Hi, i don’t know since when this happens, but on core is running always with 100%
@lymouthd --mode=boot --pid-file=/run/plymouth/pid --attach-to-session
How could i solve this?
Tried it with X11 and Wayland, both the same.
Regards
Hi @simpsonetti,
While this:
…in my opinion, has nothing to do with it, you can see the top CPU consumers with:
top -bn 1 -o %CPU | head --lines=20
More information would also be nice. Please use detailed descriptions. Considering this isn’t your first post and you even have 3 answers allocated to you, I’m honestly surprised you didn’t know this al ready. Nevertheless, please see:
[HowTo] Provide System Information.
At bare minimum we would need you to please provide a detailed description of the problem faced, as well as the output to:
inxi --admin --verbosity=8 --filter --no-host --width -
[HowTo] Post command output and file content as preformatted text.
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
Tip for legibility:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
It might be unlikely but possible that there is an ACPI kworker interrupt hanging.
This happens to my device (HP ZBook with Core i7 CPU) every time i am doing a reinstallation.
This helped me always:
$ sudo remember: High CPU usage due to kworker
firmware - Disable GPE ACPI interrupts on boot? - Unix & Linux Stack Exchange
Maybe something worth to look at.
