Haru
13 March 2022 07:52
1
i installed manjaro kde.My gpu is gtx 1650 with max q .But seems like system cant detect gpu.
Here’s inxi --G output:
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA TU117M driver: nvidia v: 510.54
Display: x11 server: X .Org v: 1.21.1.3 driver: X: loaded: modesetting
failed: nvidia gpu: i915 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
v: 4.6 Mesa 21.3.7
inxi --admin --verbosity=7 --filter --no-host --width output:
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=acc9a329-8896-4369-9af8-85c447d9feef rw quiet apparmor=1
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: GF63 Thin 9SCX v: REV:1.0
serial: Chassis: type: 10 serial:
Mobo: Micro-Star model: MS-16R4 v: REV:1.0 serial:
UEFI: American Megatrends v: E16R4IMS.505 date: 11/05/2020
ID-1: BAT1 charge: 42.4 Wh (100.0%) condition: 42.4/51.3 Wh (82.7%)
volts: 12.9 min: 11.4 model: MSI Corp. MS-16R4 type: Li-ion serial: N/A
status: Full
RAM: total: 7.61 GiB used: 2.23 GiB (29.3%)
RAM Report:
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 900 high: 901 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 900 6: 901 7: 900 8: 900 bogomips: 38408
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
alternate: nouveau,nvidia_drm pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0302
Display: x11 server: X .Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting failed: nvidia alternate: fbdev,nouveau,nv,vesa
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: AU Optronics built: 2017 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: down mac:
WAN IP:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 704.24 GiB used: 111.1 GiB (15.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: rev: ADXA0103 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM000-SSHD-8GB
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: rev: LIV9 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 19.7 GiB (8.4%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: acc9a329-8896-4369-9af8-85c447d9feef
label: NO_LABEL uuid: 9CDC-E24E
ID-3: /run/media/unenhuu/074bd73b-72a6-48ba-ac35-eabaa9a8a815
raw-size: 119.35 GiB size: 116.97 GiB (98.01%) used: 7.62 GiB (6.5%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 074bd73b-72a6-48ba-ac35-eabaa9a8a815
ID-4: /run/media/unenhuu/New Volume raw-size: 345.9 GiB
size: 345.9 GiB (100.00%) used: 83.77 GiB (24.2%) fs: ntfs dev: /dev/sda1
maj-min: 8:1 label: New Volume uuid: 84DCE41FDCE40D6C
ID-1: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: 5674-8493
ID-2: /dev/sda3 maj-min: 8:3 size: 100 MiB fs: vfat label: N/A
uuid: F82D-43E9
ID-3: /dev/sda4 maj-min: 8:4 size: 100 MiB fs: vfat label: N/A
uuid: F625-C299
ID-4: /dev/sda5 maj-min: 8:5 size: 100 MiB fs: vfat label: N/A
uuid: F44C-F88C
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.0 C pch: 53.0 C mobo: N/A
Processes: 250 Uptime: 6m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1222 pacman: 1215 lib: 327
flatpak: 0 snap: 7 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.13
My installed drivers:
video-linux,
video-hybrid-intel-nvidia-prime
Hi @Haru , and welcome!
In order for us, or anyone for that matter, to be able to help you, more information is necessary. To that end, please see:
Hope you manage!
Edit:
It’s probably because the nvidia drivers are not installed or not installed properly. Please also provide the outputs for:
mhwd --list
and
mhwd --listinstalled
Edit 2:
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Haru
13 March 2022 08:06
4
mhwd --listinstalled output:> Installed PCI configs:--------------------------------------------------------------------------------NAME VERSION FREEDRIVER TYPE -------------------------------------------------------------------------------- video-modesetting 2020.01.13 true PCI video-hybrid-intel-nvidia-prime 2021.12.18 false PCI Warning: No installed USB configs!
Mirdarthos:
Tip:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
Edit:
Please also post the output for:
prime-run glxinfo | grep "OpenGL renderer"
Haru
13 March 2022 08:15
6
prime-run glxinfo | grep “OpenGL renderer” output:
X Error of failed request: BadValue (integer parameter out of range for operation) Major opcode of failed request: 152 (GLX) Minor opcode of failed request: 24 (X_GLXCreateNewContext) Value in failed request: 0x0 Serial number of failed request: 50 Current serial number in output stream: 51
As I’ve asked before:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
Please edit your post(s) accordingly.
Edit:
Also please post the output for:
glxinfo | head -n 20
Haru
13 March 2022 08:19
8
sorry i dont really get it can i provide screenshot. There 's error message that i cant post embed photo
status: Full
RAM Report:
direct render: Yes
broadcast:
WAN IP:
uuid: 5674-8493
uuid: F82D-43E9
uuid: F625-C299
uuid: F44C-F88C
that’s what they mean by using preformatted text
