sudo pacman -Syu on May 1 2025, No sound now on Acer Chromebook with only Manjaro installed and mrChrome bios. I had sound before this update and now nothing.
I am new to Manjaro and picked it because it was the only linux distro that had sound with this chromebook and now an update and Manjaro is now just like all the other linux distros.
I tried a few things suggested online but just like all the other linux distros nothing worked.
Has anyone else had this problem and did they find a fix?
m@m asound]$ cat cards
--- no soundcards ---
not sure why it says no soundcards seeing it worked yesterday,
[m@m conf.d]$ ls
10-rate-lav.conf 50-pulseaudio.conf
10-samplerate.conf 60-a52-encoder.conf
10-speexrate.conf 60-speex.conf
50-arcam-av-ctl.conf 60-upmix.conf
50-jack.conf 60-vdownmix.conf
50-oss.conf 98-usb-stream.conf
50-pipewire.conf 99-pipewire-default.conf
Even though it shows I have alsa it says "command not found when trying to reload alsa in terminal and amixer doesnât look correct and no F6 to check speakers mute like it says to do, plus there are no âFâ keys on a chromebook.
I just do not know enough to try and fix this. Any help would be great.
Thank you
Moderator edit: Topic title edited to reflect Chromebook model via Developer Information for ChromeOS Devices
