Hi. Long searched without results. Trying to understand ways to optimize settings for vulkan running. I am addicted to flight sim and X-Plane 11 is the game. With windows and other distros Linux, Vulkan runs well. Many foruns, people tell it is even better in Manjaro. But here it just crashes every time I try to open with Vulkan and not OpenGL. How do you suggest me to search how to improve vulkan settings or even Nvidia Drivers
HI @caiooliveirac, and welcome!
- Please see How to provide good information
1.1. If applicable, please see [HowTo] post screenshots and links - Do you know if youâve got the open-source or proprietary Nvidia drivers installed?
2.1. How did you install it?
It sounds, to me, like youâre using thee unofficial, open-source drivers, and that might be the reason why.
KDE UI has a page that permits you to right click and install. But it came already with an Nvidia driver. I have booted with non-free drivers (proprietary). I was suspecting maybe this bad performance is because the Manjaro recognized bad the board and installed bad driver or the game is running on intel integrated video card not with nvidiaâŚ
It might be that. You didnât specify that you had hybrid graphics which Iâm assuming means youâre using a laptop.
Thatâs why I asked for the information in my previous reply:
Edit:
In addition, open a terminal and provide thee output for:
mhwd --listhardware
as well as
mhwd --list
and
mhwd --listinstalled
Sorry. I thought that form in sign up would make it visible in every post my config and hardware
notebook i7 7700 gtx 1050 Ti
KDE shows another option called 390xx bumblebee and an option not hybrid (just video-nvidia)
Answer the question, or circle around, but only one way will go forward. Provide your system info properly.
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=f2c5989f-8413-49fe-9e9e-b0149176f8b3 rw quiet apparmor=1
security=apparmor resume=UUID=8f640c8e-82f0-4f71-b341-38494039545d
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0P84C9 v: A01 serial: <filter> UEFI-[Legacy]: Dell
v: 1.6.0 date: 03/27/2018
ID-1: BAT0 charge: 58.4 Wh (100.0%) condition: 58.4/74.0 Wh (78.9%)
volts: 13.1 min: 11.4 model: SMP DELL 71JF452 type: Li-poly serial: <filter>
status: Full
ID-2: hidpp_battery_0 charge: N/A condition: N/A volts: 4.2 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: Charging
RAM: total: 15.22 GiB used: 6.83 GiB (44.9%)
Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: EA
cache: L2: 6 MiB bogomips: 44817
Speed: 1239 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 1239 2: 1244
3: 1362 4: 1700 5: 1700 6: 1538 7: 1700 8: 1700
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:3 chip-ID: 0c45:6a06 class-ID: 0e02
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Dell driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 03:00.0 chip-ID: 168c:003e
class-ID: 0280
IP v6: <filter> type: noprefixroute scope: global
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 0cf3:e007 class-ID: e001
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 52.24 GiB (4.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON model: CV3-8D256-11 SATA 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 10D scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10SPZX-75Z10T1
type: HDD rpm: 5400 serial: <filter> rev: 1A02
ID-1: / raw-size: 229.67 GiB size: 225 GiB (97.97%) used: 52.24 GiB (23.2%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: f2c5989f-8413-49fe-9e9e-b0149176f8b3
dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 8f640c8e-82f0-4f71-b341-38494039545d
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-1:8 info: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO
type: Mouse,Keyboard,HID driver: logitech-hidpp-device,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 046d:c091 class-ID: 0300
serial: <filter>
Device-2: 1-4:2 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e007
class-ID: e001
Device-3: 1-12:3 info: Microdia Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 67.0 C mobo: 51.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 4158
Processes: 274 Uptime: 1h 20m wakeups: 3 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: 1220 pacman: 1209 lib: 329
flatpak: 0 snap: 11 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.0```
From what we can see, you have properly installed the Nvidia hybrid drivers, on your dual GPU system.
Now with this kind of system, to run your games on the dedicated (Nvidia) GPU, you most likely need to tell to offload on the Nvidia GPU (by default it uses the Intel GPU). If you run your game through Steam, you can do that by going to your game properties and add into the Launch Options the following
prime-run %command%
It should force the use of Nvidia video card when starting the game.
See if it improves the situation.
If you are starting the games in other way, then tell us.
is this correct ?
I tried. And then the game starts⌠.I can choose the plane and the local. It begins to charge everything and exactly the instant that it is all going to appear in the screen, the games just disappear. Crash without error messages
What do you mean with âcorrectâ?
I can only see one ext4/linux (filesystem) partition on your partition list. Iâm assuming that that is your boot ssd, and that your games are on the external disk.
Im going out on a limb and guess that your external drive is formatted with the ntfs/windows filesystem. In my experience steam is incompatible for most games when installed on that filesystem with windows, and that games fail to launch in the way you described.
Moving a game that does not work to the main drive could diagnose if this is indeed the problem. And if so you might want to figure out how to add a ext4 partition to your main drive.
This was the only problem I had with running games, so hopefully its the same issue for you.
I have only one SSD 256GB ext4 here. I mean it contains Manjaro and Steam in the same partition ext4
Your CPU Temperature is 67 C by 1,2 Ghz ?
What is your Temperature by 3,8 Ghz ?
can you check this
The access permissions in the folder / SteamLibrary / steamapps / common / Proton 6.3 / dist / bin /
are wrong. This applies to all Proton versions except Proton Experimental!
Solution: Delete the folder / dist in the respective version (attention only the folder NOT the archive!)
Then start the game with the Proton version. The / dist folder is now created correctly.
google translator
I found low temperatures with Manjaro. Playing games with windows was a hot experience.
Ok. I can move the folder with all the content elsewhere and then we expect that Steam would reinstall the folder with permission?
yes
weingeist
Do you have the game on Steam? Did you try to run it with Proton instead of native?
Also make sure you have these vulkan packages.
vulkan-headers
vulkan-icd-loader
