 )
    date: 10/14/2020
  ID-1: BAT0 charge: 16.9 Wh (32.4%) condition: 52.1/57.0 Wh (91.4%)
    volts: 10.8 min: 11.5
  Info: dual core model: Intel Core i7-7600U bits: 64 type: MT MCP cache:
    L2: 512 KiB
  Speed (MHz): avg: 800 min/max: 400/3900 cores: 1: 800 2: 800 3: 800
    4: 800
  Device-1: Intel HD Graphics 620 driver: i915 v: kernel
  Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: gnome-shell driver: X: loaded: N/A unloaded: modesetting
    gpu: i915 resolution: 1920x1080~60Hz
  Message: Wayland GBM/EGL data currently not available.
  Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.59-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.56 running: yes
  Device-1: Intel Ethernet I219-LM driver: e1000e
  IF: enp0s31f6 state: down mac: 8c:16:45:2d:a2:61
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi
  IF: wlp4s0 state: up mac: b4:d5:bd:f5:29:22
  IF-ID-1: wwp0s20f0u6i12 state: down mac: 12:4c:80:66:d3:3a
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
  Local Storage: total: 238.47 GiB used: 121.88 GiB (51.1%)
  ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 238.47 GiB
  ID-1: / size: 26.46 GiB used: 19.84 GiB (75.0%) fs: ext4
    dev: /dev/nvme0n1p4
  ID-2: /boot/efi size: 256 MiB used: 36.2 MiB (14.1%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-3: /home size: 124.58 GiB used: 75.21 GiB (60.4%) fs: ext4
    dev: /dev/nvme0n1p6
  ID-1: swap-1 type: partition size: 7.91 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p8
  System Temperatures: cpu: 40.0 C pch: 38.5 C mobo: N/A
  Fan Speeds (RPM): fan-1: 0
  Processes: 227 Uptime: 10h 7m Memory: 15.38 GiB used: 2.67 GiB (17.3%)
  Shell: Bash inxi: 3.3.20
maybe this solution is related:
really sounds like it. I’ve have not noticed this before! Thanks!
