Not booting after an update (getting stuck/frozen at /dev/nvme0n1p2 clean ... files, x/x blocks))
Hello, after an update, and rebooting my laptop, it stays in a black screen with /dev/nvme0n1p2 clean … on the top left of the screen.
I tried looking for solutions and it looks like it’s related to nvidia. I saw in a recent post that he used the following commands:
sudo mhwd -r pci video-nvidia
sudo mhwd -i pci video-nvidia-470xx
The problem is that with mhwd -li, I have the following video:
video-hybrid-amd-nvidia-prime
video-linux
Which I found another solution with:
sudo mhwd -r pci video-linux
sudo mhwd -i pci video-modesetting
force reinstalling the hybrid driver
sudo mhwd -f -i pci video-hybrid-amd-nvidia-prime
Which solution do I go with? Just to be sure I already tried with sudo pacman -Syu with manjaro-chroot. I have Nvidia 3060
[manjaro /]# inxi -Fazy
12System:
  12Kernel 5.10.109-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 11.2.0
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDEM_2126 quiet
    systemd.show_status=1 apparmor=1 security=apparmor driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  12Console N/A 12wm kwin_x11 12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Laptop 12System HP 12product OMEN Laptop 15-en1xxx 12v N/A 12serial <filter>
    12Chassis 12type 10 12serial <filter>
  12Mobo HP 12model 88D1 12v 75.53 12serial <filter> 12UEFI AMI 12v F.10 12date 07/28/2021
12Battery:
  12ID-1 BAT0 12charge 62.8 Wh (93.7%) 12condition 67.0/67.0 Wh (100.0%) 12volts 13.0
    12min 11.6 12model HP Primary 12type Li-ion 12serial <filter> 12status charging
    12cycles 218
12CPU:
  12Info 12model AMD Ryzen 5 5600H with Radeon Graphics 12socket FP6 12bits 64
    12type MT MCP 12arch Zen 3 12gen 4 12level v3 12built 2021-22 12process TSMC n7 (7nm)
    12family 0x19 (25) 12model-id 0x50 (80) 12stepping 0 12microcode 0xA50000C
  12Topology 12cpus 1x 12cores 6 12tpc 2 12threads 12 12smt enabled 12cache 12L1 384 KiB
    12desc d-6x32 KiB; i-6x32 KiB 12L2 3 MiB 12desc 6x512 KiB 12L3 16 MiB 12desc 1x16 MiB
  12Speed (MHz) 12avg 1200 12min/max 1200/3300 12boost enabled 12base/boost 3300/4250
    12scaling 12driver acpi-cpufreq 12governor schedutil 12volts 1.2 V 12ext-clock 100 MHz
    12cores 121 1200 122 1200 123 1200 124 1200 125 1200 126 1200 127 1200 128 1200 129 1200
    1210 1200 1211 1200 1212 1200 12bogomips 79085
  12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  12Vulnerabilities
  12Type itlb_multihit 12status Not affected
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
    prctl and seccomp
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
  12Type spectre_v2 12mitigation Retpolines, IBPB: conditional, IBRS_FW, STIBP:
    always-on, RSB filling
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    12vendor Hewlett-Packard 12driver N/A 12non-free 515.xx+ 12status current (as of
    2022-08) 12arch Ampere 12code GAxxx 12process TSMC n7 (7nm) 12built 2020-22 12pcie
    12gen 3 12speed 8 GT/s 12lanes 8 12link-max 12gen 4 12speed 16 GT/s 12lanes 16
    12bus-ID 01:00.0 12chip-ID 10de:2520 12class-ID 0300
  12Device-2 AMD Cezanne 12vendor Hewlett-Packard 12driver amdgpu 12v kernel
    12arch GCN-5.1 12code Vega-2 12process TSMC n7 (7nm) 12built 2018-21 12pcie 12gen 3
    12speed 8 GT/s 12lanes 16 12link-max 12gen 4 12speed 16 GT/s 12ports 12active eDP-1
    12empty none 12bus-ID 07:00.0 12chip-ID 1002:1638 12class-ID 0300
  12Device-3 Quanta HP Wide Vision HD Camera 12type USB 12driver uvcvideo
    12bus-ID 1-3:3 12chip-ID 0408:5423 12class-ID 0e02 12serial <filter>
  12Display 12server X.org 12v 1.21.1.4 12compositor kwin_x11 12driver 12X 12loaded amdgpu
    12unloaded modesetting 12alternate fbdev,vesa 12gpu amdgpu 12display-ID :0
  12Monitor-1 eDP-1 12model LG Display 0x05fe 12built 2018 12res 1920x1080 12dpi 142
    12gamma 1.2 12size 344x194mm (13.54x7.64") 12diag 395mm (15.5") 12ratio 16:9 12modes
    12max 1920x1080 12min 640x480
  12Message GL data unavailable for root.
