Every time i try do update org.kde.platform through pamac it just outputs transaction finished without any errors, i have tried many times but it won’t update somehow, running sudo pacman -Syyu doesn’t even detect the update, the command outputs that there is nothing to do, pamac still shows the update after removing the package.
sudo pacman -Syyu ✔
:: Syncing packages database...
core 167,7 KiB 34,9 KiB/s 00:05 [######################] 100%
extra 1899,9 KiB 469 KiB/s 00:04 [######################] 100%
community 6,9 MiB 137 KiB/s 00:52 [######################] 100%
multilib 174,3 KiB 155 KiB/s 00:01 [######################] 100%
:: Initializing complete system update...
nothing to do
the command reported org.freedesktop.Platform.GL.default and org.freedesktop.Platform.VAAPI.Intel as unused and removed them, i’ll reboot and see if Pamac behaves.
Not sure what is going on but quite a few people are getting these messages about org.freedesktop flatpak updates. I updated with pacman -Syu and it cleared but hasn’t worked for other people
