Alright I recently did a fresh install of Manjaro with KDE and for some reason have no wifi connections available. The only thing I do have is a wired connection called lo. I can tether my phone to my pc to provide temporary wifi but I would prefer a more permanent solution.
Hi @gibby9er9er0, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as formatted text.
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
Here is the result of inxi -v7azy
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=a79ff0a7-6fff-4f66-bc52-6793265f9c24 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASRock model: B650M Pro RS WiFi
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.02
date: 11/17/2023
System RAM: total: 32 GiB note: est. available: 30.48 GiB
used: 1.72 GiB (5.7%)
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 599 high: 3587 min/max: 400/5050 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 3587 bogomips: 134197
Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv
lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:21c4
class-ID: 0300
Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 0e:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 31.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu,modesetting,nouveau,nvidia alternate: fbdev,nv,vesa
dri: radeonsi gpu: nvidia,amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2646x1024 s-dpi: 85 s-size: 791x302mm (31.14x11.89")
s-diag: 847mm (33.33") monitors: <missing: xrandr>
Monitor-1: Unknown-1 size-res: N/A modes: 1280x1024
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 535.113.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660
SUPER/PCIe/SSE2 memory: 5.86 GiB
API: Vulkan v: 1.3.264 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 SUPER driver: nvidia v: 535.113.01 device-ID: 10de:21c4
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:164e surfaces: xcb,xlib
Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1
chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.6
chip-ID: 1022:15e3 class-ID: 0403
Device-4: Kingston HyperX 7.1 Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-12:6 chip-ID: 0951:16a4 class-ID: 0300
serial: <filter>
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: N/A modules: mt7921e pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 05:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
IF-ID-1: enp11s0u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung GT-I9070 (network tethering USB debugging enabled)
driver: rndis_host v: kernel type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 3-1:8 chip-ID: 04e8:6864 class-ID: 0a00 serial: <filter>
Device-2: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:5 chip-ID: 0e8d:0616
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 3.07 TiB used: 8.65 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP6256G
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: VC2S038C temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-75WN4A1
tech: HDD rpm: 7200 serial: <filter> fw-rev: 7113 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3U0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 8.65 GiB (0.9%)
fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: a79ff0a7-6fff-4f66-bc52-6793265f9c24
used: 296 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: BA30-85A5
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 6496-677F
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 238.36 GiB fs: ntfs label: N/A
uuid: E4EE8306EE82D06A
ID-4: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: Thing 1
uuid: 247786CC336792AF
ID-5: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: Thing 2
uuid: 6515A46B110573DF
ID-6: /dev/sdd1 maj-min: 8:49 size: 24.57 GiB fs: exfat label: Ventoy
uuid: 4E21-0000
ID-7: /dev/sdd2 maj-min: 8:50 size: 32 MiB fs: vfat label: VTOYEFI
uuid: B2C8-40D2
ID-8: /dev/sdd3 maj-min: 8:51 size: 90 GiB fs: ntfs label: New Volume
uuid: E21408DB1408B517
Hub-1: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:8 info: Samsung GT-I9070 (network tethering USB debugging
enabled) type: bluetooth,CDC-data driver: rndis_host interfaces: 3 rev: 2.0
Device-2: 3-3:3 info: Microsoft Xbox360 Controller type: <vendor specific>
driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Hub-2: 3-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 3-8:5 info: MediaTek Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
Device-2: 3-12:6 info: Kingston HyperX 7.1 Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
chip-ID: 0951:16a4 class-ID: 0300 serial: <filter>
Hub-3: 4-0:1 info: super-speed hub ports: 6 rev: 3.1
Device-1: 4-4:2 info: SanDisk Ultra type: mass storage driver: usb-storage
interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
power: 896mA chip-ID: 0781:5581 class-ID: 0806 serial: <filter>
Hub-4: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-5: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 7-1:2 info: Razer USA DeathAdder V2 Pro type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1532:007d class-ID: 0300
serial: <filter>
Device-2: 7-2:3 info: Evision RGB Keyboard type: keyboard,mouse
lanes: 1 mode: 1.1 power: 400mA chip-ID: 320f:5000 class-ID: 0301
Hub-7: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-8: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 9-1:2 info: ASRock LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
serial: <filter>
Hub-9: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 33.2 C mobo: N/A gpu: amdgpu temp: 30.0 C
Fan Speeds (rpm): N/A
Processes: 302 Uptime: 11m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1120 libs: 317 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Thank you. However, it’s not what I requested, not exactly.
Nevertheless, it would seem the driver for this:
…isn’t loaded for some reason. So let’s try loading it, and see what happens. Please run:
sudo modprobe mt7921e
…and test it again. No need to reboot.
If it works, then cool. Apparently we have to make it persistent. To do so, run:
echo "mt7921e" | sudo tee /etc/modprobe.d/mt7921e_wifi.conf
…and reboot.
If not, I have no idea…so let’s hope it does!
An interweb search on the chip provides a lot of “the driver is known to be buggy”.
Maybe this thread could be of use? Mediatek MT7921e wifi driver issue - #8 by LeakyMemory
Specifically:
- You can see the PCI-ID under chip-ID
- You can see there’s now a wlp4s0 network interface
You seem to miss the interface in your inxi
I was trying to hurry and get this out before work and this was all I could find looking in the how to show sytem info. What was it you needed because this didn’t seem to fix anything
Ok so the solution was found here for anyone having this specific issue if you still have windows installed and nothing else works. Use the instructions in kiwey12’s comment about installing a driver.