12Audio:
  12Device-1 NVIDIA GA106 High Definition Audio 12vendor Hewlett-Packard
    12driver snd_hda_intel 12v kernel 12pcie 12gen 3 12speed 8 GT/s 12lanes 8 12link-max 12gen 4
    12speed 16 GT/s 12lanes 16 12bus-ID 01:00.1 12chip-ID 10de:228e 12class-ID 0403
  12Device-2 AMD ACP/ACP3X/ACP6x Audio Coprocessor 12vendor Hewlett-Packard
    12driver snd_rn_pci_acp3x 12v kernel 12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12link-max
    12gen 4 12speed 16 GT/s 12bus-ID 07:00.5 12chip-ID 1022:15e2 12class-ID 0480
  12Device-3 AMD Family 17h/19h HD Audio 12vendor Hewlett-Packard
    12driver snd_hda_intel 12v kernel 12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12link-max
    12gen 4 12speed 16 GT/s 12bus-ID 07:00.6 12chip-ID 1022:15e3 12class-ID 0403
  12Sound Server-1 ALSA 12v k5.10.109-1-MANJARO 12running yes
  12Sound Server-2 JACK 12v 1.9.21 12running no
  12Sound Server-3 PulseAudio 12v 16.1 12running yes
  12Sound Server-4 PipeWire 12v 0.3.58 12running no
12Network:
  12Device-1 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    12vendor Hewlett-Packard 12driver r8169 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s
    12lanes 1 12port e000 12bus-ID 02:00.0 12chip-ID 10ec:8168 12class-ID 0200
  12IF eno1 12state down 12mac <filter>
  12Device-2 Intel Wi-Fi 6 AX200 12driver iwlwifi 12v kernel 12pcie 12gen 2
    12speed 5 GT/s 12lanes 1 12bus-ID 03:00.0 12chip-ID 8086:2723 12class-ID 0280
  12IF wlo1 12state up 12mac <filter>
12Bluetooth:
  12Device-1 Intel AX200 Bluetooth 12type USB 12driver btusb 12v 0.8 12bus-ID 1-4:4
    12chip-ID 8087:0029 12class-ID e001
  12Report rfkill 12ID hci0 12rfk-id 0 12state up 12address see --recommends
12Drives:
  12Local Storage 12total 950.2 GiB 12used 49.35 GiB (5.2%)
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Western Digital 12model WD Blue SN570
    500GB 12size 465.76 GiB 12block-size 12physical 512 B 12logical 512 B
    12speed 31.6 Gb/s 12lanes 4 12type SSD 12serial <filter> 12rev 234100WD 12temp 31.9 C
  12SMART yes 12health PASSED 12on 21d 0h 12cycles 473 12read-units 1,524,992 [780 GB]
    12written-units 3,662,070 [1.87 TB]
  12ID-2 /dev/nvme1n1 12maj-min 259:4 12vendor Samsung 12model MZVLB512HBJQ-000H1
    12size 476.94 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s
    12lanes 4 12type SSD 12serial <filter> 12rev HPS0NEXF 12temp 34.9 C
  12SMART yes 12health PASSED 12on 23d 15h 12cycles 3,672 12read-units 19,424,929
    [9.94 TB] 12written-units 12,913,135 [6.61 TB]
  12ID-3 /dev/sda 12maj-min 8:0 12type USB 12vendor Generic 12model Flash Disk
    12size 7.5 GiB 12block-size 12physical 512 B 12logical 512 B 12type SSD
    12serial <filter> 12rev 8.07
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition:
  12ID-1 / 12raw-size 456.66 GiB 12size 448.43 GiB (98.20%) 12used 49.35 GiB (11.0%)
    12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p2 12maj-min 259:2
  12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 292 KiB
    (0.1%) 12fs vfat 12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1
12Swap:
  12Alert No swap data was found.
12Sensors:
  12System Temperatures 12cpu N/A 12mobo N/A 12gpu amdgpu 12temp 50.0 C
  12Fan Speeds (RPM) N/A
12Info:
  12Processes 350 12Uptime 7m 12wakeups 2 12Memory 15.05 GiB 12used 2.66 GiB (17.7%)
  12Init systemd 12v 251 12default graphical 12tool systemctl 12Compilers 12gcc 12.2.0
  12clang 14.0.6 12Packages 12pm pacman 12pkgs 1252 12libs 323 12tools pamac,yay
  12Client Unknown Client: systemd 12inxi 3.3.21
Hi @GerLC, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
You should be able to get all that from a chroot environment.
I had (and still do have) this issue as well. For me, I managed to boot into the display manager by removing the X11 config file in /etc/X11/xorg.conf from a live medium terminal. I have no idea what is causing this. Attemping to change any resolution/refresh-rate related settings in nvidia-settings makes the issue occur again. I’ve seen a few people have a similar problem so I assume there will be some action taken soon. Hope this helps with your issue.
Because whatever you modify via nvidia-settings has to be added to /etc/X11/mhwd.d/nvidia.conf file and NOT create the /etc/X11/xorg.conf because those two will be in conflict, creating the issue you described.
On the other hand, the OP has:
But the Nvidia driver might have some issues
