After I updated everything pamac still shows active updates for flatpak packages org.freedesktop.Platform (2 with different versions), org.gnome.Platform and org.kde.Platform (2 with different versions)
Running update all of them doesn’t do anything
Try runnning this command:
flatpak upgrade
It’s already upgraded
And what should I do?
Looks like bug is not fixed
check if it is reported or not yet: Issues · Applications / pamac · GitLab
Not reported
Same issue here. Happened on two different editions of Manjaro; KDE and Cinnamon.
I’m getting the same thing:
I’ve disabled Flatpak support for now.
I have a similar problem —
…and it will not go away by clicking apply. flatpak update && flatpak upgrade says it’s everything ok.
I can’t remove it because I need kdenlive and the package is marked as a dependency.
Anyway, it seems it’s just a nuisance (everything is working ok otherwise).
Try flatpak upgrade with your useraccount, not as root.
This fixed the problem several times for me.
Just had this Issue in 2024. I was using pamac. I was not sure if it was legit since it does not even show up in the pamac directory under Flatpak. Apparently it shows up in the update when it is at its end of life. The description page was just as vague with no statement of end of life or website link.
Thank you, rallygion for your clear fix. Now if we can get pamac to be a little bit clearer.
Please don’t necrobump old topics. There is already a current topic about this issue:
I will add the solution recommended by rallygion to the current thread.
@moderators Please close this topic.
